ajutor drivere hp dv1000 windows 7
efti
  • Răspunsuri 4
  • efti
  • FLORIN IORDACHE
  • leoncris
  • cristybadea
Zile populare
I read a few threads and seems like you guys want to know the HW ID. Here's the ones I have:2 under "Other Devices":PCI\VEN_1180&DEV_0592&SUBSYS_30A0103C&REV_0APCI\VEN_1180&DEV_0592&SUBSYS_30A0103CPCI\VEN_1180&DEV_0592&CC_088000PCI\VEN_1180&DEV_0592&CC_0880AndPCI\VEN_1180&DEV_0843&SUBSYS_30A0103C&REV_01PCI\VEN_1180&DEV_0843&SUBSYS_30A0103CPCI\VEN_1180&DEV_0843&CC_088000PCI\VEN_1180&DEV_0843&CC_0880And under Sound I get these:HDAUDIO\FUNC_01&VEN_14F1&DEV_5047&SUBSYS_103C30A0&REV_1000HDAUDIO\FUNC_01&VEN_14F1&DEV_5047&SUBSYS_103C30A0The sound card is the AC97 for most HP/Compaq laptops (from what I've read).By experimenting myself, I finally able to get sound on my dv1000. The first thing you do is use the second hardware id from audio details in device manager (that was the last thing you listed...HDAUDIO\FUNC_01&VEN_14F1&DEV_5047&SUBSYS_103C30A0. Copy it and go to Microsoft Update Catalog and let the active x install. Copy that ID into the search. You should get 4 downloads. Choose to download all...after they are done you can see 2 folders containing .cab files. Go to the folder with only one cab file and extract it to a folder with winrar. Execute the HFX file after setting it for vista compatibility and run as administrator. After it runs you will, alas, finally hear sound through the speakers. After the program runs, it should tell you to restart, if it dosen't; restart manually or you will lose the sound. This is not a fluke as my wife has a dv1710 CTO and mine is a dv1600 CTO worked like a charm on both!
