Indesit WITL 85
susanu_pisu
  • Răspunsuri 17
  • susanu_pisu
    13
  • yo9hnf
  • FLORIN IORDACHE
  • realconstruct
Masina mamei mele de spalat mergea un minut sau cateva, si pe urma se bloca (nu mai mergea, nu mai dadea apa afara etc...). De doua ori a trebuit sa-i schimb rezistenta. Nu mai stiu ce rezistenta imi dadea la masa, dar parca 50-100kohmi.
widl codes - light flashing from left to right are numbers 1-4f01 light 4, motor triacf02 light 3 motor, jammed/ tachof03 lights 3&4 Ntc faultf04 light 2. pressure sw stuck on emptyf05 lights 2&4, pressure sw stuck on fullf06 lights 2&3, N/A?f07 lights 2&3&4 heater relayf08 light 1. heater relayf09 lights 1&4 eprom/setup errorf10 lights 1&3, pressure switch not sensingf11 lights 1&3&4, pump/draining errorf12 lights 1&2, communication errorf13 lights 1&2&4, dryer ntc/ fan motorf14 lights 1&2&3, dryer heaterf15 lights 1&2&3&4, dryer heater relayf16 N/Af17 light 4, door lockf18 light 3 comms error (3 phase motor) power boardf1 and f17 share the same lightthese are the fault codes match to yoursniste coduri de eroare....pot fi utile, ar fi bine sa se faca un topys special pentru masini de spalat!
vad ca nu prea sunt depanatori in masini de spalat..am desfacut-o azi, si nu am gasit nimic suspect, rezistenta nu da fata de masa, motorul este ok...dupa cateva butonari si opriri/porniri, a inceput sa-si dea drumul...a facut 2-3 programe si iar nu a plecat motorul....sa fie cumva softul?pot gasi un dump?si cu ce program/interfata se scrie
