rellu Postat Octombrie 3, 2014 Autor Partajează Postat Octombrie 3, 2014 Actualizare lista produse :1.radio - cd - casetofon marca schneider model SP225 perfect functional cu telecomanda. pret 95 lei + posta.pe partea de cd stie sa citeasca doar cd audio nu si mp3.[imgur](http://i.imgur.com/pCrdSAY.jpg)[imgur](http://i.imgur.com/fe9aJwT.jpg)2.un radiocasetofon marca universum.functioneaza f. bine (a avut trafo. pe 220v ars,i-am adaptat altul). pret 50 lei + posta.[imgur](http://i.imgur.com/WxLKhc2.jpg)[imgur](http://i.imgur.com/EcQC5EZ.jpg)3.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg)4.un autotransformator. pret 150 lei + posta.[imgur](http://i.imgur.com/3Hg1OgC.jpg)[imgur](http://i.imgur.com/4YfJNyr.jpg)[imgur](http://i.imgur.com/8yREWkd.jpg)[imgur](http://i.imgur.com/ueueYpj.jpg)in ultima poza se vede pe ampermetru ca are si sarcina (un fier de calcat - 1000W). 5.sursa in comutatie storex :input 100v-240v output 5V/2A ; 12V/2A . pret 25 lei + posta. [imgur](http://i.imgur.com/bDd9Ip2.jpg) [imgur](http://i.imgur.com/NK3xI9X.jpg) 6.un set de incarcatoare (priza 220v + priza auto). pret / set 12 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie +5v;+12v;-12v (sursa provine din ceva casa de marcat) pret 12 lei + posta.[imgur](http://i.imgur.com/KgYmviR.jpg)[imgur](http://i.imgur.com/u6Kb1qN.jpg)8.sursa in comutatie +5v;+35V (sursa provine din ceva imprimanta epson) pret 12 lei + posta.[imgur](http://i.imgur.com/4Q0d5ww.jpg)[imgur](http://i.imgur.com/EQRKEY1.jpg)9.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)10.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)11.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)12.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)13.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)14.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)15.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)16.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)17.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)18.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)19.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 20.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)21. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg)22.sursa in comutatie in :220v c.a. / din semireglabil se poate modifica tens. de iesire intre :15 - 24 V c.c. /1A. pret 12 lei + posta.[imgur](http://i.imgur.com/dL5RIoQ.jpg)23.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)24.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)25.receviere satelit (functionale) pt. carcasa. pret 15 lei/buc. + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg)[imgur](http://i.imgur.com/NGRnPwb.jpg)26.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 27.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 28.motoare pas cu pas. pret 14 lei toata gramada + posta.[imgur](http://i.imgur.com/GCgLv.jpg)[imgur](http://i.imgur.com/G5mzZ.jpg)29.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 30.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg)31.transformator prindere pe cablaj:220v - 15v /12w. pret 14 lei.[imgur](http://i.imgur.com/MQ9DwAq.jpg)32.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 33.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 34.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)35.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)36.unitate optica dvd (dvd-recorder). pret 25 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg)37.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta.[imgur](http://i.imgur.com/TOB4oix.jpg)[imgur](http://i.imgur.com/OLtHAbD.jpg)[imgur](http://i.imgur.com/WF2Coth.jpg)[imgur](http://i.imgur.com/Xu5CAKn.jpg)[imgur](http://i.imgur.com/vuA2uOc.jpg)[imgur](http://i.imgur.com/eQc0HTq.jpg)[imgur](http://i.imgur.com/I9TAwJT.jpg)[imgur](http://i.imgur.com/ePdN1Fj.jpg)[imgur](http://i.imgur.com/lJlV3xk.jpg)[imgur](http://i.imgur.com/3rPbomB.jpg)[imgur](http://i.imgur.com/D08Sp2l.jpg)[imgur](http://i.imgur.com/HME16wR.jpg)[imgur](http://i.imgur.com/mKTgWfI.jpg)[imgur](http://i.imgur.com/9JV9Rmn.jpg)[imgur](http://i.imgur.com/ckbiPF1.jpg)38.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 39.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 40.condensatori variabili recuperati .pret 6 lei / grup + posta. [imgur](http://i.imgur.com/u2GBnVC.jpg) 41.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 42.switch ethernet (fara sursa de 12 V c.c.) pret 25 lei + posta. [imgur](http://i.imgur.com/ajnC0VI.jpg) [imgur](http://i.imgur.com/bsTZvTL.jpg) 43.telefon fara fir KX-TG7321 pret 80 lei + posta. [imgur](http://i.imgur.com/Kmujcs2.jpg) [imgur](http://i.imgur.com/eFJNoVa.jpg) [imgur](http://i.imgur.com/OoR4lLD.jpg) 44.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 45.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 46.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 47.hub 4 porturi ;2 modele. pret 8 lei / buc. (partea de intrare sunt puse de mine neavand mufa mama miniusb pt. cablaj ) [imgur](http://i.imgur.com/W1zYdiQ.jpg) [imgur](http://i.imgur.com/29lb2US.jpg) [imgur](http://i.imgur.com/mMczDhL.jpg) [imgur](http://i.imgur.com/IwpTZhh.jpg) 48.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 49.diverse aparate (defecte) foto,camere de filmat,statie pmr. toata gramada cum se vede in poze la pretul de 100 lei + posta. [imgur](http://i.imgur.com/r7vlNJB.jpg) [imgur](http://i.imgur.com/y3PfhgF.jpg) 50.docking stations nou-nout pt. samsung tab. pret 60 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 51.tv LG42PC3RA (plasma) dezmembrat : cauza dezmembrarii este urmatorul modul (c.i. STK795-820 defect) [imgur](http://i.imgur.com/usTWMhz.jpg) cadru cu picior + panel fata + capac spate + alte maruntaie. pret 70 lei + posta. [imgur](http://i.imgur.com/kpHifvE.jpg) [imgur](http://i.imgur.com/0N6HRkG.jpg) [imgur](http://i.imgur.com/jnjxuSD.jpg) [imgur](http://i.imgur.com/iYERD2s.jpg) [imgur](http://i.imgur.com/Ukm5BNZ.jpg) [imgur](http://i.imgur.com/DTOYs0E.jpg) [imgur](http://i.imgur.com/k8YAGLp.jpg) [imgur](http://i.imgur.com/LuLLahI.jpg) modul 1. pret 120 lei + posta. [imgur](http://i.imgur.com/rA0riwA.jpg) modul 2. pret 80 lei + posta. [imgur](http://i.imgur.com/lXYPm5U.jpg) modul 3. pret toate 3 buc. 80 lei + posta. [imgur](http://i.imgur.com/E4H1j3D.jpg) [imgur](http://i.imgur.com/cWoj5Pi.jpg) modul 4. pret 120 lei + posta. [imgur](http://i.imgur.com/W5fZzmW.jpg) [imgur](http://i.imgur.com/K1E9xC7.jpg) modul 5. pret 120 lei + posta. [imgur](http://i.imgur.com/fYCLp6p.jpg) [imgur](http://i.imgur.com/CKl4dB8.jpg) [imgur](http://i.imgur.com/3HCT9sY.jpg) panel plasma (ecran) pret 180 lei + posta. [imgur](http://i.imgur.com/SeVVJjW.jpg) [imgur](http://i.imgur.com/aAOGvub.jpg) [imgur](http://i.imgur.com/ekjGOMH.jpg) [imgur](http://i.imgur.com/FbBmBXJ.jpg) Link spre comentariu
rellu Postat Octombrie 5, 2014 Autor Partajează Postat Octombrie 5, 2014 Lista de mai sus valabila. UP Link spre comentariu
rellu Postat Octombrie 6, 2014 Autor Partajează Postat Octombrie 6, 2014 Lista de mai sus valabila. UP Link spre comentariu
rellu Postat Octombrie 9, 2014 Autor Partajează Postat Octombrie 9, 2014 Lista de mai sus valabila. UP Link spre comentariu
rellu Postat Octombrie 11, 2014 Autor Partajează Postat Octombrie 11, 2014 Lista de mai sus valabila. UP Link spre comentariu
rellu Postat Octombrie 12, 2014 Autor Partajează Postat Octombrie 12, 2014 Anunt valabil. Link spre comentariu
rellu Postat Octombrie 13, 2014 Autor Partajează Postat Octombrie 13, 2014 Lista de mai sus valabila. UP Link spre comentariu
rellu Postat Octombrie 14, 2014 Autor Partajează Postat Octombrie 14, 2014 Lista de mai sus valabila. UP Link spre comentariu
rellu Postat Octombrie 16, 2014 Autor Partajează Postat Octombrie 16, 2014 Actualizare lista produse :1.radio - cd - casetofon marca schneider model SP225 perfect functional cu telecomanda. pret 95 lei + posta.pe partea de cd stie sa citeasca doar cd audio nu si mp3.[imgur](http://i.imgur.com/pCrdSAY.jpg)[imgur](http://i.imgur.com/fe9aJwT.jpg)2.un radiocasetofon marca universum.functioneaza f. bine (a avut trafo. pe 220v ars,i-am adaptat altul). pret 50 lei + posta.[imgur](http://i.imgur.com/WxLKhc2.jpg)[imgur](http://i.imgur.com/EcQC5EZ.jpg)3.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg)4.un autotransformator. pret 150 lei + posta.[imgur](http://i.imgur.com/3Hg1OgC.jpg)[imgur](http://i.imgur.com/4YfJNyr.jpg)[imgur](http://i.imgur.com/8yREWkd.jpg)[imgur](http://i.imgur.com/ueueYpj.jpg)in ultima poza se vede pe ampermetru ca are si sarcina (un fier de calcat - 1000W). 5.sursa in comutatie storex :input 100v-240v output 5V/2A ; 12V/2A . pret 25 lei + posta. [imgur](http://i.imgur.com/bDd9Ip2.jpg) [imgur](http://i.imgur.com/NK3xI9X.jpg) 6.un set de incarcatoare (priza 220v + priza auto). pret / set 12 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie +5v;+12v;-12v (sursa provine din ceva casa de marcat) pret 12 lei + posta.[imgur](http://i.imgur.com/KgYmviR.jpg)[imgur](http://i.imgur.com/u6Kb1qN.jpg)8.sursa in comutatie +5v;+35V (sursa provine din ceva imprimanta epson) pret 12 lei + posta.[imgur](http://i.imgur.com/4Q0d5ww.jpg)[imgur](http://i.imgur.com/EQRKEY1.jpg)9.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)10.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)11.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)12.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)13.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)14.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)15.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)16.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)17.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)18.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)19.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 20.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)21. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg)22.sursa in comutatie in :220v c.a. / din semireglabil se poate modifica tens. de iesire intre :15 - 24 V c.c. /1A. pret 12 lei + posta.[imgur](http://i.imgur.com/dL5RIoQ.jpg)23.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)24.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)25.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 26.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 27.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 28.motoare pas cu pas. pret 14 lei toata gramada + posta.[imgur](http://i.imgur.com/GCgLv.jpg)[imgur](http://i.imgur.com/G5mzZ.jpg)29.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 30.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg)31.transformator prindere pe cablaj:220v - 15v /12w. pret 14 lei.[imgur](http://i.imgur.com/MQ9DwAq.jpg)32.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 33.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 34.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)35.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)36.unitate optica dvd (dvd-recorder). pret 25 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg)37.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta.[imgur](http://i.imgur.com/TOB4oix.jpg)[imgur](http://i.imgur.com/OLtHAbD.jpg)[imgur](http://i.imgur.com/WF2Coth.jpg)[imgur](http://i.imgur.com/Xu5CAKn.jpg)[imgur](http://i.imgur.com/vuA2uOc.jpg)[imgur](http://i.imgur.com/eQc0HTq.jpg)[imgur](http://i.imgur.com/I9TAwJT.jpg)[imgur](http://i.imgur.com/ePdN1Fj.jpg)[imgur](http://i.imgur.com/lJlV3xk.jpg)[imgur](http://i.imgur.com/3rPbomB.jpg)[imgur](http://i.imgur.com/D08Sp2l.jpg)[imgur](http://i.imgur.com/HME16wR.jpg)[imgur](http://i.imgur.com/mKTgWfI.jpg)[imgur](http://i.imgur.com/9JV9Rmn.jpg)[imgur](http://i.imgur.com/ckbiPF1.jpg)38.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 39.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 40.condensatori variabili recuperati .pret 6 lei / grup + posta. [imgur](http://i.imgur.com/u2GBnVC.jpg) 41.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 42.switch ethernet (fara sursa de 12 V c.c.) pret 25 lei + posta. [imgur](http://i.imgur.com/ajnC0VI.jpg) [imgur](http://i.imgur.com/bsTZvTL.jpg) 43.telefon fara fir KX-TG7321 pret 80 lei + posta. [imgur](http://i.imgur.com/Kmujcs2.jpg) [imgur](http://i.imgur.com/eFJNoVa.jpg) [imgur](http://i.imgur.com/OoR4lLD.jpg) 44.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 45.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 46.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 47.hub 4 porturi ;2 modele. pret 8 lei / buc. (partea de intrare sunt puse de mine neavand mufa mama miniusb pt. cablaj ) [imgur](http://i.imgur.com/W1zYdiQ.jpg) [imgur](http://i.imgur.com/29lb2US.jpg) [imgur](http://i.imgur.com/mMczDhL.jpg) [imgur](http://i.imgur.com/IwpTZhh.jpg) 48.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 49.diverse aparate (defecte) foto,camere de filmat,statie pmr. toata gramada cum se vede in poze la pretul de 100 lei + posta. [imgur](http://i.imgur.com/r7vlNJB.jpg) [imgur](http://i.imgur.com/y3PfhgF.jpg) 50.docking stations nou-nout pt. samsung tab. pret 60 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 51.tv LG42PC3RA (plasma) dezmembrat : cauza dezmembrarii este urmatorul modul (c.i. STK795-820 defect) [imgur](http://i.imgur.com/usTWMhz.jpg) cadru cu picior + panel fata + capac spate + alte maruntaie. pret 70 lei + posta. [imgur](http://i.imgur.com/kpHifvE.jpg) [imgur](http://i.imgur.com/0N6HRkG.jpg) [imgur](http://i.imgur.com/jnjxuSD.jpg) [imgur](http://i.imgur.com/iYERD2s.jpg) [imgur](http://i.imgur.com/Ukm5BNZ.jpg) [imgur](http://i.imgur.com/DTOYs0E.jpg) [imgur](http://i.imgur.com/k8YAGLp.jpg) [imgur](http://i.imgur.com/LuLLahI.jpg) modul 1. pret 120 lei + posta. [imgur](http://i.imgur.com/rA0riwA.jpg) modul 2. pret 80 lei + posta. [imgur](http://i.imgur.com/lXYPm5U.jpg) modul 3. pret toate 3 buc. 80 lei + posta. [imgur](http://i.imgur.com/E4H1j3D.jpg) [imgur](http://i.imgur.com/cWoj5Pi.jpg) modul 4. pret 120 lei + posta. [imgur](http://i.imgur.com/W5fZzmW.jpg) [imgur](http://i.imgur.com/K1E9xC7.jpg) modul 5. pret 120 lei + posta. [imgur](http://i.imgur.com/fYCLp6p.jpg) [imgur](http://i.imgur.com/CKl4dB8.jpg) [imgur](http://i.imgur.com/3HCT9sY.jpg) panel plasma (ecran) pret 180 lei + posta. [imgur](http://i.imgur.com/SeVVJjW.jpg) [imgur](http://i.imgur.com/aAOGvub.jpg) [imgur](http://i.imgur.com/ekjGOMH.jpg) [imgur](http://i.imgur.com/FbBmBXJ.jpg) Link spre comentariu
rellu Postat Octombrie 17, 2014 Autor Partajează Postat Octombrie 17, 2014 Lista de mai sus valabila. UP Link spre comentariu
rellu Postat Octombrie 18, 2014 Autor Partajează Postat Octombrie 18, 2014 Anunt valabil. Link spre comentariu
rellu Postat Octombrie 20, 2014 Autor Partajează Postat Octombrie 20, 2014 Lista de mai sus valabila. UP Link spre comentariu
rellu Postat Octombrie 21, 2014 Autor Partajează Postat Octombrie 21, 2014 Actualizare lista produse :1.radio - cd - casetofon marca schneider model SP225 perfect functional cu telecomanda. pret 95 lei + posta.pe partea de cd stie sa citeasca doar cd audio nu si mp3.[imgur](http://i.imgur.com/pCrdSAY.jpg)[imgur](http://i.imgur.com/fe9aJwT.jpg)2.un radiocasetofon marca universum.functioneaza f. bine (a avut trafo. pe 220v ars,i-am adaptat altul). pret 50 lei + posta.[imgur](http://i.imgur.com/WxLKhc2.jpg)[imgur](http://i.imgur.com/EcQC5EZ.jpg)3.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg)4.un autotransformator. pret 150 lei + posta.[imgur](http://i.imgur.com/3Hg1OgC.jpg)[imgur](http://i.imgur.com/4YfJNyr.jpg)[imgur](http://i.imgur.com/8yREWkd.jpg)[imgur](http://i.imgur.com/ueueYpj.jpg)in ultima poza se vede pe ampermetru ca are si sarcina (un fier de calcat - 1000W). 5.sursa in comutatie storex :input 100v-240v output 5V/2A ; 12V/2A . pret 25 lei + posta. [imgur](http://i.imgur.com/bDd9Ip2.jpg) [imgur](http://i.imgur.com/NK3xI9X.jpg) 6.un set de incarcatoare (priza 220v + priza auto). pret / set 12 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie +5v;+12v;-12v (sursa provine din ceva casa de marcat) pret 12 lei + posta.[imgur](http://i.imgur.com/KgYmviR.jpg)[imgur](http://i.imgur.com/u6Kb1qN.jpg)8.sursa in comutatie +5v;+35V (sursa provine din ceva imprimanta epson) pret 12 lei + posta.[imgur](http://i.imgur.com/4Q0d5ww.jpg)[imgur](http://i.imgur.com/EQRKEY1.jpg)9.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)10.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)11.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)12.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)13.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)14.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)15.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)16.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)17.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)18.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)19.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg) 20.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)21. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg)22.sursa in comutatie in :220v c.a. / din semireglabil se poate modifica tens. de iesire intre :15 - 24 V c.c. /1A. pret 12 lei + posta.[imgur](http://i.imgur.com/dL5RIoQ.jpg)23.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)24.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg)25.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) 26.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 27.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta. [imgur](http://i.imgur.com/1BsMxy3.jpg) 28.motoare pas cu pas. pret 14 lei toata gramada + posta.[imgur](http://i.imgur.com/GCgLv.jpg)[imgur](http://i.imgur.com/G5mzZ.jpg)29.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 30.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg)31.transformator prindere pe cablaj:220v - 15v /12w. pret 14 lei.[imgur](http://i.imgur.com/MQ9DwAq.jpg)32.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta. [imgur](http://i.imgur.com/oNCeaLC.jpg) 33.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 34.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)35.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)36.unitate optica dvd (dvd-recorder). pret 25 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg)37.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta.[imgur](http://i.imgur.com/TOB4oix.jpg)[imgur](http://i.imgur.com/OLtHAbD.jpg)[imgur](http://i.imgur.com/WF2Coth.jpg)[imgur](http://i.imgur.com/Xu5CAKn.jpg)[imgur](http://i.imgur.com/vuA2uOc.jpg)[imgur](http://i.imgur.com/eQc0HTq.jpg)[imgur](http://i.imgur.com/I9TAwJT.jpg)[imgur](http://i.imgur.com/ePdN1Fj.jpg)[imgur](http://i.imgur.com/lJlV3xk.jpg)[imgur](http://i.imgur.com/3rPbomB.jpg)[imgur](http://i.imgur.com/D08Sp2l.jpg)[imgur](http://i.imgur.com/HME16wR.jpg)[imgur](http://i.imgur.com/mKTgWfI.jpg)[imgur](http://i.imgur.com/9JV9Rmn.jpg)[imgur](http://i.imgur.com/ckbiPF1.jpg)38.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg) 39.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 30 lei + posta. [imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 40.condensatori variabili recuperati .pret 6 lei / grup + posta. [imgur](http://i.imgur.com/u2GBnVC.jpg) 41.modul ecou cu integratul PT2399. pret 18 lei + posta. [imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 42.switch ethernet (fara sursa de 12 V c.c.) pret 25 lei + posta. [imgur](http://i.imgur.com/ajnC0VI.jpg) [imgur](http://i.imgur.com/bsTZvTL.jpg) 43.telefon fara fir KX-TG7321 pret 80 lei + posta. [imgur](http://i.imgur.com/Kmujcs2.jpg) [imgur](http://i.imgur.com/eFJNoVa.jpg) [imgur](http://i.imgur.com/OoR4lLD.jpg) 44.motor c.c. 24V-0,4A-4200rpm pret 6 lei + posta. [imgur](http://i.imgur.com/bq5bYS6.jpg) 45.afisaj lcd ,pret 10 lei + posta. [imgur](http://i.imgur.com/BP5rzGf.jpg) [imgur](http://i.imgur.com/8rFWX2P.jpg) 46.tastatura usb pret 10 lei + posta. [imgur](http://i.imgur.com/kfdnQiF.jpg) 47.hub 4 porturi ;2 modele. pret 8 lei / buc. (partea de intrare sunt puse de mine neavand mufa mama miniusb pt. cablaj ) [imgur](http://i.imgur.com/W1zYdiQ.jpg) [imgur](http://i.imgur.com/29lb2US.jpg) [imgur](http://i.imgur.com/mMczDhL.jpg) [imgur](http://i.imgur.com/IwpTZhh.jpg) 48.memorii eprom M27C256B-12FI 1buc. - 5 lei ; M27C2001-10F1 1 buc. - 5 lei ; M27C2001-12FI 1buc. - 5 lei + posta. [imgur](http://i.imgur.com/NLKPV66.jpg) 49.diverse aparate (defecte) foto,camere de filmat,statie pmr. toata gramada cum se vede in poze la pretul de 100 lei + posta. [imgur](http://i.imgur.com/r7vlNJB.jpg) [imgur](http://i.imgur.com/y3PfhgF.jpg) 50.docking stations nou-nout pt. samsung tab. pret 60 lei + posta. [imgur](http://i.imgur.com/Mt1JoGG.jpg) [imgur](http://i.imgur.com/g4vNQxf.jpg) [imgur](http://i.imgur.com/tNkOO37.jpg) 51.tv LG42PC3RA (plasma) dezmembrat : cauza dezmembrarii este urmatorul modul (c.i. STK795-820 defect) [imgur](http://i.imgur.com/usTWMhz.jpg) cadru cu picior + panel fata + capac spate + alte maruntaie. pret 70 lei + posta. [imgur](http://i.imgur.com/kpHifvE.jpg) [imgur](http://i.imgur.com/0N6HRkG.jpg) [imgur](http://i.imgur.com/jnjxuSD.jpg) [imgur](http://i.imgur.com/iYERD2s.jpg) [imgur](http://i.imgur.com/Ukm5BNZ.jpg) [imgur](http://i.imgur.com/DTOYs0E.jpg) [imgur](http://i.imgur.com/k8YAGLp.jpg) [imgur](http://i.imgur.com/LuLLahI.jpg) modul 1. pret 120 lei + posta. [imgur](http://i.imgur.com/rA0riwA.jpg) modul 2. pret 80 lei + posta. [imgur](http://i.imgur.com/lXYPm5U.jpg) modul 3. pret toate 3 buc. 80 lei + posta. [imgur](http://i.imgur.com/E4H1j3D.jpg) [imgur](http://i.imgur.com/cWoj5Pi.jpg) modul 4. pret 120 lei + posta. [imgur](http://i.imgur.com/W5fZzmW.jpg) [imgur](http://i.imgur.com/K1E9xC7.jpg) modul 5. pret 120 lei + posta. [imgur](http://i.imgur.com/fYCLp6p.jpg) [imgur](http://i.imgur.com/CKl4dB8.jpg) [imgur](http://i.imgur.com/3HCT9sY.jpg) panel plasma (ecran) pret 180 lei + posta. [imgur](http://i.imgur.com/SeVVJjW.jpg) [imgur](http://i.imgur.com/aAOGvub.jpg) [imgur](http://i.imgur.com/ekjGOMH.jpg) [imgur](http://i.imgur.com/FbBmBXJ.jpg) 52.sursa in comutatie (pentru sony play station) ,in:220v ; out:8,5v - 5,65A. pret 30 lei + posta. http://i.imgur.com/MThthnD.jpg http://i.imgur.com/Fm2Hn2B.jpg http://i.imgur.com/558A1Ow.jpg Link spre comentariu
rellu Postat Octombrie 22, 2014 Autor Partajează Postat Octombrie 22, 2014 Lista de mai sus valabila. UP Link spre comentariu
rellu Postat Octombrie 23, 2014 Autor Partajează Postat Octombrie 23, 2014 Lista de mai sus valabila. UP Link spre comentariu
