Pareri osciloscop digital
maxente
Imi cer scuze daca am postat gresit si rog un moderator sa mute subiectul
Am vazut acest osciloscop digital si as vrea sa stiu daca e bun de ceva sau e chiar o jucarie
Vad ca merge decat pana la 1Mhz, are sonda x1,x10
Pot vedea eu o forma de semnal in primarul trafului unei susre ATX cu sonda x10?
N-am avut osciloscop pana acum si asta pare interesant ma bate gandul sa imi iau, vad ca da mura-n gura pe ecran
Cateva date despre el
Features:
Display 2.8″ Color TFT LCD
Display Resolution 320×240
Display Color 65K
Analog bandwidth 0 - 1MHz
Max sample rate 1Msps 12Bits
Sample memory depth 4096 Point
Horizontal sensitivity 1uS/Div~10S/Div (1-2-5 Step)
Horizontal position adjustable with indicator
Vertical sensitivity 10mV/Div~10V/Div (with ×1 probe)
0.5V/Div~100V/Div (with ×10 probe)
Vertical position adjustable with indicator
Input impedance >500KΩ
Max input voltage 80Vpp (by ×1 probe)
Coupling DC
Trig modes Auto, Norma, Single, None and Scan
Functionalities: Automatic measurement: frequency, cycle, duty, Vpp, Vram, Vavg and DC voltage
Precise vertical measurement with markers
Precise horizontal measurement with markers
Rising/falling edge trigger
Trig level adjustable with indicator
Trig sensitivity adjustable with indicator
Hold/run feature
Test signal Built-in 10Hz~1MHz (1-2-5 Step)
Waveform storage SD card
PC connection via USB as SD card reader
Upgrade by boot loader via USB
Power supply 3.7V Chargeable Lithium battery / USB
Dimension (w/o probe) 105mm X 53mm X 8mm
  • Răspunsuri 11
  • maxente
  • godFather89
  • Ionut Pavel
  • validae
Analog bandwidth 0 - 1MHz Max sample rate 1Msps 12Bits
De la 1Msps or ajungs la 1MHz bandwidth? :ras: Astia nu or auzit de Nyquist?Depinde de pret. Daca e peste 100 lei, nu merita.Asa ca jucarie e interesanta. In functie de ce faci, poate avea o oarecare utilitate sau poate sa nu valoreze nimic (de cele mai multe ori - nimic).
Latimea de banda analogica nu are nici o treaba cu rata de esantionare.
Nu? Atunci cu ce?
Si un citat de pe wiki:
In analog instruments, the bandwidth of the oscilloscope is limited by the vertical amplifiers and the CRT or other display subsystem. In digital instruments, the sampling rate of the analog to digital converter (ADC) is a factor, but the stated analog bandwidth (and therefore the overall bandwidth of the instrument) is usually less than the ADC's Nyquist frequency. This is due to limitations in the analog signal amplifier, deliberate design of the Anti-aliasing filter that precedes the ADC, or both.
For a digital oscilloscope, a rule of thumb is that the continuous sampling rate should be ten times the highest frequency desired to resolve; for example a 20 megasample/second rate would be applicable for measuring signals up to about 2 megahertz. This allows the anti-aliasing filter to be designed with a 3 dB down point of 2 MHz and an effective cutoff at 10 MHz (the Nyquist frequency), avoiding the artifacts of a very steep ("brick-wall") filter.
Mai exact teorema spune ca pentru ca un semnal sa poata fi refacut, rata de esantionare trebuie sa fie de 2 ori mai mare decat latimea de banda a semnalului. Latimea de banda analogica e data de viteza circuitului de S/H, de exemplu am convertoare de 30MSPS cu ABW de 180 MHz, acest lucru face posibil un lucru destul de interesant cu aplicatii in radiofrecventa, adica esantionarea Super-Nyquist sau Subesantionarea. A nu se confunda termenii "Latime de banda a osciloscopului" cu "Latime de banda", textul spune doar
Asta pentru ca exista un mod care nu e real-time si e util doar la semnale repetitive (adica... rar de tot).Pentru ca in real-time/one-shot nu au cum sa obtina mai mult de 100 kHz analogic (poate chiar mai putin).Apropo, am vazut ca exista si DSO Quad care pare mai util, desi nu stiu la ce pret:
Two 36MS/s analog channels, Upto 72MS/s if configured to single channel. (Upgrade to Two 72MS/s analog channels, Upto 144MS/s if configured to single channel from .sys version v1.31)
Întâmplător am avut de a face cu asemenea jucărie... Vezi că există și schemă pe net și update de firmware. Merge bine până la semnale de 100Khz după care începe să aibe erori prea mari pentru cerințele mele.
Cel mai bine te poți uita aici și te poți decide :
E o jucărie foarte bună dar are limitări...
Banuiesc ca va referiti la acesta de jos care e de la 162$
The AD9288-40 Over clocking to achieve 72M+72M sampling frequency, so that the maximum single-channel sampling rate up to 144M.Analog channel circuit using unity gain> 150MHz op amp, so the actual 30MHz analog bandwidth is expected to do more.
Textul de jos la ce se refera?
As low power, low-cost, QFP package and other conditions of the FPGA, storage capacity is not large, so DSO203 sampling depth of the current situation for the multi-channel 4096 points per channel, single-channel work cases, 8192 points.
