vand diverse electrice si electronice
rellu
1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta.
http://i.imgur.com/Qn0Pfbw.jpg
http://i.imgur.com/4Q0JKEH.jpg
2.modem huawei E173u-2 (decodat). pret 25 lei + posta.
http://i.imgur.com/FIdNyLF.jpg
http://i.imgur.com/BCUeZAs.jpg
3.modem usb zte K3765-Z (decodat). pret 25 lei + posta.
http://i.imgur.com/6BMIdln.jpg
http://i.imgur.com/Q5yiHL2.jpg
4.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta.
http://i.imgur.com/TSUmkcf.jpg
http://i.imgur.com/YEsuGSe.jpg
http://i.imgur.com/ZhVVF4J.jpg
5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta.
http://i.imgur.com/xLYj1pw.jpg
http://i.imgur.com/WyGhzFR.jpg
http://i.imgur.com/tNXaBXc.jpg
6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg)
7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)
9.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)10.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)11.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)12.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)13.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)14.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)15.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)16.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg)
17.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)18. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg)
19.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg)
[imgur](http://i.imgur.com/IUAAbvG.jpg)20.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg)
21.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg)
22.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta.
[imgur](http://i.imgur.com/1BsMxy3.jpg)
23.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg)
24.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg)
25.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta.
[imgur](http://i.imgur.com/oNCeaLC.jpg)
26.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta.
[imgur](http://i.imgur.com/lXepBUN.jpg)
27.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)28.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)29.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg)
30.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg)
31.modul ecou cu integratul PT2399. pret 18 lei + posta.
[imgur](http://i.imgur.com/y8qXFci.jpg)
[imgur](http://i.imgur.com/Jdfmvsi.jpg)
32.motor c.c. 24V-0,4A-4200rpm   pret 6 lei + posta.
[imgur](http://i.imgur.com/bq5bYS6.jpg)
33.afisaj lcd ,pret 10 lei + posta.
[imgur](http://i.imgur.com/BP5rzGf.jpg)
[imgur](http://i.imgur.com/8rFWX2P.jpg)
34.tastatura  usb pret 10 lei + posta.
[imgur](http://i.imgur.com/kfdnQiF.jpg)
35.memorii eprom M27C256B-12FI  1buc. - 5 lei ; M27C2001-10F1  1 buc. - 5 lei ; M27C2001-12FI  1buc. - 5 lei  + posta.
[imgur](http://i.imgur.com/NLKPV66.jpg)
36.car kit bluetooth perfect functional.din pacate capacul din spate e lipsa. pret 50 lei negociabil.
http://i.imgur.com/Frqu9QZ.jpg
http://i.imgur.com/UUNdS7N.jpg
37.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta.
http://i.imgur.com/20DXPzr.jpg
http://i.imgur.com/VrOEOOP.jpg
38.placa electronica de la cuptor cu microunde  pret 15 lei + posta.
http://i.imgur.com/zYtD8lh.jpg
http://i.imgur.com/97FEYSw.jpg
http://i.imgur.com/4Sx4GqJ.jpg
39.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile :
bluethooth nokia hf210  pret  100 lei.
http://i.imgur.com/aTWg00I.jpg
dispozitiv pt. vizualizat diapozitive  pret  20 lei.
http://i.imgur.com/rCfaeKL.jpg
http://i.imgur.com/EnMsXVZ.jpg
telefoane fixe made in france  30 lei / buc. sunt 3 modele :
http://i.imgur.com/TC6BgsL.jpg
http://i.imgur.com/Z6TbMJ4.jpg
http://i.imgur.com/TkvELli.jpg
http://i.imgur.com/LIDV9oD.jpg
http://i.imgur.com/xfpYolo.jpg
http://i.imgur.com/LGo5J4P.jpg
40.sursa in comutatie 12V / 3,75A.  pret 25 lei + posta.
http://i.imgur.com/yGoTDwJ.jpg
41.pda medion model mdppc250 pentru piese de schimb. pret 15 lei + posta.
http://i.imgur.com/2Agl8dv.jpg
http://i.imgur.com/Z9zL8Ju.jpg
42.bec led auto 12 V (2 buc.) pret 12 lei + posta.
http://i.imgur.com/EZ08JON.jpg
43.wu-metru cu leduri. pret 40 lei + posta. cine cumpara montajul are ca bonus 10 pcb-uri pt. acest tip de wu-metru.
http://i.imgur.com/JOcMIpy.jpg
http://i.imgur.com/t250v7G.jpg
bonus :  http://i.imgur.com/oYTi11h.jpg
44.trafo 220v / 13v cu prindere pe cablaj. pret 10 lei + posta.
http://i.imgur.com/XQ8kTNC.jpg
45.relee de la dacia solenza ,ambele la pretul de 15 lei + posta.
http://i.imgur.com/GGhweL0.jpg
http://i.imgur.com/GZ8nm4i.jpg
46.carcasa metalica, dimensiuni : 29cm / 27cm / 11,5cm. pret 40 lei + posta.
http://i.imgur.com/ATlDM9K.jpg
http://i.imgur.com/R0xyyqy.jpg
http://i.imgur.com/X8Yx4qE.jpg
http://i.imgur.com/LpEK1hz.jpg
47.baterie externa (power bank 5000 mah). pret 50 lei + posta.
http://i.imgur.com/CbOYzpS.jpg
http://i.imgur.com/Wz3nr5O.jpg
http://i.imgur.com/f3p4cAZ.jpg
