Masina de spalat Samsung F1245AV Doarme pe stoarcere la 7 s
Bird
Am gasit remarca legata de balans :„ Balancing device (ASSY-Main PCB)→ When the lauandry is out of balance, to prevent the noises and vibrations, the unbalancedetecting sensor helps the laundry laid even and continue the dehydating process. ”12) Unbalance detecting & laundry balance positioning system① Just before the hydrating process and just after reversal rotation for balancing laundry position, this function iscarried out② The initial 6 sec is the period of reversal rotation for balancing laundry position , Drum rotates 50rpm forinitial 6 sec③ Next 10 sec, the rotation increases the speed from 50 rpm to 90 rpm slowly④ During the next 18 sec, drum rotates at the speed of 90 rpm, the sensor decides the degree of laundryunbalance with TACHO data which is attached to motor⑤ If the degree of unbalanced laundry is over 6 times to default value, laundry balancing system carries outfeed back process 6 times13) R.P.M controlThe rotating motor enables the magnetics( i.e generator) to generate magnetic flux in proportion to r.p.m,magnetic flux induced by coil sensor in the opposite side produces the wave like the figure below to dΦ/dt andvia rectangual wave generating citcuit, the waves reaches MICOM and micom controls r.p.m with the pulse,count and cycle inputted by program. V (VOLT) Nu am inteles / localizat care este senzorul ce face detectia . Aici o fi buba ??
  • Răspunsuri 15
  • Bird
    9
  • gymy
  • ALEy
  • E_manuel
