rellu Postat August 2, 2022 Autor Partajează Postat August 2, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.sursa laptop 12v 12,5A ADP-150BB B . pret 90 lei + posta. https://imgur.com/gw4WAHC https://imgur.com/fO4Pavi https://imgur.com/7fLMWFQ 14.rama adaptoare radiocasetofon Fiat Brava. pret 40 lei + posta. https://imgur.com/gSAANc0 https://imgur.com/KzVGfiX Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat August 12, 2022 Autor Partajează Postat August 12, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.sursa laptop 12v 12,5A ADP-150BB B . pret 90 lei + posta. https://imgur.com/gw4WAHC https://imgur.com/fO4Pavi https://imgur.com/7fLMWFQ 14.rama adaptoare radiocasetofon Fiat Brava. pret 40 lei + posta. https://imgur.com/gSAANc0 https://imgur.com/KzVGfiX Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat August 25, 2022 Autor Partajează Postat August 25, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.sursa laptop 12v 12,5A ADP-150BB B . pret 90 lei + posta. https://imgur.com/gw4WAHC https://imgur.com/fO4Pavi https://imgur.com/7fLMWFQ 14.rama adaptoare radiocasetofon Fiat Brava. pret 40 lei + posta. https://imgur.com/gSAANc0 https://imgur.com/KzVGfiX Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Septembrie 5, 2022 Autor Partajează Postat Septembrie 5, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.sursa laptop 12v 12,5A ADP-150BB B . pret 90 lei + posta. https://imgur.com/gw4WAHC https://imgur.com/fO4Pavi https://imgur.com/7fLMWFQ 14.rama adaptoare radiocasetofon Fiat Brava. pret 40 lei + posta. https://imgur.com/gSAANc0 https://imgur.com/KzVGfiX Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Septembrie 13, 2022 Autor Partajează Postat Septembrie 13, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.sursa laptop 12v 12,5A ADP-150BB B . pret 90 lei + posta. https://imgur.com/gw4WAHC https://imgur.com/fO4Pavi https://imgur.com/7fLMWFQ 14.rama adaptoare radiocasetofon Fiat Brava. pret 40 lei + posta. https://imgur.com/gSAANc0 https://imgur.com/KzVGfiX 15.anvelopa de vara ecocontact 6 (aproape noi ; mai sunt 3 bucati). pret 200 lei/buc. + posta. https://imgur.com/MKKpufH https://imgur.com/9qtGPHU https://imgur.com/Tm3FNi2 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Septembrie 20, 2022 Autor Partajează Postat Septembrie 20, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.sursa laptop 12v 12,5A ADP-150BB B . pret 90 lei + posta. https://imgur.com/gw4WAHC https://imgur.com/fO4Pavi https://imgur.com/7fLMWFQ 14.rama adaptoare radiocasetofon Fiat Brava. pret 40 lei + posta. https://imgur.com/gSAANc0 https://imgur.com/KzVGfiX 15.anvelopa de vara ecocontact 6 (aproape noi ; mai sunt 3 bucati). pret 200 lei/buc. + posta. https://imgur.com/MKKpufH https://imgur.com/9qtGPHU https://imgur.com/Tm3FNi2 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Septembrie 22, 2022 Autor Partajează Postat Septembrie 22, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.sursa laptop 12v 12,5A ADP-150BB B . pret 90 lei + posta. https://imgur.com/gw4WAHC https://imgur.com/fO4Pavi https://imgur.com/7fLMWFQ 14.rama adaptoare radiocasetofon Fiat Brava. pret 40 lei + posta. https://imgur.com/gSAANc0 https://imgur.com/KzVGfiX 15.anvelopa de vara ecocontact 6 (aproape noi ; mai sunt 3 bucati). pret 200 lei/buc. + posta. https://imgur.com/MKKpufH https://imgur.com/9qtGPHU https://imgur.com/Tm3FNi2 16.memorie DDR4 laptop 4Gb la 3200 Mhz. pret 100 lei + posta. https://imgur.com/sxLvye5 https://imgur.com/nF8YUlw https://imgur.com/kId2At1 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Septembrie 28, 2022 Autor Partajează Postat Septembrie 28, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.sursa laptop 12v 12,5A ADP-150BB B . pret 90 lei + posta. https://imgur.com/gw4WAHC https://imgur.com/fO4Pavi https://imgur.com/7fLMWFQ 14.rama adaptoare radiocasetofon Fiat Brava. pret 40 lei + posta. https://imgur.com/gSAANc0 https://imgur.com/KzVGfiX 15.anvelopa de vara ecocontact 6 (aproape noi ; mai sunt 3 bucati). pret 200 lei/buc. + posta. https://imgur.com/MKKpufH https://imgur.com/9qtGPHU https://imgur.com/Tm3FNi2 16.memorie DDR4 laptop 4Gb la 3200 Mhz. pret 100 lei + posta. https://imgur.com/sxLvye5 https://imgur.com/nF8YUlw https://imgur.com/kId2At1 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Octombrie 2, 2022 Autor Partajează Postat Octombrie 2, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.sursa laptop 12v 12,5A ADP-150BB B . pret 90 lei + posta. https://imgur.com/gw4WAHC https://imgur.com/fO4Pavi https://imgur.com/7fLMWFQ 14.rama adaptoare radiocasetofon Fiat Brava. pret 40 lei + posta. https://imgur.com/gSAANc0 https://imgur.com/KzVGfiX 15.anvelopa de vara ecocontact 6 (aproape noi ; mai sunt 3 bucati). pret 200 lei/buc. + posta. https://imgur.com/MKKpufH https://imgur.com/9qtGPHU https://imgur.com/Tm3FNi2 16.memorie DDR4 laptop 4Gb la 3200 Mhz. pret 100 lei + posta. https://imgur.com/sxLvye5 https://imgur.com/nF8YUlw https://imgur.com/kId2At1 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Octombrie 8, 2022 Autor Partajează Postat Octombrie 8, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.sursa laptop 12v 12,5A ADP-150BB B . pret 90 lei + posta. https://imgur.com/gw4WAHC https://imgur.com/fO4Pavi https://imgur.com/7fLMWFQ 14.rama adaptoare radiocasetofon Fiat Brava. pret 40 lei + posta. https://imgur.com/gSAANc0 https://imgur.com/KzVGfiX 15.anvelopa de vara ecocontact 6 (aproape noi ; mai sunt 3 bucati). pret 200 lei/buc. + posta. https://imgur.com/MKKpufH https://imgur.com/9qtGPHU https://imgur.com/Tm3FNi2 16.memorie DDR4 laptop 4Gb la 3200 Mhz. pret 100 lei + posta. https://imgur.com/sxLvye5 https://imgur.com/nF8YUlw https://imgur.com/kId2At1 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
simson Postat Octombrie 8, 2022 Partajează Postat Octombrie 8, 2022 Din poz.6 m-ar interesa doar cel de 500 ohmi. Daca e posibil va rog un pret. Link spre comentariu
rellu Postat Octombrie 15, 2022 Autor Partajează Postat Octombrie 15, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.rama adaptoare radiocasetofon Fiat Brava. pret 40 lei + posta. https://imgur.com/gSAANc0 https://imgur.com/KzVGfiX 14.anvelopa de vara ecocontact 6 (aproape noi ; mai sunt 3 bucati). pret 200 lei/buc. + posta. https://imgur.com/MKKpufH https://imgur.com/9qtGPHU https://imgur.com/Tm3FNi2 15.memorie DDR4 laptop 4Gb la 3200 Mhz. pret 100 lei + posta. https://imgur.com/sxLvye5 https://imgur.com/nF8YUlw https://imgur.com/kId2At1 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Octombrie 17, 2022 Autor Partajează Postat Octombrie 17, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.rama adaptoare radiocasetofon Fiat Brava. pret 40 lei + posta. https://imgur.com/gSAANc0 https://imgur.com/KzVGfiX 14.anvelopa de vara ecocontact 6 (aproape noi ; mai sunt 3 bucati). pret 200 lei/buc. + posta. https://imgur.com/MKKpufH https://imgur.com/9qtGPHU https://imgur.com/Tm3FNi2 15.memorie DDR4 laptop 4Gb la 3200 Mhz. pret 100 lei + posta. https://imgur.com/sxLvye5 https://imgur.com/nF8YUlw https://imgur.com/kId2At1 16.ssd nvme 256Gb . pret 150 lei + posta. https://imgur.com/NMn1ZrR Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Octombrie 23, 2022 Autor Partajează Postat Octombrie 23, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.rama adaptoare radiocasetofon Fiat Brava. pret 40 lei + posta. https://imgur.com/gSAANc0 https://imgur.com/KzVGfiX 14.anvelopa de vara ecocontact 6 (aproape noi ; mai sunt 3 bucati). pret 200 lei/buc. + posta. https://imgur.com/MKKpufH https://imgur.com/9qtGPHU https://imgur.com/Tm3FNi2 15.memorie DDR4 laptop 4Gb la 3200 Mhz. pret 100 lei + posta. https://imgur.com/sxLvye5 https://imgur.com/nF8YUlw https://imgur.com/kId2At1 16.ssd nvme 256Gb . pret 150 lei + posta. https://imgur.com/NMn1ZrR 17.ssd sata 3 crucial 240Gb. pret 140 lei + posta. https://imgur.com/8vj2uTr https://imgur.com/VGpxYuK Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Octombrie 30, 2022 Autor Partajează Postat Octombrie 30, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.rama adaptoare radiocasetofon Fiat Brava. pret 40 lei + posta. https://imgur.com/gSAANc0 https://imgur.com/KzVGfiX 14.anvelopa de vara ecocontact 6 (aproape noi ; mai sunt 3 bucati). pret 200 lei/buc. + posta. https://imgur.com/MKKpufH https://imgur.com/9qtGPHU https://imgur.com/Tm3FNi2 15.memorie DDR4 laptop 4Gb la 3200 Mhz. pret 100 lei + posta. https://imgur.com/sxLvye5 https://imgur.com/nF8YUlw https://imgur.com/kId2At1 16.ssd nvme 256Gb . pret 150 lei + posta. https://imgur.com/NMn1ZrR 17.ssd sata 3 crucial 240Gb. pret 140 lei + posta. https://imgur.com/8vj2uTr https://imgur.com/VGpxYuK Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
