Vizitator Depanatorul1979 Postat Noiembrie 21, 2012 Partajează Postat Noiembrie 21, 2012 am nevoie de ajutorul celor mai avansati , am incercat de unu singur dar nu am reusit .Am nevoie de ajutor la acest proect http://kripton2035.free.fr/digital%20es ... -bera.html am nevoie de a converti fisierul sursa in hex pt pic16f876a /* * Digital Capacitor ESR Tester V3.1 * Copyright (c) 2009, Regulus Berdin * All rights reserved. * * Permission is hereby granted, free of charge, to any person * obtaining a copy of this software and associated documentation * files (the "Software"), to deal in the Software without * restriction, including without limitation the rights to use, * copy, modify, merge, publish, distribute, sublicense, and/or * sell copies of the Software, and to permit persons to whom the * Software is furnished to do so, subject to the following * conditions: * * The above copyright notice and this permission notice shall be * included in all copies or substantial portions of the Software. * * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND * NONINFRINGEMENT. IN NO EVENT SHALL REGULUS BERDIN BE LIABLE FOR * ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF * CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN * CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE * SOFTWARE.*/ #include <16F876.h>#device adc=10#FUSES NOWDT, HS, NOPUT, NOPROTECT, NOBROWNOUT, NOLVP, NOCPD, NOWRT, NODEBUG#use delay(clock=20M)#use fast_io(a)#use fast_io(b)#use fast_io(c)#define CHARGE_MASK (1<<0)#define DEBUG_MASK (1<<1)#define COM1_MASK (1<<2)#define COM2_MASK (1<<3)#define COM1_PIN PIN_B2#define COM2_PIN PIN_B3#define BUZZERP_PIN PIN_A1#define BUZZERN_PIN PIN_A2#define PASS_PIN PIN_A5#define FAIL_PIN PIN_A3float rx, fvs, fvo, fvg, fd, r1 = 3.3, r2 = 0.0;const char led_map[16] = { /* aaaa f b f b ggg e c e c ddd */ //.gfedcba 0b00111111, //0 0b00000110, //1 0b01011011, //2 0b01001111, //3 0b01100110, //4 0b01101101, //5 0b01111101, //6 0b00000111, //7 0b01111111, //8 0b01101111, //9 0b01111111, //10 0b01111111, //11 0b01111111, //12 0b01111111, //13 0b01111111, //14 0b01111111 //15};unsigned int8 digit[2], dptr=0, dseg=1, scan_skip=0, beep=0, buz_pol=0;#int_timer0void tmr0_isr(void){ set_timer0(255 - 155); //4khz ++scan_skip; if (scan_skip>=4) { output_low(COM1_PIN); output_low(COM2_PIN); if (dptr==0) { output_c(~(dseg & digit[0])); output_high(COM1_PIN); } else { output_c(~(dseg & digit[1])); output_high(COM2_PIN); } dseg <<=1; if (dseg==0) { dseg = 1; dptr ^= 1; } scan_skip = 0; } if (beep) { buz_pol ^= 1; if (buz_pol) { output_high(BUZZERP_PIN); output_low(BUZZERN_PIN); } else { output_low(BUZZERP_PIN); output_high(BUZZERN_PIN); } }}void show_status(void){ if (rx < 1.05) { output_high(PASS_PIN); beep = 1; } else if (rx < 5.05) { output_high(PASS_PIN); beep = 0; } else if (rx < 15.05) { output_high(PASS_PIN); delay_cycles(2); output_high(FAIL_PIN); beep = 0; } else { output_high(FAIL_PIN); beep = 0; }}void main(void){ unsigned int16 vs, vo, vg; unsigned int8 i, c1, c2; port_b_pullups(0); set_tris_b(0x00); set_tris_c(0x00); output_c(0xFF); set_tris_a(0x01); output_a(0); setup_adc_ports(AN0); setup_adc(ADC_CLOCK_DIV_32); set_adc_channel(0); set_tris_b(0); setup_timer_0(RTCC_INTERNAL|RTCC_DIV_4); set_timer0(255 - 155); //8khz enable_interrupts(INT_TIMER0); enable_interrupts(GLOBAL); i=0; for(;;) { output_b(0); delay_ms(20); vg = read_adc(); output_b(CHARGE_MASK); delay_ms(20); vs = read_adc(); delay_us(25); //critical part disable_interrupts(GLOBAL); output_b(DEBUG_MASK); //delay_us(1); vo = read_adc(); enable_interrupts(GLOBAL); output_b(0); fvo = vo; fvs = vs; fvg = vg; fd = (fvg - fvo) + 0.00001; if (fd<=0.00001) fd = 0.00001; rx = ((r1 * (fvg - fvs))/fd) - r1 - r2; if (rx>=99.0) { digit[0] = led_map[9]; digit[1] = led_map[9]; } else if (rx<0) { digit[0] = led_map[0] | (1<<7); digit[1] = led_map[0]; } else if (rx<10.0) { c1 = (rx + 0.05) * 10.0; //round c2 = c1 % 10; c1 -= c2; c1 /= 10; digit[0] = led_map[c1] | (1<<7); digit[1] = led_map[c2]; } else { c1 = rx + 0.5; //round c2 = c1 % 10; c1 -= c2; c1 /= 10; digit[0] = led_map[c1]; digit[1] = led_map[c2]; } show_status(); }} Link spre comentariu
Stefan Postat Noiembrie 22, 2012 Partajează Postat Noiembrie 22, 2012 testeaza acest hex si sa imi spui daca functioneaza. sourcea.zip Link spre comentariu
costyy86 Postat Decembrie 25, 2012 Partajează Postat Decembrie 25, 2012 Salutare, spec ca nu deranjez pe nimeni daca postez si eu aici.Am aceasi problema, nu pot face un fisier .hex din codul sursa, si desi exista un fisier hex, dar este sub forma txt, si am incercat sa il salvez in format .hex dar nu il recunoaste proteus... cod sursa.txt fisier hex.txt Link spre comentariu
Vizitator mestersoft Postat Decembrie 25, 2012 Partajează Postat Decembrie 25, 2012 Incearcal pe asta. Link spre comentariu
costyy86 Postat Decembrie 25, 2012 Partajează Postat Decembrie 25, 2012 Da functioneaza.Multumesc. Link spre comentariu
