Vizitator thomasghertzo Postat Martie 7, 2013 Partajează Postat Martie 7, 2013 Buna ziua. Incerc sa repar un invertor de sudura care s-a defectat. Se pare ca de vina este dioda H9740 RURG 3020C. Nu reusesc sa gasesc asa ceva in Romania. Aveti idee, cu ce poate fi inlocuita? Product Information RURG 3020C: DIODE, SOFT RECOVERY, 2X30A Diode Type: Soft Recovery Diode Configuration: Dual Common Cathode Repetitive Reverse Voltage Vrrm Max: 200V Forward Current If(AV): 30A Forward Voltage VF Max: 1V Reverse Recovery Time trr Max: 50ns Forward Surge Current Ifsm Max: 325A Operating Temperature Min: -65°C Operating Temperature Max: 175°C Diode Case Style: TO-247 No. of Pins: 3 SVHC: No SVHC (19-Dec-2012) Current Ifrm: 70A Current Ifsm: 325A Forward Voltage: 1V Junction Temperature Tj Max: 175°C Operating Temperature Range: -65°C to +175°C Package / Case: TO-247 Reverse Recovery Time trr Typ: 45ns Va multumesc. Link spre comentariu
popa ionut Postat Martie 7, 2013 Partajează Postat Martie 7, 2013 cum nu ati gasit?eu am gasit... http://www.abc.ro.ro/ Link spre comentariu
