Turbo cache chipset video
Vizitator vabogsm
Vizitator vabogsm
bun de curand mia crapat placa video si pana imi iau alta am zis sa bag onboard bun ma documentez cand ce sa aflu ca o am de 128 mb dar surpiza cik cu nush ce shestie turbo cache ajunge la 512 cum nush amm reusit pana la 256 din bios bun acum cine poata sa imi spuna cum pot da turbo cahce
motherboard:mcp6p-m2
de aici mia vebnit ideea NVIDIA GeForce 6150 GPU, On Board Graphic Max. Memory Share Up to 512MB(Under OS By Turbo Cache)
(Due to NVIDIA graphic driver update you can upgrade from GeForce 6100/nForce430 to GeForce
sursa http://www.biostar.com.tw/app/en/mb/int ... p?S_ID=315
si alta intrebare
am: am 1 amd athlon 1.5ghz X2
ram:2 gb
motherboard:mcp6p m2
hdd:wd caviar 250 sata liber 100gb
video: 256/512 dupa ce imi iau un nvidia geforce 7600 gs
bun imi suporta nfs the run? sau daca nu ce overclock pot sa dau P.S ms anticipat :d
  • Răspunsuri 0
Zile populare
