GanMark Postat Noiembrie 13, 2014 Partajează Postat Noiembrie 13, 2014 (editat) can not...... unless the author makes changes to source code .... Editat Noiembrie 13, 2014 de GanMark Link spre comentariu
Vizitator ir02x6 Postat Noiembrie 15, 2014 Partajează Postat Noiembrie 15, 2014 Hi guys Finally, I bought all the parts. Unfortunately, i can't find datasheet of this piece: can i use ":" in this project ? Link spre comentariu
yo6pir Postat Noiembrie 15, 2014 Partajează Postat Noiembrie 15, 2014 (editat) You don't need datasheet anymore! Take a resistor (470-1K), one battery (3,7-9V)and check the pins step-by-step and write the scheme on paper sheet. It's simple. Or, maybee help you this link from my site: http://www.tme.eu/html/RO/afisaje-cu-led-uri-cvadruplu-14-mm/ramka_2902_RO_pelny.html Editat Noiembrie 15, 2014 de yo6pir Link spre comentariu
Vizitator ir02x6 Postat Noiembrie 15, 2014 Partajează Postat Noiembrie 15, 2014 You don't need datasheet anymore! Take a resistor (470-1K), one battery (3,7-9V)and check the pins step-by-step and write the scheme on paper sheet. It's simple. Or, maybee help you this link from my site: http://www.tme.eu/html/RO/afisaje-cu-led-uri-cvadruplu-14-mm/ramka_2902_RO_pelny.html tank for reply mr yo6pir i find pins ! but there is a problem ! "Y" and "B" , "X" and "A" , "Z" and "C" are common cathode ! Now , How do I use the two points of clock > ":"! Link spre comentariu
yo6pir Postat Noiembrie 15, 2014 Partajează Postat Noiembrie 15, 2014 Simple! 1.Terminal 5 of your scheme you'll use it in place of the DOT pin in clock scheme 2. You'll use the the software for KINGBRIGHT displays from download section of my site. That's all! Link spre comentariu
Vizitator ir02x6 Postat Noiembrie 16, 2014 Partajează Postat Noiembrie 16, 2014 Simple! 1.Terminal 5 of your scheme you'll use it in place of the DOT pin in clock scheme 2. You'll use the the software for KINGBRIGHT displays from download section of my site. That's all! tank for reply mr yo6pir , i did it : time is correct , but temp is not stable ! please see this video and help me : http://www.4shared.com/video/ue9_GMXAba/test_ds1302.html Also , i can't use ":" in time display ! when "Terminal 5 of your scheme you'll use it in place of the DOT pin in clock scheme" both of ":" and " ' " is ON ! Link spre comentariu
GanMark Postat Noiembrie 25, 2014 Partajează Postat Noiembrie 25, 2014 mi-am cumparat un afisaj LED albastru , model OPD Q5620LB-BM de curiozitate am incercat sa vad daca afiseaza punctele dintre cifre , merg dar concomitent mi se aprinde si punctul de jos..... se poate rezolva din codul sursa ? Link spre comentariu
albasete Postat Noiembrie 25, 2014 Partajează Postat Noiembrie 25, 2014 Posibil sa fie conectat si punctul de jos. Da jos afisajul si verifical. La afisajul CA56-21 YWA, punctul de jos nu figureaza ca si conexiune. Link spre comentariu
Depanatoru Postat Noiembrie 25, 2014 Partajează Postat Noiembrie 25, 2014 (editat) Interesant , In mod normal afisajele au ori 4 puncte normale jos intre digiti ori cele doua puncte de ceas ... ca sa se foloseasca toate inseamna ca are pini suplimentari care tu i-ai unit din greseala si fara datasheet trebuie studiat afara din montaj cum sunt folositi pinii , nu e de la soft o asemenea problema . In cel mai rau caz vopsesti punctul care se aprinde aiurea , glumesc , trebuie sa fie o rezolvare Editat Noiembrie 25, 2014 de Depanatoru Link spre comentariu
fratello Postat Noiembrie 25, 2014 Partajează Postat Noiembrie 25, 2014 Dupa datasheet (http://www.tme.eu/ro/Document/a54bbbf4d8ddeebd9dffae439a3cad4b/OPD-Q5620LB-BW.pdf) DP, D5 si D6 sunt comuni, asa ca eu cred ca trebuie vopsit/obturat punctul respectiv ... Link spre comentariu
GanMark Postat Noiembrie 25, 2014 Partajează Postat Noiembrie 25, 2014 OK cu vopsitu , obturat ...nu mi-a venit ideea.... chiar e cea mai simpla metoda.... mai incerc cu ceva diode sa scad din luminozitate multumesc Link spre comentariu
albasete Postat Noiembrie 26, 2014 Partajează Postat Noiembrie 26, 2014 Merge "vopsit " cu marker negru permanent, rezistent la apa. O spun din proprie experienta. Link spre comentariu
expert Postat Decembrie 18, 2014 Partajează Postat Decembrie 18, 2014 @GanMarKDa pot sa-ti fac un soft pentru acel tip,nu-i o problema, numai ca nu am nici unul ca sa-l testez pe placa de test. O sa incerc si-mi spui tu daca merge bine sau nu. Sa vad poate fac rost de o bucata de undeva. yo6pir, un ds1307 pot sa iti trimit eu sa faci teste cu el; si eu sunt interesat de o varianta a acestui ceas cu ds1307 sau alte rtc de la maxim cu transmisie i2c! multumesc Link spre comentariu
yo6pir Postat Decembrie 18, 2014 Partajează Postat Decembrie 18, 2014 E OK baieti, va ajut cu placere, sa dezvoltam impreuna acest proiect. Cum am mai spus nu detin acele cipuri si de aceea fac cu ce am in sertare. Daca-mi trimiti un cip DS1307 cu bus I2C am sa fac un soft special pentru el. Si voi puteti veni cu idei, chiar alta schema, nu ma supar, dimpotriva, ma bucur ca o idee buna are si sustinere de grup. Astept cipul si tinem aproape! Link spre comentariu
expert Postat Decembrie 18, 2014 Partajează Postat Decembrie 18, 2014 astept adresa in MP unde sa expediez cipul! luni pleaca spre dvs! Si daca tot e vorba de reproiectare cred ca ar fi util un senzor de lumina, care sa reduca intensitatea afisajului pe timpul noptii! nu stiu cum e mai simplu: ca la majoritatea ceasurilor chinezesti, adica intre orele 22-7 intensitate redusa, in rest intensitate normala, sau cu o fotorezistenta si reglaj continuu! Link spre comentariu
