vand diverse electrice si electronice
rellu
1.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta.
http://i.imgur.com/xLYj1pw.jpg
http://i.imgur.com/WyGhzFR.jpg
http://i.imgur.com/tNXaBXc.jpg
2.aparate de masura defecte (pentru piese;afisaj;etc). pret 15 lei ambele + posta.
https://imgur.com/SzZeg5U
3.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.
[imgur](http://i.imgur.com/mtlTIuY.jpg)
4.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.
[imgur](http://i.imgur.com/yIxmzmC.jpg)
[imgur](http://i.imgur.com/kJWupcB.jpg)
5.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.
[imgur](http://i.imgur.com/u8qQ0dN.jpg)
[imgur](http://i.imgur.com/9bmAhmz.jpg)
6.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.
[imgur](http://i.imgur.com/lHhoFg1.jpg)
[imgur](http://i.imgur.com/bENzley.jpg)
7.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.
[imgur](http://i.imgur.com/rZhpDdi.jpg)
[imgur](http://i.imgur.com/mgVcZHL.jpg)
8.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.
[imgur](http://i.imgur.com/09mNFgR.jpg)
[imgur](http://i.imgur.com/IUAAbvG.jpg)
9.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.
[imgur](http://i.imgur.com/gopU9Jx.jpg)
10.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.
[imgur](http://i.imgur.com/Q6Mv7iU.jpg)
11.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta.
[imgur](http://i.imgur.com/1BsMxy3.jpg)
12.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta.
[imgur](http://i.imgur.com/vIKFhgQ.jpg)
[imgur](http://i.imgur.com/OJ8Vqfe.jpg)
13.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta.
[imgur](http://i.imgur.com/oNCeaLC.jpg)
14.grup de panglici diferite marimi. pret 15 lei / grup + posta.
[imgur](http://i.imgur.com/PYL0AKj.jpg)
15.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta.
[imgur](http://i.imgur.com/bq5bYS6.jpg)
16.afisaj lcd ,pret 10 lei + posta.
[imgur](http://i.imgur.com/BP5rzGf.jpg)
[imgur](http://i.imgur.com/8rFWX2P.jpg)
17.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta.
[imgur](http://i.imgur.com/NLKPV66.jpg)
18.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 25 lei + posta.
http://i.imgur.com/Frqu9QZ.jpg
http://i.imgur.com/UUNdS7N.jpg
19.placa electronica de la cuptor cu microunde pret 15 lei + posta.
http://i.imgur.com/zYtD8lh.jpg
http://i.imgur.com/97FEYSw.jpg
http://i.imgur.com/4Sx4GqJ.jpg
20.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta.
http://i.imgur.com/2Agl8dv.jpg
http://i.imgur.com/Z9zL8Ju.jpg
21.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru.
http://i.imgur.com/JOcMIpy.jpg
http://i.imgur.com/t250v7G.jpg
bonus : http://i.imgur.com/oYTi11h.jpg
22.relee de la dacia solenza ,ambele la pretul de 15 lei + posta.
http://i.imgur.com/GGhweL0.jpg
http://i.imgur.com/GZ8nm4i.jpg
23.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta.
http://i.imgur.com/kpI04aU.jpg
24.potentiometru de 3W 100 ohm. pret 10 lei + posta.
http://i.imgur.com/FU4l33Z.jpg
http://i.imgur.com/wgk0AiK.jpg
25.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta.
http://i.imgur.com/8CRmOOY.jpg
26.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta.
http://i.imgur.com/7TbOl4t.jpg
27.miliampermetru 300uA. pret 10 lei + posta.
http://i.imgur.com/GsO33A7.jpg
http://i.imgur.com/dDr7fEg.jpg
28.trafo. 230v / 2x9 v. pret 10 lei + posta.
http://i.imgur.com/qJne31S.jpg
http://i.imgur.com/FmxKqN4.jpg
29.motor cu 4 trepte de turatie la 230v c.a. (storcator fructe). pret 15 lei + posta.
http://imgur.com/1tisXht
http://imgur.com/cBfOwam
30.digital delay sovietic dezmembrat. pret 10 lei + posta.
http://imgur.com/qu4syhC
http://imgur.com/9csQlg1
http://imgur.com/LcSTZ9M
31.condensatori la 500v c.c. 6 buc. la 10 lei + posta.
http://imgur.com/i1vvKvR
32.releu cu bobina la 24v made poland. 2buc. 8 lei + posta.
http://imgur.com/l9XYD1U
http://imgur.com/HBSIY1y
33.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta.
http://imgur.com/Pe2a7sZ
34.sursa in comutatie ricoh. pret 15 lei + posta.
http://imgur.com/i3UL1rf
35.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta.
http://imgur.com/c4l6QJm
http://imgur.com/JnHF3Mq
36.revista depanatorul (nr.5/1992;nr.6/1993;nr.7/1994). pret 10 lei + posta.
http://imgur.com/DHwvNSc
37.mp5 player (DO QUICK model:RK-5300) in perfecta stare de functionare. pret 60 lei + posta.
-memorie interna 4 Gb
-radio fm
-reportofon
-rec. dupa fm
-display 4,5 inch
-slot card microsd
-mufa casti stereo 3,5mm
-mufa miniusb
http://imgur.com/GvwayfW
http://imgur.com/DcKI0DI
http://imgur.com/AuTTUUc
http://imgur.com/gwM8H77
http://imgur.com/AUIVo0p
http://imgur.com/dQFCXrk
http://imgur.com/VAUo7Wm
38.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta.
input : 240v
out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A
http://imgur.com/5QLw6qx
http://imgur.com/ZYTZrWe
http://imgur.com/p802IGU
http://imgur.com/b4RKXKe
39.diverse placi tv LCD. nu stiu starea lor. pret 15 lei / placa + posta.
placa2a  https://imgur.com/J4wgg8j
placa2b  https://imgur.com/K3jQ9v0
placa3a  https://imgur.com/m0VlX9q
placa3b  https://imgur.com/4S7IHan
40.radiator aluminiu (26X18X3,5 cm) pret 15 lei + posta.
https://imgur.com/wmmIEiX
https://imgur.com/hMUrpfZ
41.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta.
dif.1  https://imgur.com/EFMFjlc   ;  https://imgur.com/DGh4KqK
dif.2  https://imgur.com/MKeUVoQ   ;  https://imgur.com/VbAnMu9
dif3.  https://imgur.com/Dnj9gWl  ;  https://imgur.com/QJb9q2x
dif4.  https://imgur.com/cdZMq7b  ;  https://imgur.com/t12Xdh8
dif5. toate 4 buc. la 10 lei + posta.
https://imgur.com/ext6gui
https://imgur.com/NufOVtN
https://imgur.com/qF3TxM3
42.mp3 player + radio mpman (TS350 FM 8Gb) cu thouchscreen. pret 95 lei + posta.
https://imgur.com/PeZpd37
https://imgur.com/VszMeIx
https://imgur.com/UtjzzgN
https://imgur.com/d3hRli4
https://imgur.com/1YBDymt
43.gps garmin nuvi 300 + suport parbriz + alimentator auto. pret 120 lei + posta.
https://imgur.com/I7l6XWz
https://imgur.com/xB74YkQ
https://imgur.com/O7Qah11
https://imgur.com/cF5L0tL
https://imgur.com/QiKtV37
https://imgur.com/RfNuhVz
https://imgur.com/BvgB6kk
44.piese diverse :
1.punte redresoare 1PM4 pret 0,25 lei/buc.
https://imgur.com/TPdefmo
2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc.
https://imgur.com/vgW9yku
3.tranzistor AD152V pret 1,5 lei/buc.
https://imgur.com/bD9RPv0
4.tranzistor BC107 pret 0,25 lei/buc.
https://imgur.com/0Zof0aU
5.tranzistor BC171 pret 0,25 lei/buc.
https://imgur.com/cBGVNQl
6.tiristor T3F2 pret 1 leu/buc.
https://imgur.com/RcCOaLV
7.distantiere siliconice cu adeziv pret 10 lei.
https://imgur.com/gIJq97B
45.mini radio Thomson digital; FM/MW ;stereo ;se pot memora 10 posturi. pret 60 lei + posta.
https://imgur.com/xT9CL6I
https://imgur.com/FyX2gsP
https://imgur.com/cCoefIe
46.telecomanda logitech harmony 555. pret 100 lei + posta.
https://imgur.com/yTHJK8M
https://imgur.com/f2tauzo
https://imgur.com/MsQxMUk
https://imgur.com/RHi79yv
Componente IT :
1.placa video pc defecta. pret 5 lei + posta.
http://imgur.com/no2NWZq
2.cooler+ventilator pt. procesor pret.20 lei + posta.
[imgur](http://i.imgur.com/ix8gA.jpg)
3.tastatura usb (Germania;litere specifice) pret 10 lei + posta.
[imgur](http://i.imgur.com/kfdnQiF.jpg)
4.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta.
[imgur](http://i.imgur.com/lXepBUN.jpg)
5.unitate optica dvd (dvd-recorder). pret 15 lei + posta.
[imgur](http://i.imgur.com/o3wSwQC.jpg)
[imgur](http://i.imgur.com/7ZcTYGV.jpg)
6.cd-rom (conector IDE) perfect functional. pret 10 lei + posta.
http://imgur.com/RmkzO4d
7.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 15 lei + posta.
http://imgur.com/uO080t3
8.procesor amd sempron 64 LE-1150 socket AM2. pret 15 lei + posta.
https://imgur.com/cFAT20r
https://imgur.com/nE5kRBd
9.memorii DDR1 512 Mb diferite modele. pret 10 lei buc. + posta.
geil pc3200 - 2 buc.
kingmax pc3200 - 2 buc.
pc 2700u - 1 buc.
https://imgur.com/UmypYT5
https://imgur.com/Nbf12Bs
https://imgur.com/2TQCohF
10.router D-Link DIR-635. pret 40 lei + posta.
https://imgur.com/xgFrcHy
https://imgur.com/TmXtXHR
https://imgur.com/AsOsFiy
11. alimentator laptop cu 2 tensiuni de iesire : 16V - 5,2 A c.c. ; 19V - 4,74 A c.c.  pret 50 lei + posta.
https://imgur.com/qyRxdjk
https://imgur.com/jiUvQz5
Produsele din ultimul topic sunt valabile.
Cine face plata in cont transportul cu Posta Romana este gratis.
-radio fm
-reportofon
-rec. dupa fm
-display 4,5 inch
-slot card microsd
-mufa miniusb
input : 240v
44.piese diverse :
Componente IT :
pc 2700u - 1 buc.
-radio fm
-reportofon
-rec. dupa fm
-display 4,5 inch
-slot card microsd
-mufa miniusb
input : 240v
44.piese diverse :
Componente IT :
pc 2700u - 1 buc.
-radio fm
-reportofon
-rec. dupa fm
-display 4,5 inch
-slot card microsd
-mufa miniusb
input : 240v
44.piese diverse :
Componente IT :
pc 2700u - 1 buc.
-radio fm
-reportofon
-rec. dupa fm
-display 4,5 inch
-slot card microsd
-mufa miniusb
input : 240v
44.piese diverse :
Componente IT :
pc 2700u - 1 buc.
12.modem 4G huawei 392u-12 liber de retea. 70 lei + posta.
https://imgur.com/Xdt87Ni
https://imgur.com/zrNnsk5
https://imgur.com/dOwEHGg
13.modem 3G huawei 3131 liber de retea. 40 lei + posta.
https://imgur.com/WyMYTa7
https://imgur.com/ZfKAlYE
-radio fm
-reportofon
-rec. dupa fm
-display 4,5 inch
-slot card microsd
-mufa miniusb
input : 240v
44.piese diverse :
Componente IT :
pc 2700u - 1 buc.
-radio fm
-reportofon
-rec. dupa fm
-display 4,5 inch
-slot card microsd
-mufa miniusb
input : 240v
44.piese diverse :
Componente IT :
pc 2700u - 1 buc.
-radio fm
-reportofon
-rec. dupa fm
-display 4,5 inch
-slot card microsd
-mufa miniusb
input : 240v
44.piese diverse :
Componente IT :
pc 2700u - 1 buc.
12.modem 3G huawei 3131 liber de retea. 40 lei + posta.
10.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta.
11.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta.
12.afisaj lcd ,pret 10 lei + posta.
13.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta.
14.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 20 lei + posta.
15.placa electronica de la cuptor cu microunde pret 15 lei + posta.
16.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru.
17.relee de la dacia solenza ,ambele la pretul de 15 lei + posta.
18.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta.
19.potentiometru de 3W 100 ohm. pret 10 lei + posta.
20.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta.
21.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta.
22.miliampermetru 300uA. pret 10 lei + posta.
23.trafo. 230v / 2x9 v. pret 10 lei + posta.
24.motor cu 4 trepte de turatie la 230v c.a. (storcator fructe). pret 15 lei + posta.
25.digital delay sovietic dezmembrat. pret 10 lei + posta.
26.condensatori la 500v c.c. 6 buc. la 10 lei + posta.
27.releu cu bobina la 24v made poland. 2buc. 8 lei + posta.
28.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta.
29.sursa in comutatie ricoh. pret 15 lei + posta.
30.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta.
31.mp5 player (DO QUICK model:RK-5300) in perfecta stare de functionare. pret 60 lei + posta.
-radio fm
-reportofon
-rec. dupa fm
-display 4,5 inch
-slot card microsd
-mufa miniusb
32.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta.
input : 240v
33.radiator aluminiu (26X18X3,5 cm) pret 15 lei + posta.
34.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta.
35.mp3 player + radio mpman (TS350 FM 8Gb) cu thouchscreen. pret 95 lei + posta.
36.gps garmin nuvi 300 + suport parbriz + alimentator auto. pret 120 lei + posta.
37.piese diverse :
38.mini radio Thomson digital; FM/MW ;stereo ;se pot memora 10 posturi. pret 60 lei + posta.
39.telecomanda logitech harmony 555. pret 90 lei + posta.
Componente IT :
1.cooler+ventilator pt. procesor pret.20 lei + posta.
2.tastatura usb (Germania;litere specifice) pret 10 lei + posta.
3.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta.
4.unitate optica dvd (dvd-recorder). pret 15 lei + posta.
5.cd-rom (conector IDE) perfect functional. pret 10 lei + posta.
6.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 15 lei + posta.
7.procesor amd sempron 64 LE-1150 socket AM2. pret 15 lei + posta.
8.memorii DDR1 512 Mb diferite modele. pret 10 lei buc. + posta.
pc 2700u - 1 buc.
9. alimentator laptop cu 2 tensiuni de iesire : 16V - 5,2 A c.c. ; 19V - 4,74 A c.c.  pret 50 lei + posta.
10.modem 3G huawei 3131 liber de retea. 40 lei + posta.
-radio fm
-reportofon
-rec. dupa fm
-display 4,5 inch
-slot card microsd
-mufa miniusb
input : 240v
37.piese diverse :
Componente IT :
pc 2700u - 1 buc.
-radio fm
-reportofon
-rec. dupa fm
-display 4,5 inch
-slot card microsd
-mufa miniusb
input : 240v
37.piese diverse :
Componente IT :
pc 2700u - 1 buc.
-radio fm
-reportofon
-rec. dupa fm
-display 4,5 inch
-slot card microsd
-mufa miniusb
input : 240v
37.piese diverse :
Componente IT :
pc 2700u - 1 buc.
24.digital delay sovietic dezmembrat. pret 10 lei + posta.
25.condensatori la 500v c.c. 6 buc. la 10 lei + posta.
26.releu cu bobina la 24v made poland. 2buc. 8 lei + posta.
27.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta.
28.sursa in comutatie ricoh. pret 15 lei + posta.
29.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta.
30.mp5 player (DO QUICK model:RK-5300) in perfecta stare de functionare. pret 60 lei + posta.
-radio fm
-reportofon
-rec. dupa fm
-display 4,5 inch
-slot card microsd
-mufa miniusb
31.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta.
input : 240v
32.radiator aluminiu (26X18X3,5 cm) pret 15 lei + posta.
33.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta.
34.mp3 player + radio mpman (TS350 FM 8Gb) cu thouchscreen. pret 95 lei + posta.
35.gps garmin nuvi 300 + suport parbriz + alimentator auto. pret 120 lei + posta.
36.piese diverse :
37.mini radio Thomson digital; FM/MW ;stereo ;se pot memora 10 posturi. pret 60 lei + posta.
38.telecomanda logitech harmony 555. pret 90 lei + posta.
Componente IT :
pc 2700u - 1 buc.
-radio fm
-reportofon
-rec. dupa fm
-display 4,5 inch
-slot card microsd
-mufa miniusb
input : 240v
36.piese diverse :
Componente IT :
pc 2700u - 1 buc.
