vand diverse electrice si electronice
rellu
1.incarcator acumulatori camera video marca Panasonic model VSK0541. pret 10 lei + posta.
(din pacate nu pot sa zic prea multe despre aparat doar ca ledul de power se aprinde iar ala de charge sta stins;nu am acumulator sa pot proba)
http://i.imgur.com/DruE6yD.jpg
http://i.imgur.com/CrS5ubQ.jpg
http://i.imgur.com/L1aIeNs.jpg
2.carcasa solida pt. diverse montaje electronice :lungime 48 cm ; latime 17 cm ; inaltime 12 cm. pret 50 lei + posta.
http://i.imgur.com/TSUmkcf.jpg
http://i.imgur.com/YEsuGSe.jpg
http://i.imgur.com/ZhVVF4J.jpg
3.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg)
4.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta.
http://i.imgur.com/xLYj1pw.jpg
http://i.imgur.com/WyGhzFR.jpg
http://i.imgur.com/tNXaBXc.jpg
5.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg)
6.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)7.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)8.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)9.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)10.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)11.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)12.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)13.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)14.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)15.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)16.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg)
17.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)18. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg)
19.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)20.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg)
[imgur](http://i.imgur.com/IUAAbvG.jpg)21.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg)
22.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg)
23.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta.
[imgur](http://i.imgur.com/1BsMxy3.jpg)
24.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg)
25.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg)26.transformator prindere pe cablaj:220v - 15v /12w. pret 14 lei.[imgur](http://i.imgur.com/MQ9DwAq.jpg)27.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta.
[imgur](http://i.imgur.com/oNCeaLC.jpg)
28.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta.
[imgur](http://i.imgur.com/lXepBUN.jpg)
29.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)30.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)31.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg)32.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta.
[imgur](http://i.imgur.com/OLtHAbD.jpg)[imgur](http://i.imgur.com/WF2Coth.jpg)
[imgur](http://i.imgur.com/vuA2uOc.jpg)
[imgur](http://i.imgur.com/I9TAwJT.jpg)[imgur](http://i.imgur.com/ePdN1Fj.jpg)[imgur](http://i.imgur.com/lJlV3xk.jpg)[imgur](http://i.imgur.com/3rPbomB.jpg)[imgur](http://i.imgur.com/D08Sp2l.jpg)[imgur](http://i.imgur.com/HME16wR.jpg)[imgur](http://i.imgur.com/mKTgWfI.jpg)[imgur](http://i.imgur.com/9JV9Rmn.jpg)
33.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg)
34.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta.
[imgur](http://i.imgur.com/J1wBe6u.jpg)
[imgur](http://i.imgur.com/xhM0tWI.jpg)
[imgur](http://i.imgur.com/UtGIdnO.jpg)
35.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta.
http://i.imgur.com/ZRbPYm1.jpg
http://i.imgur.com/twjAk5h.jpg
36.modul ecou cu integratul PT2399. pret 18 lei + posta.
[imgur](http://i.imgur.com/y8qXFci.jpg)
[imgur](http://i.imgur.com/Jdfmvsi.jpg)
37.switch ethernet (fara sursa de 12 V c.c.) pret 25 lei + posta.
[imgur](http://i.imgur.com/ajnC0VI.jpg)
[imgur](http://i.imgur.com/bsTZvTL.jpg)
38.telefon fara fir KX-TG7321 pret 80 lei + posta.
[imgur](http://i.imgur.com/Kmujcs2.jpg)
[imgur](http://i.imgur.com/eFJNoVa.jpg)
[imgur](http://i.imgur.com/OoR4lLD.jpg)
39.motor c.c. 24V-0,4A-4200rpm   pret 6 lei + posta.
[imgur](http://i.imgur.com/bq5bYS6.jpg)
40.afisaj lcd ,pret 10 lei + posta.
[imgur](http://i.imgur.com/BP5rzGf.jpg)
[imgur](http://i.imgur.com/8rFWX2P.jpg)
41.tastatura  usb pret 10 lei + posta.
[imgur](http://i.imgur.com/kfdnQiF.jpg)
42.hub 4 porturi ;2 modele. pret 8 lei / buc. (partea de intrare sunt puse de mine neavand mufa mama miniusb pt. cablaj )
[imgur](http://i.imgur.com/W1zYdiQ.jpg)
[imgur](http://i.imgur.com/29lb2US.jpg)
[imgur](http://i.imgur.com/mMczDhL.jpg)
[imgur](http://i.imgur.com/IwpTZhh.jpg)
43.memorii eprom M27C256B-12FI  1buc. - 5 lei ; M27C2001-10F1  1 buc. - 5 lei ; M27C2001-12FI  1buc. - 5 lei  + posta.
[imgur](http://i.imgur.com/NLKPV66.jpg)
44.docking stations nou-nout pt. samsung tab. pret 35 lei + posta.
[imgur](http://i.imgur.com/Mt1JoGG.jpg)
[imgur](http://i.imgur.com/g4vNQxf.jpg)
[imgur](http://i.imgur.com/tNkOO37.jpg)
45.tv LG42PC3RA (plasma) dezmembrat :
cauza dezmembrarii este urmatorul modul (c.i. STK795-820 defect)
[imgur](http://i.imgur.com/usTWMhz.jpg)
cadru cu picior + panel fata + capac spate + alte maruntaie. pret 70 lei + posta.
[imgur](http://i.imgur.com/kpHifvE.jpg)
[imgur](http://i.imgur.com/0N6HRkG.jpg)
[imgur](http://i.imgur.com/jnjxuSD.jpg)
[imgur](http://i.imgur.com/iYERD2s.jpg)
[imgur](http://i.imgur.com/Ukm5BNZ.jpg)
[imgur](http://i.imgur.com/DTOYs0E.jpg)
[imgur](http://i.imgur.com/k8YAGLp.jpg)
[imgur](http://i.imgur.com/LuLLahI.jpg)
modul 1. pret 120 lei + posta.
[imgur](http://i.imgur.com/rA0riwA.jpg)
modul 2. pret 80 lei + posta.
[imgur](http://i.imgur.com/lXYPm5U.jpg)
modul 3. pret toate 3 buc. 80 lei + posta.
[imgur](http://i.imgur.com/E4H1j3D.jpg)
[imgur](http://i.imgur.com/cWoj5Pi.jpg)
modul 4. pret 120 lei + posta.
[imgur](http://i.imgur.com/W5fZzmW.jpg)
[imgur](http://i.imgur.com/K1E9xC7.jpg)
modul 5. pret 120 lei + posta.
[imgur](http://i.imgur.com/fYCLp6p.jpg)
[imgur](http://i.imgur.com/CKl4dB8.jpg)
[imgur](http://i.imgur.com/3HCT9sY.jpg)
46.sursa comutatie :+12v ; +20v ;+100v ; 6,3v  pret 10 lei + posta.
http://i.imgur.com/MoilATm.jpg
http://i.imgur.com/Y76IN3W.jpg
47.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta.
http://i.imgur.com/koKgn1r.jpg
http://i.imgur.com/hk55OzT.jpg
48.motor la 220 v . pret 15 lei + posta.
http://i.imgur.com/Nrd6Rj7.jpg
49.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta.
http://i.imgur.com/Qn0Pfbw.jpg
http://i.imgur.com/4Q0JKEH.jpg
50.modem wifi 3g huawei E 586 in stare perfecta de functionare, decodat merge in orice retea.(l-am incercat doar in rds-rcs si functioneaza perfect)
pret 100 lei + posta.
http://i.imgur.com/5z8AAjS.jpg
http://i.imgur.com/3iOpRLu.jpg
http://i.imgur.com/UmU4FVU.jpg
51.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul).
http://i.imgur.com/a4z0HQT.jpg
http://i.imgur.com/m1rPInd.jpg
http://i.imgur.com/jDWolET.jpg
http://i.imgur.com/8SzIXSK.jpg
http://i.imgur.com/XraSbM6.jpg
26.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta.
27.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta.
28.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)29.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)30.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg)31.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta.
32.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg)
33.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta.
34.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta.
35.modul ecou cu integratul PT2399. pret 18 lei + posta.
36.switch ethernet (fara sursa de 12 V c.c.) pret 25 lei + posta.
37.telefon fara fir KX-TG7321 pret 80 lei + posta.
38.motor c.c. 24V-0,4A-4200rpm   pret 6 lei + posta.
39.afisaj lcd ,pret 10 lei + posta.
40.tastatura  usb pret 10 lei + posta.
41.hub 4 porturi ;2 modele. pret 8 lei / buc. (partea de intrare sunt puse de mine neavand mufa mama miniusb pt. cablaj )
42.memorii eprom M27C256B-12FI  1buc. - 5 lei ; M27C2001-10F1  1 buc. - 5 lei ; M27C2001-12FI  1buc. - 5 lei  + posta.
43.docking stations nou-nout pt. samsung tab. pret 35 lei + posta.
44.tv LG42PC3RA (plasma) dezmembrat :
45.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta.
46.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta.
47.modem wifi 3g huawei E 586 in stare perfecta de functionare, decodat merge in orice retea.(l-am incercat doar in rds-rcs si functioneaza perfect)
48.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul).
