Detalii placa de baza
Georgefreerunner
  • Răspunsuri 1
  • Georgefreerunner
Zile populare
Vizitator vdrapaca
Cine imi poate da niste detalii despre aceasta placa de baza KOB KM266 FDSMx V7.2A ?
Description- AMD K7 Mainboard with VIA KM266 Chipset DesignProcessors- 462 pin Socket A supports AMD K7 processors * Full series of Athon XP/Athlon/Duron processors. Chipset- VIA KM266 (NB) & VT8233 (SB) * KM266 V-Link Host system controller and VT8233 V-Link Client to PCI/LPC bridge * Peak Bandwidth 266MB/S 8-bit V-link Host Controller * Integrated Savage 4 2D/3D Video Accelerator, 32MB shared memory - LPC I/O ?IT8705F - VIA VT6202 USB 2.0 Host Controller (optional) - AC97 Audio Codec * Compliant with AC97 2.1 specification System BIOS- AMI 2Mb Flash EEPROM - Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI - Support for ACPI revision 1.0 specification Memory- Two 184-pin DDR DIMM sockets for 2.5V DDR SDRAM (DDR266/DDR200), and two DIMM sockets ( PC133/PC100) - Maximum: 1GB (Unbuffered Memory)I/O Interface - Supports Plug and Play function - PS/2 keyboard and PS/2 mouse connectors - Dual USB Ports - One - EPP/ECP mode parallel port - One - 16550 high-speed serial I/O ports - VGA Connector - Audio Ports (Line-in, Line-out, Mic-in, CD-in and game port) - Dual PCI IDE interfaces - support four IDE devices (PIO mode 4, DMA Mode 2, Ultra DMA 66/100) - Supports 360K~2.88M Byte, 3 Mode FDDs or LS120 - ATX Power Supply Connector - Ports, headers and others * IrDA header * Two extra USB Ports (USB2, USB3) (v1.1), USB5 (USB2.0) optional * Front Panel MIC/Line-Out Header * COM2 Header * HDD LED, ACPI MSG LED, Reset Switch, Power Switch headers * CPU and Case Fan headers * LAN Card Wake Up/Wake-Up headers RTC & Battery- VT8233 included 256 byte of CMOS - With CMOS hardware clear jumper Expansion Slots- 2 PCI slots, 1 AGP slot, 1 CNR slot Form Factor & Layers- microATX (244mm x 244mm), 4 LayersEste o placa interesanta ... pentru muzeu. Chiar daca era in top acum 9 ani nu as fi luat-o... :nebunrau: Prefer Intel ... Pentium.BAFTA!http://www.mercury-pc.com/product-detai ... oductid=62
