rellu Postat Martie 18, 2015 Autor Partajează Postat Martie 18, 2015 1.incarcator acumulatori camera video marca Panasonic model VSK0541. pret 10 lei + posta. (din pacate nu pot sa zic prea multe despre aparat doar ca ledul de power se aprinde iar ala de charge sta stins;nu am acumulator sa pot proba) http://i.imgur.com/DruE6yD.jpg http://i.imgur.com/CrS5ubQ.jpg http://i.imgur.com/L1aIeNs.jpg 2.sursa laptop huntkey 19V ; 4,74A pret 25 lei + posta. http://i.imgur.com/GkYco11.jpg 3.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg)4.un autotransformator. pret 150 lei + posta.[imgur](http://i.imgur.com/3Hg1OgC.jpg)[imgur](http://i.imgur.com/4YfJNyr.jpg)[imgur](http://i.imgur.com/8yREWkd.jpg)[imgur](http://i.imgur.com/ueueYpj.jpg)in ultima poza se vede pe ampermetru ca are si sarcina (un fier de calcat - 1000W). 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg)27.transformator prindere pe cablaj:220v - 15v /12w. pret 14 lei.[imgur](http://i.imgur.com/MQ9DwAq.jpg)28.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 29.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 30.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)31.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)32.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg)33.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta. [imgur](http://i.imgur.com/OLtHAbD.jpg)[imgur](http://i.imgur.com/WF2Coth.jpg) [imgur](http://i.imgur.com/vuA2uOc.jpg) [imgur](http://i.imgur.com/I9TAwJT.jpg)[imgur](http://i.imgur.com/ePdN1Fj.jpg)[imgur](http://i.imgur.com/lJlV3xk.jpg)[imgur](http://i.imgur.com/3rPbomB.jpg)[imgur](http://i.imgur.com/D08Sp2l.jpg)[imgur](http://i.imgur.com/HME16wR.jpg)[imgur](http://i.imgur.com/mKTgWfI.jpg)[imgur](http://i.imgur.com/9JV9Rmn.jpg) 34.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 35.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 36.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 37.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 38.switch ethernet (fara sursa de 12 V c.c.) pret 25 lei + posta. [imgur](http://i.imgur.com/ajnC0VI.jpg) [imgur](http://i.imgur.com/bsTZvTL.jpg) 39.telefon fara fir KX-TG7321 pret 80 lei + posta. [imgur](http://i.imgur.com/Kmujcs2.jpg) [imgur](http://i.imgur.com/eFJNoVa.jpg) [imgur](http://i.imgur.com/OoR4lLD.jpg) 40.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 41.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 42.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 43.hub 4 porturi ;2 modele. pret 8 lei / buc. (partea de intrare sunt puse de mine neavand mufa mama miniusb pt. cablaj ) [imgur](http://i.imgur.com/W1zYdiQ.jpg) [imgur](http://i.imgur.com/29lb2US.jpg) [imgur](http://i.imgur.com/mMczDhL.jpg) [imgur](http://i.imgur.com/IwpTZhh.jpg) 44.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 45.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 46.tv LG42PC3RA (plasma) dezmembrat : cauza dezmembrarii este urmatorul modul (c.i. STK795-820 defect) [imgur](http://i.imgur.com/usTWMhz.jpg) cadru cu picior + panel fata + capac spate + alte maruntaie. pret 70 lei + posta. [imgur](http://i.imgur.com/kpHifvE.jpg) [imgur](http://i.imgur.com/0N6HRkG.jpg) [imgur](http://i.imgur.com/jnjxuSD.jpg) [imgur](http://i.imgur.com/iYERD2s.jpg) [imgur](http://i.imgur.com/Ukm5BNZ.jpg) [imgur](http://i.imgur.com/DTOYs0E.jpg) [imgur](http://i.imgur.com/k8YAGLp.jpg) [imgur](http://i.imgur.com/LuLLahI.jpg) modul 1. pret 120 lei + posta. [imgur](http://i.imgur.com/rA0riwA.jpg) modul 2. pret 80 lei + posta. [imgur](http://i.imgur.com/lXYPm5U.jpg) modul 3. pret toate 3 buc. 80 lei + posta. [imgur](http://i.imgur.com/E4H1j3D.jpg) [imgur](http://i.imgur.com/cWoj5Pi.jpg) modul 4. pret 120 lei + posta. [imgur](http://i.imgur.com/W5fZzmW.jpg) [imgur](http://i.imgur.com/K1E9xC7.jpg) modul 5. pret 120 lei + posta. [imgur](http://i.imgur.com/fYCLp6p.jpg) [imgur](http://i.imgur.com/CKl4dB8.jpg) [imgur](http://i.imgur.com/3HCT9sY.jpg) 47.sursa comutatie :+12v ; +20v ;+100v ; 6,3v pret 10 lei + posta. http://i.imgur.com/MoilATm.jpg http://i.imgur.com/Y76IN3W.jpg 48.condensatori diverse valori si tensiuni. pret toata gramada 10 lei + posta. http://i.imgur.com/bsaKbzJ.jpg 49.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 50.motor la 220 v . pret 15 lei + posta. http://i.imgur.com/Nrd6Rj7.jpg 51.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 52.modem wifi 3g huawei E 586 in stare perfecta de functionare, decodat merge in orice retea.(l-am incercat doar in rds-rcs si functioneaza perfect) pret 100 lei + posta. http://i.imgur.com/5z8AAjS.jpg http://i.imgur.com/3iOpRLu.jpg http://i.imgur.com/UmU4FVU.jpg 53.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg Link spre comentariu
rellu Postat Martie 19, 2015 Autor Partajează Postat Martie 19, 2015 1.incarcator acumulatori camera video marca Panasonic model VSK0541. pret 10 lei + posta. (din pacate nu pot sa zic prea multe despre aparat doar ca ledul de power se aprinde iar ala de charge sta stins;nu am acumulator sa pot proba) http://i.imgur.com/DruE6yD.jpg http://i.imgur.com/CrS5ubQ.jpg http://i.imgur.com/L1aIeNs.jpg 2.sursa laptop huntkey 19V ; 4,74A pret 25 lei + posta. http://i.imgur.com/GkYco11.jpg 3.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg)4.un autotransformator. pret 150 lei + posta.[imgur](http://i.imgur.com/3Hg1OgC.jpg)[imgur](http://i.imgur.com/4YfJNyr.jpg)[imgur](http://i.imgur.com/8yREWkd.jpg)[imgur](http://i.imgur.com/ueueYpj.jpg)in ultima poza se vede pe ampermetru ca are si sarcina (un fier de calcat - 1000W). 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg)27.transformator prindere pe cablaj:220v - 15v /12w. pret 14 lei.[imgur](http://i.imgur.com/MQ9DwAq.jpg)28.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 29.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 30.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)31.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)32.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg)33.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta. [imgur](http://i.imgur.com/OLtHAbD.jpg)[imgur](http://i.imgur.com/WF2Coth.jpg) [imgur](http://i.imgur.com/vuA2uOc.jpg) [imgur](http://i.imgur.com/I9TAwJT.jpg)[imgur](http://i.imgur.com/ePdN1Fj.jpg)[imgur](http://i.imgur.com/lJlV3xk.jpg)[imgur](http://i.imgur.com/3rPbomB.jpg)[imgur](http://i.imgur.com/D08Sp2l.jpg)[imgur](http://i.imgur.com/HME16wR.jpg)[imgur](http://i.imgur.com/mKTgWfI.jpg)[imgur](http://i.imgur.com/9JV9Rmn.jpg) 34.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 35.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 36.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 37.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 38.switch ethernet (fara sursa de 12 V c.c.) pret 25 lei + posta. [imgur](http://i.imgur.com/ajnC0VI.jpg) [imgur](http://i.imgur.com/bsTZvTL.jpg) 39.telefon fara fir KX-TG7321 pret 80 lei + posta. [imgur](http://i.imgur.com/Kmujcs2.jpg) [imgur](http://i.imgur.com/eFJNoVa.jpg) [imgur](http://i.imgur.com/OoR4lLD.jpg) 40.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 41.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 42.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 43.hub 4 porturi ;2 modele. pret 8 lei / buc. (partea de intrare sunt puse de mine neavand mufa mama miniusb pt. cablaj ) [imgur](http://i.imgur.com/W1zYdiQ.jpg) [imgur](http://i.imgur.com/29lb2US.jpg) [imgur](http://i.imgur.com/mMczDhL.jpg) [imgur](http://i.imgur.com/IwpTZhh.jpg) 44.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 45.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 46.tv LG42PC3RA (plasma) dezmembrat : cauza dezmembrarii este urmatorul modul (c.i. STK795-820 defect) [imgur](http://i.imgur.com/usTWMhz.jpg) cadru cu picior + panel fata + capac spate + alte maruntaie. pret 70 lei + posta. [imgur](http://i.imgur.com/kpHifvE.jpg) [imgur](http://i.imgur.com/0N6HRkG.jpg) [imgur](http://i.imgur.com/jnjxuSD.jpg) [imgur](http://i.imgur.com/iYERD2s.jpg) [imgur](http://i.imgur.com/Ukm5BNZ.jpg) [imgur](http://i.imgur.com/DTOYs0E.jpg) [imgur](http://i.imgur.com/k8YAGLp.jpg) [imgur](http://i.imgur.com/LuLLahI.jpg) modul 1. pret 120 lei + posta. [imgur](http://i.imgur.com/rA0riwA.jpg) modul 2. pret 80 lei + posta. [imgur](http://i.imgur.com/lXYPm5U.jpg) modul 3. pret toate 3 buc. 80 lei + posta. [imgur](http://i.imgur.com/E4H1j3D.jpg) [imgur](http://i.imgur.com/cWoj5Pi.jpg) modul 4. pret 120 lei + posta. [imgur](http://i.imgur.com/W5fZzmW.jpg) [imgur](http://i.imgur.com/K1E9xC7.jpg) modul 5. pret 120 lei + posta. [imgur](http://i.imgur.com/fYCLp6p.jpg) [imgur](http://i.imgur.com/CKl4dB8.jpg) [imgur](http://i.imgur.com/3HCT9sY.jpg) 47.sursa comutatie :+12v ; +20v ;+100v ; 6,3v pret 10 lei + posta. http://i.imgur.com/MoilATm.jpg http://i.imgur.com/Y76IN3W.jpg 48.condensatori diverse valori si tensiuni. pret toata gramada 10 lei + posta. http://i.imgur.com/bsaKbzJ.jpg 49.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 50.motor la 220 v . pret 15 lei + posta. http://i.imgur.com/Nrd6Rj7.jpg 51.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 52.modem wifi 3g huawei E 586 in stare perfecta de functionare, decodat merge in orice retea.(l-am incercat doar in rds-rcs si functioneaza perfect) pret 100 lei + posta. http://i.imgur.com/5z8AAjS.jpg http://i.imgur.com/3iOpRLu.jpg http://i.imgur.com/UmU4FVU.jpg 53.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg Link spre comentariu
rellu Postat Martie 20, 2015 Autor Partajează Postat Martie 20, 2015 Lista de mai sus valaila. Link spre comentariu
rellu Postat Martie 21, 2015 Autor Partajează Postat Martie 21, 2015 Lista de mai sus valaila. Link spre comentariu
rellu Postat Martie 22, 2015 Autor Partajează Postat Martie 22, 2015 1.incarcator acumulatori camera video marca Panasonic model VSK0541. pret 10 lei + posta. (din pacate nu pot sa zic prea multe despre aparat doar ca ledul de power se aprinde iar ala de charge sta stins;nu am acumulator sa pot proba) http://i.imgur.com/DruE6yD.jpg http://i.imgur.com/CrS5ubQ.jpg http://i.imgur.com/L1aIeNs.jpg 2.sursa laptop huntkey 19V ; 4,74A pret 25 lei + posta. http://i.imgur.com/GkYco11.jpg 3.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg)4.un autotransformator. pret 150 lei + posta.[imgur](http://i.imgur.com/3Hg1OgC.jpg)[imgur](http://i.imgur.com/4YfJNyr.jpg)[imgur](http://i.imgur.com/8yREWkd.jpg)[imgur](http://i.imgur.com/ueueYpj.jpg)in ultima poza se vede pe ampermetru ca are si sarcina (un fier de calcat - 1000W). 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg)27.transformator prindere pe cablaj:220v - 15v /12w. pret 14 lei.[imgur](http://i.imgur.com/MQ9DwAq.jpg)28.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 29.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 30.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)31.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)32.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg)33.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta. [imgur](http://i.imgur.com/OLtHAbD.jpg)[imgur](http://i.imgur.com/WF2Coth.jpg) [imgur](http://i.imgur.com/vuA2uOc.jpg) [imgur](http://i.imgur.com/I9TAwJT.jpg)[imgur](http://i.imgur.com/ePdN1Fj.jpg)[imgur](http://i.imgur.com/lJlV3xk.jpg)[imgur](http://i.imgur.com/3rPbomB.jpg)[imgur](http://i.imgur.com/D08Sp2l.jpg)[imgur](http://i.imgur.com/HME16wR.jpg)[imgur](http://i.imgur.com/mKTgWfI.jpg)[imgur](http://i.imgur.com/9JV9Rmn.jpg) 34.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 35.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 36.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 37.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 38.switch ethernet (fara sursa de 12 V c.c.) pret 25 lei + posta. [imgur](http://i.imgur.com/ajnC0VI.jpg) [imgur](http://i.imgur.com/bsTZvTL.jpg) 39.telefon fara fir KX-TG7321 pret 80 lei + posta. [imgur](http://i.imgur.com/Kmujcs2.jpg) [imgur](http://i.imgur.com/eFJNoVa.jpg) [imgur](http://i.imgur.com/OoR4lLD.jpg) 40.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 41.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 42.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 43.hub 4 porturi ;2 modele. pret 8 lei / buc. (partea de intrare sunt puse de mine neavand mufa mama miniusb pt. cablaj ) [imgur](http://i.imgur.com/W1zYdiQ.jpg) [imgur](http://i.imgur.com/29lb2US.jpg) [imgur](http://i.imgur.com/mMczDhL.jpg) [imgur](http://i.imgur.com/IwpTZhh.jpg) 44.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 45.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 46.tv LG42PC3RA (plasma) dezmembrat : cauza dezmembrarii este urmatorul modul (c.i. STK795-820 defect) [imgur](http://i.imgur.com/usTWMhz.jpg) cadru cu picior + panel fata + capac spate + alte maruntaie. pret 70 lei + posta. [imgur](http://i.imgur.com/kpHifvE.jpg) [imgur](http://i.imgur.com/0N6HRkG.jpg) [imgur](http://i.imgur.com/jnjxuSD.jpg) [imgur](http://i.imgur.com/iYERD2s.jpg) [imgur](http://i.imgur.com/Ukm5BNZ.jpg) [imgur](http://i.imgur.com/DTOYs0E.jpg) [imgur](http://i.imgur.com/k8YAGLp.jpg) [imgur](http://i.imgur.com/LuLLahI.jpg) modul 1. pret 120 lei + posta. [imgur](http://i.imgur.com/rA0riwA.jpg) modul 2. pret 80 lei + posta. [imgur](http://i.imgur.com/lXYPm5U.jpg) modul 3. pret toate 3 buc. 80 lei + posta. [imgur](http://i.imgur.com/E4H1j3D.jpg) [imgur](http://i.imgur.com/cWoj5Pi.jpg) modul 4. pret 120 lei + posta. [imgur](http://i.imgur.com/W5fZzmW.jpg) [imgur](http://i.imgur.com/K1E9xC7.jpg) modul 5. pret 120 lei + posta. [imgur](http://i.imgur.com/fYCLp6p.jpg) [imgur](http://i.imgur.com/CKl4dB8.jpg) [imgur](http://i.imgur.com/3HCT9sY.jpg) 47.sursa comutatie :+12v ; +20v ;+100v ; 6,3v pret 10 lei + posta. http://i.imgur.com/MoilATm.jpg http://i.imgur.com/Y76IN3W.jpg 48.condensatori diverse valori si tensiuni. pret toata gramada 10 lei + posta. http://i.imgur.com/bsaKbzJ.jpg 49.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 50.motor la 220 v . pret 15 lei + posta. http://i.imgur.com/Nrd6Rj7.jpg 51.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 52.modem wifi 3g huawei E 586 in stare perfecta de functionare, decodat merge in orice retea.(l-am incercat doar in rds-rcs si functioneaza perfect) pret 100 lei + posta. http://i.imgur.com/5z8AAjS.jpg http://i.imgur.com/3iOpRLu.jpg http://i.imgur.com/UmU4FVU.jpg 53.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg Link spre comentariu
rellu Postat Martie 23, 2015 Autor Partajează Postat Martie 23, 2015 Lista de mai sus valaila. Link spre comentariu
rellu Postat Martie 24, 2015 Autor Partajează Postat Martie 24, 2015 Lista de mai sus valaila. Link spre comentariu
rellu Postat Martie 25, 2015 Autor Partajează Postat Martie 25, 2015 Lista de mai sus valaila. Link spre comentariu
rellu Postat Martie 26, 2015 Autor Partajează Postat Martie 26, 2015 1.incarcator acumulatori camera video marca Panasonic model VSK0541. pret 10 lei + posta. (din pacate nu pot sa zic prea multe despre aparat doar ca ledul de power se aprinde iar ala de charge sta stins;nu am acumulator sa pot proba) http://i.imgur.com/DruE6yD.jpg http://i.imgur.com/CrS5ubQ.jpg http://i.imgur.com/L1aIeNs.jpg 2.sursa laptop huntkey 19V ; 4,74A pret 25 lei + posta. http://i.imgur.com/GkYco11.jpg 3.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg)4.un autotransformator. pret 150 lei + posta.[imgur](http://i.imgur.com/3Hg1OgC.jpg)[imgur](http://i.imgur.com/4YfJNyr.jpg)[imgur](http://i.imgur.com/8yREWkd.jpg)[imgur](http://i.imgur.com/ueueYpj.jpg)in ultima poza se vede pe ampermetru ca are si sarcina (un fier de calcat - 1000W). 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg)27.transformator prindere pe cablaj:220v - 15v /12w. pret 14 lei.[imgur](http://i.imgur.com/MQ9DwAq.jpg)28.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 29.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 30.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)31.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)32.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg)33.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta. [imgur](http://i.imgur.com/OLtHAbD.jpg)[imgur](http://i.imgur.com/WF2Coth.jpg) [imgur](http://i.imgur.com/vuA2uOc.jpg) [imgur](http://i.imgur.com/I9TAwJT.jpg)[imgur](http://i.imgur.com/ePdN1Fj.jpg)[imgur](http://i.imgur.com/lJlV3xk.jpg)[imgur](http://i.imgur.com/3rPbomB.jpg)[imgur](http://i.imgur.com/D08Sp2l.jpg)[imgur](http://i.imgur.com/HME16wR.jpg)[imgur](http://i.imgur.com/mKTgWfI.jpg)[imgur](http://i.imgur.com/9JV9Rmn.jpg) 34.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 35.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 36.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 37.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 38.switch ethernet (fara sursa de 12 V c.c.) pret 25 lei + posta. [imgur](http://i.imgur.com/ajnC0VI.jpg) [imgur](http://i.imgur.com/bsTZvTL.jpg) 39.telefon fara fir KX-TG7321 pret 80 lei + posta. [imgur](http://i.imgur.com/Kmujcs2.jpg) [imgur](http://i.imgur.com/eFJNoVa.jpg) [imgur](http://i.imgur.com/OoR4lLD.jpg) 40.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 41.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 42.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 43.hub 4 porturi ;2 modele. pret 8 lei / buc. (partea de intrare sunt puse de mine neavand mufa mama miniusb pt. cablaj ) [imgur](http://i.imgur.com/W1zYdiQ.jpg) [imgur](http://i.imgur.com/29lb2US.jpg) [imgur](http://i.imgur.com/mMczDhL.jpg) [imgur](http://i.imgur.com/IwpTZhh.jpg) 44.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 45.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 46.tv LG42PC3RA (plasma) dezmembrat : cauza dezmembrarii este urmatorul modul (c.i. STK795-820 defect) [imgur](http://i.imgur.com/usTWMhz.jpg) cadru cu picior + panel fata + capac spate + alte maruntaie. pret 70 lei + posta. [imgur](http://i.imgur.com/kpHifvE.jpg) [imgur](http://i.imgur.com/0N6HRkG.jpg) [imgur](http://i.imgur.com/jnjxuSD.jpg) [imgur](http://i.imgur.com/iYERD2s.jpg) [imgur](http://i.imgur.com/Ukm5BNZ.jpg) [imgur](http://i.imgur.com/DTOYs0E.jpg) [imgur](http://i.imgur.com/k8YAGLp.jpg) [imgur](http://i.imgur.com/LuLLahI.jpg) modul 1. pret 120 lei + posta. [imgur](http://i.imgur.com/rA0riwA.jpg) modul 2. pret 80 lei + posta. [imgur](http://i.imgur.com/lXYPm5U.jpg) modul 3. pret toate 3 buc. 80 lei + posta. [imgur](http://i.imgur.com/E4H1j3D.jpg) [imgur](http://i.imgur.com/cWoj5Pi.jpg) modul 4. pret 120 lei + posta. [imgur](http://i.imgur.com/W5fZzmW.jpg) [imgur](http://i.imgur.com/K1E9xC7.jpg) modul 5. pret 120 lei + posta. [imgur](http://i.imgur.com/fYCLp6p.jpg) [imgur](http://i.imgur.com/CKl4dB8.jpg) [imgur](http://i.imgur.com/3HCT9sY.jpg) 47.sursa comutatie :+12v ; +20v ;+100v ; 6,3v pret 10 lei + posta. http://i.imgur.com/MoilATm.jpg http://i.imgur.com/Y76IN3W.jpg 48.condensatori diverse valori si tensiuni. pret toata gramada 10 lei + posta. http://i.imgur.com/bsaKbzJ.jpg 49.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 50.motor la 220 v . pret 15 lei + posta. http://i.imgur.com/Nrd6Rj7.jpg 51.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 52.modem wifi 3g huawei E 586 in stare perfecta de functionare, decodat merge in orice retea.(l-am incercat doar in rds-rcs si functioneaza perfect) pret 100 lei + posta. http://i.imgur.com/5z8AAjS.jpg http://i.imgur.com/3iOpRLu.jpg http://i.imgur.com/UmU4FVU.jpg 53.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg Link spre comentariu
rellu Postat Martie 27, 2015 Autor Partajează Postat Martie 27, 2015 1.incarcator acumulatori camera video marca Panasonic model VSK0541. pret 10 lei + posta. (din pacate nu pot sa zic prea multe despre aparat doar ca ledul de power se aprinde iar ala de charge sta stins;nu am acumulator sa pot proba) http://i.imgur.com/DruE6yD.jpg http://i.imgur.com/CrS5ubQ.jpg http://i.imgur.com/L1aIeNs.jpg 2.sursa laptop huntkey 19V ; 4,74A pret 25 lei + posta. http://i.imgur.com/GkYco11.jpg 3.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg)4.un autotransformator. pret 150 lei + posta.[imgur](http://i.imgur.com/3Hg1OgC.jpg)[imgur](http://i.imgur.com/4YfJNyr.jpg)[imgur](http://i.imgur.com/8yREWkd.jpg)[imgur](http://i.imgur.com/ueueYpj.jpg)in ultima poza se vede pe ampermetru ca are si sarcina (un fier de calcat - 1000W). 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg)27.transformator prindere pe cablaj:220v - 15v /12w. pret 14 lei.[imgur](http://i.imgur.com/MQ9DwAq.jpg)28.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 29.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 30.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)31.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)32.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg)33.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta. [imgur](http://i.imgur.com/OLtHAbD.jpg)[imgur](http://i.imgur.com/WF2Coth.jpg) [imgur](http://i.imgur.com/vuA2uOc.jpg) [imgur](http://i.imgur.com/I9TAwJT.jpg)[imgur](http://i.imgur.com/ePdN1Fj.jpg)[imgur](http://i.imgur.com/lJlV3xk.jpg)[imgur](http://i.imgur.com/3rPbomB.jpg)[imgur](http://i.imgur.com/D08Sp2l.jpg)[imgur](http://i.imgur.com/HME16wR.jpg)[imgur](http://i.imgur.com/mKTgWfI.jpg)[imgur](http://i.imgur.com/9JV9Rmn.jpg) 34.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 35.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 36.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 37.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 38.switch ethernet (fara sursa de 12 V c.c.) pret 25 lei + posta. [imgur](http://i.imgur.com/ajnC0VI.jpg) [imgur](http://i.imgur.com/bsTZvTL.jpg) 39.telefon fara fir KX-TG7321 pret 80 lei + posta. [imgur](http://i.imgur.com/Kmujcs2.jpg) [imgur](http://i.imgur.com/eFJNoVa.jpg) [imgur](http://i.imgur.com/OoR4lLD.jpg) 40.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 41.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 42.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 43.hub 4 porturi ;2 modele. pret 8 lei / buc. (partea de intrare sunt puse de mine neavand mufa mama miniusb pt. cablaj ) [imgur](http://i.imgur.com/W1zYdiQ.jpg) [imgur](http://i.imgur.com/29lb2US.jpg) [imgur](http://i.imgur.com/mMczDhL.jpg) [imgur](http://i.imgur.com/IwpTZhh.jpg) 44.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 45.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 46.tv LG42PC3RA (plasma) dezmembrat : cauza dezmembrarii este urmatorul modul (c.i. STK795-820 defect) [imgur](http://i.imgur.com/usTWMhz.jpg) cadru cu picior + panel fata + capac spate + alte maruntaie. pret 70 lei + posta. [imgur](http://i.imgur.com/kpHifvE.jpg) [imgur](http://i.imgur.com/0N6HRkG.jpg) [imgur](http://i.imgur.com/jnjxuSD.jpg) [imgur](http://i.imgur.com/iYERD2s.jpg) [imgur](http://i.imgur.com/Ukm5BNZ.jpg) [imgur](http://i.imgur.com/DTOYs0E.jpg) [imgur](http://i.imgur.com/k8YAGLp.jpg) [imgur](http://i.imgur.com/LuLLahI.jpg) modul 1. pret 120 lei + posta. [imgur](http://i.imgur.com/rA0riwA.jpg) modul 2. pret 80 lei + posta. [imgur](http://i.imgur.com/lXYPm5U.jpg) modul 3. pret toate 3 buc. 80 lei + posta. [imgur](http://i.imgur.com/E4H1j3D.jpg) [imgur](http://i.imgur.com/cWoj5Pi.jpg) modul 4. pret 120 lei + posta. [imgur](http://i.imgur.com/W5fZzmW.jpg) [imgur](http://i.imgur.com/K1E9xC7.jpg) modul 5. pret 120 lei + posta. [imgur](http://i.imgur.com/fYCLp6p.jpg) [imgur](http://i.imgur.com/CKl4dB8.jpg) [imgur](http://i.imgur.com/3HCT9sY.jpg) 47.sursa comutatie :+12v ; +20v ;+100v ; 6,3v pret 10 lei + posta. http://i.imgur.com/MoilATm.jpg http://i.imgur.com/Y76IN3W.jpg 48.condensatori diverse valori si tensiuni. pret toata gramada 10 lei + posta. http://i.imgur.com/bsaKbzJ.jpg 49.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 50.motor la 220 v . pret 15 lei + posta. http://i.imgur.com/Nrd6Rj7.jpg 51.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 52.modem wifi 3g huawei E 586 in stare perfecta de functionare, decodat merge in orice retea.(l-am incercat doar in rds-rcs si functioneaza perfect) pret 100 lei + posta. http://i.imgur.com/5z8AAjS.jpg http://i.imgur.com/3iOpRLu.jpg http://i.imgur.com/UmU4FVU.jpg 53.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg Link spre comentariu
rellu Postat Martie 28, 2015 Autor Partajează Postat Martie 28, 2015 Lista de mai sus valaila. Link spre comentariu
rellu Postat Martie 29, 2015 Autor Partajează Postat Martie 29, 2015 Lista de mai sus valaila. Link spre comentariu
rellu Postat Martie 30, 2015 Autor Partajează Postat Martie 30, 2015 1.incarcator acumulatori camera video marca Panasonic model VSK0541. pret 10 lei + posta. (din pacate nu pot sa zic prea multe despre aparat doar ca ledul de power se aprinde iar ala de charge sta stins;nu am acumulator sa pot proba) http://i.imgur.com/DruE6yD.jpg http://i.imgur.com/CrS5ubQ.jpg http://i.imgur.com/L1aIeNs.jpg 2.sursa laptop huntkey 19V ; 4,74A pret 25 lei + posta. http://i.imgur.com/GkYco11.jpg 3.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg)4.un autotransformator. pret 150 lei + posta.[imgur](http://i.imgur.com/3Hg1OgC.jpg)[imgur](http://i.imgur.com/4YfJNyr.jpg)[imgur](http://i.imgur.com/8yREWkd.jpg)[imgur](http://i.imgur.com/ueueYpj.jpg)in ultima poza se vede pe ampermetru ca are si sarcina (un fier de calcat - 1000W). 5.carcasa goala de la aparat proiectie diapozitive (URSS). pret 12 lei + posta. http://i.imgur.com/xLYj1pw.jpg http://i.imgur.com/WyGhzFR.jpg http://i.imgur.com/tNXaBXc.jpg 6.un set de incarcatoare (priza 220v + priza auto). pret / set 10 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)8.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)9.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)11.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)14.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)15.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)16.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)17.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 18.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)19. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 20.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)21.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)22.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 23.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 24.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 25.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 26.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg)27.transformator prindere pe cablaj:220v - 15v /12w. pret 14 lei.[imgur](http://i.imgur.com/MQ9DwAq.jpg)28.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 29.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 30.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)31.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)32.unitate optica dvd (dvd-recorder). pret 20 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg)33.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta. [imgur](http://i.imgur.com/OLtHAbD.jpg)[imgur](http://i.imgur.com/WF2Coth.jpg) [imgur](http://i.imgur.com/vuA2uOc.jpg) [imgur](http://i.imgur.com/I9TAwJT.jpg)[imgur](http://i.imgur.com/ePdN1Fj.jpg)[imgur](http://i.imgur.com/lJlV3xk.jpg)[imgur](http://i.imgur.com/3rPbomB.jpg)[imgur](http://i.imgur.com/D08Sp2l.jpg)[imgur](http://i.imgur.com/HME16wR.jpg)[imgur](http://i.imgur.com/mKTgWfI.jpg)[imgur](http://i.imgur.com/9JV9Rmn.jpg) 34.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 35.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 36.releu cu bobina la 12v c.c. / 2 contacte la 5A .pret 6 lei + posta. http://i.imgur.com/ZRbPYm1.jpg http://i.imgur.com/twjAk5h.jpg 37.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 38.switch ethernet (fara sursa de 12 V c.c.) pret 25 lei + posta. [imgur](http://i.imgur.com/ajnC0VI.jpg) [imgur](http://i.imgur.com/bsTZvTL.jpg) 39.telefon fara fir KX-TG7321 pret 80 lei + posta. [imgur](http://i.imgur.com/Kmujcs2.jpg) [imgur](http://i.imgur.com/eFJNoVa.jpg) [imgur](http://i.imgur.com/OoR4lLD.jpg) 40.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 41.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 42.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 43.hub 4 porturi ;2 modele. pret 8 lei / buc. (partea de intrare sunt puse de mine neavand mufa mama miniusb pt. cablaj ) [imgur](http://i.imgur.com/W1zYdiQ.jpg) [imgur](http://i.imgur.com/29lb2US.jpg) [imgur](http://i.imgur.com/mMczDhL.jpg) [imgur](http://i.imgur.com/IwpTZhh.jpg) 44.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 45.docking stations nou-nout pt. samsung tab. pret 35 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 46.tv LG42PC3RA (plasma) dezmembrat : cauza dezmembrarii este urmatorul modul (c.i. STK795-820 defect) [imgur](http://i.imgur.com/usTWMhz.jpg) cadru cu picior + panel fata + capac spate + alte maruntaie. pret 70 lei + posta. [imgur](http://i.imgur.com/kpHifvE.jpg) [imgur](http://i.imgur.com/0N6HRkG.jpg) [imgur](http://i.imgur.com/jnjxuSD.jpg) [imgur](http://i.imgur.com/iYERD2s.jpg) [imgur](http://i.imgur.com/Ukm5BNZ.jpg) [imgur](http://i.imgur.com/DTOYs0E.jpg) [imgur](http://i.imgur.com/k8YAGLp.jpg) [imgur](http://i.imgur.com/LuLLahI.jpg) modul 1. pret 120 lei + posta. [imgur](http://i.imgur.com/rA0riwA.jpg) modul 2. pret 80 lei + posta. [imgur](http://i.imgur.com/lXYPm5U.jpg) modul 3. pret toate 3 buc. 80 lei + posta. [imgur](http://i.imgur.com/E4H1j3D.jpg) [imgur](http://i.imgur.com/cWoj5Pi.jpg) modul 4. pret 120 lei + posta. [imgur](http://i.imgur.com/W5fZzmW.jpg) [imgur](http://i.imgur.com/K1E9xC7.jpg) modul 5. pret 120 lei + posta. [imgur](http://i.imgur.com/fYCLp6p.jpg) [imgur](http://i.imgur.com/CKl4dB8.jpg) [imgur](http://i.imgur.com/3HCT9sY.jpg) 47.sursa comutatie :+12v ; +20v ;+100v ; 6,3v pret 10 lei + posta. http://i.imgur.com/MoilATm.jpg http://i.imgur.com/Y76IN3W.jpg 48.condensatori diverse valori si tensiuni. pret toata gramada 10 lei + posta. http://i.imgur.com/bsaKbzJ.jpg 49.relee + soclu (bobina la 12v ;4 randuri de contacte NC/NO ).pret toate 8 lei + posta. http://i.imgur.com/koKgn1r.jpg http://i.imgur.com/hk55OzT.jpg 50.motor la 220 v . pret 15 lei + posta. http://i.imgur.com/Nrd6Rj7.jpg 51.modem usb huawei K3565-rev2 (decodat). pret 25 lei + posta. http://i.imgur.com/Qn0Pfbw.jpg http://i.imgur.com/4Q0JKEH.jpg 52.modem wifi 3g huawei E 586 in stare perfecta de functionare, decodat merge in orice retea.(l-am incercat doar in rds-rcs si functioneaza perfect) pret 100 lei + posta. http://i.imgur.com/5z8AAjS.jpg http://i.imgur.com/3iOpRLu.jpg http://i.imgur.com/UmU4FVU.jpg 53.placa din tv platinium SKY-2122AI . pret 30 lei +posta. (dupa ce i-am schimbat tz. din sursa, a functionat ,doar cand l-am mutat in alta parte a cazut pe tub si s-a crapat placa TK si tubul). http://i.imgur.com/a4z0HQT.jpg http://i.imgur.com/m1rPInd.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/jDWolET.jpg http://i.imgur.com/8SzIXSK.jpg http://i.imgur.com/XraSbM6.jpg Link spre comentariu
rellu Postat Martie 31, 2015 Autor Partajează Postat Martie 31, 2015 Lista de mai sus valaila. Link spre comentariu
rellu Postat Aprilie 1, 2015 Autor Partajează Postat Aprilie 1, 2015 Lista de mai sus valaila. Link spre comentariu
