RobyToby Postat Ianuarie 19, 2013 Partajează Postat Ianuarie 19, 2013 Salutare ,am o problema cu o imprimanta Canon i250 care functiona pana acum doua zile . Cand vreau sa printez un document apare prima data "printer is busy " apoi "eror service 5200" . Va rog sa ma ajutati sa rezolv aceasta problema ,dau o bere . Link spre comentariu
RobyToby Postat Ianuarie 19, 2013 Autor Partajează Postat Ianuarie 19, 2013 Nu mai apare eror 5200 , acum este decat printer is busy .Nu primeste absolut nici o comanda , vreau sa resetez contorul de la cartuse nu merge, vreau sa printez nu merge .Nu stie nimeni ce poate sa aiba ? Va rog sa ma ajutati . :jytuiyuAm incercat si varianta de mai jos. Reset the printer to resolve error conditions or if the printer does not respondResetting the PrinterBy resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; a message may appear.Follow these steps to reset the printer: Turn the printer off with the Power button (if available). Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) . Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared). Turn the printer back on. Link spre comentariu
