vand diverse electrice si electronice
rellu
Actualizare lista produse :1.radio - cd - casetofon marca schneider model SP225 perfect functional cu telecomanda. pret 150 lei negociabil + posta.pe partea de cd stie sa citeasca doar cd audio nu si mp3.[imgur](http://i.imgur.com/pCrdSAY.jpg)[imgur](http://i.imgur.com/fe9aJwT.jpg)2.un radiocasetofon marca universum.functioneaza f. bine (a avut trafo. pe 220v ars,i-am adaptat altul). pret 50 lei + posta.[imgur](http://i.imgur.com/WxLKhc2.jpg)[imgur](http://i.imgur.com/EcQC5EZ.jpg)3.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg)[imgur](http://i.imgur.com/k0Kfxmz.jpg)[imgur](http://i.imgur.com/deYEbv2.jpg)[imgur](http://i.imgur.com/YdFKBn7.jpg)4.un autotransformator. pret 150 lei + posta.[imgur](http://i.imgur.com/3Hg1OgC.jpg)[imgur](http://i.imgur.com/4YfJNyr.jpg)[imgur](http://i.imgur.com/8yREWkd.jpg)[imgur](http://i.imgur.com/ueueYpj.jpg)in ultima poza se vede pe ampermetru ca are si sarcina (un fier de calcat - 1000W).5.un modem Huawei E3765 ,decodat merge in orice retea(in poza se vede ca scrie pe el Vodafon). pret 45 lei + posta.[imgur](http://i.imgur.com/rfQju0z.jpg)[imgur](http://i.imgur.com/LgLzb98.jpg)6.un set de incarcatoare (priza 220v + priza auto). pret / set 12 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg)
7.sursa in comutatie +5v;+12v;-12v (sursa provine din ceva casa de marcat) pret 12 lei + posta.[imgur](http://i.imgur.com/KgYmviR.jpg)[imgur](http://i.imgur.com/u6Kb1qN.jpg)8.sursa in comutatie +5v;+35V (sursa provine din ceva imprimanta epson) pret 12 lei + posta.[imgur](http://i.imgur.com/4Q0d5ww.jpg)[imgur](http://i.imgur.com/EQRKEY1.jpg)9.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg)[imgur](http://i.imgur.com/5RX8qLB.jpg)10.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg)[imgur](http://i.imgur.com/xv4IwiW.jpg)11.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg)[imgur](http://i.imgur.com/HHG6TtO.jpg)12.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg)13.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg)14.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg)[imgur](http://i.imgur.com/2YoLZQX.jpg)[imgur](http://i.imgur.com/max1jVH.jpg)15.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg)[imgur](http://i.imgur.com/sJfvlE0.jpg)16.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg)[imgur](http://i.imgur.com/kJWupcB.jpg)17.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg)18.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg)[imgur](http://i.imgur.com/9bmAhmz.jpg)19.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg)[imgur](http://i.imgur.com/bENzley.jpg)
20.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg)[imgur](http://i.imgur.com/mgVcZHL.jpg)21. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg)22.sursa in comutatie in :220v c.a. / din semireglabil se poate modifica tens. de iesire intre :15 - 24 V c.c. /1A. pret 12 lei + posta.[imgur](http://i.imgur.com/dL5RIoQ.jpg)23.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg)[imgur](http://i.imgur.com/pvM0Ija.jpg)24.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg)
[imgur](http://i.imgur.com/IUAAbvG.jpg)25.receviere satelit (functionale) pt. carcasa. pret 15 lei/buc. + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg)[imgur](http://i.imgur.com/NGRnPwb.jpg)26.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg)
27.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta.
[imgur](http://i.imgur.com/1BsMxy3.jpg)
28.motoare pas cu pas. pret 14 lei toata gramada + posta.[imgur](http://i.imgur.com/GCgLv.jpg)[imgur](http://i.imgur.com/G5mzZ.jpg)29.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg)
30.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg)[imgur](http://i.imgur.com/OJ8Vqfe.jpg)31.transformator prindere pe cablaj:220v - 15v /12w. pret 14 lei.[imgur](http://i.imgur.com/MQ9DwAq.jpg)32.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta.
[imgur](http://i.imgur.com/oNCeaLC.jpg)
33.cablu nou vga cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta.
[imgur](http://i.imgur.com/lXepBUN.jpg)
34.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg)[imgur](http://i.imgur.com/ZmFtNhb.jpg)35.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg)36.unitate optica dvd (dvd-recorder). pret 25 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg)[imgur](http://i.imgur.com/7ZcTYGV.jpg)37.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta.[imgur](http://i.imgur.com/TOB4oix.jpg)[imgur](http://i.imgur.com/OLtHAbD.jpg)[imgur](http://i.imgur.com/WF2Coth.jpg)[imgur](http://i.imgur.com/Xu5CAKn.jpg)[imgur](http://i.imgur.com/vuA2uOc.jpg)[imgur](http://i.imgur.com/eQc0HTq.jpg)[imgur](http://i.imgur.com/I9TAwJT.jpg)[imgur](http://i.imgur.com/ePdN1Fj.jpg)[imgur](http://i.imgur.com/lJlV3xk.jpg)[imgur](http://i.imgur.com/3rPbomB.jpg)[imgur](http://i.imgur.com/D08Sp2l.jpg)[imgur](http://i.imgur.com/HME16wR.jpg)[imgur](http://i.imgur.com/mKTgWfI.jpg)[imgur](http://i.imgur.com/9JV9Rmn.jpg)[imgur](http://i.imgur.com/ckbiPF1.jpg)38.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg)[imgur](http://i.imgur.com/iSfJOUa.jpg)
39.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 35 lei + posta.
[imgur](http://i.imgur.com/J1wBe6u.jpg)
[imgur](http://i.imgur.com/xhM0tWI.jpg)
[imgur](http://i.imgur.com/UtGIdnO.jpg)
40.condensatori variabili recuperati .pret 6 lei / grup + posta.
[imgur](http://i.imgur.com/u2GBnVC.jpg)
41.husa tableta 10 "( 260x180x17 mm) noua. pret 25 lei + posta.
[imgur](http://i.imgur.com/gaNVfGr.jpg)
42.modul ecou cu integratul PT2399. pret 18 lei + posta.
[imgur](http://i.imgur.com/y8qXFci.jpg)
[imgur](http://i.imgur.com/Jdfmvsi.jpg)
43.switch ethernet (fara sursa de 12 V c.c.) pret 30 lei + posta.
[imgur](http://i.imgur.com/ajnC0VI.jpg)
[imgur](http://i.imgur.com/bsTZvTL.jpg)
44.telefon fix rds-rcs . pret 30 lei + posta.
[imgur](http://i.imgur.com/0mZfpqk.jpg)
[imgur](http://i.imgur.com/ZvLK3lk.jpg)
45.telefon fara fir KX-TG7321 pret 80 lei + posta.
[imgur](http://i.imgur.com/Kmujcs2.jpg)
[imgur](http://i.imgur.com/eFJNoVa.jpg)
[imgur](http://i.imgur.com/OoR4lLD.jpg)
46.motor c.c. 24V-0,4A-4200rpm   pret 6 lei + posta.
[imgur](http://i.imgur.com/bq5bYS6.jpg)
43.switch ethernet (fara sursa de 12 V c.c.) pret 25 lei + posta.
Actualizare lista produse :1.radio - cd - casetofon marca schneider model SP225 perfect functional cu telecomanda. pret 150 lei negociabil + posta.pe partea de cd stie sa citeasca doar cd audio nu si mp3.[imgur](http://i.imgur.com/pCrdSAY.jpg) [imgur](http://i.imgur.com/fe9aJwT.jpg) 2.un radiocasetofon marca universum.functioneaza f. bine (a avut trafo. pe 220v ars,i-am adaptat altul). pret 50 lei + posta.[imgur](http://i.imgur.com/WxLKhc2.jpg) [imgur](http://i.imgur.com/EcQC5EZ.jpg) 3.amplif. homemade (LA4445 2X6W). pret 29 lei + posta.[imgur](http://i.imgur.com/c5b4A8E.jpg) [imgur](http://i.imgur.com/k0Kfxmz.jpg) [imgur](http://i.imgur.com/deYEbv2.jpg) [imgur](http://i.imgur.com/YdFKBn7.jpg) 4.un autotransformator. pret 150 lei + posta.[imgur](http://i.imgur.com/3Hg1OgC.jpg) [imgur](http://i.imgur.com/4YfJNyr.jpg) [imgur](http://i.imgur.com/8yREWkd.jpg) [imgur](http://i.imgur.com/ueueYpj.jpg) in ultima poza se vede pe ampermetru ca are si sarcina (un fier de calcat - 1000W).5.un modem Huawei E3765 ,decodat merge in orice retea(in poza se vede ca scrie pe el Vodafon). pret 45 lei + posta.[imgur](http://i.imgur.com/rfQju0z.jpg) [imgur](http://i.imgur.com/LgLzb98.jpg) 6.un set de incarcatoare (priza 220v + priza auto). pret / set 12 lei + posta.[imgur](http://i.imgur.com/JEx4ooT.jpg) 7.sursa in comutatie +5v;+12v;-12v (sursa provine din ceva casa de marcat) pret 12 lei + posta.[imgur](http://i.imgur.com/KgYmviR.jpg) [imgur](http://i.imgur.com/u6Kb1qN.jpg) 8.sursa in comutatie +5v;+35V (sursa provine din ceva imprimanta epson) pret 12 lei + posta.[imgur](http://i.imgur.com/4Q0d5ww.jpg) [imgur](http://i.imgur.com/EQRKEY1.jpg) 9.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.[imgur](http://i.imgur.com/l91e4cK.jpg) [imgur](http://i.imgur.com/5RX8qLB.jpg) 10.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.[imgur](http://i.imgur.com/DbYTdfM.jpg) [imgur](http://i.imgur.com/xv4IwiW.jpg) 11.miniamplif homemade (TDA2822 2X1W). pret 14 lei + posta.[imgur](http://i.imgur.com/wDzJgzF.jpg) [imgur](http://i.imgur.com/HHG6TtO.jpg) 12.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.[imgur](http://i.imgur.com/mtlTIuY.jpg) 13.cooler+ventilator pt. procesor pret.20 lei + posta.[imgur](http://i.imgur.com/ix8gA.jpg) 14.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.[imgur](http://i.imgur.com/nM7Ifvw.jpg) [imgur](http://i.imgur.com/2YoLZQX.jpg) [imgur](http://i.imgur.com/max1jVH.jpg) 15.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.[imgur](http://i.imgur.com/HfBeWrc.jpg) [imgur](http://i.imgur.com/sJfvlE0.jpg) 16.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.[imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 17.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.[imgur](http://i.imgur.com/oD0eS.jpg) 18.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.[imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 19.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.[imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 20.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.[imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 21. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q2VTi1Q.jpg) 22.sursa in comutatie in :220v c.a. / din semireglabil se poate modifica tens. de iesire intre :15 - 24 V c.c. /1A. pret 12 lei + posta.[imgur](http://i.imgur.com/dL5RIoQ.jpg) 23.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.[imgur](http://i.imgur.com/tcjIPbl.jpg) [imgur](http://i.imgur.com/pvM0Ija.jpg) 24.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.[imgur](http://i.imgur.com/09mNFgR.jpg) [imgur](http://i.imgur.com/IUAAbvG.jpg) 25.receviere satelit (functionale) pt. carcasa. pret 15 lei/buc. + posta.[imgur](http://i.imgur.com/gopU9Jx.jpg) [imgur](http://i.imgur.com/NGRnPwb.jpg) 26.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.[imgur](http://i.imgur.com/Q6Mv7iU.jpg) 27.sursa 220Vc.a. / 12Vc.c. 1A pret 12 lei + posta.[imgur](http://i.imgur.com/1BsMxy3.jpg) 28.motoare pas cu pas. pret 14 lei toata gramada + posta.[imgur](http://i.imgur.com/GCgLv.jpg) [imgur](http://i.imgur.com/G5mzZ.jpg) 29.grup de microfoane si galene. pret 12 lei/grup + posta.[imgur](http://i.imgur.com/SLgKp3l.jpg) 30.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.[imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 31.transformator prindere pe cablaj:220v - 15v /12w. pret 14 lei.[imgur](http://i.imgur.com/MQ9DwAq.jpg) 32.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta.[imgur](http://i.imgur.com/oNCeaLC.jpg) 33.cablu nou vga cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta.[imgur](http://i.imgur.com/lXepBUN.jpg) 34.grup potentiometri diferite valori + butoane. pret 25 lei / grup + posta.[imgur](http://i.imgur.com/qdx43oQ.jpg) [imgur](http://i.imgur.com/ZmFtNhb.jpg) 35.grup de panglici diferite marimi. pret 15 lei / grup + posta.[imgur](http://i.imgur.com/PYL0AKj.jpg) 36.unitate optica dvd (dvd-recorder). pret 25 lei + posta.[imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 37.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta.[imgur](http://i.imgur.com/TOB4oix.jpg) [imgur](http://i.imgur.com/OLtHAbD.jpg) [imgur](http://i.imgur.com/WF2Coth.jpg) [imgur](http://i.imgur.com/Xu5CAKn.jpg) [imgur](http://i.imgur.com/vuA2uOc.jpg) [imgur](http://i.imgur.com/eQc0HTq.jpg) [imgur](http://i.imgur.com/I9TAwJT.jpg) [imgur](http://i.imgur.com/ePdN1Fj.jpg) [imgur](http://i.imgur.com/lJlV3xk.jpg) [imgur](http://i.imgur.com/3rPbomB.jpg) [imgur](http://i.imgur.com/D08Sp2l.jpg) [imgur](http://i.imgur.com/HME16wR.jpg) [imgur](http://i.imgur.com/mKTgWfI.jpg) [imgur](http://i.imgur.com/9JV9Rmn.jpg) [imgur](http://i.imgur.com/ckbiPF1.jpg) 38.mini radio AIWA AR-888 made in India. functioneaza perfect, pret 19 lei + posta.[imgur](http://i.imgur.com/FAylmeh.jpg) [imgur](http://i.imgur.com/iSfJOUa.jpg) 39.sursa clasica trf. + diode + condi. cu doua tensiuni c.c. 11v si 39v. a fost in ceva masina de scris electrica. pret 35 lei + posta.[imgur](http://i.imgur.com/J1wBe6u.jpg) [imgur](http://i.imgur.com/xhM0tWI.jpg) [imgur](http://i.imgur.com/UtGIdnO.jpg) 40.condensatori variabili recuperati .pret 6 lei / grup + posta.[imgur](http://i.imgur.com/u2GBnVC.jpg) 41.modul ecou cu integratul PT2399. pret 18 lei + posta.[imgur](http://i.imgur.com/y8qXFci.jpg) [imgur](http://i.imgur.com/Jdfmvsi.jpg) 42.switch ethernet (fara sursa de 12 V c.c.) pret 25 lei + posta.[imgur](http://i.imgur.com/ajnC0VI.jpg) [imgur](http://i.imgur.com/bsTZvTL.jpg) 43.telefon fix rds-rcs . pret 30 lei + posta.[imgur](http://i.imgur.com/0mZfpqk.jpg) [imgur](http://i.imgur.com/ZvLK3lk.jpg) 44.telefon fara fir KX-TG7321 pret 80 lei + posta.[imgur](http://i.imgur.com/Kmujcs2.jpg) [imgur](http://i.imgur.com/eFJNoVa.jpg) [imgur](http://i.imgur.com/OoR4lLD.jpg) 45.motor c.c. 24V-0,4A-4200rpm   pret 6 lei + posta.[imgur](http://i.imgur.com/bq5bYS6.jpg)
33.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta.
