Timer cutie expunere uv
MariusTehnik
Atasez mai jos o schema cu pic 12f628a si ecran lcd 16x2 , temporizator secunde-minute cu posibilitate de a seta dublu strat sau simplu strat(cumpland un releu sau amandoua) , totul facandu-se din butoanele din schema.Hex-ul aferent si pcb-ul in eagle.Se mai poate cosmetiza pentru cine mai doreste....:)
  • Răspunsuri 7
  • dorelb
  • MariusTehnik
  • tiberiu2006
  • vasile eugen
Zile populare
Nu este nici un fisier hex, in acea arhiva. Asta contine fisierul hex :
'* Name : UV PCB Exposure System Timer *
'* Author : Stijn Coenen [stynus] *
'* Notice : Licensed under Creative Commons *
'* : Attribution-Noncommercial 2.0 Belgium Licence *
'* : http://creativecommons.org/licenses/by-nc/2.0/be/ *
'* Date : 28/08/2011 *
'* Version : 2.11 *
'* Url : English: en.elektronicastynus.be/projects/81/ *
'* : Dutch: http://www.elektronicastynus.be/Projecten/81/ *
Device 16F628A
Config INTRC_OSC_NOCLKOUT, WDT_off, PWRTE_ON, LVP_off, MCLRE_OFF
All_Digital TRUE
Xtal = 4
'Set the default data in the eeprom at programming
EData 0,0,10, 107 'Singe Sided, Exposure Time minutes, Exposure Time Seconds, Interrupt preload
'In and outputs
'Tris registers
'76543210
TRISA = %01100000
TRISB = %00001111
Symbol Relay1 = PORTA.2
Symbol Relay2 = PORTA.3
Symbol Buzzer = PORTA.7
High Buzzer 'Buzzer is connected to the 5V, so pin must be high to disable
Symbol Btn_1 = PORTB.2 '3 input buttons
Symbol Btn_2 = PORTB.1
Symbol Btn_3 = PORTB.0
'Lcd screen
Declare LCD_ENPin PORTA.1
Declare LCD_RSPin PORTA.0
Declare LCD_DTPin PORTB.4
Declare LCD_Interface 4
Declare LCD_Lines 2
Symbol LcdTime = 200 'Time for each step at the startup message and hidden menu
etc.etc.etc
Si asta am descarcat de pe site-ul pus de @tiberiu2006.
:020000000F29C6
:08000800FF0003088301FE0064
:100010000408FD00CC2FA701A901A8000130A5000C
:1000200029082702031D1628280826020430031871
:100030000130031902302505031D01300B298030E2
:10004000A100FE30AF200130AF207530A700303066
:10005000DB28A101A117AF00FE30AF202F08AF2889
:10006000A401AA00AB01A01124080319A0150530B2
:10007000A3002730A900103049200330A900E83040
:100080004920A90164304920A9010A3049202A08E1
:100090005028A8002B08A7002A08A600EF20260851
:1000A000A600A3030319A011240803195A28230248
:1000B000031861282608031DA011A0196128303EED
etc.etc.etc
In arhiva pusa de @flo_tiesto nu este nici un hex .
Cine are nevoie de hex sa il ia din arhiva de mai jos .
PCB_Exposure_Box_Timer_Code.zip
  • Administratori
Asta e hex
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
