rellu Postat Iulie 31, 2015 Autor Partajează Postat Iulie 31, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.modem wifi 3g huawei E 586 in stare perfecta de functionare, decodat merge in orice retea.(l-am incercat in rds-rcs / telekom si functioneaza perfect) pret 100 lei + posta. http://i.imgur.com/5z8AAjS.jpg http://i.imgur.com/3iOpRLu.jpg http://i.imgur.com/UmU4FVU.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.hub 4 porturi. pret 8 lei / buc. + posta. [imgur](http://i.imgur.com/mMczDhL.jpg) [imgur](http://i.imgur.com/IwpTZhh.jpg) 40.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 41.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 42.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 43.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 44.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 45.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 46.surse in comutatie pret 10 lei / buc. + posta. http://i.imgur.com/hOyhRF5.jpg http://i.imgur.com/kZDHhhb.jpg 47.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 48.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg 49.transformator rusesc 220 v / 34,5v-1,8A;6,3v-0,3A;19v-0,88A. pret 25 lei + posta. http://i.imgur.com/4GQTMlG.jpg Link spre comentariu
rellu Postat August 3, 2015 Autor Partajează Postat August 3, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.modem wifi 3g huawei E 586 in stare perfecta de functionare, decodat merge in orice retea.(l-am incercat in rds-rcs / telekom si functioneaza perfect) pret 100 lei + posta. http://i.imgur.com/5z8AAjS.jpg http://i.imgur.com/3iOpRLu.jpg http://i.imgur.com/UmU4FVU.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.hub 4 porturi. pret 8 lei / buc. + posta. [imgur](http://i.imgur.com/mMczDhL.jpg) [imgur](http://i.imgur.com/IwpTZhh.jpg) 40.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 41.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 42.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 43.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 44.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 45.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 46.surse in comutatie pret 10 lei / buc. + posta. http://i.imgur.com/hOyhRF5.jpg http://i.imgur.com/kZDHhhb.jpg 47.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 48.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg 49.transformator rusesc 220 v / 34,5v-1,8A;6,3v-0,3A;19v-0,88A. pret 25 lei + posta. http://i.imgur.com/4GQTMlG.jpg Link spre comentariu
rellu Postat August 4, 2015 Autor Partajează Postat August 4, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.transformator rusesc 220 v / 34,5v-1,8A;6,3v-0,3A;19v-0,88A. pret 25 lei + posta. http://i.imgur.com/4GQTMlG.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.hub 4 porturi. pret 8 lei / buc. + posta. [imgur](http://i.imgur.com/mMczDhL.jpg) [imgur](http://i.imgur.com/IwpTZhh.jpg) 40.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 41.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 42.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 43.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 44.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 45.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 46.surse in comutatie pret 10 lei / buc. + posta. http://i.imgur.com/hOyhRF5.jpg http://i.imgur.com/kZDHhhb.jpg 47.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 48.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg Link spre comentariu
rellu Postat August 5, 2015 Autor Partajează Postat August 5, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.transformator rusesc 220 v / 34,5v-1,8A;6,3v-0,3A;19v-0,88A. pret 25 lei + posta. http://i.imgur.com/4GQTMlG.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg Link spre comentariu
rellu Postat August 8, 2015 Autor Partajează Postat August 8, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.transformator rusesc 220 v / 34,5v-1,8A;6,3v-0,3A;19v-0,88A. pret 25 lei + posta. http://i.imgur.com/4GQTMlG.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg Link spre comentariu
rellu Postat August 9, 2015 Autor Partajează Postat August 9, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.transformator rusesc 220 v / 34,5v-1,8A;6,3v-0,3A;19v-0,88A. pret 25 lei + posta. http://i.imgur.com/4GQTMlG.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg Link spre comentariu
rellu Postat August 10, 2015 Autor Partajează Postat August 10, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.transformator rusesc 220 v / 34,5v-1,8A;6,3v-0,3A;19v-0,88A. pret 25 lei + posta. http://i.imgur.com/4GQTMlG.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg Link spre comentariu
rellu Postat August 13, 2015 Autor Partajează Postat August 13, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.transformator rusesc 220 v / 34,5v-1,8A;6,3v-0,3A;19v-0,88A. pret 25 lei + posta. http://i.imgur.com/4GQTMlG.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg Link spre comentariu
rellu Postat August 14, 2015 Autor Partajează Postat August 14, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.transformator rusesc 220 v / 34,5v-1,8A;6,3v-0,3A;19v-0,88A. pret 25 lei + posta. http://i.imgur.com/4GQTMlG.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg Link spre comentariu
rellu Postat August 16, 2015 Autor Partajează Postat August 16, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.transformator rusesc 220 v / 34,5v-1,8A;6,3v-0,3A;19v-0,88A. pret 25 lei + posta. http://i.imgur.com/4GQTMlG.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg Link spre comentariu
rellu Postat August 18, 2015 Autor Partajează Postat August 18, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.transformator rusesc 220 v / 34,5v-1,8A;6,3v-0,3A;19v-0,88A. pret 25 lei + posta. http://i.imgur.com/4GQTMlG.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg Link spre comentariu
rellu Postat August 20, 2015 Autor Partajează Postat August 20, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.transformator rusesc 220 v / 34,5v-1,8A;6,3v-0,3A;19v-0,88A. pret 25 lei + posta. http://i.imgur.com/4GQTMlG.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg Link spre comentariu
rellu Postat August 22, 2015 Autor Partajează Postat August 22, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.transformator rusesc 220 v / 34,5v-1,8A;6,3v-0,3A;19v-0,88A. pret 25 lei + posta. http://i.imgur.com/4GQTMlG.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg Link spre comentariu
rellu Postat August 25, 2015 Autor Partajează Postat August 25, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.transformator rusesc 220 v / 34,5v-1,8A;6,3v-0,3A;19v-0,88A. pret 25 lei + posta. http://i.imgur.com/4GQTMlG.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg Link spre comentariu
rellu Postat August 27, 2015 Autor Partajează Postat August 27, 2015 1.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 2.transformator rusesc 220 v / 34,5v-1,8A;6,3v-0,3A;19v-0,88A. pret 25 lei + posta. http://i.imgur.com/4GQTMlG.jpg 3.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta. http://i.imgur.com/TSUmkcf.jpg http://i.imgur.com/YEsuGSe.jpg http://i.imgur.com/ZhVVF4J.jpg 4.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg) 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg) 27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg) 32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 35.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 36.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 37.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 38.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 39.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 40.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 41.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 42.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg 43.sursa in comutatie din dvd lg LH-T6540 functionala. pret 15 lei + posta. http://i.imgur.com/G6oolkS.jpg http://i.imgur.com/Byho862.jpg http://i.imgur.com/75ybstu.jpg http://i.imgur.com/5GH7dEt.jpg 44.aparat masura analog sunwa YX-360TRN (functioneaza cu 2 baterii : 1,5V + 9V ) pret 19 lei + posta. http://i.imgur.com/20DXPzr.jpg http://i.imgur.com/VrOEOOP.jpg 45.sursa in comutatie pret 10 lei + posta. http://i.imgur.com/kZDHhhb.jpg 46.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 47.urmatoarele produse sunt ale unui prieten,asa ca daca vreuna prezinta interes v-a dau nr. de telefon pt. a stabili detaliile : bluethooth nokia hf210 pret 100 lei. http://i.imgur.com/aTWg00I.jpg dispozitiv pt. vizualizat diapozitive pret 20 lei. http://i.imgur.com/rCfaeKL.jpg http://i.imgur.com/EnMsXVZ.jpg telefoane fixe made in france 30 lei / buc. sunt 3 modele : http://i.imgur.com/TC6BgsL.jpg http://i.imgur.com/Z6TbMJ4.jpg http://i.imgur.com/TkvELli.jpg http://i.imgur.com/LIDV9oD.jpg http://i.imgur.com/xfpYolo.jpg http://i.imgur.com/LGo5J4P.jpg Link spre comentariu
