Vizitator Postat Iulie 12, 2006 Partajează Postat Iulie 12, 2006 salut.miam luat un hard western digital pe sata II (200gb). sitemu de operare estewin xp cu sp 2 placa de baza un asus A8NE. placa video un leadteck 6200. problema este urmatoarea. hardul carie putin cam tot timpul, oprinduse din cand in cand dar ledul care indica ca hardul ar face ceva este stins. antivirusul (kaspesky) este dezactivat progrmamele de gen DC++ nu sunt active....ce ar putea sa faca ca hardul sa stea cam tot timpul in fct. Link spre comentariu
danb1974 Postat Iulie 13, 2006 Partajează Postat Iulie 13, 2006 Posibil sa aiba auto-diagnoza interna (scanare dupa sectoare defecte in momentele cind este idle)Al meu Seagate face ceva de genul asta Link spre comentariu
Extasy2525 Postat Iulie 13, 2006 Partajează Postat Iulie 13, 2006 Daca ti lai luat de la un magazin si este in garantie...eu iti recomand sa te duci inapoi cu el...sa iti dea altul....eu am un Samsung SATA I de 160G de 2 ani...si nu imi face nici un zgomot Link spre comentariu
danb1974 Postat Iulie 13, 2006 Partajează Postat Iulie 13, 2006 http://www.wdc.com/en/library/2579-850105.pdf Data LifeguardTM is a Western Digital exclusive feature that automatically detects, isolates and repairs problem areas on hard drives to prevent data loss. This proactive datareliability feature improves hard drive performance through a continuous self-tuning process that performs scans and repairs while the hard drive is idle. It identifies defects that can result from component wear, and repairs or isolates them to protect the data. Data Lifeguard is both an enhancement and an extension to Western Digital?s S.M.A.R.T. (Self Monitoring, Analysis and Reporting Technology) System that monitors and predicts the performance of hard drives. When enabled, S.M.A.R.T. protects against system downtime and possible loss of productivity and data by communicating reliability status to the user. Data Lifeguard is always enabled, and works independently from S.M.A.R.T. to provide a self-tuning capability. The feature is incorporated in Western Digital?s latest generation of high-performance Enhanced IDE (EIDE) hard drives?the WD Caviar AC13200, AC24300, AC26400,AC38400 and AC310100. Link spre comentariu
Vizitator Postat Iulie 13, 2006 Partajează Postat Iulie 13, 2006 ok. iti ms foarte mult.ideea e cum dezactivez fct asta de rahat.o sa scot hardu sa vad dak are vreun jumper pt asa ceva. ms inca odata. si va satept cu sugestii Link spre comentariu
danb1974 Postat Iulie 13, 2006 Partajează Postat Iulie 13, 2006 Nu cred ca se poate dezactiva.Dar fii optimist, e pentru binele tau :)Cu ce ajuta - daca gaseste un sector cu erori corectabile (ecc si/sau recitiri) se rescrie sau daca asta nu ajuta se reloca. Si cum tinta lor e sa faca o scanare pe zi poate chiar ajuta.In caz de erori "catastrofice" (gen defect electronica sau cap zburat) nu ajuta. Link spre comentariu
Vizitator mla Postat Iulie 20, 2006 Partajează Postat Iulie 20, 2006 ai putea sa iti faci un suport din cauciuc sau un mod de prindere prin niste cureluse de cauciuc si cred ca rezolvi problema Link spre comentariu
Mircea Bartic Postat Iulie 20, 2006 Partajează Postat Iulie 20, 2006 ok. iti ms foarte mult.ideea e cum dezactivez fct asta de rahat.o sa scot hardu sa vad dak are vreun jumper pt asa ceva. ms inca odata. si va satept cu sugestiise opreste dupa ce isi face verificarile, va dura o vreme pana termina tinand cont de capacitateeventual vezi in task manager daca nu ai pornita mizeria aceea de findfast de la Win XP Link spre comentariu
MifTy Postat Iulie 20, 2006 Partajează Postat Iulie 20, 2006 mi se pare că se poate dezactiva funcţia SMART din BIOS-ul plăcii de bază... unele au posibilitatea asta... Link spre comentariu
Vizitator Postat Iulie 21, 2006 Partajează Postat Iulie 21, 2006 iti ms. am gait fct aia de dezactivare din bios si am dezactivato. acu nu mai face zgomot ca inainte Link spre comentariu
ALEKS Postat Iulie 23, 2006 Partajează Postat Iulie 23, 2006 N-am citit ce s-a scris aici dar ca fapt divers va pot spune ca prin 1993 aveam un 80386 cu controller SCSI 10Mbps si un HDD Quantum de 52Mb cu diagnoza interna. In sistemul de operare DOS fara "smartdrv.exe" sau alte utilitare care ar putea accesa discul, la intervale regulate (cca 6 minute din cate imi amintesc) HDD-ul scotea niste zgomote scurte in ritmul miscarii actuatorului. In prima faza, intrigat, l-am cuplat doar pe alimentare fara fisa de date, acelasi lucru la intervale ciclice.Stima,ALEKS Link spre comentariu
Kiusro Postat Octombrie 24, 2006 Partajează Postat Octombrie 24, 2006 !ATENTIE! Western Digital? = Caviar. Din experienta va spun caviar nu este o marca buna cand vine vb de hdd-uri Link spre comentariu
