BF963
  • Răspunsuri 6
  • zvartoshu
  • Toni Marginean
  • sla
  • techs
Merci de date:BF963 MOSFET transistor datasheet. Parameters and characteristics.Type Designator: BF963Type of BF963 transistor: MOSFETType of control channel: N-channelMaximum power dissipation (Pd): 200mWMaximum drain-source voltage (Uds): 20VMaximum drain-gate voltage (Udg):Maximum gate-source voltage (Ugs): 6VMaximum drain current (Id): 50mAMaximum junction temperature (Tj): 150°CRise Time of BF963 transistor (tr):Drain-source Capacitance (Cd), pf: 2.5pFMaximum drain-source on-state resistance (Rds), Ohm:Manufacturer of BF963 transistor: N/APackage: SOT-103Application: MOSFET, Dual gateEquivalent transistors for BF963BF963 PDF documents for downloads:o intrebare mai am , cat gain are? o fi intre 18- 25dB?So asemana cu bf987 ca amplificare?
Eu stiu ca BF960, 961, 963, 964, 966 si 981 au 4 pini, sunt MOS-FET dubla poarta. In anii '80 am folosit in amlificatoare de antena: 961 - FIF, 960- UIF, 981- UKW. Mai rar am folosit si 963, care este tot pentru FIF, are zgomotul putin mai mic decat 961 si castigul in amplificare ceva mai mare. Nu mai tin minte, dar parca am renuntat la el fiindca era foarte sensibil la descarcari electrice si se defecta repede ( cel putin seria care a ajuns la mine, desi scria ca sunt Philips).
