Vizitator danny71 Postat Decembrie 1, 2012 Partajează Postat Decembrie 1, 2012 Va salut, De ceva timp doresc sa programez un CPLD seria xc2c64a dar nu reusesc din cauza cablului utilizat. Folosesc urmatoarele: - Xilinx Design suite 10.1 (este ultima versiune care suporta cablu paralel tip III) - cablu tip III creat de mine dupa schema pusa la dispozitie de Xilinx disponibila la adresa http://www.xilinx.com/support/documentation/user_guides/xtp029.pdf; - un card PCI cu port LPT disponibil la adresa 0xc700 (LPT3) intrucat PC-ul nu are un port LPT onboard. Mesajul returnat de aplicatie este: // *** BATCH CMD : setMode -bs // *** BATCH CMD : setMode -bs GUI --- Auto connect to cable... // *** BATCH CMD : setCable -port auto AutoDetecting cable. Please wait. PROGRESS_START - Starting Operation. Connecting to cable (Parallel Port - LPT3). Checking cable driver. Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo © 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS 12:35:07, version = 811. LPT base address = C700h. ECP base address = C600h. Cable connection established. PROGRESS_END - End Operation. Elapsed time = 1 sec. Attempting to identify devices in the boundary-scan chain configuration...// *** BATCH CMD : Identify PROGRESS_START - Starting Operation. Identifying chain contents ....done. ERROR:iMPACT:585 - A problem may exist in the hardware configuration. Check that the cable, scan chain, and power connections are intact, that the specified scan chain configuration matches the actual hardware, and that the power supply is adequate and delivering the correct voltage. PROGRESS_END - End Operation. Elapsed time = 1 sec. // *** BATCH CMD : identifyMPM Daca cineva stie ce pot face ca sa nu-mi mai apara aceasta eroare il rog respectuos sa ma ajute. Cu stima, Dan Link spre comentariu
Ionut Pavel Postat Februarie 2, 2015 Partajează Postat Februarie 2, 2015 Pe ce ramura de tensiune sunt pinii de la JTAG?. Daca sunt pe ceva mai mic de 3.3V e posibil sa nu mearga cablul. El nu iti gaseste nici un dispozitiv in chain. Acum am vazut ca postul e din 2012 pff. Link spre comentariu
Vizitator yo3hfp Postat Ianuarie 7, 2016 Partajează Postat Ianuarie 7, 2016 Salutare si la multi ani! Sunt user nou pe acest forum si vreau sa-ti cer parerea intr-o chestiune. De curand m-am decis sa-mi fac un frecventmetru si am gasi o schema foarte interesanta a unui japonez: http://elm-chan.org/works/uctr/report.html Schema e buna rau! incepand de la TXCO pana la modul cum isi modifica baza te timp in functie de frcventa de intrare (din cate am inteles eu...). Am ales-o pe asta pt ca TXCO-ul il am; ar merge pana la 2.4Ghz si nu in ultimul rand pare "lucrata bine". Problema: Autorul da fisierul pt µC Atmel si pt LSI, dupa cum vezi in josul paginei sale. (le-am atasat si eu aici) Acuma: pt Atmel e OK, dar fisierul text PLD pt. ispLSI2032 nu inteleg cu ce se mananca... Din cate am inteles, in definitiv, este un fel de µC facut de LATTICE, pe care il faci sa divizeze dupa cum e scris in acel fisier. Nu am mai lucrat cu microcontrollere si... banuiesc ca esti mai in tema decat sunt eu. Te-as ruga, daca poti sa ma lamuresti cum procedez cu fisierul ala text pt ispLSI2032. Daca e sa-l compilez, cu ce, si cum se face... Asta e... Nimeni nu s-a nascut invatat... Multumesc. Traian YO3HFP PLD CODE.txt ucsrc.rar Link spre comentariu
moro Postat Aprilie 16, 2017 Partajează Postat Aprilie 16, 2017 Interesanta schema, si eu lucrez la un proiect similar pe un spartan 6 In loc de TXCO se poate folosi OCXO au drift mai mic , dezavantaj fiind pretul mai ridicat Pe intrare se poate merge cu un buffer pentru adaptare de impedanta ( impedanta mare la intrare cu ceva comparator super rapid) Link spre comentariu
