Pc euro 200
cristybadea
Am incercat sa instalez win xp sp3 pe 2 pc-uri identice dar cand ajunge in faza de partionare a hdd-ului afiseza urmatorul mesaj: Windows canot create partition.Ce sa fac????Pc-uri cu placa de baza MB INTEL 865,proc INTEL PENTIUM 4 2.8 GHZ,HDD 160GB, 1GB ram
  • Răspunsuri 35
  • cristybadea
    20
  • FLORIN IORDACHE
    5
  • cristian_draghiescu
  • Copak
Pe aceste pc-uri este instalat Linux-ul dar peoprietarii vor windowsAm reusit formatarea hdd-ului cu windows7,dar si acesta se blocheaza imediat dupa partitionare.Am pus win xp sp3 si dupa rulare si copiererea fisierelor exact in momentul cand trebuie sa faca prima restartare da urmatoarea informatie(eroare): A problem has been detected and WINDOWS has been shout down to prevent damage to your computer.PAGE_FAULT_IN_NON_PAGED_AREEA.If this first time your"ve seen this stop error screen,restart your computer.If this screen appears again,follow these steeps:Check to make sure any new hardware or software is properly installed.If this is a new installation,ask your hardware or software manufacturer for any windows updates your might need.If problems continue,disable or remove any newly installed hardware or software.Disable BIOS memory option such as caching or shadowing.If you need to use safe mode to remove or disable components,restart your computer,pres F8 to select ADVANCED STARTAP OPTION,and then select Safe Mode.TEHNICAL Information: STOP:0x00000050(0xCEE8F67D,0X00000001,0X809EE962,0X00000000)....CE POT FACE MAI DEPARTE???????multumesc
Link-ul este corect şi merge.Mai întâi citiţi-l (cu atenţie), nu e cazul să vă alarmaţi de la început.Cu un linux live CD sistemele funcţionează corect ?
