Vizitator mestericafarafrica Postat Mai 25, 2014 Partajează Postat Mai 25, 2014 aceasta setare o fac in Marlin la config h sau la setarea portului COM? Link spre comentariu
Vizitator mestericafarafrica Postat Mai 25, 2014 Partajează Postat Mai 25, 2014 ok multumesc pentru raspunsuri , maine dimineata fac modificarile , Link spre comentariu
Vizitator mestericafarafrica Postat Mai 26, 2014 Partajează Postat Mai 26, 2014 salutare tuturor pentru cineva "mai greu de cap" adica eu, are cineva fisierul de configurare pentru marlin firmware cu ramps 1.4 fara endstop activ, cursa de 190x190x180mm multumesc anticipat Link spre comentariu
Vizitator mestericafarafrica Postat Mai 27, 2014 Partajează Postat Mai 27, 2014 trebuie sa fac modificarele acestea ca sa fumctioneze? Connecting... start Printer is now online. echo: External Reset Marlin1.0.0 echo: Last Updated: May 27 2014 10:28:30 | Author: (none, default config) Compiled: May 27 2014 echo: Free Memory: 5248 PlannerBufferBytes: 1232 echo:Hardcoded Default Settings Loaded echo:Steps per unit: echo: M92 X78.74 Y78.74 Z533.33 E836.00 echo:Maximum feedrates (mm/s): echo: M203 X500.00 Y500.00 Z5.00 E25.00 echo:Maximum Acceleration (mm/s2): echo: M201 X9000 Y9000 Z100 E10000 echo:Acceleration: S=acceleration, T=retract acceleration echo: M204 S3000.00 T3000.00 echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s) echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00 echo:Home offset (mm): echo: M206 X0.00 Y0.00 Z0.00 echo:PID settings: echo: M301 P22.20 I1.08 D114.00 Error:0 [ERROR] Error:0 : Extruder switched off. MINTEMP triggered ! Error:Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting) [ERROR] Error:Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting) Link spre comentariu
chas3 Postat Mai 27, 2014 Partajează Postat Mai 27, 2014 Termistorul de la hotend nu este conectat. Link spre comentariu
Vizitator mestericafarafrica Postat Mai 27, 2014 Partajează Postat Mai 27, 2014 dupa conectarea imprimantei ar trebui sa ia comanda de incalzire a hotend-ului si a heatbed-ului? de fapt comanda o ia dar nu se incalzeste nici una raman la tem de 37-39 de grade Link spre comentariu
chas3 Postat Mai 27, 2014 Partajează Postat Mai 27, 2014 Singure nu se incalzesc, doar daca dai tu comanda sa se incalzeasca la o anumita temperatura.Fara sursa de 12V conectata nu o sa se incalzeasca nimic, USB-ul alimenteaza doar chipul ATMEGA, nu si restul. Link spre comentariu
Vizitator mestericafarafrica Postat Mai 27, 2014 Partajează Postat Mai 27, 2014 am sursa conectata si nici un motor nu se misca dau comanda de homing sau macar extrudorul Link spre comentariu
chas3 Postat Mai 27, 2014 Partajează Postat Mai 27, 2014 Posibil sa ai potentiometrul de pe drivere la minim. Motorul de pe extrudor nu se misca oricum, daca nu este incalzit hotend-ul la temperatura minima de extrudare (setat la vreo 175 default parca). Link spre comentariu
Vizitator mestericafarafrica Postat Mai 27, 2014 Partajează Postat Mai 27, 2014 dar daca nici hotend-ul si nici heatbed-ul nu se incalzeste care ar putea fi cauza? Link spre comentariu
chas3 Postat Mai 27, 2014 Partajează Postat Mai 27, 2014 Masoara daca ai 12V pe conexiunile lor. Link spre comentariu
Vizitator mestericafarafrica Postat Mai 28, 2014 Partajează Postat Mai 28, 2014 pana la urma am remediat problema aveam 12v am dat comanda de incalzire a hotend-ului si heatbed-ului, a luat comanda pana cand sa auzit un poc si a iesit fum si nu mai imi vede mega 2560 in portul com rezervat ei am instalat pe mega singura setari configuration h si a mers pana la urma la placa ramps cred ca e problema dupa cum a iesit fum cred ca e din zona diodei dintre drivere, e posibil sa se arda?care ar cam fi cauza? Link spre comentariu
chas3 Postat Mai 28, 2014 Partajează Postat Mai 28, 2014 Pune o poza cu incendiul.Nu iti vede portul nici nu shield-ul RAMPS scos de pe placa Arduino? Link spre comentariu
Vizitator mestericafarafrica Postat Mai 28, 2014 Partajează Postat Mai 28, 2014 ba da imi vede portul cand am scos Ramps si este "afumat" un piciorus de la dioda o sa incerc sa revin cu poza nu sunt prea reusite pozele dar se vede urme de arsura pe un piciorus de la dioda http://tinypic.com/view.php?pic=2zewh9x&s=8#.U4XJi3J_shM http://tinypic.com/view.php?pic=2zewh9x&s=8#.U4XJqXJ_shM a si mosfetul de langa patul incalzit era destul de fierbinte dupa 2-3 minute functionare Link spre comentariu
