maricelTECUCI Postat Februarie 17, 2012 Partajează Postat Februarie 17, 2012 telefonul nu porneste deloc am incercat cu phoenix sai rescriu softul dar nu am reusit am observat ca la apasarea butun de pornire instaleaza un driver ceva de rom dupa care se decupleaza driverul .cum se poate aduce la viata Link spre comentariu
riderinblack Postat Februarie 18, 2012 Partajează Postat Februarie 18, 2012 Uite cum am reusit eu: Link spre comentariu
maricelTECUCI Postat Februarie 18, 2012 Autor Partajează Postat Februarie 18, 2012 JAF version 1.98.62Detected PKEY: 9000BC25Card life counter: 99.99%P-key nokia module version 01.02FBUS INTERFACE NOT CONNECTED!!!USB Cable Driver version: 7.0.2.0Changing mode...Done!FILES SET FOR FLASHING:MCU Flash file: NONEPPM Flash file: NONECNT Flash file: NONEAPE Variant file: NONEDetected P-KEY: 9000BC25P-key nokia module version 01.02Init usb communication...Phone Type: FILES SET FOR FLASHING:MCU Flash file: C:\ProgramData\Nokia\Packages\Products\rm-364\rm364__09.41.c0rPPM Flash file: NONECNT Flash file: NONEAPE Variant file: NONEDetected P-KEY: 9000BC25P-key nokia module version 01.02Init usb communication...Phone Type: FILES SET FOR FLASHING:MCU Flash file: C:\ProgramData\Nokia\Packages\Products\rm-364\rm364__09.41.c0rPPM Flash file: C:\ProgramData\Nokia\Packages\Products\rm-364\rm364__09.41.ppm_cCNT Flash file: NONEAPE Variant file: NONELanguages in ppm: English,German,French,Italian,Dutch,Spanish,Turkish,PortugueseDetected P-KEY: 9000BC25P-key nokia module version 01.02Init usb communication...Phone Type: FILES SET FOR FLASHING:MCU Flash file: C:\ProgramData\Nokia\Packages\Products\rm-364\rm364__09.41.c0rPPM Flash file: C:\ProgramData\Nokia\Packages\Products\rm-364\rm364__09.41.ppm_cCNT Flash file: C:\ProgramData\Nokia\Packages\Products\rm-364\rm364__09.41_ISM_010.image_3_it_graphAPE Variant file: NONELanguages in ppm: English,German,French,Italian,Dutch,Spanish,Turkish,PortugueseBacking up CRT...Detected P-KEY: 9000BC25P-key nokia module version 01.02Init usb communication...Failed to backup CRT...Detected P-KEY: 9000BC25P-key nokia module version 01.02Init usb communication...PRESS POWER ON NOW!Searching for phone...FoundSending RAW loader...Using 06.02.002 Elf2flash 07.14.000 CMT RAW loader...Patching RAW boot step1...Patching RAW boot step2...Patching RAW boot step3...Sending RAW Loader......................Loader Sent!Stage 2 starting.............................................................................Loader Sent!Stage 3 starting..................Phone prepared OK!Waiting for the phone to boot...Searching for phone...Phone failed to boot in flash mode CMT...aici sa oprit Link spre comentariu
Vizitator Postat Februarie 19, 2012 Partajează Postat Februarie 19, 2012 Încearcă din nou, dar cu o versiune de firmware mai mare... like this. Link spre comentariu
maricelTECUCI Postat Februarie 20, 2012 Autor Partajează Postat Februarie 20, 2012 nu aciasi problema am inteles ca sint conexiuni prin serial sau un soft prin portul serial Link spre comentariu
nascadorel Postat Februarie 20, 2012 Partajează Postat Februarie 20, 2012 nu aciasi problema am inteles ca sint conexiuni prin serial sau un soft prin portul serial Nu pe serial ci pe Mbus, acelasi soft "jaf" merge si pe Mbus insa nu prin cablul USB ci pe padurile de pe placa de baza cu un cablu special pt service si o interfata Jaf box sau ce-o fi din gama "Saras". Link spre comentariu
maricelTECUCI Postat Februarie 22, 2012 Autor Partajează Postat Februarie 22, 2012 am gasit pe net o schema cu max232 pe care am realizato cu st232 dar nu am reusit nu gaseste nimicjaf cauta numai pe usbdeasemenea am programat empromuri si pic dar am observat ca are tensiune negativa practic gnd este + si st232 nu are curent. binenteles ca lam alimentat separat dar nimic am incerca pe conexiunile de pe telefon rx tx gnd vpp fara baterie si cu baterie. daca se poate o schema completa va multumesc pentru cei care ma poate ajuta Link spre comentariu
