rellu Postat August 30, 2016 Autor Partajează Postat August 30, 2016 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 3.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 4.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg) 5.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)6.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)7.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)8.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)9.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)10.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)11.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)12.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 13.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg) 14.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)15.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 16.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 17.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 18.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 19.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 20.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 21.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 22.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)23.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)24.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 25.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 26.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 27.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 28.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 29.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 30.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 31.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 50 lei negociabil. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 32.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 33.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 34.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 35.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 36.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 37.carcasa metalica, dimensiuni : 29cm / 27cm / 11,5cm. pret 40 lei + posta. http://i.imgur.com/ATlDM9K.jpg http://i.imgur.com/R0xyyqy.jpg http://i.imgur.com/X8Yx4qE.jpg http://i.imgur.com/LpEK1hz.jpg 38.baterie externa (power bank 5000 mah). pret 50 lei + posta. http://i.imgur.com/CbOYzpS.jpg http://i.imgur.com/Wz3nr5O.jpg http://i.imgur.com/f3p4cAZ.jpg 39.sursa in comutatie 220 v / 12v - 4,8A . pret 25 lei + posta. http://i.imgur.com/9u4EsQS.jpg 40.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 41.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 42.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 43.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 44.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 45.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 46.placi frontale pentru PC ,una cu tot felul de mufe iar cealalta cu cititori carduri (nu stiu starea lor). pret 14 lei + posta. http://i.imgur.com/forzZdq.jpg http://i.imgur.com/Lni7xjv.jpg http://i.imgur.com/yX4XczR.jpg http://i.imgur.com/2f0Fm1W.jpg 47.video AC adaptor Panasonic VW-AM5 ; pret 25 lei + posta. http://i.imgur.com/FxeCTii.jpg http://i.imgur.com/adCWveu.jpg http://i.imgur.com/IObENup.jpg Link spre comentariu
rellu Postat Septembrie 2, 2016 Autor Partajează Postat Septembrie 2, 2016 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 3.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 4.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg) 5.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)6.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)7.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)8.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)9.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)10.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)11.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)12.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 13.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg) 14.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)15.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 16.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 17.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 18.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 19.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 20.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 21.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 22.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)23.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)24.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 25.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 26.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 27.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 28.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 29.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 30.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 31.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 50 lei negociabil. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 32.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 33.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 34.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 35.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 36.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 37.carcasa metalica, dimensiuni : 29cm / 27cm / 11,5cm. pret 40 lei + posta. http://i.imgur.com/ATlDM9K.jpg http://i.imgur.com/R0xyyqy.jpg http://i.imgur.com/X8Yx4qE.jpg http://i.imgur.com/LpEK1hz.jpg 38.baterie externa (power bank 5000 mah). pret 50 lei + posta. http://i.imgur.com/CbOYzpS.jpg http://i.imgur.com/Wz3nr5O.jpg http://i.imgur.com/f3p4cAZ.jpg 39.sursa in comutatie 220 v / 12v - 4,8A . pret 25 lei + posta. http://i.imgur.com/9u4EsQS.jpg 40.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 41.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 42.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 43.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 44.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 45.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 46.placi frontale pentru PC ,una cu tot felul de mufe iar cealalta cu cititori carduri (nu stiu starea lor). pret 14 lei + posta. http://i.imgur.com/forzZdq.jpg http://i.imgur.com/Lni7xjv.jpg http://i.imgur.com/yX4XczR.jpg http://i.imgur.com/2f0Fm1W.jpg 47.video AC adaptor Panasonic VW-AM5 ; pret 25 lei + posta. http://i.imgur.com/FxeCTii.jpg http://i.imgur.com/adCWveu.jpg http://i.imgur.com/IObENup.jpg 48.radiator cu aripioare (20/9/8 cm) pret 40 lei + posta. bonus placa si integratele audio (Pioneer model:VSX-D512-S). http://imgur.com/a/qwm28 http://imgur.com/e5I9tjB http://imgur.com/yHkbd60 http://imgur.com/N64e8XO Link spre comentariu
rellu Postat Septembrie 3, 2016 Autor Partajează Postat Septembrie 3, 2016 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 3.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 4.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg) 5.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)6.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)7.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)8.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)9.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)10.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)11.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)12.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 13.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg) 14.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)15.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 16.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 17.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 18.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 19.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 20.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 21.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 22.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)23.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)24.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 25.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 26.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 27.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 28.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 29.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 30.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 31.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 50 lei negociabil. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 32.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 33.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 34.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 35.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 36.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 37.carcasa metalica, dimensiuni : 29cm / 27cm / 11,5cm. pret 40 lei + posta. http://i.imgur.com/ATlDM9K.jpg http://i.imgur.com/R0xyyqy.jpg http://i.imgur.com/X8Yx4qE.jpg http://i.imgur.com/LpEK1hz.jpg 38.baterie externa (power bank 5000 mah). pret 50 lei + posta. http://i.imgur.com/CbOYzpS.jpg http://i.imgur.com/Wz3nr5O.jpg http://i.imgur.com/f3p4cAZ.jpg 39.sursa in comutatie 220 v / 12v - 4,8A . pret 25 lei + posta. http://i.imgur.com/9u4EsQS.jpg 40.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 41.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 42.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 43.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 44.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 45.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 46.placi frontale pentru PC ,una cu tot felul de mufe iar cealalta cu cititori carduri (nu stiu starea lor). pret 14 lei + posta. http://i.imgur.com/forzZdq.jpg http://i.imgur.com/Lni7xjv.jpg http://i.imgur.com/yX4XczR.jpg http://i.imgur.com/2f0Fm1W.jpg 47.video AC adaptor Panasonic VW-AM5 ; pret 25 lei + posta. http://i.imgur.com/FxeCTii.jpg http://i.imgur.com/adCWveu.jpg http://i.imgur.com/IObENup.jpg 48.radiator cu aripioare (20/9/8 cm) pret 40 lei + posta. bonus placa si integratele audio (Pioneer model:VSX-D512-S). http://imgur.com/a/qwm28 http://imgur.com/e5I9tjB http://imgur.com/yHkbd60 http://imgur.com/N64e8XO Link spre comentariu
rellu Postat Septembrie 5, 2016 Autor Partajează Postat Septembrie 5, 2016 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 3.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 4.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg) 5.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)6.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)7.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)8.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)9.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)10.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)11.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)12.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 13.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg) 14.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)15.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 16.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 17.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 18.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 19.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 20.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 21.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 22.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)23.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)24.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 25.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 26.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 27.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 28.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 29.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 30.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 31.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 50 lei negociabil. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 32.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 33.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 34.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 35.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 36.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 37.carcasa metalica, dimensiuni : 29cm / 27cm / 11,5cm. pret 40 lei + posta. http://i.imgur.com/ATlDM9K.jpg http://i.imgur.com/R0xyyqy.jpg http://i.imgur.com/X8Yx4qE.jpg http://i.imgur.com/LpEK1hz.jpg 38.baterie externa (power bank 5000 mah). pret 50 lei + posta. http://i.imgur.com/CbOYzpS.jpg http://i.imgur.com/Wz3nr5O.jpg http://i.imgur.com/f3p4cAZ.jpg 39.sursa in comutatie 220 v / 12v - 4,8A . pret 25 lei + posta. http://i.imgur.com/9u4EsQS.jpg 40.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 41.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 42.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 43.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 44.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 45.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 46.placi frontale pentru PC ,una cu tot felul de mufe iar cealalta cu cititori carduri (nu stiu starea lor). pret 14 lei + posta. http://i.imgur.com/forzZdq.jpg http://i.imgur.com/Lni7xjv.jpg http://i.imgur.com/yX4XczR.jpg http://i.imgur.com/2f0Fm1W.jpg 47.video AC adaptor Panasonic VW-AM5 ; pret 25 lei + posta. http://i.imgur.com/FxeCTii.jpg http://i.imgur.com/adCWveu.jpg http://i.imgur.com/IObENup.jpg 48.radiator cu aripioare (20/9/8 cm) pret 40 lei + posta. bonus placa si integratele audio (Pioneer model:VSX-D512-S). http://imgur.com/a/qwm28 http://imgur.com/e5I9tjB http://imgur.com/yHkbd60 http://imgur.com/N64e8XO Link spre comentariu
rellu Postat Septembrie 7, 2016 Autor Partajează Postat Septembrie 7, 2016 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 3.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 4.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg) 5.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)6.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)7.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)8.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)9.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)10.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)11.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)12.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 13.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg) 14.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)15.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 16.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 17.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 18.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 19.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 20.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 21.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 22.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)23.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)24.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 25.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 26.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 27.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 28.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 29.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 30.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 31.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 50 lei negociabil. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 32.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 33.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 34.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 35.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 36.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 37.carcasa metalica, dimensiuni : 29cm / 27cm / 11,5cm. pret 40 lei + posta. http://i.imgur.com/ATlDM9K.jpg http://i.imgur.com/R0xyyqy.jpg http://i.imgur.com/X8Yx4qE.jpg http://i.imgur.com/LpEK1hz.jpg 38.baterie externa (power bank 5000 mah). pret 50 lei + posta. http://i.imgur.com/CbOYzpS.jpg http://i.imgur.com/Wz3nr5O.jpg http://i.imgur.com/f3p4cAZ.jpg 39.sursa in comutatie 220 v / 12v - 4,8A . pret 25 lei + posta. http://i.imgur.com/9u4EsQS.jpg 40.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 41.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 42.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 43.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 44.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 45.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 46.placi frontale pentru PC ,una cu tot felul de mufe iar cealalta cu cititori carduri (nu stiu starea lor). pret 14 lei + posta. http://i.imgur.com/forzZdq.jpg http://i.imgur.com/Lni7xjv.jpg http://i.imgur.com/yX4XczR.jpg http://i.imgur.com/2f0Fm1W.jpg 47.video AC adaptor Panasonic VW-AM5 ; pret 25 lei + posta. http://i.imgur.com/FxeCTii.jpg http://i.imgur.com/adCWveu.jpg http://i.imgur.com/IObENup.jpg 48.radiator cu aripioare (20/9/8 cm) pret 40 lei + posta. bonus placa si integratele audio (Pioneer model:VSX-D512-S). http://imgur.com/a/qwm28 http://imgur.com/e5I9tjB http://imgur.com/yHkbd60 http://imgur.com/N64e8XO Link spre comentariu
rellu Postat Septembrie 8, 2016 Autor Partajează Postat Septembrie 8, 2016 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 3.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 4.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg) 5.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)6.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)7.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)8.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)9.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)10.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)11.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)12.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 13.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg) 14.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)15.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 16.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 17.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 18.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 19.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 20.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 21.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 22.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)23.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)24.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 25.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 26.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 27.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 28.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 29.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 30.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 31.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 50 lei negociabil. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 32.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 33.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 34.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 35.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 36.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 37.carcasa metalica, dimensiuni : 29cm / 27cm / 11,5cm. pret 40 lei + posta. http://i.imgur.com/ATlDM9K.jpg http://i.imgur.com/R0xyyqy.jpg http://i.imgur.com/X8Yx4qE.jpg http://i.imgur.com/LpEK1hz.jpg 38.baterie externa (power bank 5000 mah). pret 50 lei + posta. http://i.imgur.com/CbOYzpS.jpg http://i.imgur.com/Wz3nr5O.jpg http://i.imgur.com/f3p4cAZ.jpg 39.sursa in comutatie 220 v / 12v - 4,8A . pret 25 lei + posta. http://i.imgur.com/9u4EsQS.jpg 40.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 41.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 42.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 43.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 44.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 45.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 46.placi frontale pentru PC ,una cu tot felul de mufe iar cealalta cu cititori carduri (nu stiu starea lor). pret 14 lei + posta. http://i.imgur.com/forzZdq.jpg http://i.imgur.com/Lni7xjv.jpg http://i.imgur.com/yX4XczR.jpg http://i.imgur.com/2f0Fm1W.jpg 47.video AC adaptor Panasonic VW-AM5 ; pret 25 lei + posta. http://i.imgur.com/FxeCTii.jpg http://i.imgur.com/adCWveu.jpg http://i.imgur.com/IObENup.jpg 48.radiator cu aripioare (20/9/8 cm) pret 40 lei + posta. bonus placa si integratele audio (Pioneer model:VSX-D512-S). http://imgur.com/a/qwm28 http://imgur.com/e5I9tjB http://imgur.com/yHkbd60 http://imgur.com/N64e8XO Link spre comentariu
rellu Postat Septembrie 9, 2016 Autor Partajează Postat Septembrie 9, 2016 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 3.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 4.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg) 5.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)6.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)7.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)8.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)9.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)10.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)11.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)12.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 13.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg) 14.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)15.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 16.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 17.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 18.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 19.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 20.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 21.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 22.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)23.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)24.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 25.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 26.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 27.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 28.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 29.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 30.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 31.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 50 lei negociabil. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 32.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 33.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 34.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 35.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 36.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 37.carcasa metalica, dimensiuni : 29cm / 27cm / 11,5cm. pret 40 lei + posta. http://i.imgur.com/ATlDM9K.jpg http://i.imgur.com/R0xyyqy.jpg http://i.imgur.com/X8Yx4qE.jpg http://i.imgur.com/LpEK1hz.jpg 38.baterie externa (power bank 5000 mah). pret 50 lei + posta. http://i.imgur.com/CbOYzpS.jpg http://i.imgur.com/Wz3nr5O.jpg http://i.imgur.com/f3p4cAZ.jpg 39.sursa in comutatie 220 v / 12v - 4,8A . pret 25 lei + posta. http://i.imgur.com/9u4EsQS.jpg 40.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 41.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 42.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 43.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 44.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 45.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 46.placi frontale pentru PC ,una cu tot felul de mufe iar cealalta cu cititori carduri (nu stiu starea lor). pret 14 lei + posta. http://i.imgur.com/forzZdq.jpg http://i.imgur.com/Lni7xjv.jpg http://i.imgur.com/yX4XczR.jpg http://i.imgur.com/2f0Fm1W.jpg 47.video AC adaptor Panasonic VW-AM5 ; pret 25 lei + posta. http://i.imgur.com/FxeCTii.jpg http://i.imgur.com/adCWveu.jpg http://i.imgur.com/IObENup.jpg 48.radiator cu aripioare (20/9/8 cm) pret 40 lei + posta. bonus placa si integratele audio (Pioneer model:VSX-D512-S). http://imgur.com/a/qwm28 http://imgur.com/e5I9tjB http://imgur.com/yHkbd60 http://imgur.com/N64e8XO Link spre comentariu
rellu Postat Septembrie 11, 2016 Autor Partajează Postat Septembrie 11, 2016 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 3.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 4.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg) 5.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)6.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)7.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)8.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)9.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)10.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)11.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)12.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 13.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg) 14.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)15.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 16.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 17.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 18.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 19.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 20.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 21.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 22.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)23.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)24.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 25.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 26.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 27.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 28.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 29.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 30.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 31.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 50 lei negociabil. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 32.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 33.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 34.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 35.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 36.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 37.carcasa metalica, dimensiuni : 29cm / 27cm / 11,5cm. pret 40 lei + posta. http://i.imgur.com/ATlDM9K.jpg http://i.imgur.com/R0xyyqy.jpg http://i.imgur.com/X8Yx4qE.jpg http://i.imgur.com/LpEK1hz.jpg 38.baterie externa (power bank 5000 mah). pret 50 lei + posta. http://i.imgur.com/CbOYzpS.jpg http://i.imgur.com/Wz3nr5O.jpg http://i.imgur.com/f3p4cAZ.jpg 39.sursa in comutatie 220 v / 12v - 4,8A . pret 25 lei + posta. http://i.imgur.com/9u4EsQS.jpg 40.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 41.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 42.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 43.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 44.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 45.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 46.placi frontale pentru PC ,una cu tot felul de mufe iar cealalta cu cititori carduri (nu stiu starea lor). pret 14 lei + posta. http://i.imgur.com/forzZdq.jpg http://i.imgur.com/Lni7xjv.jpg http://i.imgur.com/yX4XczR.jpg http://i.imgur.com/2f0Fm1W.jpg 47.video AC adaptor Panasonic VW-AM5 ; pret 25 lei + posta. http://i.imgur.com/FxeCTii.jpg http://i.imgur.com/adCWveu.jpg http://i.imgur.com/IObENup.jpg 48.radiator cu aripioare (20/9/8 cm) pret 40 lei + posta. bonus placa si integratele audio (Pioneer model:VSX-D512-S). http://imgur.com/a/qwm28 http://imgur.com/e5I9tjB http://imgur.com/yHkbd60 http://imgur.com/N64e8XO Link spre comentariu
rellu Postat Septembrie 12, 2016 Autor Partajează Postat Septembrie 12, 2016 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 3.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 4.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg) 5.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)6.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)7.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)8.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)9.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)10.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)11.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)12.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 13.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg) 14.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)15.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 16.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 17.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 18.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 19.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 20.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 21.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 22.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)23.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)24.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 25.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 26.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 27.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 28.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 29.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 30.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 31.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 50 lei negociabil. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 32.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 33.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 34.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 35.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 36.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 37.carcasa metalica, dimensiuni : 29cm / 27cm / 11,5cm. pret 40 lei + posta. http://i.imgur.com/ATlDM9K.jpg http://i.imgur.com/R0xyyqy.jpg http://i.imgur.com/X8Yx4qE.jpg http://i.imgur.com/LpEK1hz.jpg 38.baterie externa (power bank 5000 mah). pret 50 lei + posta. http://i.imgur.com/CbOYzpS.jpg http://i.imgur.com/Wz3nr5O.jpg http://i.imgur.com/f3p4cAZ.jpg 39.sursa in comutatie 220 v / 12v - 4,8A . pret 25 lei + posta. http://i.imgur.com/9u4EsQS.jpg 40.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 41.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 42.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 43.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 44.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 45.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 46.placi frontale pentru PC ,una cu tot felul de mufe iar cealalta cu cititori carduri (nu stiu starea lor). pret 14 lei + posta. http://i.imgur.com/forzZdq.jpg http://i.imgur.com/Lni7xjv.jpg http://i.imgur.com/yX4XczR.jpg http://i.imgur.com/2f0Fm1W.jpg 47.video AC adaptor Panasonic VW-AM5 ; pret 25 lei + posta. http://i.imgur.com/FxeCTii.jpg http://i.imgur.com/adCWveu.jpg http://i.imgur.com/IObENup.jpg 48.radiator cu aripioare (20/9/8 cm) pret 40 lei + posta. bonus placa si integratele audio (Pioneer model:VSX-D512-S). http://imgur.com/a/qwm28 http://imgur.com/e5I9tjB http://imgur.com/yHkbd60 http://imgur.com/N64e8XO Link spre comentariu
rellu Postat Septembrie 14, 2016 Autor Partajează Postat Septembrie 14, 2016 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 3.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 4.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg) 5.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)6.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)7.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)8.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)9.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)10.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)11.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)12.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 13.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg) 14.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)15.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 16.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 17.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 18.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 19.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 20.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 21.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 22.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)23.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)24.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 25.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 26.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 27.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 28.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 29.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 30.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 31.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 50 lei negociabil. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 32.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 33.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 34.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 35.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 36.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 37.carcasa metalica, dimensiuni : 29cm / 27cm / 11,5cm. pret 40 lei + posta. http://i.imgur.com/ATlDM9K.jpg http://i.imgur.com/R0xyyqy.jpg http://i.imgur.com/X8Yx4qE.jpg http://i.imgur.com/LpEK1hz.jpg 38.baterie externa (power bank 5000 mah). pret 50 lei + posta. http://i.imgur.com/CbOYzpS.jpg http://i.imgur.com/Wz3nr5O.jpg http://i.imgur.com/f3p4cAZ.jpg 39.sursa in comutatie 220 v / 12v - 4,8A . pret 25 lei + posta. http://i.imgur.com/9u4EsQS.jpg 40.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 41.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 42.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 43.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 44.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 45.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 46.placi frontale pentru PC ,una cu tot felul de mufe iar cealalta cu cititori carduri (nu stiu starea lor). pret 14 lei + posta. http://i.imgur.com/forzZdq.jpg http://i.imgur.com/Lni7xjv.jpg http://i.imgur.com/yX4XczR.jpg http://i.imgur.com/2f0Fm1W.jpg 47.video AC adaptor Panasonic VW-AM5 ; pret 25 lei + posta. http://i.imgur.com/FxeCTii.jpg http://i.imgur.com/adCWveu.jpg http://i.imgur.com/IObENup.jpg 48.radiator cu aripioare (20/9/8 cm) pret 40 lei + posta. bonus placa si integratele audio (Pioneer model:VSX-D512-S). http://imgur.com/a/qwm28 http://imgur.com/e5I9tjB http://imgur.com/yHkbd60 http://imgur.com/N64e8XO Link spre comentariu
rellu Postat Septembrie 16, 2016 Autor Partajează Postat Septembrie 16, 2016 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 3.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 4.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg) 5.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)6.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)7.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)8.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)9.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)10.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)11.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)12.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 13.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg) 14.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)15.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 16.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 17.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 18.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 19.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 20.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 21.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 22.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)23.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)24.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 25.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 26.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 27.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 28.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 29.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 30.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 31.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 50 lei negociabil. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 32.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 33.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 34.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 35.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 36.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 37.carcasa metalica, dimensiuni : 29cm / 27cm / 11,5cm. pret 40 lei + posta. http://i.imgur.com/ATlDM9K.jpg http://i.imgur.com/R0xyyqy.jpg http://i.imgur.com/X8Yx4qE.jpg http://i.imgur.com/LpEK1hz.jpg 38.baterie externa (power bank 5000 mah). pret 50 lei + posta. http://i.imgur.com/CbOYzpS.jpg http://i.imgur.com/Wz3nr5O.jpg http://i.imgur.com/f3p4cAZ.jpg 39.sursa in comutatie 220 v / 12v - 4,8A . pret 25 lei + posta. http://i.imgur.com/9u4EsQS.jpg 40.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 41.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 42.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 43.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 44.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 45.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 46.placi frontale pentru PC ,una cu tot felul de mufe iar cealalta cu cititori carduri (nu stiu starea lor). pret 14 lei + posta. http://i.imgur.com/forzZdq.jpg http://i.imgur.com/Lni7xjv.jpg http://i.imgur.com/yX4XczR.jpg http://i.imgur.com/2f0Fm1W.jpg 47.video AC adaptor Panasonic VW-AM5 ; pret 25 lei + posta. http://i.imgur.com/FxeCTii.jpg http://i.imgur.com/adCWveu.jpg http://i.imgur.com/IObENup.jpg 48.radiator cu aripioare (20/9/8 cm) pret 40 lei + posta. bonus placa si integratele audio (Pioneer model:VSX-D512-S). http://imgur.com/a/qwm28 http://imgur.com/e5I9tjB http://imgur.com/yHkbd60 http://imgur.com/N64e8XO Link spre comentariu
rellu Postat Septembrie 17, 2016 Autor Partajează Postat Septembrie 17, 2016 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 3.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 4.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg) 5.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)6.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)7.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)8.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)9.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)10.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)11.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)12.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 13.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg) 14.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)15.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 16.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 17.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 18.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 19.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 20.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 21.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 22.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)23.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)24.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 25.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 26.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 27.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 28.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 29.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 30.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 31.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 50 lei negociabil. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 32.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 33.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 34.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 35.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 36.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 37.carcasa metalica, dimensiuni : 29cm / 27cm / 11,5cm. pret 40 lei + posta. http://i.imgur.com/ATlDM9K.jpg http://i.imgur.com/R0xyyqy.jpg http://i.imgur.com/X8Yx4qE.jpg http://i.imgur.com/LpEK1hz.jpg 38.baterie externa (power bank 5000 mah). pret 50 lei + posta. http://i.imgur.com/CbOYzpS.jpg http://i.imgur.com/Wz3nr5O.jpg http://i.imgur.com/f3p4cAZ.jpg 39.sursa in comutatie 220 v / 12v - 4,8A . pret 25 lei + posta. http://i.imgur.com/9u4EsQS.jpg 40.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 41.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 42.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 43.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 44.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 45.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 46.placi frontale pentru PC ,una cu tot felul de mufe iar cealalta cu cititori carduri (nu stiu starea lor). pret 14 lei + posta. http://i.imgur.com/forzZdq.jpg http://i.imgur.com/Lni7xjv.jpg http://i.imgur.com/yX4XczR.jpg http://i.imgur.com/2f0Fm1W.jpg 47.video AC adaptor Panasonic VW-AM5 ; pret 25 lei + posta. http://i.imgur.com/FxeCTii.jpg http://i.imgur.com/adCWveu.jpg http://i.imgur.com/IObENup.jpg 48.radiator cu aripioare (20/9/8 cm) pret 40 lei + posta. bonus placa si integratele audio (Pioneer model:VSX-D512-S). http://imgur.com/a/qwm28 http://imgur.com/e5I9tjB http://imgur.com/yHkbd60 http://imgur.com/N64e8XO Link spre comentariu
rellu Postat Septembrie 19, 2016 Autor Partajează Postat Septembrie 19, 2016 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 3.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 4.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg) 5.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)6.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)7.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)8.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)9.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)10.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)11.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)12.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 13.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg) 14.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)15.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 16.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 17.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 18.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 19.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 20.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 21.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 22.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)23.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)24.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 25.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 26.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 27.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 28.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 29.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 30.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 31.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 50 lei negociabil. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 32.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 33.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 34.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 35.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 36.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 37.carcasa metalica, dimensiuni : 29cm / 27cm / 11,5cm. pret 40 lei + posta. http://i.imgur.com/ATlDM9K.jpg http://i.imgur.com/R0xyyqy.jpg http://i.imgur.com/X8Yx4qE.jpg http://i.imgur.com/LpEK1hz.jpg 38.baterie externa (power bank 5000 mah). pret 50 lei + posta. http://i.imgur.com/CbOYzpS.jpg http://i.imgur.com/Wz3nr5O.jpg http://i.imgur.com/f3p4cAZ.jpg 39.sursa in comutatie 220 v / 12v - 4,8A . pret 25 lei + posta. http://i.imgur.com/9u4EsQS.jpg 40.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 41.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 42.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 43.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 44.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 45.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 46.placi frontale pentru PC ,una cu tot felul de mufe iar cealalta cu cititori carduri (nu stiu starea lor). pret 14 lei + posta. http://i.imgur.com/forzZdq.jpg http://i.imgur.com/Lni7xjv.jpg http://i.imgur.com/yX4XczR.jpg http://i.imgur.com/2f0Fm1W.jpg 47.video AC adaptor Panasonic VW-AM5 ; pret 25 lei + posta. http://i.imgur.com/FxeCTii.jpg http://i.imgur.com/adCWveu.jpg http://i.imgur.com/IObENup.jpg 48.radiator cu aripioare (20/9/8 cm) pret 40 lei + posta. bonus placa si integratele audio (Pioneer model:VSX-D512-S). http://imgur.com/a/qwm28 http://imgur.com/e5I9tjB http://imgur.com/yHkbd60 http://imgur.com/N64e8XO Link spre comentariu
rellu Postat Septembrie 20, 2016 Autor Partajează Postat Septembrie 20, 2016 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 3.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 4.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg) 5.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)6.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)7.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)8.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)9.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)10.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)11.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)12.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 13.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg) 14.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)15.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 16.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 17.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 18.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 19.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 20.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 21.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 22.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)23.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)24.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 25.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 26.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 27.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 28.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 29.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 30.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 31.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 50 lei negociabil. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 32.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 33.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 34.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 35.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 36.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 37.carcasa metalica, dimensiuni : 29cm / 27cm / 11,5cm. pret 40 lei + posta. http://i.imgur.com/ATlDM9K.jpg http://i.imgur.com/R0xyyqy.jpg http://i.imgur.com/X8Yx4qE.jpg http://i.imgur.com/LpEK1hz.jpg 38.baterie externa (power bank 5000 mah). pret 50 lei + posta. http://i.imgur.com/CbOYzpS.jpg http://i.imgur.com/Wz3nr5O.jpg http://i.imgur.com/f3p4cAZ.jpg 39.sursa in comutatie 220 v / 12v - 4,8A . pret 25 lei + posta. http://i.imgur.com/9u4EsQS.jpg 40.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 41.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 42.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 43.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 44.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 45.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 46.placi frontale pentru PC ,una cu tot felul de mufe iar cealalta cu cititori carduri (nu stiu starea lor). pret 14 lei + posta. http://i.imgur.com/forzZdq.jpg http://i.imgur.com/Lni7xjv.jpg http://i.imgur.com/yX4XczR.jpg http://i.imgur.com/2f0Fm1W.jpg 47.video AC adaptor Panasonic VW-AM5 ; pret 25 lei + posta. http://i.imgur.com/FxeCTii.jpg http://i.imgur.com/adCWveu.jpg http://i.imgur.com/IObENup.jpg 48.radiator cu aripioare (20/9/8 cm) pret 40 lei + posta. bonus placa si integratele audio (Pioneer model:VSX-D512-S). http://imgur.com/a/qwm28 http://imgur.com/e5I9tjB http://imgur.com/yHkbd60 http://imgur.com/N64e8XO Link spre comentariu
rellu Postat Septembrie 21, 2016 Autor Partajează Postat Septembrie 21, 2016 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 3.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 4.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg) 5.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)6.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)7.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)8.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)9.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)10.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)11.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)12.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 13.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg) 14.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)15.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 16.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 17.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 18.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 19.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 20.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 21.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 22.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)23.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)24.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 25.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 26.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 27.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 28.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 29.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 30.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 31.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 50 lei negociabil. http://i.imgur.com/Frqu9QZ.jpg http://i.imgur.com/UUNdS7N.jpg 32.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 33.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 34.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta. http://i.imgur.com/2Agl8dv.jpg http://i.imgur.com/Z9zL8Ju.jpg 35.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru. http://i.imgur.com/JOcMIpy.jpg http://i.imgur.com/t250v7G.jpg bonus : http://i.imgur.com/oYTi11h.jpg 36.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 37.carcasa metalica, dimensiuni : 29cm / 27cm / 11,5cm. pret 40 lei + posta. http://i.imgur.com/ATlDM9K.jpg http://i.imgur.com/R0xyyqy.jpg http://i.imgur.com/X8Yx4qE.jpg http://i.imgur.com/LpEK1hz.jpg 38.baterie externa (power bank 5000 mah). pret 50 lei + posta. http://i.imgur.com/CbOYzpS.jpg http://i.imgur.com/Wz3nr5O.jpg http://i.imgur.com/f3p4cAZ.jpg 39.sursa in comutatie 220 v / 12v - 4,8A . pret 25 lei + posta. http://i.imgur.com/9u4EsQS.jpg 40.acumulator (SP3676B1A 7000mA/h)tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 41.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 42.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 43.trafo. cu prindere pe cablaj 230v / 2x7.5v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/7TbOl4t.jpg 44.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 45.trafo. 230v / 2x9 v. pret 10 lei + posta. http://i.imgur.com/qJne31S.jpg http://i.imgur.com/FmxKqN4.jpg 46.placi frontale pentru PC ,una cu tot felul de mufe iar cealalta cu cititori carduri (nu stiu starea lor). pret 14 lei + posta. http://i.imgur.com/forzZdq.jpg http://i.imgur.com/Lni7xjv.jpg http://i.imgur.com/yX4XczR.jpg http://i.imgur.com/2f0Fm1W.jpg 47.video AC adaptor Panasonic VW-AM5 ; pret 25 lei + posta. http://i.imgur.com/FxeCTii.jpg http://i.imgur.com/adCWveu.jpg http://i.imgur.com/IObENup.jpg 48.radiator cu aripioare (20/9/8 cm) pret 40 lei + posta. bonus placa si integratele audio (Pioneer model:VSX-D512-S). http://imgur.com/a/qwm28 http://imgur.com/e5I9tjB http://imgur.com/yHkbd60 http://imgur.com/N64e8XO Link spre comentariu
