vand diverse electrice si electronice
rellu
Actualizare lista produse :
1.radio - cd - casetofon marca schneider model SP225 perfect functional cu telecomanda. pret 150 lei + posta.
[imgur](http://i.imgur.com/pCrdSAY.jpg)
[imgur](http://i.imgur.com/fe9aJwT.jpg)
2.un radiocasetofon marca universum.functioneaza f. bine (a avut trafo. pe 220v ars,i-am adaptat altul). pret 50 lei + posta.
[imgur](http://i.imgur.com/WxLKhc2.jpg)
[imgur](http://i.imgur.com/EcQC5EZ.jpg)
3.radio casetofon auto (grundig AD182H2 - fiat brava) modificat ,si anume s-a renuntat la partea de cass. iar in usita de caseta a intrat un cititor cu telecomanda, de cardSD + memorie stick usb. tot odata s-au schimbat si ledurile smd de backlight (rosu). arata super si functioneaza de nota 10.
pret 150lei + posta.
[imgur](http://i.imgur.com/zOvRFzb.jpg)
[imgur](http://i.imgur.com/Se5vVh6.jpg)
[imgur](http://i.imgur.com/DGR8ij8.jpg)
4.un autotransformator. pret 150 lei + posta.
[imgur](http://i.imgur.com/3Hg1OgC.jpg)
[imgur](http://i.imgur.com/4YfJNyr.jpg)
[imgur](http://i.imgur.com/8yREWkd.jpg)
[imgur](http://i.imgur.com/ueueYpj.jpg)
in ultima poza se vede pe ampermetru ca are si sarcina (un fier de calcat - 1000W).
5.sursa in comutatie +5v;+12v;-12v (sursa provine din ceva casa de marcat) pret 12 lei + posta.
[imgur](http://i.imgur.com/KgYmviR.jpg)
[imgur](http://i.imgur.com/u6Kb1qN.jpg)
6.sursa in comutatie +5v;+35V (sursa provine din ceva imprimanta epson) pret 12 lei + posta.
[imgur](http://i.imgur.com/4Q0d5ww.jpg)
[imgur](http://i.imgur.com/EQRKEY1.jpg)
7.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.
[imgur](http://i.imgur.com/l91e4cK.jpg)
[imgur](http://i.imgur.com/5RX8qLB.jpg)
8.o cutie metalica pt. diverse montaje : 30cm x 22cm x 6,5cm . pret 35 lei + posta.
[imgur](http://i.imgur.com/o9UFyJV.jpg)
[imgur](http://i.imgur.com/Xmc66Gw.jpg)
[imgur](http://i.imgur.com/TTwp2G3.jpg)
[imgur](http://i.imgur.com/jSDKMbd.jpg)
9.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.
[imgur](http://i.imgur.com/DbYTdfM.jpg)
[imgur](http://i.imgur.com/xv4IwiW.jpg)
10.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.
[imgur](http://i.imgur.com/mtlTIuY.jpg)
11.cooler+ventilator pt. procesor pret.20 lei + posta.
[imgur](http://i.imgur.com/ix8gA.jpg)
12.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.
[imgur](http://i.imgur.com/nM7Ifvw.jpg)
[imgur](http://i.imgur.com/2YoLZQX.jpg)
[imgur](http://i.imgur.com/max1jVH.jpg)
13.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.
[imgur](http://i.imgur.com/HfBeWrc.jpg)
[imgur](http://i.imgur.com/sJfvlE0.jpg)
14.un modul audio (nu stiu starea lui dar se vede si in poze ca nu-s lipituri de reparatii pe el).pret 11 lei + posta.
[imgur](http://i.imgur.com/rJ8qQnK.jpg)
[imgur](http://i.imgur.com/sUEU8YK.jpg)
[imgur](http://i.imgur.com/TrQ8cqU.jpg)
[imgur](http://i.imgur.com/qybmhFX.jpg)
15.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.
[imgur](http://i.imgur.com/yIxmzmC.jpg)
[imgur](http://i.imgur.com/kJWupcB.jpg)
16.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 40 lei + posta.
[imgur](http://i.imgur.com/oD0eS.jpg)
17.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.
[imgur](http://i.imgur.com/u8qQ0dN.jpg)
[imgur](http://i.imgur.com/9bmAhmz.jpg)
18.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.
[imgur](http://i.imgur.com/lHhoFg1.jpg)
[imgur](http://i.imgur.com/bENzley.jpg)
19.releie cu bobina la 3 v/cc (anclansarea/declansarea se face prin inversarea polaritatii). pret 8 lei toate cele 6 buc. + posta.
[imgur](http://i.imgur.com/kDsxS.jpg)
20.ceas cu PIC16F628 + LCD albastru (schema si hex sunt luate de pe internet). pret 30 lei + posta.
[imgur](http://i.imgur.com/WTHyLcz.jpg)
[imgur](http://i.imgur.com/o3B2obh.jpg)
21.radio cu ceas Fugison pret 18 lei + posta.
Atentie pe partea de FM trebuie "tras" din bobine inapoi pe 88 - 108 Mhz.
[imgur](http://i.imgur.com/rZhpDdi.jpg)
[imgur](http://i.imgur.com/mgVcZHL.jpg)
22. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.
[imgur](http://i.imgur.com/Q2VTi1Q.jpg)
23.sursa in comutatie in :220v c.a. / din semireglabil se poate modifica tens. de iesire intre :15 - 24 V c.c. /1A. pret 12 lei + posta.
[imgur](http://i.imgur.com/dL5RIoQ.jpg)
24.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.
[imgur](http://i.imgur.com/tcjIPbl.jpg)
[imgur](http://i.imgur.com/pvM0Ija.jpg)
25.o ramasita dintr-un osciloscop medical (TK spart). pret 12 lei + posta.
[imgur](http://i.imgur.com/mskTevy.jpg)
[imgur](http://i.imgur.com/CdJaM9d.jpg)
[imgur](http://i.imgur.com/0oyE84d.jpg)
[imgur](http://i.imgur.com/RZyqkVd.jpg)
26.montaj pt. verificat C.I. logice seria CDB.... pret 15 lei + posta.
[imgur](http://i.imgur.com/gmnf9sx.jpg)
[imgur](http://i.imgur.com/7diuvvV.jpg)
[imgur](http://i.imgur.com/HvB6ifx.jpg)
27.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta.
[imgur](http://i.imgur.com/TOB4oix.jpg)
[imgur](http://i.imgur.com/OLtHAbD.jpg)
[imgur](http://i.imgur.com/WF2Coth.jpg)
[imgur](http://i.imgur.com/Xu5CAKn.jpg)
[imgur](http://i.imgur.com/vuA2uOc.jpg)
[imgur](http://i.imgur.com/eQc0HTq.jpg)
[imgur](http://i.imgur.com/I9TAwJT.jpg)
[imgur](http://i.imgur.com/ePdN1Fj.jpg)
[imgur](http://i.imgur.com/lJlV3xk.jpg)
[imgur](http://i.imgur.com/3rPbomB.jpg)
[imgur](http://i.imgur.com/D08Sp2l.jpg)
[imgur](http://i.imgur.com/HME16wR.jpg)
[imgur](http://i.imgur.com/mKTgWfI.jpg)
[imgur](http://i.imgur.com/9JV9Rmn.jpg)
[imgur](http://i.imgur.com/ckbiPF1.jpg)
28.mixer audio Realistic. pret 30 lei + posta.
[imgur](http://i.imgur.com/BXP38Va.jpg)
[imgur](http://i.imgur.com/dasi6pB.jpg)
29.o placa descomplectata de amplif. de putere (2buc. STK442-530). pret 40 lei + posta.
[imgur](http://i.imgur.com/xv44rhU.jpg)
[imgur](http://i.imgur.com/WhMU9bD.jpg)
[imgur](http://i.imgur.com/5B4FXCR.jpg)
[imgur](http://i.imgur.com/LQpJpPG.jpg)
25.incarcator telefoane la 220v / 5v - 500mA + incarcator telefoane la priza auto cu 2 usb 5v - 1A. pret 15 lei / set + posta.
[imgur](http://i.imgur.com/6BJSquT.jpg)
26.o ramasita dintr-un osciloscop medical (TK spart). pret 12 lei + posta.
27.montaj pt. verificat C.I. logice seria CDB.... pret 15 lei + posta.
28.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta.
29.mixer audio Realistic. pret 30 lei + posta.
30.o placa descomplectata de amplif. de putere (2buc. STK442-530). pret 40 lei + posta.
25.transformatoare din tv pe lampi ,ambele la pretul de 14 lei + posta.
[imgur](http://i.imgur.com/sKr7jIL.jpg)
26.receviere satelit (functionale) pt. carcasa. pret 15 lei/buc. + posta.
[imgur](http://i.imgur.com/gopU9Jx.jpg)
[imgur](http://i.imgur.com/NGRnPwb.jpg)
27.incarcator telefoane la 220v / 5v - 500mA + incarcator telefoane la priza auto cu 2 usb 5v - 1A. pret 15 lei / set + posta.
28.o ramasita dintr-un osciloscop medical (TK spart). pret 12 lei + posta.
29.montaj pt. verificat C.I. logice seria CDB.... pret 15 lei + posta.
30.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta.
31.mixer audio Realistic. pret 30 lei + posta.
32.o placa descomplectata de amplif. de putere (2buc. STK442-530). pret 40 lei + posta.
au plecat spre userul radu42. :aplauze
27.un miniamplif. homemade 2.1(TDA7375) pret 20 lei + posta.
[imgur](http://i.imgur.com/nRY6ufk.jpg)
[imgur](http://i.imgur.com/64ROufR.jpg)
[imgur](http://i.imgur.com/14YwbhM.jpg)
28.montaj pt. verificat C.I. logice seria CDB.... pret 15 lei + posta.
29.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta.
30.mixer audio Realistic. pret 30 lei + posta.
31.o placa descomplectata de amplif. de putere (2buc. STK442-530). pret 40 lei + posta.
au plecat spre userul hixpp02. :aplauze
27.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.
[imgur](http://i.imgur.com/Q6Mv7iU.jpg)
4.un MP3 player marca Sweex (memorie proprie 1Gb) + accesorii (casti ; cablu date-incarcare). pret 70 lei + posta.
[imgur](http://i.imgur.com/LsRLwil.jpg)
5.un autotransformator. pret 150 lei + posta.
6.sursa in comutatie +5v;+12v;-12v (sursa provine din ceva casa de marcat) pret 12 lei + posta.
7.sursa in comutatie +5v;+35V (sursa provine din ceva imprimanta epson) pret 12 lei + posta.
8.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.
9.o cutie metalica pt. diverse montaje : 30cm x 22cm x 6,5cm . pret 35 lei + posta.
10.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.
11.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.
12.cooler+ventilator pt. procesor pret.20 lei + posta.
13.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.
14.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.
15.un modul audio (nu stiu starea lui dar se vede si in poze ca nu-s lipituri de reparatii pe el).pret 11 lei + posta.
16.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.
17.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 40 lei + posta.
18.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.
19.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.
20.releie cu bobina la 3 v/cc (anclansarea/declansarea se face prin inversarea polaritatii). pret 8 lei toate cele 6 buc. + posta.
21.ceas cu PIC16F628 + LCD albastru (schema si hex sunt luate de pe internet). pret 30 lei + posta.
22.radio cu ceas Fugison pret 18 lei + posta.
23. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.
24.sursa in comutatie in :220v c.a. / din semireglabil se poate modifica tens. de iesire intre :15 - 24 V c.c. /1A. pret 12 lei + posta.
25.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.
26.transformatoare din tv pe lampi ,ambele la pretul de 14 lei + posta.
27.receviere satelit (functionale) pt. carcasa. pret 15 lei/buc. + posta.
28.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.
6.un modem Huawei E3765 ,decodat merge in orice retea(in poza se vede ca scrie pe el Vodafon). pret 45 lei + posta.
[imgur](http://i.imgur.com/rfQju0z.jpg)
[imgur](http://i.imgur.com/LgLzb98.jpg)
7.un set de incarcatoare (priza 220v + priza auto). pret / set 14 lei + posta.
[imgur](http://i.imgur.com/JEx4ooT.jpg)
8.sursa in comutatie din dvd recorder. pret 19 lei + posta.
[imgur](http://i.imgur.com/GAmURrv.jpg)
9.sursa in comutatie +5v;+12v;-12v (sursa provine din ceva casa de marcat) pret 12 lei + posta.
10.sursa in comutatie +5v;+35V (sursa provine din ceva imprimanta epson) pret 12 lei + posta.
11.sursa in comutatie + 3,3v ;+ 30v (provine din ceva fax) pret 12 lei + posta.
12.o cutie metalica pt. diverse montaje : 30cm x 22cm x 6,5cm . pret 35 lei + posta.
13.o pereche de boxe (plastic ,imitatie lemn,difuzor 8 ohmi/4w) pret. 15 lei + posta.
14.un modul ceas electronic programator tip CEP-1 .pret 10 lei+posta.
15.cooler+ventilator pt. procesor pret.20 lei + posta.
16.un selector de canale si un modul din ceva tv sony (pe placa scrie 1-681-585-12) pret pt. ambele 10 lei + posta.
17.o placa recevier satelit (dupa codul ce se vede in poza ar fi vorba de Coship CDVB5668). pret 10 lei + posta.
18.un modul audio (nu stiu starea lui dar se vede si in poze ca nu-s lipituri de reparatii pe el).pret 11 lei + posta.
19.un motor la 12V c.c. (suflanta radiator auto) pret 18 lei + posta.
20.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 40 lei + posta.
21.ventilator cuptor microunde alimentare 220v. pret 15 lei + posta.
22.ventilator cuptor microunde alimentare 220v. pret 12 lei + posta.
23.releie cu bobina la 3 v/cc (anclansarea/declansarea se face prin inversarea polaritatii). pret 8 lei toate cele 6 buc. + posta.
24.ceas cu PIC16F628 + LCD albastru (schema si hex sunt luate de pe internet). pret 30 lei + posta.
25.radio cu ceas Fugison pret 18 lei + posta.
26. o sursa de la multifunctionala canon. in :~220vc.a. ; aut : 24v c.c. / 1,25A. pret 12 lei + posta.
27.sursa in comutatie in :220v c.a. / din semireglabil se poate modifica tens. de iesire intre :15 - 24 V c.c. /1A. pret 12 lei + posta.
28.sursa in comutatie dintr-un monitor mare marca Sun (functional la momentul dezmembrarii). pret 18 lei + posta.
29.transformatoare din tv pe lampi ,ambele la pretul de 14 lei + posta.
30.receviere satelit (functionale) pt. carcasa. pret 15 lei/buc. + posta.
31.sursa in comutatie in:220Vc.a. / out:12Vc.c. 1,12A. pret 12 lei + posta.
32.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta.
33.mixer audio Realistic. pret 30 lei + posta.
32.motoare pas cu pas. pret 14 lei toata gramada + posta.
[imgur](http://i.imgur.com/GCgLv.jpg)
[imgur](http://i.imgur.com/G5mzZ.jpg)
33.grup de microfoane si galene. pret 12 lei/grup + posta.
[imgur](http://i.imgur.com/SLgKp3l.jpg)
34.grup de rezistente vataj. pret 12 lei/grup + posta.
[imgur](http://i.imgur.com/veAepb0.jpg)
35.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta.
36.mixer audio Realistic. pret 30 lei + posta.
au plecat spre userul monday. :aplauze
29.un transformator cu multe tensiuni in secundar (cred ca e din ceva osciloscop). pret 24 lei + posta.
[imgur](http://i.imgur.com/09mNFgR.jpg)
35.potentiometri bobinati de vataj (ala mic de 100 ohm ; ala mare 500 ohm). amandoi la pretul de 45 lei + posta.
[imgur](http://i.imgur.com/vIKFhgQ.jpg)
[imgur](http://i.imgur.com/OJ8Vqfe.jpg)
36.transformator prindere pe cablaj:220v - 15v /12w. pret 14 lei.
[imgur](http://i.imgur.com/MQ9DwAq.jpg)
37.amplificator homemade 2 X TDA2040 cu radiatore. pret 24 lei + posta.
[imgur](http://i.imgur.com/Rcp0KjV.jpg)
[imgur](http://i.imgur.com/lRfmnp1.jpg)
[imgur](http://i.imgur.com/D94EveK.jpg)
38.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta.
39.mixer audio Realistic. pret 30 lei + posta.
4.un MP3 player marca Sweex (memorie proprie 1Gb) + accesorii (casti ; cablu date-incarcare). pret 50 lei + posta.
7.un set de incarcatoare (priza 220v + priza auto). pret / set 12 lei + posta.
18.un modul audio (nu stiu starea lui dar se vede si in poze ca nu-s lipituri de reparatii pe el).pret 10 lei + posta.
20.carcasa complecta folosita de la htc diamond 2 + acumulator original (tinea doar o zi si jumatate). pret pt. toate 35 lei + posta.
38.alimentator 3-4,5-6-9-12V / 300mA. pret 8 lei + posta.
[imgur](http://i.imgur.com/oNCeaLC.jpg)
39.surse in comutatie sau cu transformator. pret 12 lei / buc. sau 10 lei/buc. daca se cumpara mai multe + posta.
40.mixer audio Realistic. pret 30 lei + posta.
