rellu Postat Septembrie 21, 2015 Autor Partajează Postat Septembrie 21, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.modem huawei E173u-2 (decodat). pret 25 lei + posta. http://i.imgur.com/FIdNyLF.jpg http://i.imgur.com/BCUeZAs.jpg 2a.modem usb zte K3765-Z (decodat). pret 25 lei + posta. http://i.imgur.com/6BMIdln.jpg http://i.imgur.com/Q5yiHL2.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg 48.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg Link spre comentariu
rellu Postat Septembrie 23, 2015 Autor Partajează Postat Septembrie 23, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.modem huawei E173u-2 (decodat). pret 25 lei + posta. http://i.imgur.com/FIdNyLF.jpg http://i.imgur.com/BCUeZAs.jpg 2a.modem usb zte K3765-Z (decodat). pret 25 lei + posta. http://i.imgur.com/6BMIdln.jpg http://i.imgur.com/Q5yiHL2.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg 48.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg Link spre comentariu
rellu Postat Septembrie 24, 2015 Autor Partajează Postat Septembrie 24, 2015 Lista de mai sus valabila. Link spre comentariu
rellu Postat Septembrie 26, 2015 Autor Partajează Postat Septembrie 26, 2015 Lista de mai sus valabila. Link spre comentariu
rellu Postat Septembrie 27, 2015 Autor Partajează Postat Septembrie 27, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.modem huawei E173u-2 (decodat). pret 25 lei + posta. http://i.imgur.com/FIdNyLF.jpg http://i.imgur.com/BCUeZAs.jpg 2a.modem usb zte K3765-Z (decodat). pret 25 lei + posta. http://i.imgur.com/6BMIdln.jpg http://i.imgur.com/Q5yiHL2.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg 48.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg Link spre comentariu
rellu Postat Septembrie 28, 2015 Autor Partajează Postat Septembrie 28, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.modem huawei E173u-2 (decodat). pret 25 lei + posta. http://i.imgur.com/FIdNyLF.jpg http://i.imgur.com/BCUeZAs.jpg 2a.modem usb zte K3765-Z (decodat). pret 25 lei + posta. http://i.imgur.com/6BMIdln.jpg http://i.imgur.com/Q5yiHL2.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg 48.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 49.difuzoare PC cu alimentare la priza. pret 12 lei + posta. http://i.imgur.com/GUFvRmY.jpg Link spre comentariu
rellu Postat Septembrie 29, 2015 Autor Partajează Postat Septembrie 29, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.modem huawei E173u-2 (decodat). pret 25 lei + posta. http://i.imgur.com/FIdNyLF.jpg http://i.imgur.com/BCUeZAs.jpg 2a.modem usb zte K3765-Z (decodat). pret 25 lei + posta. http://i.imgur.com/6BMIdln.jpg http://i.imgur.com/Q5yiHL2.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg 48.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 49.difuzoare PC cu alimentare la priza. pret 12 lei + posta. http://i.imgur.com/GUFvRmY.jpg 50.adaptor wireles usb Sagem M4Y-XG760A. pret 20 lei + posta. http://i.imgur.com/i8e8zD1.jpg Link spre comentariu
rellu Postat Septembrie 30, 2015 Autor Partajează Postat Septembrie 30, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.modem huawei E173u-2 (decodat). pret 25 lei + posta. http://i.imgur.com/FIdNyLF.jpg http://i.imgur.com/BCUeZAs.jpg 2a.modem usb zte K3765-Z (decodat). pret 25 lei + posta. http://i.imgur.com/6BMIdln.jpg http://i.imgur.com/Q5yiHL2.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg 48.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 49.difuzoare PC cu alimentare la priza. pret 12 lei + posta. http://i.imgur.com/GUFvRmY.jpg 50.adaptor wireles usb Sagem M4Y-XG760A. pret 20 lei + posta. http://i.imgur.com/i8e8zD1.jpg Link spre comentariu
rellu Postat Octombrie 1, 2015 Autor Partajează Postat Octombrie 1, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.modem huawei E173u-2 (decodat). pret 25 lei + posta. http://i.imgur.com/FIdNyLF.jpg http://i.imgur.com/BCUeZAs.jpg 2a.modem usb zte K3765-Z (decodat). pret 25 lei + posta. http://i.imgur.com/6BMIdln.jpg http://i.imgur.com/Q5yiHL2.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg 48.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 49.difuzoare PC cu alimentare la priza. pret 12 lei + posta. http://i.imgur.com/GUFvRmY.jpg 50.adaptor wireles usb Sagem M4Y-XG760A. pret 20 lei + posta. http://i.imgur.com/i8e8zD1.jpg Link spre comentariu
rellu Postat Octombrie 2, 2015 Autor Partajează Postat Octombrie 2, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.modem huawei E173u-2 (decodat). pret 25 lei + posta. http://i.imgur.com/FIdNyLF.jpg http://i.imgur.com/BCUeZAs.jpg 2a.modem usb zte K3765-Z (decodat). pret 25 lei + posta. http://i.imgur.com/6BMIdln.jpg http://i.imgur.com/Q5yiHL2.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg 48.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 49.difuzoare PC cu alimentare la priza. pret 12 lei + posta. http://i.imgur.com/GUFvRmY.jpg Link spre comentariu
rellu Postat Octombrie 3, 2015 Autor Partajează Postat Octombrie 3, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.modem huawei E173u-2 (decodat). pret 25 lei + posta. http://i.imgur.com/FIdNyLF.jpg http://i.imgur.com/BCUeZAs.jpg 2a.modem usb zte K3765-Z (decodat). pret 25 lei + posta. http://i.imgur.com/6BMIdln.jpg http://i.imgur.com/Q5yiHL2.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg 48.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 49.difuzoare PC cu alimentare la priza. pret 12 lei + posta. http://i.imgur.com/GUFvRmY.jpg 50.cradle pentru PDA Acer N300 model:CR-1402106. pret 15 lei + posta. http://i.imgur.com/vOztxMD.jpg http://i.imgur.com/RxkCoXY.jpg Link spre comentariu
rellu Postat Octombrie 5, 2015 Autor Partajează Postat Octombrie 5, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.modem huawei E173u-2 (decodat). pret 25 lei + posta. http://i.imgur.com/FIdNyLF.jpg http://i.imgur.com/BCUeZAs.jpg 2a.modem usb zte K3765-Z (decodat). pret 25 lei + posta. http://i.imgur.com/6BMIdln.jpg http://i.imgur.com/Q5yiHL2.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg 48.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 49.difuzoare PC cu alimentare la priza. pret 12 lei + posta. http://i.imgur.com/GUFvRmY.jpg 50.cradle pentru PDA Acer N300 model:CR-1402106. pret 15 lei + posta. http://i.imgur.com/vOztxMD.jpg http://i.imgur.com/RxkCoXY.jpg 51.pda O2 lli se vinde ca defect (nu porneste;baterie descarcata;nu am cablu de date/incarcare). pret 15 lei + posta. http://i.imgur.com/DfzqO8t.jpg http://i.imgur.com/1d4Vm4h.jpg Link spre comentariu
romicap Postat Octombrie 5, 2015 Partajează Postat Octombrie 5, 2015 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg) Ce valori au potentiometrii ? Sunt interesat . Link spre comentariu
rellu Postat Octombrie 8, 2015 Autor Partajează Postat Octombrie 8, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.modem huawei E173u-2 (decodat). pret 25 lei + posta. http://i.imgur.com/FIdNyLF.jpg http://i.imgur.com/BCUeZAs.jpg 2a.modem usb zte K3765-Z (decodat). pret 25 lei + posta. http://i.imgur.com/6BMIdln.jpg http://i.imgur.com/Q5yiHL2.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg 48.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 49.difuzoare PC cu alimentare la priza. pret 12 lei + posta. http://i.imgur.com/GUFvRmY.jpg 50.cradle pentru PDA Acer N300 model:CR-1402106. pret 15 lei + posta. http://i.imgur.com/vOztxMD.jpg http://i.imgur.com/RxkCoXY.jpg 51.pda O2 lli se vinde ca defect (nu porneste;baterie descarcata;nu am cablu de date/incarcare). pret 15 lei + posta. http://i.imgur.com/DfzqO8t.jpg http://i.imgur.com/1d4Vm4h.jpg Link spre comentariu
rellu Postat Octombrie 10, 2015 Autor Partajează Postat Octombrie 10, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.modem huawei E173u-2 (decodat). pret 25 lei + posta. http://i.imgur.com/FIdNyLF.jpg http://i.imgur.com/BCUeZAs.jpg 2a.modem usb zte K3765-Z (decodat). pret 25 lei + posta. http://i.imgur.com/6BMIdln.jpg http://i.imgur.com/Q5yiHL2.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg 48.sursa in comutatie 12V / 3,75A. pret 25 lei + posta. http://i.imgur.com/yGoTDwJ.jpg 49.difuzoare PC cu alimentare la priza. pret 12 lei + posta. http://i.imgur.com/GUFvRmY.jpg 50.cradle pentru PDA Acer N300 model:CR-1402106. pret 15 lei + posta. http://i.imgur.com/vOztxMD.jpg http://i.imgur.com/RxkCoXY.jpg Link spre comentariu
