florin70il Postat Decembrie 7, 2012 Partajează Postat Decembrie 7, 2012 Va salut stimati colegi. Sunt varza in programare, drept pentru care va cer ajutorul. Am un soft de telecomanda de la userul fratello, codare RC5, 5 butoane. Totul functioneaza cu o singura problema, codurile 16 si 17 sunt transmise doar o data, si ar trebui transmise ciclic,atata timp cat se tine butonul respectiv apasat. Ma poate ajuta cineva? Va multumesc. ;------------------------------------------------------; PROJECT : 5 CHANNEL TX IR REMOTE; without CRYSTAL ; Modify by Niculescu Dan, january 2010; RC5 FORMAT @38KHz , 35% DUTY CYCLE;; PIC12F675: +--U--+ ; +5V [ ] GND ; key 5 |---/--- >[ ]< ---/---| key 1 ; key 4 |---/--- >[ ]< ---/---| key 2 ; pull-up! key 3 |---/--- >[ ]>--[4K7]-- NPN Transistor, IR LED ; +-----+ ; WWW.SIXCA.COM;------------------------------------------------------ list P=12F675 #include <P12F675.INC> __config _WDT_OFF & _INTRC_OSC_NOCLKOUT & _CPD_OFF & _BODEN_OFF & _MCLRE_OFF & _PWRTE_ON#DEFINE CH1 GPIO,0 ; CONNECT WITH TX SWITCH CHANNEL 1#DEFINE CH2 GPIO,1 ; CONNECT WITH TX SWITCH CHANNEL 2#DEFINE CH3 GPIO,3 ; CONNECT WITH TX SWITCH CHANNEL 3#DEFINE CH4 GPIO,4 ; CONNECT WITH TX SWITCH CHANNEL 4#DEFINE CH5 GPIO,5 ; CONNECT WITH TX SWITCH CHANNEL 5#DEFINE IR GPIO,2 ; CONNECT WITH IR LED WITH TRANSISTOR DRIVES#DEFINE TOG_BIT TOGGLE,0 ; TOGLE BIT NOT USE FOR THIS PROJECT #DEFINE CH1_CMD .16 ; CHANNEL 1 COMMAND - Vol Up ; aici se modifica codul tastei, dupa preferinte#DEFINE CH2_CMD .17 ; CHANNEL 2 COMMAND - Vol Down#DEFINE CH3_CMD .32 ; CHANNEL 3 COMMAND - Source#DEFINE CH4_CMD .33 ; CHANNEL 4 COMMAND - ON/OFF#DEFINE CH5_CMD .13 ; CHANNEL 4 COMMAND - MUTECNT1 EQU 20HCNT2 EQU 21HCNT3 EQU 22HCNT4 EQU 23HTOGGLE EQU 24HCMD EQU 25H ; IR COMMAND BUFFER ORG 000 BCF IR BSF STATUS,RP0 CALL 0X3FF MOVWF OSCCAL BCF STATUS,RP0 CALL DEBOUNCE ; MOVLW 0X07 MOVWF CMCON ; MAKE ALL GPIO TO DIGITAL I/O BSF STATUS,RP0 BCF OPTION_REG,7 ; PULLUP SE ACTIVEAZA INDIVIDUAL MOVLW B'00111011' MOVWF WPU ; ACTIVARE PULLUP LA TOATE MAI PUTIN .2 MOVLW B'00111011' ; GPIO.01345=IN, GPIO 2 = OUT MOVWF TRISIO clrf ANSEL ; No analog here, we want digital because is 12F675 ! ; no need if using 12F629 BCF INTCON,GPIF BSF IOC,IOC0 BSF IOC,IOC1 BSF IOC,IOC3 BSF IOC,IOC4 BSF IOC,IOC5 BSF INTCON,GPIE BCF STATUS,RP0 BCF INTCON,GIE BCF TOG_BIT BCF GPIO,5 ;------------------------------------; MAIN LOOP MAIN: NOP SLEEP ; GOTO SLEEP MODE(I'm a sleepy! and need to save my energy) NOP BCF INTCON,GPIF BTFSS CH1 GOTO DO_CH1 BTFSS CH2 GOTO DO_CH2 BTFSS CH3 GOTO DO_CH3 BTFSS CH4 GOTO DO_CH4 BTFSS CH5 GOTO DO_CH5 GOTO MAIN ;------------------------------------DO_CH1: CALL DEBOUNCE BTFSC CH1 GOTO MAIN MOVLW CH1_CMD ; LOAD COMMANE FOR CHANNEL 1 MOVWF CMD CALL SEND_RC5 ; BTFSS CH1 GOTO $-1 ; WAIT FOR SWITCH RELEASED ; CALL DEBOUNCE ; DELAY AFTER SWITCH RELEASED GOTO MAIN;------------------------------------ DO_CH2: CALL DEBOUNCE BTFSC CH2 GOTO MAIN MOVLW CH2_CMD ; LOAD COMMANE FOR CHANNEL 2 MOVWF CMD CALL SEND_RC5 ; BTFSS CH2 GOTO $-1 ; WAIT FOR SWITCH RELEASED ; CALL DEBOUNCE ; DELAY AFTER SWITCH RELEASED GOTO MAIN ;;------------------------------------ DO_CH3: CALL DEBOUNCE BTFSC CH3 GOTO MAIN MOVLW CH3_CMD ; LOAD COMMANE FOR CHANNEL 3 MOVWF CMD CALL SEND_RC5 ; BTFSS CH3 GOTO $-1 ; WAIT FOR SWITCH RELEASED ; CALL DEBOUNCE ; DELAY AFTER SWITCH RELEASED GOTO MAIN ; ;------------------------------------ DO_CH4: CALL DEBOUNCE BTFSC CH4 GOTO MAIN MOVLW CH4_CMD ; LOAD COMMANE FOR CHANNEL 4 MOVWF CMD CALL SEND_RC5 ; BTFSS CH4 GOTO $-1 ; WAIT FOR SWITCH RELEASED ; CALL DEBOUNCE ; DELAY AFTER SWITCH RELEASED GOTO MAIN ;;-------------------------------------DO_CH5: CALL DEBOUNCE BTFSC CH5 GOTO MAIN MOVLW CH5_CMD ; LOAD COMMAND FOR CHANNEL 5 MOVWF CMD CALL SEND_RC5 ; BTFSS CH5 GOTO $-1 ; WAIT FOR SWITCH RELEASED ; CALL DEBOUNCE ; DELAY AFTER SWITCH RELEASED GOTO MAIN ;======================================; SEND LOGIC 0;======================================LOGIC0: MOVLW .35 ; 1 MOVWF CNT1 ; 1 ;LOG0_1: BSF IR ; 1 MAKE IR HIGH 35% Duty cycle = 9 uS GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 ; ;=================================== BCF IR ; 1 MAKE IR LOW 17 uS GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 NOP ; 1 ; DECFSZ CNT1,F ; 1/2 GOTO LOG0_1 ; 2 26 uS ; CALL DELAY_OFF RETURN ; 2 ;;======================================; SEND LOGIC 1;======================================LOGIC1: CALL DELAY_OFF ; DELAY 899 uS MOVLW .35 ; 1 MOVWF CNT1 ; 1 ;LOG1_1: BSF IR ; 1 MAKE IR HIGH 35% Duty cycle = 9 uS GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 ; ;=================================== BCF IR ; 1 MAKE IR LOW 17 uS GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 NOP ; 1 ; DECFSZ CNT1,F ; 1/2 GOTO LOG1_1 ; 2 ; RETURN ; 2 ;;======================================; DELAY FOR NO CARRAIR; DELAY ABOUT 835 uS;======================================DELAY_OFF: MOVLW 5 ; 1 MOVWF CNT3 ; 1 MOVLW .57 ; 1 '54 MOVWF CNT4 ; 1 DECFSZ CNT4,F ; 1/2 GOTO $-1 ; 2 DECFSZ CNT3,F ; 1/2 GOTO $-5 ; 2 RETURN ; 2 ;======================================; SEND RC5 TO REMOTE; INPUT : CMD (6 BIT IR COMMAND);======================================SEND_RC5: ; SEND 2 START BIT CALL LOGIC1 CALL LOGIC1 ; SEND TOGGLE BIT BTFSS TOG_BIT GOTO $+3 CALL LOGIC1 GOTO $+2 CALL LOGIC0 ; SEND ADDRESS 5 BIT FIX AT 01011 (0X0B) IT MAY BE CHANGED BY YOU CALL LOGIC0 ; 0 MSB FIRST BIT 4 CALL LOGIC0 ; 1 CALL LOGIC0 ; 0 CALL LOGIC0 ; 1 CALL LOGIC0 ; 1 LSB BIT 0 ; ; SEND COMMAND 6 BIT(00HH LLLL) MSB FIRST BCF STATUS,C RLF CMD,F ; AFTER FIRST ROTAGE 0HHL LLL0 RLF CMD,F ; AFTER SECOND ROTAGE HHLL LL00 ; MOVLW 6 MOVWF CNT2 ; RLF CMD,F ; SEND MSB FIRST BTFSS STATUS,C GOTO $+3 CALL LOGIC1 GOTO $+2 ; CALL LOGIC0 DECFSZ CNT2,F GOTO $-7 ; RETLW 0 ; ;======================================; DEBOUNCE SWITCH; DELAY 15 mS;======================================DEBOUNCE: MOVLW .1 ; 1 MOVWF CNT1 ; 1DEL_1: MOVLW .20 MOVWF CNT2 ; 1DEL_2: CLRF CNT3 ; 1DEL_3: DECFSZ CNT3,F ; 1/2 GOTO DEL_3 ; 2 DECFSZ CNT2,F ; 1/2 GOTO DEL_2 ; 2 DECFSZ CNT1,F ; 1/2 GOTO DEL_1 ; 2 RETLW 0 ; 2 END Link spre comentariu
bercioiu Postat Decembrie 7, 2012 Partajează Postat Decembrie 7, 2012 Pai modifici cele 5 sectiuni "DO_CHx" (x = 1 to 5)DO_CH1: CALL DEBOUNCE BTFSC CH1 GOTO MAIN MOVLW CH1_CMD ; LOAD COMMANE FOR CHANNEL 1 MOVWF CMD CALL SEND_RC5 ; BTFSS CH1 GOTO DO_CH1: ; WAIT FOR SWITCH RELEASED (in loc de "$-1" pui "DO_CH1:")sau adaugi o eticheta la "CALL SEND_RC5" si in loc de "$-1" pui eticheta respectiva Link spre comentariu
florin70il Postat Decembrie 10, 2012 Autor Partajează Postat Decembrie 10, 2012 Multumesc pentru ajutor, dar Mplab imi da eroare de "illegal character" la ":" Cred ca trebuie folosit doar"GOTO DO_CHx" Link spre comentariu
bercioiu Postat Decembrie 10, 2012 Partajează Postat Decembrie 10, 2012 Uite, am pus cate un label la fiecare canal "SENDx" . Sper sa mearga, cred ca mai trebuie si cate un delay, nu sunt sigur... Si eu sunt super incepator... Poate ne ajuta un senior... ;------------------------------------------------------; PROJECT : 5 CHANNEL TX IR REMOTE; without CRYSTAL; Modify by Niculescu Dan, january 2010; RC5 FORMAT @38KHz , 35% DUTY CYCLE;; PIC12F675: +--U--+ ; +5V [ ] GND ; key 5 |---/--- >[ ]< ---/---| key 1 ; key 4 |---/--- >[ ]< ---/---| key 2 ; pull-up! key 3 |---/--- >[ ]>--[4K7]-- NPN Transistor, IR LED ; +-----+ ; WWW.SIXCA.COM;------------------------------------------------------ list P=12F675 #include <P12F675.INC> __config _WDT_OFF & _INTRC_OSC_NOCLKOUT & _CPD_OFF & _BODEN_OFF & _MCLRE_OFF & _PWRTE_ON#DEFINE CH1 GPIO,0 ; CONNECT WITH TX SWITCH CHANNEL 1#DEFINE CH2 GPIO,1 ; CONNECT WITH TX SWITCH CHANNEL 2#DEFINE CH3 GPIO,3 ; CONNECT WITH TX SWITCH CHANNEL 3#DEFINE CH4 GPIO,4 ; CONNECT WITH TX SWITCH CHANNEL 4#DEFINE CH5 GPIO,5 ; CONNECT WITH TX SWITCH CHANNEL 5#DEFINE IR GPIO,2 ; CONNECT WITH IR LED WITH TRANSISTOR DRIVES#DEFINE TOG_BIT TOGGLE,0 ; TOGLE BIT NOT USE FOR THIS PROJECT #DEFINE CH1_CMD .16 ; CHANNEL 1 COMMAND - Vol Up ; aici se modifica codul tastei, dupa preferinte#DEFINE CH2_CMD .17 ; CHANNEL 2 COMMAND - Vol Down#DEFINE CH3_CMD .32 ; CHANNEL 3 COMMAND - Source#DEFINE CH4_CMD .33 ; CHANNEL 4 COMMAND - ON/OFF#DEFINE CH5_CMD .13 ; CHANNEL 4 COMMAND - MUTECNT1 EQU 20HCNT2 EQU 21HCNT3 EQU 22HCNT4 EQU 23HTOGGLE EQU 24HCMD EQU 25H ; IR COMMAND BUFFER ORG 000 BCF IR BSF STATUS,RP0 CALL 0X3FF MOVWF OSCCAL BCF STATUS,RP0 CALL DEBOUNCE ; MOVLW 0X07 MOVWF CMCON ; MAKE ALL GPIO TO DIGITAL I/O BSF STATUS,RP0 BCF OPTION_REG,7 ; PULLUP SE ACTIVEAZA INDIVIDUAL MOVLW B'00111011' MOVWF WPU ; ACTIVARE PULLUP LA TOATE MAI PUTIN .2 MOVLW B'00111011' ; GPIO.01345=IN, GPIO 2 = OUT MOVWF TRISIO clrf ANSEL ; No analog here, we want digital because is 12F675 ! ; no need if using 12F629 BCF INTCON,GPIF BSF IOC,IOC0 BSF IOC,IOC1 BSF IOC,IOC3 BSF IOC,IOC4 BSF IOC,IOC5 BSF INTCON,GPIE BCF STATUS,RP0 BCF INTCON,GIE BCF TOG_BIT BCF GPIO,5 ;------------------------------------; MAIN LOOP MAIN: NOP SLEEP ; GOTO SLEEP MODE(I'm a sleepy! and need to save my energy) NOP BCF INTCON,GPIF BTFSS CH1 GOTO DO_CH1 BTFSS CH2 GOTO DO_CH2 BTFSS CH3 GOTO DO_CH3 BTFSS CH4 GOTO DO_CH4 BTFSS CH5 GOTO DO_CH5 GOTO MAIN ;------------------------------------DO_CH1: CALL DEBOUNCE BTFSC CH1 GOTO MAIN MOVLW CH1_CMD ; LOAD COMMANE FOR CHANNEL 1 MOVWF CMDSEND1 CALL SEND_RC5 ; BTFSS CH1 ; GOTO $-1 ; WAIT FOR SWITCH RELEASED GOTO SEND1 ; CALL DEBOUNCE ; DELAY AFTER SWITCH RELEASED GOTO MAIN;------------------------------------ DO_CH2: CALL DEBOUNCE BTFSC CH2 GOTO MAIN MOVLW CH2_CMD ; LOAD COMMANE FOR CHANNEL 2 MOVWF CMDSEND2 CALL SEND_RC5 ; BTFSS CH2 ;GOTO $-1 ; WAIT FOR SWITCH RELEASED GOTO SEND2 ; CALL DEBOUNCE ; DELAY AFTER SWITCH RELEASED GOTO MAIN ;;------------------------------------ DO_CH3: CALL DEBOUNCE BTFSC CH3 GOTO MAIN MOVLW CH3_CMD ; LOAD COMMANE FOR CHANNEL 3 MOVWF CMDSEND3 CALL SEND_RC5 ; BTFSS CH3 ;GOTO $-1 ; WAIT FOR SWITCH RELEASED GOTO SEND3 ; CALL DEBOUNCE ; DELAY AFTER SWITCH RELEASED GOTO MAIN ; ;------------------------------------ DO_CH4: CALL DEBOUNCE BTFSC CH4 GOTO MAIN MOVLW CH4_CMD ; LOAD COMMANE FOR CHANNEL 4 MOVWF CMDSEND4 CALL SEND_RC5 ; BTFSS CH4 ;GOTO $-1 ; WAIT FOR SWITCH RELEASED GOTO SEND4 ; CALL DEBOUNCE ; DELAY AFTER SWITCH RELEASED GOTO MAIN ;;-------------------------------------DO_CH5: CALL DEBOUNCE BTFSC CH5 GOTO MAIN MOVLW CH5_CMD ; LOAD COMMAND FOR CHANNEL 5 MOVWF CMDSEND5 CALL SEND_RC5 ; BTFSS CH5 ;GOTO $-1 ; WAIT FOR SWITCH RELEASED GOTO SEND5 ; CALL DEBOUNCE ; DELAY AFTER SWITCH RELEASED GOTO MAIN ;======================================; SEND LOGIC 0;======================================LOGIC0: MOVLW .35 ; 1 MOVWF CNT1 ; 1 ;LOG0_1: BSF IR ; 1 MAKE IR HIGH 35% Duty cycle = 9 uS GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 ; ;=================================== BCF IR ; 1 MAKE IR LOW 17 uS GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 NOP ; 1 ; DECFSZ CNT1,F ; 1/2 GOTO LOG0_1 ; 2 26 uS ; CALL DELAY_OFF RETURN ; 2 ;;======================================; SEND LOGIC 1;======================================LOGIC1: CALL DELAY_OFF ; DELAY 899 uS MOVLW .35 ; 1 MOVWF CNT1 ; 1 ;LOG1_1: BSF IR ; 1 MAKE IR HIGH 35% Duty cycle = 9 uS GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 ; ;=================================== BCF IR ; 1 MAKE IR LOW 17 uS GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 NOP ; 1 ; DECFSZ CNT1,F ; 1/2 GOTO LOG1_1 ; 2 ; RETURN ; 2 ;;======================================; DELAY FOR NO CARRAIR; DELAY ABOUT 835 uS;======================================DELAY_OFF: MOVLW 5 ; 1 MOVWF CNT3 ; 1 MOVLW .57 ; 1 '54 MOVWF CNT4 ; 1 DECFSZ CNT4,F ; 1/2 GOTO $-1 ; 2 DECFSZ CNT3,F ; 1/2 GOTO $-5 ; 2 RETURN ; 2 ;======================================; SEND RC5 TO REMOTE; INPUT : CMD (6 BIT IR COMMAND);======================================SEND_RC5: ; SEND 2 START BIT CALL LOGIC1 CALL LOGIC1 ; SEND TOGGLE BIT BTFSS TOG_BIT GOTO $+3 CALL LOGIC1 GOTO $+2 CALL LOGIC0 ; SEND ADDRESS 5 BIT FIX AT 01011 (0X0B) IT MAY BE CHANGED BY YOU CALL LOGIC0 ; 0 MSB FIRST BIT 4 CALL LOGIC0 ; 1 CALL LOGIC0 ; 0 CALL LOGIC0 ; 1 CALL LOGIC0 ; 1 LSB BIT 0 ; ; SEND COMMAND 6 BIT(00HH LLLL) MSB FIRST BCF STATUS,C RLF CMD,F ; AFTER FIRST ROTAGE 0HHL LLL0 RLF CMD,F ; AFTER SECOND ROTAGE HHLL LL00 ; MOVLW 6 MOVWF CNT2 ; RLF CMD,F ; SEND MSB FIRST BTFSS STATUS,C GOTO $+3 CALL LOGIC1 GOTO $+2 ; CALL LOGIC0 DECFSZ CNT2,F GOTO $-7 ; RETLW 0 ; ;======================================; DEBOUNCE SWITCH; DELAY 15 mS;======================================DEBOUNCE: MOVLW .1 ; 1 MOVWF CNT1 ; 1DEL_1: MOVLW .20 MOVWF CNT2 ; 1DEL_2: CLRF CNT3 ; 1DEL_3: DECFSZ CNT3,F ; 1/2 GOTO DEL_3 ; 2 DECFSZ CNT2,F ; 1/2 GOTO DEL_2 ; 2 DECFSZ CNT1,F ; 1/2 GOTO DEL_1 ; 2 RETLW 0 ; 2 END Link spre comentariu
florin70il Postat Decembrie 12, 2012 Autor Partajează Postat Decembrie 12, 2012 Multumesc foarte mult pentru ajutor, a mers prima varianta, cea cu GOTO DO_CHx, pe a doua nu am mai incercat-o. Acum transmite ciclic pe key 1 si key 2(Vol+ si Vol-). Pentru cei doritori, afisez codul asm. Schema este in headerul asm. ;------------------------------------------------------ ; PROJECT : 5 CHANNEL TX IR REMOTE ; without CRYSTAL ; Modify by Niculescu Dan, january 2010 ; RC5 FORMAT @38KHz , 35% DUTY CYCLE ; ; PIC12F629: +--U--+ ; +5V [ ] GND ; key 5 |---/--- >[ ]< ---/---| key 1 ; key 4 |---/--- >[ ]< ---/---| key 2 ; pull-up 10k! key 3 |---/--- >[ ]>--[4K7]-- NPN Transistor, IR LED ; +-----+ ; WWW.SIXCA.COM ;------------------------------------------------------ list P=12F629 #include __config _WDT_OFF & _INTRC_OSC_NOCLKOUT & _CPD_OFF & _BODEN_OFF & _MCLRE_OFF & _PWRTE_ON #DEFINE CH1 GPIO,0 ; CONNECT WITH TX SWITCH CHANNEL 1 #DEFINE CH2 GPIO,1 ; CONNECT WITH TX SWITCH CHANNEL 2 #DEFINE CH3 GPIO,3 ; CONNECT WITH TX SWITCH CHANNEL 3 #DEFINE CH4 GPIO,4 ; CONNECT WITH TX SWITCH CHANNEL 4 #DEFINE CH5 GPIO,5 ; CONNECT WITH TX SWITCH CHANNEL 5 #DEFINE IR GPIO,2 ; CONNECT WITH IR LED WITH TRANSISTOR DRIVES #DEFINE TOG_BIT TOGGLE,0 ; TOGLE BIT NOT USE FOR THIS PROJECT #DEFINE CH1_CMD .16 ; CHANNEL 1 COMMAND - Vol Up ; aici se modifica codul tastei, dupa preferinte #DEFINE CH2_CMD .17 ; CHANNEL 2 COMMAND - Vol Down #DEFINE CH3_CMD .32 ; CHANNEL 3 COMMAND - CH+ #DEFINE CH4_CMD .33 ; CHANNEL 4 COMMAND - CH- #DEFINE CH5_CMD .13 ; CHANNEL 4 COMMAND - MUTE CNT1 EQU 20H CNT2 EQU 21H CNT3 EQU 22H CNT4 EQU 23H TOGGLE EQU 24H CMD EQU 25H ; IR COMMAND BUFFER ORG 000 BCF IR BSF STATUS,RP0 CALL 0X3FF MOVWF OSCCAL BCF STATUS,RP0 CALL DEBOUNCE ; MOVLW 0X07 MOVWF CMCON ; MAKE ALL GPIO TO DIGITAL I/O BSF STATUS,RP0 BCF OPTION_REG,7 ; PULLUP SE ACTIVEAZA INDIVIDUAL MOVLW B'00111011' MOVWF WPU ; ACTIVARE PULLUP LA TOATE MAI PUTIN .2 MOVLW B'00111011' ; GPIO.01345=IN, GPIO 2 = OUT MOVWF TRISIO ;clrf ANSEL ;setari pentru 12F629, "clrf ANSEL" este pentru 12F675 ; no need if using 12F629 BCF INTCON,GPIF BSF IOC,IOC0 BSF IOC,IOC1 BSF IOC,IOC3 BSF IOC,IOC4 BSF IOC,IOC5 BSF INTCON,GPIE BCF STATUS,RP0 BCF INTCON,GIE BCF TOG_BIT BCF GPIO,5 ;------------------------------------ ; MAIN LOOP MAIN: NOP SLEEP ; GOTO SLEEP MODE(I'm a sleepy! and need to save my energy) NOP BCF INTCON,GPIF BTFSS CH1 GOTO DO_CH1 BTFSS CH2 GOTO DO_CH2 BTFSS CH3 GOTO DO_CH3 BTFSS CH4 GOTO DO_CH4 BTFSS CH5 GOTO DO_CH5 GOTO MAIN ;------------------------------------ DO_CH1: CALL DEBOUNCE BTFSC CH1 GOTO MAIN MOVLW CH1_CMD ; LOAD COMMANE FOR CHANNEL 1 MOVWF CMD CALL SEND_RC5 ; BTFSS CH1 GOTO DO_CH1 ; WAIT FOR SWITCH RELEASED ; CALL DEBOUNCE ; DELAY AFTER SWITCH RELEASED GOTO MAIN ;------------------------------------ DO_CH2: CALL DEBOUNCE BTFSC CH2 GOTO MAIN MOVLW CH2_CMD ; LOAD COMMANE FOR CHANNEL 2 MOVWF CMD CALL SEND_RC5 ; BTFSS CH2 GOTO DO_CH2 ; WAIT FOR SWITCH RELEASED ; CALL DEBOUNCE ; DELAY AFTER SWITCH RELEASED GOTO MAIN ; ;------------------------------------ DO_CH3: CALL DEBOUNCE BTFSC CH3 GOTO MAIN MOVLW CH3_CMD ; LOAD COMMANE FOR CHANNEL 3 MOVWF CMD CALL SEND_RC5 ; BTFSS CH3 GOTO $-1 ; WAIT FOR SWITCH RELEASED ; CALL DEBOUNCE ; DELAY AFTER SWITCH RELEASED GOTO MAIN ; ;------------------------------------ DO_CH4: CALL DEBOUNCE BTFSC CH4 GOTO MAIN MOVLW CH4_CMD ; LOAD COMMANE FOR CHANNEL 4 MOVWF CMD CALL SEND_RC5 ; BTFSS CH4 GOTO $-1 ; WAIT FOR SWITCH RELEASED ; CALL DEBOUNCE ; DELAY AFTER SWITCH RELEASED GOTO MAIN ; ;------------------------------------- DO_CH5: CALL DEBOUNCE BTFSC CH5 GOTO MAIN MOVLW CH5_CMD ; LOAD COMMAND FOR CHANNEL 5 MOVWF CMD CALL SEND_RC5 ; BTFSS CH5 GOTO $-1 ; WAIT FOR SWITCH RELEASED ; CALL DEBOUNCE ; DELAY AFTER SWITCH RELEASED GOTO MAIN ;====================================== ; SEND LOGIC 0 ;====================================== LOGIC0: MOVLW .35 ; 1 MOVWF CNT1 ; 1 ; LOG0_1: BSF IR ; 1 MAKE IR HIGH 35% Duty cycle = 9 uS GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 ; ;=================================== BCF IR ; 1 MAKE IR LOW 17 uS GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 NOP ; 1 ; DECFSZ CNT1,F ; 1/2 GOTO LOG0_1 ; 2 26 uS ; CALL DELAY_OFF RETURN ; 2 ; ;====================================== ; SEND LOGIC 1 ;====================================== LOGIC1: CALL DELAY_OFF ; DELAY 899 uS MOVLW .35 ; 1 MOVWF CNT1 ; 1 ; LOG1_1: BSF IR ; 1 MAKE IR HIGH 35% Duty cycle = 9 uS GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 ; ;=================================== BCF IR ; 1 MAKE IR LOW 17 uS GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 NOP ; 1 ; DECFSZ CNT1,F ; 1/2 GOTO LOG1_1 ; 2 ; RETURN ; 2 ; ;====================================== ; DELAY FOR NO CARRAIR ; DELAY ABOUT 835 uS ;====================================== DELAY_OFF: MOVLW 5 ; 1 MOVWF CNT3 ; 1 MOVLW .57 ; 1 '54 MOVWF CNT4 ; 1 DECFSZ CNT4,F ; 1/2 GOTO $-1 ; 2 DECFSZ CNT3,F ; 1/2 GOTO $-5 ; 2 RETURN ; 2 ;====================================== ; SEND RC5 TO REMOTE ; INPUT : CMD (6 BIT IR COMMAND) ;====================================== SEND_RC5: ; SEND 2 START BIT CALL LOGIC1 CALL LOGIC1 ; SEND TOGGLE BIT BTFSS TOG_BIT GOTO $+3 CALL LOGIC1 GOTO $+2 CALL LOGIC0 ; SEND ADDRESS 5 BIT FIX AT 01011 (0X0B) IT MAY BE CHANGED BY YOU CALL LOGIC0 ; 0 MSB FIRST BIT 4 CALL LOGIC0 ; 1 CALL LOGIC0 ; 0 CALL LOGIC0 ; 1 CALL LOGIC0 ; 1 LSB BIT 0 ; ; SEND COMMAND 6 BIT(00HH LLLL) MSB FIRST BCF STATUS,C RLF CMD,F ; AFTER FIRST ROTAGE 0HHL LLL0 RLF CMD,F ; AFTER SECOND ROTAGE HHLL LL00 ; MOVLW 6 MOVWF CNT2 ; RLF CMD,F ; SEND MSB FIRST BTFSS STATUS,C GOTO $+3 CALL LOGIC1 GOTO $+2 ; CALL LOGIC0 DECFSZ CNT2,F GOTO $-7 ; RETLW 0 ; ;====================================== ; DEBOUNCE SWITCH ; DELAY 15 mS ;====================================== DEBOUNCE: MOVLW .1 ; 1 MOVWF CNT1 ; 1 DEL_1: MOVLW .20 MOVWF CNT2 ; 1 DEL_2: CLRF CNT3 ; 1 DEL_3: DECFSZ CNT3,F ; 1/2 GOTO DEL_3 ; 2 DECFSZ CNT2,F ; 1/2 GOTO DEL_2 ; 2 DECFSZ CNT1,F ; 1/2 GOTO DEL_1 ; 2 RETLW 0 ; 2 END Link spre comentariu
bercioiu Postat Decembrie 12, 2012 Partajează Postat Decembrie 12, 2012 Bravo, ma bucur ca ai rezolvat, Link spre comentariu
