rellu Postat Iunie 5, 2018 Autor Partajează Postat Iunie 5, 2018 1.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 2.aparate de masura defecte (pentru piese;afisaj;etc). pret 15 lei ambele + posta. https://imgur.com/SzZeg5U 3.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta. [imgur](http://i.imgur.com/mtlTIuY.jpg) 4.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 5.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 6.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 7.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 8.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta. [imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg) 9.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 10.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta. [imgur](http://i.imgur.com/Q6Mv7iU.jpg) 11.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 12.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 13.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 14.grup de panglici diferite marimi. pret 15 lei / grup + posta. [imgur](http://i.imgur.com/PYL0AKj.jpg) 15.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 16.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 17.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 18.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 25 lei + posta. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 19.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 20.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 21.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 22.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 23.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 24.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 25.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 26.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 27.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 28.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 29.motor cu 4 trepte de turatie la 230v c.a. (storcator fructe). pret 15 lei + posta. http://imgur.com/1tisXht http://imgur.com/cBfOwam 30.digital delay sovietic dezmembrat. pret 10 lei + posta. http://imgur.com/qu4syhC http://imgur.com/9csQlg1 http://imgur.com/LcSTZ9M 31.condensatori la 500v c.c. 6 buc. la 10 lei + posta. http://imgur.com/i1vvKvR 32.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 33.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 34.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 35.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 36.revista depanatorul (nr.5/1992;nr.6/1993;nr.7/1994). pret 10 lei + posta. http://imgur.com/DHwvNSc 37.mp5 player (DO QUICK model:RK-5300) in perfecta stare de functionare. pret 60 lei + posta. -memorie interna 4 Gb -radio fm -reportofon -rec. dupa fm -display 4,5 inch -slot card microsd -mufa casti stereo 3,5mm -mufa miniusb http://imgur.com/GvwayfW http://imgur.com/DcKI0DI http://imgur.com/AuTTUUc http://imgur.com/gwM8H77 http://imgur.com/AUIVo0p http://imgur.com/dQFCXrk http://imgur.com/VAUo7Wm 38.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 39.Garmin Nuvi 660FM, harti Romania si Europa 2017. pret 150 lei + posta. ventuza parbriz, incarcator original, receptor trafic. https://imgur.com/xuZaNHp https://imgur.com/mDwXgcH https://imgur.com/X8Rbv2k https://imgur.com/Iw2hZtG 40.diverse placi tv LCD. nu stiu starea lor. pret 15 lei / placa + posta. placa2a https://imgur.com/J4wgg8j placa2b https://imgur.com/K3jQ9v0 placa3a https://imgur.com/m0VlX9q placa3b https://imgur.com/4S7IHan 41.radiator aluminiu (26X18X3,5 cm) pret 15 lei + posta. https://imgur.com/wmmIEiX https://imgur.com/hMUrpfZ 42.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. https://imgur.com/cdZMq7b ; https://imgur.com/t12Xdh8 dif5. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 43.mp3 player + radio mpman (TS350 FM 8Gb) cu thouchscreen. pret 140 lei + posta. https://imgur.com/PeZpd37 https://imgur.com/VszMeIx https://imgur.com/UtjzzgN https://imgur.com/d3hRli4 https://imgur.com/1YBDymt 44.gps garmin nuvi 300 + suport parbriz. pret 100 lei + posta. https://imgur.com/I7l6XWz https://imgur.com/xB74YkQ https://imgur.com/O7Qah11 https://imgur.com/cF5L0tL https://imgur.com/QiKtV37 45.piese diverse : 1.tranzistor 2N3055H pret 2,50 lei/buc. https://imgur.com/6AghLqC 2.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 3.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 4.tranzistor AD152V pret 1,5 lei/buc. https://imgur.com/bD9RPv0 5.tranzistor BC107 pret 0,25 lei/buc. https://imgur.com/0Zof0aU 6.tranzistor BC171 pret 0,25 lei/buc. https://imgur.com/cBGVNQl 7.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 8.distantiere siliconice cu adeziv pret 10 lei. https://imgur.com/gIJq97B Componente IT : 1.placa video pc defecta. pret 5 lei + posta. http://imgur.com/no2NWZq 2.cooler+ventilator pt. procesor pret.20 lei + posta. [imgur](http://i.imgur.com/ix8gA.jpg) 3.tastatura usb (Germania;litere specifice) pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 4.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 5.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 6.antena wifi. pret 15 lei + posta. http://imgur.com/YqnlEYN 7.cd-rom (conector IDE) perfect functional. pret 10 lei + posta. http://imgur.com/RmkzO4d 8.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 20 lei + posta. http://imgur.com/uO080t3 9.memorie server Elpida ( 2GB 2Rx4 PC2-3200R-333 10-J0) pret 20 lei/buc. + posta. https://imgur.com/gnBSYT5 10.procesor amd sempron 64 LE-1150 socket AM2. pret 20 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 11.memorii DDR1 512 Mb diferite modele. pret 10 lei buc. + posta. geil pc3200 - 2 buc. kingmax pc3200 - 2 buc. pc 2700u - 1 buc. https://imgur.com/UmypYT5 https://imgur.com/Nbf12Bs https://imgur.com/2TQCohF 12. memorie ddr3 8Gb la 1600Mhz in perfecta stare de functionare. pret 190 lei + posta. https://imgur.com/SlSqytY https://imgur.com/AnVvWKp https://imgur.com/ivySFUW 13.router D-Link DIR-635. pret 40 lei + posta. https://imgur.com/xgFrcHy https://imgur.com/TmXtXHR https://imgur.com/AsOsFiy 14. alimentator laptop cu 2 tensiuni de iesire : 16V - 5,2 A c.c. ; 19V - 4,74 A c.c. pret 50 lei + posta. https://imgur.com/qyRxdjk https://imgur.com/jiUvQz5 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Iunie 7, 2018 Autor Partajează Postat Iunie 7, 2018 1.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 2.aparate de masura defecte (pentru piese;afisaj;etc). pret 15 lei ambele + posta. https://imgur.com/SzZeg5U 3.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta. [imgur](http://i.imgur.com/mtlTIuY.jpg) 4.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 5.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 6.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 7.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 8.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta. [imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg) 9.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 10.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta. [imgur](http://i.imgur.com/Q6Mv7iU.jpg) 11.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 12.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 13.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 14.grup de panglici diferite marimi. pret 15 lei / grup + posta. [imgur](http://i.imgur.com/PYL0AKj.jpg) 15.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 16.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 17.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 18.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 25 lei + posta. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 19.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 20.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 21.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 22.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 23.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 24.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 25.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 26.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 27.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 28.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 29.motor cu 4 trepte de turatie la 230v c.a. (storcator fructe). pret 15 lei + posta. http://imgur.com/1tisXht http://imgur.com/cBfOwam 30.digital delay sovietic dezmembrat. pret 10 lei + posta. http://imgur.com/qu4syhC http://imgur.com/9csQlg1 http://imgur.com/LcSTZ9M 31.condensatori la 500v c.c. 6 buc. la 10 lei + posta. http://imgur.com/i1vvKvR 32.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 33.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 34.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 35.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 36.revista depanatorul (nr.5/1992;nr.6/1993;nr.7/1994). pret 10 lei + posta. http://imgur.com/DHwvNSc 37.mp5 player (DO QUICK model:RK-5300) in perfecta stare de functionare. pret 60 lei + posta. -memorie interna 4 Gb -radio fm -reportofon -rec. dupa fm -display 4,5 inch -slot card microsd -mufa casti stereo 3,5mm -mufa miniusb http://imgur.com/GvwayfW http://imgur.com/DcKI0DI http://imgur.com/AuTTUUc http://imgur.com/gwM8H77 http://imgur.com/AUIVo0p http://imgur.com/dQFCXrk http://imgur.com/VAUo7Wm 38.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 39.Garmin Nuvi 660FM, harti Romania si Europa 2017. pret 150 lei + posta. ventuza parbriz, incarcator original, receptor trafic. https://imgur.com/xuZaNHp https://imgur.com/mDwXgcH https://imgur.com/X8Rbv2k https://imgur.com/Iw2hZtG 40.diverse placi tv LCD. nu stiu starea lor. pret 15 lei / placa + posta. placa2a https://imgur.com/J4wgg8j placa2b https://imgur.com/K3jQ9v0 placa3a https://imgur.com/m0VlX9q placa3b https://imgur.com/4S7IHan 41.radiator aluminiu (26X18X3,5 cm) pret 15 lei + posta. https://imgur.com/wmmIEiX https://imgur.com/hMUrpfZ 42.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. https://imgur.com/cdZMq7b ; https://imgur.com/t12Xdh8 dif5. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 43.mp3 player + radio mpman (TS350 FM 8Gb) cu thouchscreen. pret 140 lei + posta. https://imgur.com/PeZpd37 https://imgur.com/VszMeIx https://imgur.com/UtjzzgN https://imgur.com/d3hRli4 https://imgur.com/1YBDymt 44.gps garmin nuvi 300 + suport parbriz. pret 100 lei + posta. https://imgur.com/I7l6XWz https://imgur.com/xB74YkQ https://imgur.com/O7Qah11 https://imgur.com/cF5L0tL https://imgur.com/QiKtV37 45.piese diverse : 1.tranzistor 2N3055H pret 2,50 lei/buc. https://imgur.com/6AghLqC 2.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 3.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 4.tranzistor AD152V pret 1,5 lei/buc. https://imgur.com/bD9RPv0 5.tranzistor BC107 pret 0,25 lei/buc. https://imgur.com/0Zof0aU 6.tranzistor BC171 pret 0,25 lei/buc. https://imgur.com/cBGVNQl 7.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 8.distantiere siliconice cu adeziv pret 10 lei. https://imgur.com/gIJq97B Componente IT : 1.placa video pc defecta. pret 5 lei + posta. http://imgur.com/no2NWZq 2.cooler+ventilator pt. procesor pret.20 lei + posta. [imgur](http://i.imgur.com/ix8gA.jpg) 3.tastatura usb (Germania;litere specifice) pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 4.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 5.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 6.antena wifi. pret 15 lei + posta. http://imgur.com/YqnlEYN 7.cd-rom (conector IDE) perfect functional. pret 10 lei + posta. http://imgur.com/RmkzO4d 8.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 20 lei + posta. http://imgur.com/uO080t3 9.memorie server Elpida ( 2GB 2Rx4 PC2-3200R-333 10-J0) pret 20 lei/buc. + posta. https://imgur.com/gnBSYT5 10.procesor amd sempron 64 LE-1150 socket AM2. pret 20 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 11.memorii DDR1 512 Mb diferite modele. pret 10 lei buc. + posta. geil pc3200 - 2 buc. kingmax pc3200 - 2 buc. pc 2700u - 1 buc. https://imgur.com/UmypYT5 https://imgur.com/Nbf12Bs https://imgur.com/2TQCohF 12. memorie ddr3 8Gb la 1600Mhz in perfecta stare de functionare. pret 190 lei + posta. https://imgur.com/SlSqytY https://imgur.com/AnVvWKp https://imgur.com/ivySFUW 13.router D-Link DIR-635. pret 40 lei + posta. https://imgur.com/xgFrcHy https://imgur.com/TmXtXHR https://imgur.com/AsOsFiy 14. alimentator laptop cu 2 tensiuni de iesire : 16V - 5,2 A c.c. ; 19V - 4,74 A c.c. pret 50 lei + posta. https://imgur.com/qyRxdjk https://imgur.com/jiUvQz5 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Iunie 9, 2018 Autor Partajează Postat Iunie 9, 2018 1.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 2.aparate de masura defecte (pentru piese;afisaj;etc). pret 15 lei ambele + posta. https://imgur.com/SzZeg5U 3.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta. [imgur](http://i.imgur.com/mtlTIuY.jpg) 4.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 5.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 6.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 7.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 8.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta. [imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg) 9.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 10.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta. [imgur](http://i.imgur.com/Q6Mv7iU.jpg) 11.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 12.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 13.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 14.grup de panglici diferite marimi. pret 15 lei / grup + posta. [imgur](http://i.imgur.com/PYL0AKj.jpg) 15.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 16.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 17.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 18.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 25 lei + posta. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 19.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 20.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 21.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 22.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 23.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 24.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 25.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 26.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 27.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 28.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 29.motor cu 4 trepte de turatie la 230v c.a. (storcator fructe). pret 15 lei + posta. http://imgur.com/1tisXht http://imgur.com/cBfOwam 30.digital delay sovietic dezmembrat. pret 10 lei + posta. http://imgur.com/qu4syhC http://imgur.com/9csQlg1 http://imgur.com/LcSTZ9M 31.condensatori la 500v c.c. 6 buc. la 10 lei + posta. http://imgur.com/i1vvKvR 32.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 33.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 34.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 35.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 36.revista depanatorul (nr.5/1992;nr.6/1993;nr.7/1994). pret 10 lei + posta. http://imgur.com/DHwvNSc 37.mp5 player (DO QUICK model:RK-5300) in perfecta stare de functionare. pret 60 lei + posta. -memorie interna 4 Gb -radio fm -reportofon -rec. dupa fm -display 4,5 inch -slot card microsd -mufa casti stereo 3,5mm -mufa miniusb http://imgur.com/GvwayfW http://imgur.com/DcKI0DI http://imgur.com/AuTTUUc http://imgur.com/gwM8H77 http://imgur.com/AUIVo0p http://imgur.com/dQFCXrk http://imgur.com/VAUo7Wm 38.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 39.Garmin Nuvi 660FM, harti Romania si Europa 2017. pret 150 lei + posta. ventuza parbriz, incarcator original, receptor trafic. https://imgur.com/xuZaNHp https://imgur.com/mDwXgcH https://imgur.com/X8Rbv2k https://imgur.com/Iw2hZtG 40.diverse placi tv LCD. nu stiu starea lor. pret 15 lei / placa + posta. placa2a https://imgur.com/J4wgg8j placa2b https://imgur.com/K3jQ9v0 placa3a https://imgur.com/m0VlX9q placa3b https://imgur.com/4S7IHan 41.radiator aluminiu (26X18X3,5 cm) pret 15 lei + posta. https://imgur.com/wmmIEiX https://imgur.com/hMUrpfZ 42.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. https://imgur.com/cdZMq7b ; https://imgur.com/t12Xdh8 dif5. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 43.mp3 player + radio mpman (TS350 FM 8Gb) cu thouchscreen. pret 140 lei + posta. https://imgur.com/PeZpd37 https://imgur.com/VszMeIx https://imgur.com/UtjzzgN https://imgur.com/d3hRli4 https://imgur.com/1YBDymt 44.gps garmin nuvi 300 + suport parbriz. pret 100 lei + posta. https://imgur.com/I7l6XWz https://imgur.com/xB74YkQ https://imgur.com/O7Qah11 https://imgur.com/cF5L0tL https://imgur.com/QiKtV37 45.piese diverse : 1.tranzistor 2N3055H pret 2,50 lei/buc. https://imgur.com/6AghLqC 2.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 3.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 4.tranzistor AD152V pret 1,5 lei/buc. https://imgur.com/bD9RPv0 5.tranzistor BC107 pret 0,25 lei/buc. https://imgur.com/0Zof0aU 6.tranzistor BC171 pret 0,25 lei/buc. https://imgur.com/cBGVNQl 7.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 8.distantiere siliconice cu adeziv pret 10 lei. https://imgur.com/gIJq97B Componente IT : 1.placa video pc defecta. pret 5 lei + posta. http://imgur.com/no2NWZq 2.cooler+ventilator pt. procesor pret.20 lei + posta. [imgur](http://i.imgur.com/ix8gA.jpg) 3.tastatura usb (Germania;litere specifice) pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 4.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 5.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 6.antena wifi. pret 15 lei + posta. http://imgur.com/YqnlEYN 7.cd-rom (conector IDE) perfect functional. pret 10 lei + posta. http://imgur.com/RmkzO4d 8.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 20 lei + posta. http://imgur.com/uO080t3 9.memorie server Elpida ( 2GB 2Rx4 PC2-3200R-333 10-J0) pret 20 lei/buc. + posta. https://imgur.com/gnBSYT5 10.procesor amd sempron 64 LE-1150 socket AM2. pret 20 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 11.memorii DDR1 512 Mb diferite modele. pret 10 lei buc. + posta. geil pc3200 - 2 buc. kingmax pc3200 - 2 buc. pc 2700u - 1 buc. https://imgur.com/UmypYT5 https://imgur.com/Nbf12Bs https://imgur.com/2TQCohF 12. memorie ddr3 8Gb la 1600Mhz in perfecta stare de functionare. pret 190 lei + posta. https://imgur.com/SlSqytY https://imgur.com/AnVvWKp https://imgur.com/ivySFUW 13.router D-Link DIR-635. pret 40 lei + posta. https://imgur.com/xgFrcHy https://imgur.com/TmXtXHR https://imgur.com/AsOsFiy 14. alimentator laptop cu 2 tensiuni de iesire : 16V - 5,2 A c.c. ; 19V - 4,74 A c.c. pret 50 lei + posta. https://imgur.com/qyRxdjk https://imgur.com/jiUvQz5 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
GMCD Postat Iunie 9, 2018 Partajează Postat Iunie 9, 2018 Am primit coletul, totul OK. Va multumesc pentru piesele bonus! Link spre comentariu
rellu Postat Iunie 11, 2018 Autor Partajează Postat Iunie 11, 2018 1.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 2.aparate de masura defecte (pentru piese;afisaj;etc). pret 15 lei ambele + posta. https://imgur.com/SzZeg5U 3.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta. [imgur](http://i.imgur.com/mtlTIuY.jpg) 4.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 5.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 6.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 7.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 8.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta. [imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg) 9.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 10.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta. [imgur](http://i.imgur.com/Q6Mv7iU.jpg) 11.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 12.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 13.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 14.grup de panglici diferite marimi. pret 15 lei / grup + posta. [imgur](http://i.imgur.com/PYL0AKj.jpg) 15.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 16.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 17.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 18.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 25 lei + posta. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 19.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 20.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 21.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 22.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 23.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 24.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 25.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 26.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 27.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 28.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 29.motor cu 4 trepte de turatie la 230v c.a. (storcator fructe). pret 15 lei + posta. http://imgur.com/1tisXht http://imgur.com/cBfOwam 30.digital delay sovietic dezmembrat. pret 10 lei + posta. http://imgur.com/qu4syhC http://imgur.com/9csQlg1 http://imgur.com/LcSTZ9M 31.condensatori la 500v c.c. 6 buc. la 10 lei + posta. http://imgur.com/i1vvKvR 32.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 33.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 34.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 35.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 36.revista depanatorul (nr.5/1992;nr.6/1993;nr.7/1994). pret 10 lei + posta. http://imgur.com/DHwvNSc 37.mp5 player (DO QUICK model:RK-5300) in perfecta stare de functionare. pret 60 lei + posta. -memorie interna 4 Gb -radio fm -reportofon -rec. dupa fm -display 4,5 inch -slot card microsd -mufa casti stereo 3,5mm -mufa miniusb http://imgur.com/GvwayfW http://imgur.com/DcKI0DI http://imgur.com/AuTTUUc http://imgur.com/gwM8H77 http://imgur.com/AUIVo0p http://imgur.com/dQFCXrk http://imgur.com/VAUo7Wm 38.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 39.Garmin Nuvi 660FM, harti Romania si Europa 2017. pret 150 lei + posta. ventuza parbriz, incarcator original, receptor trafic. https://imgur.com/xuZaNHp https://imgur.com/mDwXgcH https://imgur.com/X8Rbv2k https://imgur.com/Iw2hZtG 40.diverse placi tv LCD. nu stiu starea lor. pret 15 lei / placa + posta. placa2a https://imgur.com/J4wgg8j placa2b https://imgur.com/K3jQ9v0 placa3a https://imgur.com/m0VlX9q placa3b https://imgur.com/4S7IHan 41.radiator aluminiu (26X18X3,5 cm) pret 15 lei + posta. https://imgur.com/wmmIEiX https://imgur.com/hMUrpfZ 42.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. https://imgur.com/cdZMq7b ; https://imgur.com/t12Xdh8 dif5. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 43.mp3 player + radio mpman (TS350 FM 8Gb) cu thouchscreen. pret 140 lei + posta. https://imgur.com/PeZpd37 https://imgur.com/VszMeIx https://imgur.com/UtjzzgN https://imgur.com/d3hRli4 https://imgur.com/1YBDymt 44.gps garmin nuvi 300 + suport parbriz. pret 100 lei + posta. https://imgur.com/I7l6XWz https://imgur.com/xB74YkQ https://imgur.com/O7Qah11 https://imgur.com/cF5L0tL https://imgur.com/QiKtV37 45.piese diverse : 1.tranzistor 2N3055H pret 2,50 lei/buc. https://imgur.com/6AghLqC 2.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 3.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 4.tranzistor AD152V pret 1,5 lei/buc. https://imgur.com/bD9RPv0 5.tranzistor BC107 pret 0,25 lei/buc. https://imgur.com/0Zof0aU 6.tranzistor BC171 pret 0,25 lei/buc. https://imgur.com/cBGVNQl 7.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 8.distantiere siliconice cu adeziv pret 10 lei. https://imgur.com/gIJq97B Componente IT : 1.placa video pc defecta. pret 5 lei + posta. http://imgur.com/no2NWZq 2.cooler+ventilator pt. procesor pret.20 lei + posta. [imgur](http://i.imgur.com/ix8gA.jpg) 3.tastatura usb (Germania;litere specifice) pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 4.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 5.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 6.antena wifi. pret 15 lei + posta. http://imgur.com/YqnlEYN 7.cd-rom (conector IDE) perfect functional. pret 10 lei + posta. http://imgur.com/RmkzO4d 8.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 20 lei + posta. http://imgur.com/uO080t3 9.memorie server Elpida ( 2GB 2Rx4 PC2-3200R-333 10-J0) pret 20 lei/buc. + posta. https://imgur.com/gnBSYT5 10.procesor amd sempron 64 LE-1150 socket AM2. pret 20 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 11.memorii DDR1 512 Mb diferite modele. pret 10 lei buc. + posta. geil pc3200 - 2 buc. kingmax pc3200 - 2 buc. pc 2700u - 1 buc. https://imgur.com/UmypYT5 https://imgur.com/Nbf12Bs https://imgur.com/2TQCohF 12. memorie ddr3 8Gb la 1600Mhz in perfecta stare de functionare. pret 190 lei + posta. https://imgur.com/SlSqytY https://imgur.com/AnVvWKp https://imgur.com/ivySFUW 13.router D-Link DIR-635. pret 40 lei + posta. https://imgur.com/xgFrcHy https://imgur.com/TmXtXHR https://imgur.com/AsOsFiy 14. alimentator laptop cu 2 tensiuni de iesire : 16V - 5,2 A c.c. ; 19V - 4,74 A c.c. pret 50 lei + posta. https://imgur.com/qyRxdjk https://imgur.com/jiUvQz5 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Iunie 12, 2018 Autor Partajează Postat Iunie 12, 2018 1.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 2.aparate de masura defecte (pentru piese;afisaj;etc). pret 15 lei ambele + posta. https://imgur.com/SzZeg5U 3.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta. [imgur](http://i.imgur.com/mtlTIuY.jpg) 4.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 5.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 6.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 7.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 8.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta. [imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg) 9.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 10.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta. [imgur](http://i.imgur.com/Q6Mv7iU.jpg) 11.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 12.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 13.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 14.grup de panglici diferite marimi. pret 15 lei / grup + posta. [imgur](http://i.imgur.com/PYL0AKj.jpg) 15.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 16.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 17.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 18.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 25 lei + posta. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 19.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 20.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 21.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 22.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 23.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 24.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 25.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 26.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 27.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 28.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 29.motor cu 4 trepte de turatie la 230v c.a. (storcator fructe). pret 15 lei + posta. http://imgur.com/1tisXht http://imgur.com/cBfOwam 30.digital delay sovietic dezmembrat. pret 10 lei + posta. http://imgur.com/qu4syhC http://imgur.com/9csQlg1 http://imgur.com/LcSTZ9M 31.condensatori la 500v c.c. 6 buc. la 10 lei + posta. http://imgur.com/i1vvKvR 32.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 33.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 34.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 35.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 36.revista depanatorul (nr.5/1992;nr.6/1993;nr.7/1994). pret 10 lei + posta. http://imgur.com/DHwvNSc 37.mp5 player (DO QUICK model:RK-5300) in perfecta stare de functionare. pret 60 lei + posta. -memorie interna 4 Gb -radio fm -reportofon -rec. dupa fm -display 4,5 inch -slot card microsd -mufa casti stereo 3,5mm -mufa miniusb http://imgur.com/GvwayfW http://imgur.com/DcKI0DI http://imgur.com/AuTTUUc http://imgur.com/gwM8H77 http://imgur.com/AUIVo0p http://imgur.com/dQFCXrk http://imgur.com/VAUo7Wm 38.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 39.Garmin Nuvi 660FM, harti Romania si Europa 2017. pret 150 lei + posta. ventuza parbriz, incarcator original, receptor trafic. https://imgur.com/xuZaNHp https://imgur.com/mDwXgcH https://imgur.com/X8Rbv2k https://imgur.com/Iw2hZtG 40.diverse placi tv LCD. nu stiu starea lor. pret 15 lei / placa + posta. placa2a https://imgur.com/J4wgg8j placa2b https://imgur.com/K3jQ9v0 placa3a https://imgur.com/m0VlX9q placa3b https://imgur.com/4S7IHan 41.radiator aluminiu (26X18X3,5 cm) pret 15 lei + posta. https://imgur.com/wmmIEiX https://imgur.com/hMUrpfZ 42.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. https://imgur.com/cdZMq7b ; https://imgur.com/t12Xdh8 dif5. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 43.mp3 player + radio mpman (TS350 FM 8Gb) cu thouchscreen. pret 140 lei + posta. https://imgur.com/PeZpd37 https://imgur.com/VszMeIx https://imgur.com/UtjzzgN https://imgur.com/d3hRli4 https://imgur.com/1YBDymt 44.gps garmin nuvi 300 + suport parbriz. pret 100 lei + posta. https://imgur.com/I7l6XWz https://imgur.com/xB74YkQ https://imgur.com/O7Qah11 https://imgur.com/cF5L0tL https://imgur.com/QiKtV37 45.piese diverse : 1.tranzistor 2N3055H pret 2,50 lei/buc. https://imgur.com/6AghLqC 2.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 3.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 4.tranzistor AD152V pret 1,5 lei/buc. https://imgur.com/bD9RPv0 5.tranzistor BC107 pret 0,25 lei/buc. https://imgur.com/0Zof0aU 6.tranzistor BC171 pret 0,25 lei/buc. https://imgur.com/cBGVNQl 7.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 8.distantiere siliconice cu adeziv pret 10 lei. https://imgur.com/gIJq97B Componente IT : 1.placa video pc defecta. pret 5 lei + posta. http://imgur.com/no2NWZq 2.cooler+ventilator pt. procesor pret.20 lei + posta. [imgur](http://i.imgur.com/ix8gA.jpg) 3.tastatura usb (Germania;litere specifice) pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 4.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 5.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 6.antena wifi. pret 15 lei + posta. http://imgur.com/YqnlEYN 7.cd-rom (conector IDE) perfect functional. pret 10 lei + posta. http://imgur.com/RmkzO4d 8.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 20 lei + posta. http://imgur.com/uO080t3 9.memorie server Elpida ( 2GB 2Rx4 PC2-3200R-333 10-J0) pret 20 lei/buc. + posta. https://imgur.com/gnBSYT5 10.procesor amd sempron 64 LE-1150 socket AM2. pret 20 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 11.memorii DDR1 512 Mb diferite modele. pret 10 lei buc. + posta. geil pc3200 - 2 buc. kingmax pc3200 - 2 buc. pc 2700u - 1 buc. https://imgur.com/UmypYT5 https://imgur.com/Nbf12Bs https://imgur.com/2TQCohF 12. memorie ddr3 8Gb la 1600Mhz in perfecta stare de functionare. pret 190 lei + posta. https://imgur.com/SlSqytY https://imgur.com/AnVvWKp https://imgur.com/ivySFUW 13.router D-Link DIR-635. pret 40 lei + posta. https://imgur.com/xgFrcHy https://imgur.com/TmXtXHR https://imgur.com/AsOsFiy 14. alimentator laptop cu 2 tensiuni de iesire : 16V - 5,2 A c.c. ; 19V - 4,74 A c.c. pret 50 lei + posta. https://imgur.com/qyRxdjk https://imgur.com/jiUvQz5 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Iunie 13, 2018 Autor Partajează Postat Iunie 13, 2018 1.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 2.aparate de masura defecte (pentru piese;afisaj;etc). pret 15 lei ambele + posta. https://imgur.com/SzZeg5U 3.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta. [imgur](http://i.imgur.com/mtlTIuY.jpg) 4.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 5.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 6.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 7.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 8.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta. [imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg) 9.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 10.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta. [imgur](http://i.imgur.com/Q6Mv7iU.jpg) 11.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 12.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 13.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 14.grup de panglici diferite marimi. pret 15 lei / grup + posta. [imgur](http://i.imgur.com/PYL0AKj.jpg) 15.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 16.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 17.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 18.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 25 lei + posta. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 19.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 20.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 21.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 22.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 23.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 24.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 25.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 26.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 27.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 28.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 29.motor cu 4 trepte de turatie la 230v c.a. (storcator fructe). pret 15 lei + posta. http://imgur.com/1tisXht http://imgur.com/cBfOwam 30.digital delay sovietic dezmembrat. pret 10 lei + posta. http://imgur.com/qu4syhC http://imgur.com/9csQlg1 http://imgur.com/LcSTZ9M 31.condensatori la 500v c.c. 6 buc. la 10 lei + posta. http://imgur.com/i1vvKvR 32.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 33.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 34.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 35.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 36.revista depanatorul (nr.5/1992;nr.6/1993;nr.7/1994). pret 10 lei + posta. http://imgur.com/DHwvNSc 37.mp5 player (DO QUICK model:RK-5300) in perfecta stare de functionare. pret 60 lei + posta. -memorie interna 4 Gb -radio fm -reportofon -rec. dupa fm -display 4,5 inch -slot card microsd -mufa casti stereo 3,5mm -mufa miniusb http://imgur.com/GvwayfW http://imgur.com/DcKI0DI http://imgur.com/AuTTUUc http://imgur.com/gwM8H77 http://imgur.com/AUIVo0p http://imgur.com/dQFCXrk http://imgur.com/VAUo7Wm 38.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 39.Garmin Nuvi 660FM, harti Romania si Europa 2017. pret 150 lei + posta. ventuza parbriz, incarcator original, receptor trafic. https://imgur.com/xuZaNHp https://imgur.com/mDwXgcH https://imgur.com/X8Rbv2k https://imgur.com/Iw2hZtG 40.diverse placi tv LCD. nu stiu starea lor. pret 15 lei / placa + posta. placa2a https://imgur.com/J4wgg8j placa2b https://imgur.com/K3jQ9v0 placa3a https://imgur.com/m0VlX9q placa3b https://imgur.com/4S7IHan 41.radiator aluminiu (26X18X3,5 cm) pret 15 lei + posta. https://imgur.com/wmmIEiX https://imgur.com/hMUrpfZ 42.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. https://imgur.com/cdZMq7b ; https://imgur.com/t12Xdh8 dif5. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 43.mp3 player + radio mpman (TS350 FM 8Gb) cu thouchscreen. pret 140 lei + posta. https://imgur.com/PeZpd37 https://imgur.com/VszMeIx https://imgur.com/UtjzzgN https://imgur.com/d3hRli4 https://imgur.com/1YBDymt 44.gps garmin nuvi 300 + suport parbriz. pret 100 lei + posta. https://imgur.com/I7l6XWz https://imgur.com/xB74YkQ https://imgur.com/O7Qah11 https://imgur.com/cF5L0tL https://imgur.com/QiKtV37 45.piese diverse : 1.tranzistor 2N3055H pret 2,50 lei/buc. https://imgur.com/6AghLqC 2.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 3.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 4.tranzistor AD152V pret 1,5 lei/buc. https://imgur.com/bD9RPv0 5.tranzistor BC107 pret 0,25 lei/buc. https://imgur.com/0Zof0aU 6.tranzistor BC171 pret 0,25 lei/buc. https://imgur.com/cBGVNQl 7.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 8.distantiere siliconice cu adeziv pret 10 lei. https://imgur.com/gIJq97B Componente IT : 1.placa video pc defecta. pret 5 lei + posta. http://imgur.com/no2NWZq 2.cooler+ventilator pt. procesor pret.20 lei + posta. [imgur](http://i.imgur.com/ix8gA.jpg) 3.tastatura usb (Germania;litere specifice) pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 4.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 5.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 6.antena wifi. pret 15 lei + posta. http://imgur.com/YqnlEYN 7.cd-rom (conector IDE) perfect functional. pret 10 lei + posta. http://imgur.com/RmkzO4d 8.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 20 lei + posta. http://imgur.com/uO080t3 9.memorie server Elpida ( 2GB 2Rx4 PC2-3200R-333 10-J0) pret 20 lei/buc. + posta. https://imgur.com/gnBSYT5 10.procesor amd sempron 64 LE-1150 socket AM2. pret 20 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 11.memorii DDR1 512 Mb diferite modele. pret 10 lei buc. + posta. geil pc3200 - 2 buc. kingmax pc3200 - 2 buc. pc 2700u - 1 buc. https://imgur.com/UmypYT5 https://imgur.com/Nbf12Bs https://imgur.com/2TQCohF 12. memorie ddr3 8Gb la 1600Mhz in perfecta stare de functionare. pret 190 lei + posta. https://imgur.com/SlSqytY https://imgur.com/AnVvWKp https://imgur.com/ivySFUW 13.router D-Link DIR-635. pret 40 lei + posta. https://imgur.com/xgFrcHy https://imgur.com/TmXtXHR https://imgur.com/AsOsFiy 14. alimentator laptop cu 2 tensiuni de iesire : 16V - 5,2 A c.c. ; 19V - 4,74 A c.c. pret 50 lei + posta. https://imgur.com/qyRxdjk https://imgur.com/jiUvQz5 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Iunie 14, 2018 Autor Partajează Postat Iunie 14, 2018 1.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 2.aparate de masura defecte (pentru piese;afisaj;etc). pret 15 lei ambele + posta. https://imgur.com/SzZeg5U 3.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta. [imgur](http://i.imgur.com/mtlTIuY.jpg) 4.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 5.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 6.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 7.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 8.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta. [imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg) 9.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 10.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta. [imgur](http://i.imgur.com/Q6Mv7iU.jpg) 11.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 12.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 13.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 14.grup de panglici diferite marimi. pret 15 lei / grup + posta. [imgur](http://i.imgur.com/PYL0AKj.jpg) 15.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 16.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 17.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 18.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 25 lei + posta. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 19.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 20.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 21.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 22.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 23.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 24.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 25.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 26.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 27.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 28.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 29.motor cu 4 trepte de turatie la 230v c.a. (storcator fructe). pret 15 lei + posta. http://imgur.com/1tisXht http://imgur.com/cBfOwam 30.digital delay sovietic dezmembrat. pret 10 lei + posta. http://imgur.com/qu4syhC http://imgur.com/9csQlg1 http://imgur.com/LcSTZ9M 31.condensatori la 500v c.c. 6 buc. la 10 lei + posta. http://imgur.com/i1vvKvR 32.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 33.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 34.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 35.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 36.revista depanatorul (nr.5/1992;nr.6/1993;nr.7/1994). pret 10 lei + posta. http://imgur.com/DHwvNSc 37.mp5 player (DO QUICK model:RK-5300) in perfecta stare de functionare. pret 60 lei + posta. -memorie interna 4 Gb -radio fm -reportofon -rec. dupa fm -display 4,5 inch -slot card microsd -mufa casti stereo 3,5mm -mufa miniusb http://imgur.com/GvwayfW http://imgur.com/DcKI0DI http://imgur.com/AuTTUUc http://imgur.com/gwM8H77 http://imgur.com/AUIVo0p http://imgur.com/dQFCXrk http://imgur.com/VAUo7Wm 38.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 39.Garmin Nuvi 660FM, harti Romania si Europa 2017. pret 150 lei + posta. ventuza parbriz, incarcator original, receptor trafic. https://imgur.com/xuZaNHp https://imgur.com/mDwXgcH https://imgur.com/X8Rbv2k https://imgur.com/Iw2hZtG 40.diverse placi tv LCD. nu stiu starea lor. pret 15 lei / placa + posta. placa2a https://imgur.com/J4wgg8j placa2b https://imgur.com/K3jQ9v0 placa3a https://imgur.com/m0VlX9q placa3b https://imgur.com/4S7IHan 41.radiator aluminiu (26X18X3,5 cm) pret 15 lei + posta. https://imgur.com/wmmIEiX https://imgur.com/hMUrpfZ 42.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. https://imgur.com/cdZMq7b ; https://imgur.com/t12Xdh8 dif5. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 43.mp3 player + radio mpman (TS350 FM 8Gb) cu thouchscreen. pret 140 lei + posta. https://imgur.com/PeZpd37 https://imgur.com/VszMeIx https://imgur.com/UtjzzgN https://imgur.com/d3hRli4 https://imgur.com/1YBDymt 44.gps garmin nuvi 300 + suport parbriz. pret 100 lei + posta. https://imgur.com/I7l6XWz https://imgur.com/xB74YkQ https://imgur.com/O7Qah11 https://imgur.com/cF5L0tL https://imgur.com/QiKtV37 45.piese diverse : 1.tranzistor 2N3055H pret 2,50 lei/buc. https://imgur.com/6AghLqC 2.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 3.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 4.tranzistor AD152V pret 1,5 lei/buc. https://imgur.com/bD9RPv0 5.tranzistor BC107 pret 0,25 lei/buc. https://imgur.com/0Zof0aU 6.tranzistor BC171 pret 0,25 lei/buc. https://imgur.com/cBGVNQl 7.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 8.distantiere siliconice cu adeziv pret 10 lei. https://imgur.com/gIJq97B Componente IT : 1.placa video pc defecta. pret 5 lei + posta. http://imgur.com/no2NWZq 2.cooler+ventilator pt. procesor pret.20 lei + posta. [imgur](http://i.imgur.com/ix8gA.jpg) 3.tastatura usb (Germania;litere specifice) pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 4.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 5.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 6.antena wifi. pret 15 lei + posta. http://imgur.com/YqnlEYN 7.cd-rom (conector IDE) perfect functional. pret 10 lei + posta. http://imgur.com/RmkzO4d 8.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 20 lei + posta. http://imgur.com/uO080t3 9.memorie server Elpida ( 2GB 2Rx4 PC2-3200R-333 10-J0) pret 20 lei/buc. + posta. https://imgur.com/gnBSYT5 10.procesor amd sempron 64 LE-1150 socket AM2. pret 20 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 11.memorii DDR1 512 Mb diferite modele. pret 10 lei buc. + posta. geil pc3200 - 2 buc. kingmax pc3200 - 2 buc. pc 2700u - 1 buc. https://imgur.com/UmypYT5 https://imgur.com/Nbf12Bs https://imgur.com/2TQCohF 12. memorie ddr3 8Gb la 1600Mhz in perfecta stare de functionare. pret 190 lei + posta. https://imgur.com/SlSqytY https://imgur.com/AnVvWKp https://imgur.com/ivySFUW 13.router D-Link DIR-635. pret 40 lei + posta. https://imgur.com/xgFrcHy https://imgur.com/TmXtXHR https://imgur.com/AsOsFiy 14. alimentator laptop cu 2 tensiuni de iesire : 16V - 5,2 A c.c. ; 19V - 4,74 A c.c. pret 50 lei + posta. https://imgur.com/qyRxdjk https://imgur.com/jiUvQz5 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Iunie 15, 2018 Autor Partajează Postat Iunie 15, 2018 1.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 2.aparate de masura defecte (pentru piese;afisaj;etc). pret 15 lei ambele + posta. https://imgur.com/SzZeg5U 3.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta. [imgur](http://i.imgur.com/mtlTIuY.jpg) 4.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 5.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 6.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 7.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 8.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta. [imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg) 9.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 10.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta. [imgur](http://i.imgur.com/Q6Mv7iU.jpg) 11.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 12.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 13.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 14.grup de panglici diferite marimi. pret 15 lei / grup + posta. [imgur](http://i.imgur.com/PYL0AKj.jpg) 15.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 16.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 17.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 18.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 25 lei + posta. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 19.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 20.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 21.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 22.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 23.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 24.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 25.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 26.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 27.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 28.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 29.motor cu 4 trepte de turatie la 230v c.a. (storcator fructe). pret 15 lei + posta. http://imgur.com/1tisXht http://imgur.com/cBfOwam 30.digital delay sovietic dezmembrat. pret 10 lei + posta. http://imgur.com/qu4syhC http://imgur.com/9csQlg1 http://imgur.com/LcSTZ9M 31.condensatori la 500v c.c. 6 buc. la 10 lei + posta. http://imgur.com/i1vvKvR 32.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 33.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 34.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 35.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 36.revista depanatorul (nr.5/1992;nr.6/1993;nr.7/1994). pret 10 lei + posta. http://imgur.com/DHwvNSc 37.mp5 player (DO QUICK model:RK-5300) in perfecta stare de functionare. pret 60 lei + posta. -memorie interna 4 Gb -radio fm -reportofon -rec. dupa fm -display 4,5 inch -slot card microsd -mufa casti stereo 3,5mm -mufa miniusb http://imgur.com/GvwayfW http://imgur.com/DcKI0DI http://imgur.com/AuTTUUc http://imgur.com/gwM8H77 http://imgur.com/AUIVo0p http://imgur.com/dQFCXrk http://imgur.com/VAUo7Wm 38.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 39.Garmin Nuvi 660FM, harti Romania si Europa 2017. pret 150 lei + posta. ventuza parbriz, incarcator original, receptor trafic. https://imgur.com/xuZaNHp https://imgur.com/mDwXgcH https://imgur.com/X8Rbv2k https://imgur.com/Iw2hZtG 40.diverse placi tv LCD. nu stiu starea lor. pret 15 lei / placa + posta. placa2a https://imgur.com/J4wgg8j placa2b https://imgur.com/K3jQ9v0 placa3a https://imgur.com/m0VlX9q placa3b https://imgur.com/4S7IHan 41.radiator aluminiu (26X18X3,5 cm) pret 15 lei + posta. https://imgur.com/wmmIEiX https://imgur.com/hMUrpfZ 42.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. https://imgur.com/cdZMq7b ; https://imgur.com/t12Xdh8 dif5. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 43.mp3 player + radio mpman (TS350 FM 8Gb) cu thouchscreen. pret 140 lei + posta. https://imgur.com/PeZpd37 https://imgur.com/VszMeIx https://imgur.com/UtjzzgN https://imgur.com/d3hRli4 https://imgur.com/1YBDymt 44.gps garmin nuvi 300 + suport parbriz. pret 100 lei + posta. https://imgur.com/I7l6XWz https://imgur.com/xB74YkQ https://imgur.com/O7Qah11 https://imgur.com/cF5L0tL https://imgur.com/QiKtV37 45.piese diverse : 1.tranzistor 2N3055H pret 2,50 lei/buc. https://imgur.com/6AghLqC 2.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 3.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 4.tranzistor AD152V pret 1,5 lei/buc. https://imgur.com/bD9RPv0 5.tranzistor BC107 pret 0,25 lei/buc. https://imgur.com/0Zof0aU 6.tranzistor BC171 pret 0,25 lei/buc. https://imgur.com/cBGVNQl 7.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 8.distantiere siliconice cu adeziv pret 10 lei. https://imgur.com/gIJq97B Componente IT : 1.placa video pc defecta. pret 5 lei + posta. http://imgur.com/no2NWZq 2.cooler+ventilator pt. procesor pret.20 lei + posta. [imgur](http://i.imgur.com/ix8gA.jpg) 3.tastatura usb (Germania;litere specifice) pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 4.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 5.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 6.antena wifi. pret 15 lei + posta. http://imgur.com/YqnlEYN 7.cd-rom (conector IDE) perfect functional. pret 10 lei + posta. http://imgur.com/RmkzO4d 8.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 20 lei + posta. http://imgur.com/uO080t3 9.memorie server Elpida ( 2GB 2Rx4 PC2-3200R-333 10-J0) pret 20 lei/buc. + posta. https://imgur.com/gnBSYT5 10.procesor amd sempron 64 LE-1150 socket AM2. pret 20 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 11.memorii DDR1 512 Mb diferite modele. pret 10 lei buc. + posta. geil pc3200 - 2 buc. kingmax pc3200 - 2 buc. pc 2700u - 1 buc. https://imgur.com/UmypYT5 https://imgur.com/Nbf12Bs https://imgur.com/2TQCohF 12.router D-Link DIR-635. pret 40 lei + posta. https://imgur.com/xgFrcHy https://imgur.com/TmXtXHR https://imgur.com/AsOsFiy 13. alimentator laptop cu 2 tensiuni de iesire : 16V - 5,2 A c.c. ; 19V - 4,74 A c.c. pret 50 lei + posta. https://imgur.com/qyRxdjk https://imgur.com/jiUvQz5 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Iunie 17, 2018 Autor Partajează Postat Iunie 17, 2018 1.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 2.aparate de masura defecte (pentru piese;afisaj;etc). pret 15 lei ambele + posta. https://imgur.com/SzZeg5U 3.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta. [imgur](http://i.imgur.com/mtlTIuY.jpg) 4.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 5.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 6.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 7.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 8.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta. [imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg) 9.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 10.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta. [imgur](http://i.imgur.com/Q6Mv7iU.jpg) 11.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 12.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 13.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 14.grup de panglici diferite marimi. pret 15 lei / grup + posta. [imgur](http://i.imgur.com/PYL0AKj.jpg) 15.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 16.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 17.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 18.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 25 lei + posta. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 19.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 20.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 21.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 22.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 23.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 24.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 25.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 26.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 27.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 28.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 29.motor cu 4 trepte de turatie la 230v c.a. (storcator fructe). pret 15 lei + posta. http://imgur.com/1tisXht http://imgur.com/cBfOwam 30.digital delay sovietic dezmembrat. pret 10 lei + posta. http://imgur.com/qu4syhC http://imgur.com/9csQlg1 http://imgur.com/LcSTZ9M 31.condensatori la 500v c.c. 6 buc. la 10 lei + posta. http://imgur.com/i1vvKvR 32.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 33.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 34.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 35.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 36.revista depanatorul (nr.5/1992;nr.6/1993;nr.7/1994). pret 10 lei + posta. http://imgur.com/DHwvNSc 37.mp5 player (DO QUICK model:RK-5300) in perfecta stare de functionare. pret 60 lei + posta. -memorie interna 4 Gb -radio fm -reportofon -rec. dupa fm -display 4,5 inch -slot card microsd -mufa casti stereo 3,5mm -mufa miniusb http://imgur.com/GvwayfW http://imgur.com/DcKI0DI http://imgur.com/AuTTUUc http://imgur.com/gwM8H77 http://imgur.com/AUIVo0p http://imgur.com/dQFCXrk http://imgur.com/VAUo7Wm 38.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 39.Garmin Nuvi 660FM, harti Romania si Europa 2017. pret 150 lei + posta. ventuza parbriz, incarcator original, receptor trafic. https://imgur.com/xuZaNHp https://imgur.com/mDwXgcH https://imgur.com/X8Rbv2k https://imgur.com/Iw2hZtG 40.diverse placi tv LCD. nu stiu starea lor. pret 15 lei / placa + posta. placa2a https://imgur.com/J4wgg8j placa2b https://imgur.com/K3jQ9v0 placa3a https://imgur.com/m0VlX9q placa3b https://imgur.com/4S7IHan 41.radiator aluminiu (26X18X3,5 cm) pret 15 lei + posta. https://imgur.com/wmmIEiX https://imgur.com/hMUrpfZ 42.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. https://imgur.com/cdZMq7b ; https://imgur.com/t12Xdh8 dif5. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 43.mp3 player + radio mpman (TS350 FM 8Gb) cu thouchscreen. pret 140 lei + posta. https://imgur.com/PeZpd37 https://imgur.com/VszMeIx https://imgur.com/UtjzzgN https://imgur.com/d3hRli4 https://imgur.com/1YBDymt 44.gps garmin nuvi 300 + suport parbriz. pret 100 lei + posta. https://imgur.com/I7l6XWz https://imgur.com/xB74YkQ https://imgur.com/O7Qah11 https://imgur.com/cF5L0tL https://imgur.com/QiKtV37 45.piese diverse : 1.tranzistor 2N3055H pret 2,50 lei/buc. https://imgur.com/6AghLqC 2.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 3.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 4.tranzistor AD152V pret 1,5 lei/buc. https://imgur.com/bD9RPv0 5.tranzistor BC107 pret 0,25 lei/buc. https://imgur.com/0Zof0aU 6.tranzistor BC171 pret 0,25 lei/buc. https://imgur.com/cBGVNQl 7.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 8.distantiere siliconice cu adeziv pret 10 lei. https://imgur.com/gIJq97B 46.mini radio Thomson digital; FM/MW ;stereo ;se pot memora 10 posturi. pret 60 lei + posta. https://imgur.com/xT9CL6I https://imgur.com/FyX2gsP https://imgur.com/cCoefIe Componente IT : 1.placa video pc defecta. pret 5 lei + posta. http://imgur.com/no2NWZq 2.cooler+ventilator pt. procesor pret.20 lei + posta. [imgur](http://i.imgur.com/ix8gA.jpg) 3.tastatura usb (Germania;litere specifice) pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 4.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 5.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 6.antena wifi. pret 15 lei + posta. http://imgur.com/YqnlEYN 7.cd-rom (conector IDE) perfect functional. pret 10 lei + posta. http://imgur.com/RmkzO4d 8.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 20 lei + posta. http://imgur.com/uO080t3 9.memorie server Elpida ( 2GB 2Rx4 PC2-3200R-333 10-J0) pret 20 lei/buc. + posta. https://imgur.com/gnBSYT5 10.procesor amd sempron 64 LE-1150 socket AM2. pret 20 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 11.memorii DDR1 512 Mb diferite modele. pret 10 lei buc. + posta. geil pc3200 - 2 buc. kingmax pc3200 - 2 buc. pc 2700u - 1 buc. https://imgur.com/UmypYT5 https://imgur.com/Nbf12Bs https://imgur.com/2TQCohF 12.router D-Link DIR-635. pret 40 lei + posta. https://imgur.com/xgFrcHy https://imgur.com/TmXtXHR https://imgur.com/AsOsFiy 13. alimentator laptop cu 2 tensiuni de iesire : 16V - 5,2 A c.c. ; 19V - 4,74 A c.c. pret 50 lei + posta. https://imgur.com/qyRxdjk https://imgur.com/jiUvQz5 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Iunie 18, 2018 Autor Partajează Postat Iunie 18, 2018 1.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 2.aparate de masura defecte (pentru piese;afisaj;etc). pret 15 lei ambele + posta. https://imgur.com/SzZeg5U 3.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta. [imgur](http://i.imgur.com/mtlTIuY.jpg) 4.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 5.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 6.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 7.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 8.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta. [imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg) 9.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 10.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta. [imgur](http://i.imgur.com/Q6Mv7iU.jpg) 11.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 12.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 13.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 14.grup de panglici diferite marimi. pret 15 lei / grup + posta. [imgur](http://i.imgur.com/PYL0AKj.jpg) 15.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 16.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 17.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 18.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 25 lei + posta. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 19.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 20.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 21.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 22.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 23.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 24.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 25.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 26.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 27.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 28.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 29.motor cu 4 trepte de turatie la 230v c.a. (storcator fructe). pret 15 lei + posta. http://imgur.com/1tisXht http://imgur.com/cBfOwam 30.digital delay sovietic dezmembrat. pret 10 lei + posta. http://imgur.com/qu4syhC http://imgur.com/9csQlg1 http://imgur.com/LcSTZ9M 31.condensatori la 500v c.c. 6 buc. la 10 lei + posta. http://imgur.com/i1vvKvR 32.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 33.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 34.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 35.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 36.revista depanatorul (nr.5/1992;nr.6/1993;nr.7/1994). pret 10 lei + posta. http://imgur.com/DHwvNSc 37.mp5 player (DO QUICK model:RK-5300) in perfecta stare de functionare. pret 60 lei + posta. -memorie interna 4 Gb -radio fm -reportofon -rec. dupa fm -display 4,5 inch -slot card microsd -mufa casti stereo 3,5mm -mufa miniusb http://imgur.com/GvwayfW http://imgur.com/DcKI0DI http://imgur.com/AuTTUUc http://imgur.com/gwM8H77 http://imgur.com/AUIVo0p http://imgur.com/dQFCXrk http://imgur.com/VAUo7Wm 38.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 39.Garmin Nuvi 660FM, harti Romania si Europa 2017. pret 150 lei + posta. ventuza parbriz, incarcator original, receptor trafic. https://imgur.com/xuZaNHp https://imgur.com/mDwXgcH https://imgur.com/X8Rbv2k https://imgur.com/Iw2hZtG 40.diverse placi tv LCD. nu stiu starea lor. pret 15 lei / placa + posta. placa2a https://imgur.com/J4wgg8j placa2b https://imgur.com/K3jQ9v0 placa3a https://imgur.com/m0VlX9q placa3b https://imgur.com/4S7IHan 41.radiator aluminiu (26X18X3,5 cm) pret 15 lei + posta. https://imgur.com/wmmIEiX https://imgur.com/hMUrpfZ 42.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. https://imgur.com/cdZMq7b ; https://imgur.com/t12Xdh8 dif5. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 43.mp3 player + radio mpman (TS350 FM 8Gb) cu thouchscreen. pret 140 lei + posta. https://imgur.com/PeZpd37 https://imgur.com/VszMeIx https://imgur.com/UtjzzgN https://imgur.com/d3hRli4 https://imgur.com/1YBDymt 44.gps garmin nuvi 300 + suport parbriz. pret 100 lei + posta. https://imgur.com/I7l6XWz https://imgur.com/xB74YkQ https://imgur.com/O7Qah11 https://imgur.com/cF5L0tL https://imgur.com/QiKtV37 45.piese diverse : 1.tranzistor 2N3055H pret 2,50 lei/buc. https://imgur.com/6AghLqC 2.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 3.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 4.tranzistor AD152V pret 1,5 lei/buc. https://imgur.com/bD9RPv0 5.tranzistor BC107 pret 0,25 lei/buc. https://imgur.com/0Zof0aU 6.tranzistor BC171 pret 0,25 lei/buc. https://imgur.com/cBGVNQl 7.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 8.distantiere siliconice cu adeziv pret 10 lei. https://imgur.com/gIJq97B 46.mini radio Thomson digital; FM/MW ;stereo ;se pot memora 10 posturi. pret 60 lei + posta. https://imgur.com/xT9CL6I https://imgur.com/FyX2gsP https://imgur.com/cCoefIe Componente IT : 1.placa video pc defecta. pret 5 lei + posta. http://imgur.com/no2NWZq 2.cooler+ventilator pt. procesor pret.20 lei + posta. [imgur](http://i.imgur.com/ix8gA.jpg) 3.tastatura usb (Germania;litere specifice) pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 4.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 5.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 6.antena wifi. pret 15 lei + posta. http://imgur.com/YqnlEYN 7.cd-rom (conector IDE) perfect functional. pret 10 lei + posta. http://imgur.com/RmkzO4d 8.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 20 lei + posta. http://imgur.com/uO080t3 9.memorie server Elpida ( 2GB 2Rx4 PC2-3200R-333 10-J0) pret 20 lei/buc. + posta. https://imgur.com/gnBSYT5 10.procesor amd sempron 64 LE-1150 socket AM2. pret 20 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 11.memorii DDR1 512 Mb diferite modele. pret 10 lei buc. + posta. geil pc3200 - 2 buc. kingmax pc3200 - 2 buc. pc 2700u - 1 buc. https://imgur.com/UmypYT5 https://imgur.com/Nbf12Bs https://imgur.com/2TQCohF 12.router D-Link DIR-635. pret 40 lei + posta. https://imgur.com/xgFrcHy https://imgur.com/TmXtXHR https://imgur.com/AsOsFiy 13. alimentator laptop cu 2 tensiuni de iesire : 16V - 5,2 A c.c. ; 19V - 4,74 A c.c. pret 50 lei + posta. https://imgur.com/qyRxdjk https://imgur.com/jiUvQz5 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Iunie 19, 2018 Autor Partajează Postat Iunie 19, 2018 1.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 2.aparate de masura defecte (pentru piese;afisaj;etc). pret 15 lei ambele + posta. https://imgur.com/SzZeg5U 3.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta. [imgur](http://i.imgur.com/mtlTIuY.jpg) 4.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 5.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 6.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 7.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 8.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta. [imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg) 9.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 10.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta. [imgur](http://i.imgur.com/Q6Mv7iU.jpg) 11.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 12.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 13.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 14.grup de panglici diferite marimi. pret 15 lei / grup + posta. [imgur](http://i.imgur.com/PYL0AKj.jpg) 15.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 16.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 17.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 18.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 25 lei + posta. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 19.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 20.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 21.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 22.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 23.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 24.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 25.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 26.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 27.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 28.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 29.motor cu 4 trepte de turatie la 230v c.a. (storcator fructe). pret 15 lei + posta. http://imgur.com/1tisXht http://imgur.com/cBfOwam 30.digital delay sovietic dezmembrat. pret 10 lei + posta. http://imgur.com/qu4syhC http://imgur.com/9csQlg1 http://imgur.com/LcSTZ9M 31.condensatori la 500v c.c. 6 buc. la 10 lei + posta. http://imgur.com/i1vvKvR 32.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 33.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 34.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 35.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 36.revista depanatorul (nr.5/1992;nr.6/1993;nr.7/1994). pret 10 lei + posta. http://imgur.com/DHwvNSc 37.mp5 player (DO QUICK model:RK-5300) in perfecta stare de functionare. pret 60 lei + posta. -memorie interna 4 Gb -radio fm -reportofon -rec. dupa fm -display 4,5 inch -slot card microsd -mufa casti stereo 3,5mm -mufa miniusb http://imgur.com/GvwayfW http://imgur.com/DcKI0DI http://imgur.com/AuTTUUc http://imgur.com/gwM8H77 http://imgur.com/AUIVo0p http://imgur.com/dQFCXrk http://imgur.com/VAUo7Wm 38.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 39.Garmin Nuvi 660FM, harti Romania si Europa 2017. pret 150 lei + posta. ventuza parbriz, incarcator original, receptor trafic. https://imgur.com/xuZaNHp https://imgur.com/mDwXgcH https://imgur.com/X8Rbv2k https://imgur.com/Iw2hZtG 40.diverse placi tv LCD. nu stiu starea lor. pret 15 lei / placa + posta. placa2a https://imgur.com/J4wgg8j placa2b https://imgur.com/K3jQ9v0 placa3a https://imgur.com/m0VlX9q placa3b https://imgur.com/4S7IHan 41.radiator aluminiu (26X18X3,5 cm) pret 15 lei + posta. https://imgur.com/wmmIEiX https://imgur.com/hMUrpfZ 42.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. https://imgur.com/cdZMq7b ; https://imgur.com/t12Xdh8 dif5. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 43.mp3 player + radio mpman (TS350 FM 8Gb) cu thouchscreen. pret 140 lei + posta. https://imgur.com/PeZpd37 https://imgur.com/VszMeIx https://imgur.com/UtjzzgN https://imgur.com/d3hRli4 https://imgur.com/1YBDymt 44.gps garmin nuvi 300 + suport parbriz. pret 100 lei + posta. https://imgur.com/I7l6XWz https://imgur.com/xB74YkQ https://imgur.com/O7Qah11 https://imgur.com/cF5L0tL https://imgur.com/QiKtV37 45.piese diverse : 1.tranzistor 2N3055H pret 2,50 lei/buc. https://imgur.com/6AghLqC 2.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 3.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 4.tranzistor AD152V pret 1,5 lei/buc. https://imgur.com/bD9RPv0 5.tranzistor BC107 pret 0,25 lei/buc. https://imgur.com/0Zof0aU 6.tranzistor BC171 pret 0,25 lei/buc. https://imgur.com/cBGVNQl 7.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 8.distantiere siliconice cu adeziv pret 10 lei. https://imgur.com/gIJq97B 46.mini radio Thomson digital; FM/MW ;stereo ;se pot memora 10 posturi. pret 60 lei + posta. https://imgur.com/xT9CL6I https://imgur.com/FyX2gsP https://imgur.com/cCoefIe Componente IT : 1.placa video pc defecta. pret 5 lei + posta. http://imgur.com/no2NWZq 2.cooler+ventilator pt. procesor pret.20 lei + posta. [imgur](http://i.imgur.com/ix8gA.jpg) 3.tastatura usb (Germania;litere specifice) pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 4.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 5.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 6.antena wifi. pret 15 lei + posta. http://imgur.com/YqnlEYN 7.cd-rom (conector IDE) perfect functional. pret 10 lei + posta. http://imgur.com/RmkzO4d 8.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 20 lei + posta. http://imgur.com/uO080t3 9.memorie server Elpida ( 2GB 2Rx4 PC2-3200R-333 10-J0) pret 20 lei/buc. + posta. https://imgur.com/gnBSYT5 10.procesor amd sempron 64 LE-1150 socket AM2. pret 20 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 11.memorii DDR1 512 Mb diferite modele. pret 10 lei buc. + posta. geil pc3200 - 2 buc. kingmax pc3200 - 2 buc. pc 2700u - 1 buc. https://imgur.com/UmypYT5 https://imgur.com/Nbf12Bs https://imgur.com/2TQCohF 12.router D-Link DIR-635. pret 40 lei + posta. https://imgur.com/xgFrcHy https://imgur.com/TmXtXHR https://imgur.com/AsOsFiy 13. alimentator laptop cu 2 tensiuni de iesire : 16V - 5,2 A c.c. ; 19V - 4,74 A c.c. pret 50 lei + posta. https://imgur.com/qyRxdjk https://imgur.com/jiUvQz5 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Iunie 20, 2018 Autor Partajează Postat Iunie 20, 2018 1.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 2.aparate de masura defecte (pentru piese;afisaj;etc). pret 15 lei ambele + posta. https://imgur.com/SzZeg5U 3.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta. [imgur](http://i.imgur.com/mtlTIuY.jpg) 4.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 5.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 6.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 7.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 8.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta. [imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg) 9.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 10.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta. [imgur](http://i.imgur.com/Q6Mv7iU.jpg) 11.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 12.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 13.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 14.grup de panglici diferite marimi. pret 15 lei / grup + posta. [imgur](http://i.imgur.com/PYL0AKj.jpg) 15.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 16.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 17.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 18.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 25 lei + posta. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 19.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 20.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 21.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 22.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 23.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 24.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 25.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 26.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 27.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 28.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 29.motor cu 4 trepte de turatie la 230v c.a. (storcator fructe). pret 15 lei + posta. http://imgur.com/1tisXht http://imgur.com/cBfOwam 30.digital delay sovietic dezmembrat. pret 10 lei + posta. http://imgur.com/qu4syhC http://imgur.com/9csQlg1 http://imgur.com/LcSTZ9M 31.condensatori la 500v c.c. 6 buc. la 10 lei + posta. http://imgur.com/i1vvKvR 32.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 33.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 34.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 35.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 36.revista depanatorul (nr.5/1992;nr.6/1993;nr.7/1994). pret 10 lei + posta. http://imgur.com/DHwvNSc 37.mp5 player (DO QUICK model:RK-5300) in perfecta stare de functionare. pret 60 lei + posta. -memorie interna 4 Gb -radio fm -reportofon -rec. dupa fm -display 4,5 inch -slot card microsd -mufa casti stereo 3,5mm -mufa miniusb http://imgur.com/GvwayfW http://imgur.com/DcKI0DI http://imgur.com/AuTTUUc http://imgur.com/gwM8H77 http://imgur.com/AUIVo0p http://imgur.com/dQFCXrk http://imgur.com/VAUo7Wm 38.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 39.Garmin Nuvi 660FM, harti Romania si Europa 2017. pret 150 lei + posta. ventuza parbriz, incarcator original, receptor trafic. https://imgur.com/xuZaNHp https://imgur.com/mDwXgcH https://imgur.com/X8Rbv2k https://imgur.com/Iw2hZtG 40.diverse placi tv LCD. nu stiu starea lor. pret 15 lei / placa + posta. placa2a https://imgur.com/J4wgg8j placa2b https://imgur.com/K3jQ9v0 placa3a https://imgur.com/m0VlX9q placa3b https://imgur.com/4S7IHan 41.radiator aluminiu (26X18X3,5 cm) pret 15 lei + posta. https://imgur.com/wmmIEiX https://imgur.com/hMUrpfZ 42.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. https://imgur.com/cdZMq7b ; https://imgur.com/t12Xdh8 dif5. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 43.mp3 player + radio mpman (TS350 FM 8Gb) cu thouchscreen. pret 110 lei + posta. https://imgur.com/PeZpd37 https://imgur.com/VszMeIx https://imgur.com/UtjzzgN https://imgur.com/d3hRli4 https://imgur.com/1YBDymt 44.gps garmin nuvi 300 + suport parbriz. pret 100 lei + posta. https://imgur.com/I7l6XWz https://imgur.com/xB74YkQ https://imgur.com/O7Qah11 https://imgur.com/cF5L0tL https://imgur.com/QiKtV37 45.piese diverse : 1.tranzistor 2N3055H pret 2,50 lei/buc. https://imgur.com/6AghLqC 2.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 3.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 4.tranzistor AD152V pret 1,5 lei/buc. https://imgur.com/bD9RPv0 5.tranzistor BC107 pret 0,25 lei/buc. https://imgur.com/0Zof0aU 6.tranzistor BC171 pret 0,25 lei/buc. https://imgur.com/cBGVNQl 7.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 8.distantiere siliconice cu adeziv pret 10 lei. https://imgur.com/gIJq97B 46.mini radio Thomson digital; FM/MW ;stereo ;se pot memora 10 posturi. pret 60 lei + posta. https://imgur.com/xT9CL6I https://imgur.com/FyX2gsP https://imgur.com/cCoefIe Componente IT : 1.placa video pc defecta. pret 5 lei + posta. http://imgur.com/no2NWZq 2.cooler+ventilator pt. procesor pret.20 lei + posta. [imgur](http://i.imgur.com/ix8gA.jpg) 3.tastatura usb (Germania;litere specifice) pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 4.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 5.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 6.antena wifi. pret 15 lei + posta. http://imgur.com/YqnlEYN 7.cd-rom (conector IDE) perfect functional. pret 10 lei + posta. http://imgur.com/RmkzO4d 8.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 20 lei + posta. http://imgur.com/uO080t3 9.memorie server Elpida ( 2GB 2Rx4 PC2-3200R-333 10-J0) pret 20 lei/buc. + posta. https://imgur.com/gnBSYT5 10.procesor amd sempron 64 LE-1150 socket AM2. pret 20 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 11.memorii DDR1 512 Mb diferite modele. pret 10 lei buc. + posta. geil pc3200 - 2 buc. kingmax pc3200 - 2 buc. pc 2700u - 1 buc. https://imgur.com/UmypYT5 https://imgur.com/Nbf12Bs https://imgur.com/2TQCohF 12.router D-Link DIR-635. pret 40 lei + posta. https://imgur.com/xgFrcHy https://imgur.com/TmXtXHR https://imgur.com/AsOsFiy 13. alimentator laptop cu 2 tensiuni de iesire : 16V - 5,2 A c.c. ; 19V - 4,74 A c.c. pret 50 lei + posta. https://imgur.com/qyRxdjk https://imgur.com/jiUvQz5 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Iunie 22, 2018 Autor Partajează Postat Iunie 22, 2018 1.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 2.aparate de masura defecte (pentru piese;afisaj;etc). pret 15 lei ambele + posta. https://imgur.com/SzZeg5U 3.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta. [imgur](http://i.imgur.com/mtlTIuY.jpg) 4.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 5.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 6.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 7.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 8.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta. [imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg) 9.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 10.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta. [imgur](http://i.imgur.com/Q6Mv7iU.jpg) 11.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 12.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 13.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 14.grup de panglici diferite marimi. pret 15 lei / grup + posta. [imgur](http://i.imgur.com/PYL0AKj.jpg) 15.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 16.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 17.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 18.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 25 lei + posta. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 19.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 20.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 21.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 22.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 23.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 24.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 25.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 26.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 27.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 28.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 29.motor cu 4 trepte de turatie la 230v c.a. (storcator fructe). pret 15 lei + posta. http://imgur.com/1tisXht http://imgur.com/cBfOwam 30.digital delay sovietic dezmembrat. pret 10 lei + posta. http://imgur.com/qu4syhC http://imgur.com/9csQlg1 http://imgur.com/LcSTZ9M 31.condensatori la 500v c.c. 6 buc. la 10 lei + posta. http://imgur.com/i1vvKvR 32.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 33.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 34.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 35.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 36.revista depanatorul (nr.5/1992;nr.6/1993;nr.7/1994). pret 10 lei + posta. http://imgur.com/DHwvNSc 37.mp5 player (DO QUICK model:RK-5300) in perfecta stare de functionare. pret 60 lei + posta. -memorie interna 4 Gb -radio fm -reportofon -rec. dupa fm -display 4,5 inch -slot card microsd -mufa casti stereo 3,5mm -mufa miniusb http://imgur.com/GvwayfW http://imgur.com/DcKI0DI http://imgur.com/AuTTUUc http://imgur.com/gwM8H77 http://imgur.com/AUIVo0p http://imgur.com/dQFCXrk http://imgur.com/VAUo7Wm 38.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 39.Garmin Nuvi 660FM, harti Romania si Europa 2017. pret 150 lei + posta. ventuza parbriz, incarcator original, receptor trafic. https://imgur.com/xuZaNHp https://imgur.com/mDwXgcH https://imgur.com/X8Rbv2k https://imgur.com/Iw2hZtG 40.diverse placi tv LCD. nu stiu starea lor. pret 15 lei / placa + posta. placa2a https://imgur.com/J4wgg8j placa2b https://imgur.com/K3jQ9v0 placa3a https://imgur.com/m0VlX9q placa3b https://imgur.com/4S7IHan 41.radiator aluminiu (26X18X3,5 cm) pret 15 lei + posta. https://imgur.com/wmmIEiX https://imgur.com/hMUrpfZ 42.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. https://imgur.com/cdZMq7b ; https://imgur.com/t12Xdh8 dif5. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 43.mp3 player + radio mpman (TS350 FM 8Gb) cu thouchscreen. pret 110 lei + posta. https://imgur.com/PeZpd37 https://imgur.com/VszMeIx https://imgur.com/UtjzzgN https://imgur.com/d3hRli4 https://imgur.com/1YBDymt 44.gps garmin nuvi 300 + suport parbriz. pret 100 lei + posta. https://imgur.com/I7l6XWz https://imgur.com/xB74YkQ https://imgur.com/O7Qah11 https://imgur.com/cF5L0tL https://imgur.com/QiKtV37 45.piese diverse : 1.tranzistor 2N3055H pret 2,50 lei/buc. https://imgur.com/6AghLqC 2.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 3.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 4.tranzistor AD152V pret 1,5 lei/buc. https://imgur.com/bD9RPv0 5.tranzistor BC107 pret 0,25 lei/buc. https://imgur.com/0Zof0aU 6.tranzistor BC171 pret 0,25 lei/buc. https://imgur.com/cBGVNQl 7.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 8.distantiere siliconice cu adeziv pret 10 lei. https://imgur.com/gIJq97B 46.mini radio Thomson digital; FM/MW ;stereo ;se pot memora 10 posturi. pret 60 lei + posta. https://imgur.com/xT9CL6I https://imgur.com/FyX2gsP https://imgur.com/cCoefIe Componente IT : 1.placa video pc defecta. pret 5 lei + posta. http://imgur.com/no2NWZq 2.cooler+ventilator pt. procesor pret.20 lei + posta. [imgur](http://i.imgur.com/ix8gA.jpg) 3.tastatura usb (Germania;litere specifice) pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 4.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 5.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 6.antena wifi. pret 15 lei + posta. http://imgur.com/YqnlEYN 7.cd-rom (conector IDE) perfect functional. pret 10 lei + posta. http://imgur.com/RmkzO4d 8.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 20 lei + posta. http://imgur.com/uO080t3 9.memorie server Elpida ( 2GB 2Rx4 PC2-3200R-333 10-J0) pret 20 lei/buc. + posta. https://imgur.com/gnBSYT5 10.procesor amd sempron 64 LE-1150 socket AM2. pret 20 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 11.memorii DDR1 512 Mb diferite modele. pret 10 lei buc. + posta. geil pc3200 - 2 buc. kingmax pc3200 - 2 buc. pc 2700u - 1 buc. https://imgur.com/UmypYT5 https://imgur.com/Nbf12Bs https://imgur.com/2TQCohF 12.router D-Link DIR-635. pret 40 lei + posta. https://imgur.com/xgFrcHy https://imgur.com/TmXtXHR https://imgur.com/AsOsFiy 13. alimentator laptop cu 2 tensiuni de iesire : 16V - 5,2 A c.c. ; 19V - 4,74 A c.c. pret 50 lei + posta. https://imgur.com/qyRxdjk https://imgur.com/jiUvQz5 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Iunie 23, 2018 Autor Partajează Postat Iunie 23, 2018 1.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 2.aparate de masura defecte (pentru piese;afisaj;etc). pret 15 lei ambele + posta. https://imgur.com/SzZeg5U 3.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta. [imgur](http://i.imgur.com/mtlTIuY.jpg) 4.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 5.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 6.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 7.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 8.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta. [imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg) 9.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 10.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta. [imgur](http://i.imgur.com/Q6Mv7iU.jpg) 11.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 12.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 13.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 14.grup de panglici diferite marimi. pret 15 lei / grup + posta. [imgur](http://i.imgur.com/PYL0AKj.jpg) 15.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 16.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 17.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 18.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 25 lei + posta. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 19.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 20.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 21.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 22.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 23.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 24.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 25.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 26.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 27.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 28.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 29.motor cu 4 trepte de turatie la 230v c.a. (storcator fructe). pret 15 lei + posta. http://imgur.com/1tisXht http://imgur.com/cBfOwam 30.digital delay sovietic dezmembrat. pret 10 lei + posta. http://imgur.com/qu4syhC http://imgur.com/9csQlg1 http://imgur.com/LcSTZ9M 31.condensatori la 500v c.c. 6 buc. la 10 lei + posta. http://imgur.com/i1vvKvR 32.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 33.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 34.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 35.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 36.revista depanatorul (nr.5/1992;nr.6/1993;nr.7/1994). pret 10 lei + posta. http://imgur.com/DHwvNSc 37.mp5 player (DO QUICK model:RK-5300) in perfecta stare de functionare. pret 60 lei + posta. -memorie interna 4 Gb -radio fm -reportofon -rec. dupa fm -display 4,5 inch -slot card microsd -mufa casti stereo 3,5mm -mufa miniusb http://imgur.com/GvwayfW http://imgur.com/DcKI0DI http://imgur.com/AuTTUUc http://imgur.com/gwM8H77 http://imgur.com/AUIVo0p http://imgur.com/dQFCXrk http://imgur.com/VAUo7Wm 38.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 39.Garmin Nuvi 660FM, harti Romania si Europa 2017. pret 150 lei + posta. ventuza parbriz, incarcator original, receptor trafic. https://imgur.com/xuZaNHp https://imgur.com/mDwXgcH https://imgur.com/X8Rbv2k https://imgur.com/Iw2hZtG 40.diverse placi tv LCD. nu stiu starea lor. pret 15 lei / placa + posta. placa2a https://imgur.com/J4wgg8j placa2b https://imgur.com/K3jQ9v0 placa3a https://imgur.com/m0VlX9q placa3b https://imgur.com/4S7IHan 41.radiator aluminiu (26X18X3,5 cm) pret 15 lei + posta. https://imgur.com/wmmIEiX https://imgur.com/hMUrpfZ 42.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. https://imgur.com/cdZMq7b ; https://imgur.com/t12Xdh8 dif5. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 43.mp3 player + radio mpman (TS350 FM 8Gb) cu thouchscreen. pret 110 lei + posta. https://imgur.com/PeZpd37 https://imgur.com/VszMeIx https://imgur.com/UtjzzgN https://imgur.com/d3hRli4 https://imgur.com/1YBDymt 44.gps garmin nuvi 300 + suport parbriz. pret 100 lei + posta. https://imgur.com/I7l6XWz https://imgur.com/xB74YkQ https://imgur.com/O7Qah11 https://imgur.com/cF5L0tL https://imgur.com/QiKtV37 45.piese diverse : 1.tranzistor 2N3055H pret 2,50 lei/buc. https://imgur.com/6AghLqC 2.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 3.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 4.tranzistor AD152V pret 1,5 lei/buc. https://imgur.com/bD9RPv0 5.tranzistor BC107 pret 0,25 lei/buc. https://imgur.com/0Zof0aU 6.tranzistor BC171 pret 0,25 lei/buc. https://imgur.com/cBGVNQl 7.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 8.distantiere siliconice cu adeziv pret 10 lei. https://imgur.com/gIJq97B 46.mini radio Thomson digital; FM/MW ;stereo ;se pot memora 10 posturi. pret 60 lei + posta. https://imgur.com/xT9CL6I https://imgur.com/FyX2gsP https://imgur.com/cCoefIe Componente IT : 1.placa video pc defecta. pret 5 lei + posta. http://imgur.com/no2NWZq 2.cooler+ventilator pt. procesor pret.20 lei + posta. [imgur](http://i.imgur.com/ix8gA.jpg) 3.tastatura usb (Germania;litere specifice) pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 4.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 5.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 6.antena wifi. pret 15 lei + posta. http://imgur.com/YqnlEYN 7.cd-rom (conector IDE) perfect functional. pret 10 lei + posta. http://imgur.com/RmkzO4d 8.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 20 lei + posta. http://imgur.com/uO080t3 9.memorie server Elpida ( 2GB 2Rx4 PC2-3200R-333 10-J0) pret 20 lei/buc. + posta. https://imgur.com/gnBSYT5 10.procesor amd sempron 64 LE-1150 socket AM2. pret 20 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 11.memorii DDR1 512 Mb diferite modele. pret 10 lei buc. + posta. geil pc3200 - 2 buc. kingmax pc3200 - 2 buc. pc 2700u - 1 buc. https://imgur.com/UmypYT5 https://imgur.com/Nbf12Bs https://imgur.com/2TQCohF 12.router D-Link DIR-635. pret 40 lei + posta. https://imgur.com/xgFrcHy https://imgur.com/TmXtXHR https://imgur.com/AsOsFiy 13. alimentator laptop cu 2 tensiuni de iesire : 16V - 5,2 A c.c. ; 19V - 4,74 A c.c. pret 50 lei + posta. https://imgur.com/qyRxdjk https://imgur.com/jiUvQz5 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
