fenddder Postat Februarie 7, 2012 Partajează Postat Februarie 7, 2012 Zilele astea am inceput sa lucrez la un line follower cu uC ATmega16. Sursa: #include <avr\io.h>#include <avr\interrupt.h>#define MOTOR1_DDR DDRA#define MOTOR1_PORT PORTA#define ACTVIVARE1 PA0#define INTRARE1 PA1#define PWM1_DDR DDRD#define PWM1_PORT PORTD#define PWM1 PD5#define MOTOR2_DDR DDRA#define MOTOR2_PORT PORTA#define ACTIVARE2 PA3#define INTRARE2 PA4#define PWM2_DDR DDRD#define PWM2_PORT PORTD#define PWM2 PD4#define SENZOR_DDR DDRC#define SENZOR_PIN PINC#define S1 PC0#define S2 PC1#define S3 PC2#define IN_AFARA_LINIEI (sensors == 0)#define AFARA_CENTRU_DREAPTA (sensors == 1)#define AFARA_CENTRU_STANGA (sensors == 4)#define AFARA_DREAPTA (sensors == 3)#define AFARA_STANGA (sensors == 6)#define PE_LINIE (sensors == 7)void stop1(){ OCR1A = 0; MOTOR1_PORT &= ~(_BV(INTRARE1));}void stop2(){ OCR1B = 0; MOTOR2_PORT &= ~(_BV(INTRARE2));}void mergiINAINTE1(float speed){ MOTOR1_PORT &= ~(_BV(INTRARE1)); OCR1A = (int)(255 * speed);}void mergiINAINTE2(float speed){ MOTOR2_PORT &= ~(_BV(INTRARE2)); OCR1B = (int)(255 * speed);}void mergiINAPOI1(){ MOTOR1_PORT |= _BV(INTRARE1); OCR1A = 0;}void mergiINAPOI2(){ MOTOR2_PORT |= _BV(INTRARE2); OCR1B = 0;}void vireazaSTANGAbrusc(){ stop1(); mergiINAINTE2(1);}void vireazaDREAPTAbrusc(){ stop2(); mergiINAINTE1(1);}void vireazaSTANGAlin(){ mergiINAINTE1(0.5); mergiINAINTE2(1);}void vireazaDREAPTAlin(){ mergiINAINTE2(0.5); mergiINAINTE1(1);}void init(){ TCCR1A = _BV(COM1A1) | _BV(COM1B1) | _BV(WGM10); TCCR1B = _BV(WGM12) | _BV(CS10) | _BV(CS12); MOTOR1_DDR = MOTOR2_DDR = PWM1_DDR = PWM2_DDR = SENSOR_DDR = 0; MOTOR1_DDR |= _BV(ACTIVEAZA1) | _BV(INTRARE1); MOTOR2_DDR |= _BV(ACTIVEAZA2) | _BV(INTRARE2); PWM1_DDR |= _BV(PWM1); PWM2_DDR |= _BV(PWM2); SENSOR_PIN &= ~(_BV(S1) | _BV(S2) | _BV(S3)); MOTOR1_PORT |= _BV(ACTIVEAZA1); MOTOR2_PORT |= _BV(ACTIVEAZA2); mergiINAINTE1(1); mergiINAINTE2(1);} int main(){ init(); unsigned char sensors; while (1) { sensors = SENSOR_PIN & (_BV(S1) | _BV(S2) | _BV(S3)); if (AFARA_STANGA) { vireazaDREAPTAlin(); continue; } if (AFARA_DREAPTA) { vireazaSTANGAlin(); continue; } if (AFARA_CENTRU_STANGA) { vireazaDREAPTAbrusc(); continue; } if (AFARA_CENTRU_DREAPTA) { vireazaSTANGAbrusc(); continue; } if (IN_AFARA_LINIEI) { mergiINAPOI1(); mergiINAPOI2(); continue; } mergiINAINTE1(1); mergiINAINTE2(1); } return 0;} Link spre comentariu
Vizitator djfllo Postat Februarie 12, 2012 Partajează Postat Februarie 12, 2012 ne dai si noua schema:D ? as vrea sa-mi fac si eu unul.... Link spre comentariu
fenddder Postat Februarie 13, 2012 Autor Partajează Postat Februarie 13, 2012 Daca te uiti in program e suficient sa stii schema.O postez cand ajung de la scoala!cuartul este de 16mhz, condensatori de 15pf pentru cuart, rezistor de 10k pe reset iar driverul de motoare este L293. Link spre comentariu
Vizitator djfllo Postat Februarie 13, 2012 Partajează Postat Februarie 13, 2012 cam cat te-au costat toate piesele ? Link spre comentariu
fenddder Postat Februarie 14, 2012 Autor Partajează Postat Februarie 14, 2012 Majoritatea le aveam.Aproximez ca m-a costat cam 200lei proiectul, din care 80 lei motoarele. Link spre comentariu
negru_voda Postat Iunie 3, 2012 Partajează Postat Iunie 3, 2012 si totusi ... o schema poti posta? Link spre comentariu
fenddder Postat Iunie 5, 2012 Autor Partajează Postat Iunie 5, 2012 Nu exista o schema completa ci doar pe module!Succes Link spre comentariu
