vand diverse electrice si electronice
rellu
1.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.
[imgur](http://i.imgur.com/yIxmzmC.jpg)
[imgur](http://i.imgur.com/kJWupcB.jpg)
2.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.
[imgur](http://i.imgur.com/u8qQ0dN.jpg)
[imgur](http://i.imgur.com/9bmAhmz.jpg)
3.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.
[imgur](http://i.imgur.com/lHhoFg1.jpg)
[imgur](http://i.imgur.com/bENzley.jpg)
4.radio cu ceas Fugison pret 18 lei + posta.Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.
[imgur](http://i.imgur.com/rZhpDdi.jpg)
[imgur](http://i.imgur.com/mgVcZHL.jpg)
5.recevier satelit (functional) pt. carcasa. pret 15 lei + posta.
[imgur](http://i.imgur.com/gopU9Jx.jpg)
6.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 35 lei + posta.
[imgur](http://i.imgur.com/vIKFhgQ.jpg)
[imgur](http://i.imgur.com/OJ8Vqfe.jpg)
7.placa electronica de la cuptor cu microunde pret 15 lei + posta.
http://i.imgur.com/zYtD8lh.jpg
http://i.imgur.com/97FEYSw.jpg
http://i.imgur.com/4Sx4GqJ.jpg
8.relee de la dacia solenza ,ambele la pretul de 15 lei + posta.
http://i.imgur.com/GGhweL0.jpg
http://i.imgur.com/GZ8nm4i.jpg
9.acumulator (SP3676B1A 7000mA/h) tableta samsung tab2 P5110 (10.1 inch) pret 40 lei + posta.
http://i.imgur.com/kpI04aU.jpg
10.potentiometru de 3W 100 ohm. pret 10 lei + posta.
http://i.imgur.com/FU4l33Z.jpg
http://i.imgur.com/wgk0AiK.jpg
11.trafo. 230v / 25 v (dimensiuni mici) pret 10 lei + posta.
http://i.imgur.com/8CRmOOY.jpg
12.miliampermetru 300uA. pret 10 lei + posta.
http://i.imgur.com/GsO33A7.jpg
http://i.imgur.com/dDr7fEg.jpg
13.releu cu bobina la 24v made poland. 2buc. 8 lei + posta.
http://imgur.com/l9XYD1U
http://imgur.com/HBSIY1y
14.telecomanda noua 5Y29 (tv Ivory) 8 lei + posta.
http://imgur.com/Pe2a7sZ
15.sursa in comutatie ricoh. pret 15 lei + posta.
http://imgur.com/i3UL1rf
16.o pereche difuzoare skyworth 5w;16 ohm. pret 15 lei + posta.
http://imgur.com/c4l6QJm
http://imgur.com/JnHF3Mq
17.sursa xerox model : DPS-274AB-2A (105K25302) in perfecta stare de functionare. pret 50 lei + posta.
input : 240v
out : 5,15v/1,2A ;24v/5,5A ;5,1v/5,7A ;12v/1,5A ;5,1v/4,9A ;24,5v/3,5A ;12v/0,5A
http://imgur.com/5QLw6qx
http://imgur.com/ZYTZrWe
http://imgur.com/p802IGU
http://imgur.com/b4RKXKe
18.difuzoare recuperate din tv lcd. pret 10 lei perechea + posta.
dif.1  https://imgur.com/EFMFjlc   ;  https://imgur.com/DGh4KqK
dif.2  https://imgur.com/MKeUVoQ   ;  https://imgur.com/VbAnMu9
dif3.  https://imgur.com/Dnj9gWl  ;  https://imgur.com/QJb9q2x
dif4. toate 4 buc. la 10 lei + posta.
https://imgur.com/ext6gui
https://imgur.com/NufOVtN
https://imgur.com/qF3TxM3
19.piese diverse :
1.punte redresoare 1PM4 pret 0,25 lei/buc.
https://imgur.com/TPdefmo
2.dioda zener 2N3020B (10V;25mA;1W) pret 0,15 lei/buc.
https://imgur.com/vgW9yku
3.tiristor T3F2 pret 1 leu/buc.
https://imgur.com/RcCOaLV
21.releu cu bobina la 12 v c.c.; 2 contacte. pret 2,5 lei/buc. + posta. (stoc 10 buc.)
https://imgur.com/C1efSzO
https://imgur.com/AFsBiS5
https://imgur.com/5MSKzwA
Componente IT :
1.cablu nou serial cu dispunerea pinilor pe 2 randuri. pret 10 lei + posta.
[imgur](http://i.imgur.com/lXepBUN.jpg)
2.unitate optica dvd (dvd-recorder). pret 15 lei + posta.
[imgur](http://i.imgur.com/o3wSwQC.jpg)
[imgur](http://i.imgur.com/7ZcTYGV.jpg)
3.procesor amd semprom 3400+ :SDA3400IAA3CW. pret 10 lei + posta.
http://imgur.com/uO080t3
4.procesor amd sempron 64 LE-1150 socket AM2. pret 10 lei + posta.
https://imgur.com/cFAT20r
https://imgur.com/nE5kRBd
5.sursa pc dell 210w . pret 30 lei + posta.
https://imgur.com/Zg5wzzJ
https://imgur.com/2CJjRZ5
https://imgur.com/dCqd5cC
6.display 15 inch + placa +invertor. pret 25 lei + posta.
https://imgur.com/HMe021d
https://imgur.com/abwPKO5
https://imgur.com/wFibnKE
https://imgur.com/Af2ZDTI
https://imgur.com/eBegWDV
7.soclu sigurante cu prindere pe cablaj, toate 7 buc. la 10 lei + posta.
https://imgur.com/bhM2mLc
https://imgur.com/tXtxJJ8
8.procesor i3-540 socket 1156. pret 25 lei  + posta.
https://imgur.com/gKike0w
9.separator galvanic pentru semnal tv. pret 25 lei + posta.
https://imgur.com/jWFsbCy
https://imgur.com/t5ab7wi
10.placa pci-e adaptor de la sata la esata asmedia asm1061. pret 80 lei + posta.
https://imgur.com/yoWzM9k
https://imgur.com/PY2CGLI
https://imgur.com/lgADZKh
11.hdd wd 640 Gb sata II. pret 50 lei + posta.
https://imgur.com/FaNmdA6
https://imgur.com/UTiT30S
https://imgur.com/XNTdCoP
12.modul securitate TPM pentru placi de baza Asus. pret 150 lei + posta.
https://imgur.com/l4RdjWy
https://imgur.com/Hpqnp86
Produsele din ultimul topic sunt valabile.
Cine face plata in cont transportul cu Posta Romana este gratis.
input : 240v
19.piese diverse :
Componente IT :
input : 240v
19.piese diverse :
Componente IT :
input : 240v
19.piese diverse :
Componente IT :
input : 240v
19.piese diverse :
Componente IT :
input : 240v
19.piese diverse :
Componente IT :
input : 240v
19.piese diverse :
Componente IT :
input : 240v
19.piese diverse :
Componente IT :
input : 240v
19.piese diverse :
Componente IT :
input : 240v
19.piese diverse :
Componente IT :
input : 240v
19.piese diverse :
Componente IT :
input : 240v
19.piese diverse :
Componente IT :
input : 240v
19.piese diverse :
Componente IT :
input : 240v
19.piese diverse :
Componente IT :
13.sursa pc corsair cx500 100 lei + posta.
https://imgur.com/yxcA8jR
https://imgur.com/3w4T2IO
https://imgur.com/ZZIv7Rd
input : 240v
19.piese diverse :
Componente IT :
14.sursa pc semimodulara cooler master 650wati 160 lei + posta.
https://imgur.com/AN57W2x
https://imgur.com/VSQ1odj
https://imgur.com/iZQ4meD
https://imgur.com/pMOJMnu
15.sursa pc modulara corsair hx1200 (Atentie!! doar sursa fara cabluri) 650 lei + posta.
https://imgur.com/H5CGeb0
https://imgur.com/edx5gy2
https://imgur.com/MSN2YGt
https://imgur.com/UpdRoh3
