rellu Postat Martie 18, 2022 Autor Partajează Postat Martie 18, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.hdd wd 640 Gb sata II. pret 50 lei + posta. https://imgur.com/FaNmdA6 https://imgur.com/UTiT30S https://imgur.com/XNTdCoP 12.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 13.sursa pc corsair cx500 100 lei + posta. https://imgur.com/yxcA8jR https://imgur.com/3w4T2IO https://imgur.com/ZZIv7Rd 14.sursa pc semimodulara cooler master 650wati 160 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 15.sursa pc modulara corsair hx1200 (Atentie!! doar sursa fara cabluri) 600 lei + posta. https://imgur.com/H5CGeb0 https://imgur.com/edx5gy2 https://imgur.com/MSN2YGt https://imgur.com/UpdRoh3 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Martie 20, 2022 Autor Partajează Postat Martie 20, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc corsair cx500 100 lei + posta. https://imgur.com/yxcA8jR https://imgur.com/3w4T2IO https://imgur.com/ZZIv7Rd 13.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 14.sursa pc modulara corsair hx1200 (Atentie!! doar sursa fara cabluri) 600 lei + posta. https://imgur.com/H5CGeb0 https://imgur.com/edx5gy2 https://imgur.com/MSN2YGt https://imgur.com/UpdRoh3 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Martie 23, 2022 Autor Partajează Postat Martie 23, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc corsair cx500 100 lei + posta. https://imgur.com/yxcA8jR https://imgur.com/3w4T2IO https://imgur.com/ZZIv7Rd 13.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 14.sursa pc modulara corsair hx1200 (Atentie!! doar sursa fara cabluri) 600 lei + posta. https://imgur.com/H5CGeb0 https://imgur.com/edx5gy2 https://imgur.com/MSN2YGt https://imgur.com/UpdRoh3 Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Martie 25, 2022 Autor Partajează Postat Martie 25, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc corsair cx500 100 lei + posta. https://imgur.com/yxcA8jR https://imgur.com/3w4T2IO https://imgur.com/ZZIv7Rd 13.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Martie 30, 2022 Autor Partajează Postat Martie 30, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Aprilie 3, 2022 Autor Partajează Postat Aprilie 3, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Aprilie 5, 2022 Autor Partajează Postat Aprilie 5, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.sursa laptop 12v 12,5A ADP-150BB B . pret 90 lei + posta. https://imgur.com/gw4WAHC https://imgur.com/fO4Pavi https://imgur.com/7fLMWFQ Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Aprilie 7, 2022 Autor Partajează Postat Aprilie 7, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.sursa laptop 12v 12,5A ADP-150BB B . pret 90 lei + posta. https://imgur.com/gw4WAHC https://imgur.com/fO4Pavi https://imgur.com/7fLMWFQ 14.amplificator antena auto (sunt 2 modele) pret 35 lei/buc. + posta. https://imgur.com/dz5YQmj https://imgur.com/3y8OJYM https://imgur.com/w2TKc8i https://imgur.com/PoOZAzP Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Aprilie 10, 2022 Autor Partajează Postat Aprilie 10, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.sursa laptop 12v 12,5A ADP-150BB B . pret 90 lei + posta. https://imgur.com/gw4WAHC https://imgur.com/fO4Pavi https://imgur.com/7fLMWFQ 14.amplificator antena auto (sunt 2 modele) pret 35 lei/buc. + posta. https://imgur.com/dz5YQmj https://imgur.com/3y8OJYM https://imgur.com/w2TKc8i https://imgur.com/PoOZAzP Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Aprilie 13, 2022 Autor Partajează Postat Aprilie 13, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.sursa laptop 12v 12,5A ADP-150BB B . pret 90 lei + posta. https://imgur.com/gw4WAHC https://imgur.com/fO4Pavi https://imgur.com/7fLMWFQ 14.amplificator antena auto (sunt 2 modele) pret 35 lei/buc. + posta. https://imgur.com/dz5YQmj https://imgur.com/3y8OJYM https://imgur.com/w2TKc8i https://imgur.com/PoOZAzP 15.radio auto logan,duster : mp3 ; bluetooth . pret 300lei + posta. https://imgur.com/9S4GwPo Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Aprilie 17, 2022 Autor Partajează Postat Aprilie 17, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.sursa laptop 12v 12,5A ADP-150BB B . pret 90 lei + posta. https://imgur.com/gw4WAHC https://imgur.com/fO4Pavi https://imgur.com/7fLMWFQ 14.amplificator antena auto (sunt 2 modele) pret 35 lei/buc. + posta. https://imgur.com/dz5YQmj https://imgur.com/3y8OJYM https://imgur.com/w2TKc8i https://imgur.com/PoOZAzP 15.radio auto logan,duster : mp3 ; bluetooth . pret 300lei + posta. https://imgur.com/9S4GwPo Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Aprilie 21, 2022 Autor Partajează Postat Aprilie 21, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.sursa laptop 12v 12,5A ADP-150BB B . pret 90 lei + posta. https://imgur.com/gw4WAHC https://imgur.com/fO4Pavi https://imgur.com/7fLMWFQ 14.amplificator antena auto (sunt 2 modele) pret 35 lei/buc. + posta. https://imgur.com/dz5YQmj https://imgur.com/3y8OJYM https://imgur.com/w2TKc8i https://imgur.com/PoOZAzP 15.radio auto logan,duster : mp3 ; bluetooth . pret 300lei + posta. https://imgur.com/9S4GwPo Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Aprilie 26, 2022 Autor Partajează Postat Aprilie 26, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.sursa laptop 12v 12,5A ADP-150BB B . pret 90 lei + posta. https://imgur.com/gw4WAHC https://imgur.com/fO4Pavi https://imgur.com/7fLMWFQ 14.amplificator antena auto (sunt 2 modele) pret 35 lei/buc. + posta. https://imgur.com/dz5YQmj https://imgur.com/3y8OJYM https://imgur.com/w2TKc8i https://imgur.com/PoOZAzP 15.radio auto logan,duster : mp3 ; bluetooth . pret 300lei + posta. https://imgur.com/9S4GwPo Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Aprilie 30, 2022 Autor Partajează Postat Aprilie 30, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.sursa laptop 12v 12,5A ADP-150BB B . pret 90 lei + posta. https://imgur.com/gw4WAHC https://imgur.com/fO4Pavi https://imgur.com/7fLMWFQ 14.amplificator antena auto (sunt 2 modele) pret 35 lei/buc. + posta. https://imgur.com/dz5YQmj https://imgur.com/3y8OJYM https://imgur.com/w2TKc8i https://imgur.com/PoOZAzP 15.radio auto logan,duster : mp3 ; bluetooth . pret 300lei + posta. https://imgur.com/9S4GwPo Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
rellu Postat Mai 2, 2022 Autor Partajează Postat Mai 2, 2022 1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta. [imgur](http://i.imgur.com/yIxmzmC.jpg) [imgur](http://i.imgur.com/kJWupcB.jpg) 2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta. [imgur](http://i.imgur.com/u8qQ0dN.jpg) [imgur](http://i.imgur.com/9bmAhmz.jpg) 3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta. [imgur](http://i.imgur.com/lHhoFg1.jpg) [imgur](http://i.imgur.com/bENzley.jpg) 4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz. [imgur](http://i.imgur.com/rZhpDdi.jpg) [imgur](http://i.imgur.com/mgVcZHL.jpg) 5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta. [imgur](http://i.imgur.com/gopU9Jx.jpg) 6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta. [imgur](http://i.imgur.com/vIKFhgQ.jpg) [imgur](http://i.imgur.com/OJ8Vqfe.jpg) 7.placa electronica de la cuptor cu microunde pret 15 lei + posta. http://i.imgur.com/zYtD8lh.jpg http://i.imgur.com/97FEYSw.jpg http://i.imgur.com/4Sx4GqJ.jpg 8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta. http://i.imgur.com/GGhweL0.jpg http://i.imgur.com/GZ8nm4i.jpg 9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta. http://i.imgur.com/kpI04aU.jpg 10.potentiometru de 3W 100 ohm. pret 10 lei + posta. http://i.imgur.com/FU4l33Z.jpg http://i.imgur.com/wgk0AiK.jpg 11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta. http://i.imgur.com/8CRmOOY.jpg 12.miliampermetru 300uA. pret 10 lei + posta. http://i.imgur.com/GsO33A7.jpg http://i.imgur.com/dDr7fEg.jpg 13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta. http://imgur.com/l9XYD1U http://imgur.com/HBSIY1y 14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta. http://imgur.com/Pe2a7sZ 15.sursa in comutatie ricoh. pret 15 lei + posta. http://imgur.com/i3UL1rf 16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta. http://imgur.com/c4l6QJm http://imgur.com/JnHF3Mq 17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta. input : 240v out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A http://imgur.com/5QLw6qx http://imgur.com/ZYTZrWe http://imgur.com/p802IGU http://imgur.com/b4RKXKe 18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta. dif.1 https://imgur.com/EFMFjlc ; https://imgur.com/DGh4KqK dif.2 https://imgur.com/MKeUVoQ ; https://imgur.com/VbAnMu9 dif3. https://imgur.com/Dnj9gWl ; https://imgur.com/QJb9q2x dif4. toate 4 buc. la 10 lei + posta. https://imgur.com/ext6gui https://imgur.com/NufOVtN https://imgur.com/qF3TxM3 19.piese diverse : 1.punte redresoare 1PM4 pret 0,25 lei/buc. https://imgur.com/TPdefmo 2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc. https://imgur.com/vgW9yku 3.tiristor T3F2 pret 1 leu/buc. https://imgur.com/RcCOaLV 21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.) https://imgur.com/C1efSzO https://imgur.com/AFsBiS5 https://imgur.com/5MSKzwA Componente IT : 1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta. [imgur](http://i.imgur.com/lXepBUN.jpg) 2.unitate optica dvd (dvd-recorder). pret 15 lei + posta. [imgur](http://i.imgur.com/o3wSwQC.jpg) [imgur](http://i.imgur.com/7ZcTYGV.jpg) 3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta. http://imgur.com/uO080t3 4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta. https://imgur.com/cFAT20r https://imgur.com/nE5kRBd 5.sursa pc dell 210w . pret 30 lei + posta. https://imgur.com/Zg5wzzJ https://imgur.com/2CJjRZ5 https://imgur.com/dCqd5cC 6.display 15 inch + placa +invertor. pret 25 lei + posta. https://imgur.com/HMe021d https://imgur.com/abwPKO5 https://imgur.com/wFibnKE https://imgur.com/Af2ZDTI https://imgur.com/eBegWDV 7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta. https://imgur.com/bhM2mLc https://imgur.com/tXtxJJ8 8.procesor i3-540 socket 1156. pret 25 lei + posta. https://imgur.com/gKike0w 9.separator galvanic pentru semnal tv. pret 25 lei + posta. https://imgur.com/jWFsbCy https://imgur.com/t5ab7wi 10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta. https://imgur.com/yoWzM9k https://imgur.com/PY2CGLI https://imgur.com/lgADZKh 11.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta. https://imgur.com/l4RdjWy https://imgur.com/Hpqnp86 12.sursa pc semimodulara cooler master 650wati 150 lei + posta. https://imgur.com/AN57W2x https://imgur.com/VSQ1odj https://imgur.com/iZQ4meD https://imgur.com/pMOJMnu 13.sursa laptop 12v 12,5A ADP-150BB B . pret 90 lei + posta. https://imgur.com/gw4WAHC https://imgur.com/fO4Pavi https://imgur.com/7fLMWFQ 14.amplificator antena auto (sunt 2 modele) pret 35 lei/buc. + posta. https://imgur.com/dz5YQmj https://imgur.com/3y8OJYM https://imgur.com/w2TKc8i https://imgur.com/PoOZAzP 15.radio auto logan,duster : mp3 ; bluetooth . pret 300lei + posta. https://imgur.com/9S4GwPo https://imgur.com/xWhOdXU https://imgur.com/h8mF8H6 https://imgur.com/OOiqAW0 16.microfon+cablaj duster,sandero,logan pret 60 lei + posta. https://imgur.com/LX1OV9J https://imgur.com/WhnTMa1 https://imgur.com/7O39efQ https://imgur.com/7O39efQ 17.adaptor mufa antena auto Fakra. pret 45 lei + posta. https://imgur.com/MyFe4xu 18.mufe adaptoare dacia logan,duster,sandero. pret 50 lei + posta. https://imgur.com/zmuPcQk https://imgur.com/75inx9A 19.rama adaptoare radiocasetofon Fiat Brava. pret 40 lei + posta. https://imgur.com/gSAANc0 https://imgur.com/KzVGfiX Produsele din ultimul topic sunt valabile. Cine face plata in cont transportul cu Posta Romana este gratis. Link spre comentariu
