constanta osccal la pic12f508
a_sorien
Salutare ! Cum scriu din nou aceasta constanta , inainte de programare ?! Cica e specifica fiecarui cip ." In addition, a calibration instruction is programmed intothe last address of memory, which contains thecalibration value for the internal RC oscillator. Thislocation is always uncode protected, regardless of thecode-protect settings. This value is programmed as aMOVLW XX instruction where XX is the calibration value,and is placed at the Reset vector. This will load the Wregister with the calibration value upon Reset and thePC will then roll over to the users program at address0x000. The user then has the option of writing the valueto the OSCCAL Register (05h) or ignoring it.OSCCAL, when written to with the calibration value, will“trim” the internal oscillator to remove process variationfrom the oscillator frequency.For the PIC12F508/509/16F505 devices, only bits<7:1> of OSCCAL are implemented. Bits CAL6-CAL0are used for calibration. Adjusting CAL6-CAL0 from‘0000000’ to ‘1111111’ changes the clock speed. SeeRegister 4-5 for more information.VDDREXTCEXTVSSOSC1InternalclockPIC16F505NFOSC/4 OSC2/CLKOUTPIC12F508PIC12F509Note: Erasing the device will also erase the preprogrammedinternal calibration value forthe internal oscillator. The calibrationvalue must be read prior to erasing thepart so it can be reprogrammed correctlylater.Note: The 0 bit of OSCCAL is unimplementedand should be written as ‘0’ whenmodifying OSCCAL for compatibility withfuture devices. "Multumesc anticipat!
  • Răspunsuri 9
  • a_sorien
    5
  • Liviu M
  • MatyC
Salut ! E un picp02 de la Adelaida si programez cu winpic800 . Cum citesc constanta asta cred ca stiu , dar cum o salvez din nou la programare..?Trebuie scrisa din nou la 0x3F..? Multumesc..!
Si daca o ignor...?! O sterg la programare si nu ma intereseaza...aplicatia nefiind pretentioasa in acest domeniu .Sau mai bine sa o fac cu rezonator si am scapat de ...problema...!? Insa imi ramane pe creier .
Atata timp cat nu apesi pe butonul "Scrie", poti sa vezi ce se intampla cand conectezi programatorul la calculator, pui picul in programator si pornesti winpin800. Din cate tin eu minte *), citeste automat valoarea OSCCAL si ti-o arata. Daca stergi valoarea OSCCAL, iti vor functiona corect aplicatiile care nu au nevoie de timpi exacti. Daca reusesti sa-l stergi, cauta pe forum, in cateva topicuri ai sa gasesti niste valori care se potrivesc mai bine decat "totul 0" sau "totul 1".*) Sunt sanse sa ma insel, am testat winpic-ul cu mult timp in urma.
Nu se scrie in cod, programatorul/softul de programare e cel care se ocupa de asta.Cum exact face winpic asta trebuie sa cauti singur. Cred ca e suficient sa ai grija ca in campul pentru OSCCAL sa fie valoarea care trebuie/sa n-o stergi din greseala. Daca o stergi, nu-i problema, o scrii la urmatoarea programare. Trebuie doar s-o notezi, ca s-o poti rescrie.LE Am instalat acum si winpic800 si picpgm si picpgm mi se pare mai prietenos. Daca as fi in locul tau l-as incerca mai intai pe ultimul (picpgm).
Sa nu ignori valoarea OSCCAL ca eu am patit-o din cauza ei. Un prieten a modificat un program de blink led si la OSCCAL a fost belea. Softul de programare a cerut valoarea default, a dat OK si in final functionarea era haotica. Pana nu am folosit Pickit 2 software pentru recuperare valoare OSCCAL nu a functionat. In cazul meu a fost vorba de un PIC12F675 sau 629 ca nu mai stiu sigur.NU IGNORA VALOAREA OSCCAL, prezenta la unele variante de microcontrolere PIC !!!
  • 4 săptămâni mai târziu...
Deci , pana acum , mo ucis OSCCAL . PICKIT2 are posibilitatea sa o regenereze , dar eu nu am reusit . Am scris totusi o valoare ( 00ff) in osccal si am decis sa folosesc quartz . La programare insa ma tot avertizeaza ca val osccal nu e cea valida . Mai are importanta acum , daca eu lucrez cu setarea _XT_OSC ..???!! Zau nu inteleg de ce totusi Microchip nu a facut asta in fabrica sa nu ma mai chinuie pe mine...!!?Seta valoarea asta ...implicit...si gata!Ma lumineaza si pe mine cineva..?!
