Pareri System Fidelity SF-3030 + Amplificator SA-D30
Vizitator razvan621
Vizitator razvan621
Buna seara.as dori cateva pareri legate de aceste boxe , daca a ascultat cineva boxele astea ....Pretul setului 700 lei camera 16mp muzica pe care o ascult, r&b , house , filme Multumesc .Fisa tehnica amplificator Putere iesire:15w / canal la 4 ohmi (THD 10%)11w/ canal la 4 ohmi (THD 0.1%) @ 22Hz-20kHz10w/ canal la 8 ohmi (THD10%)6w/canal la 8 ohmi (THD 0.01%) @ 22 Hz-20kHzRaport semnal-zgomot: >98 dbCalitate sunet audiofilaAhitectura T-classSursa switching high current r3egulatedProtectie impotriva supraincalzirii si supraincarcariiDimensiuni: 157x53x98 mmSystem Fidelity SF3030Configuration: 2-WayTweeter Driver:1"Woofer Driver: 6,5"Cabinet Type: Bass reflex MDFPower Handling:100 / 140 WFrequency Responce:45Hz - 20kHzSensitivity: 88 dBImpedance: 6 OhmsCrossover Frequency:3 kHzWeight: 4,8 kgDimensions (cm): 34 x 18,5 x 25
  • Răspunsuri 5
  • radu8982
  • LUCI
  • Mihai85
  • BF37
Zile populare
Mai bun e amplificatorul asta,costa 275 RON
Maximum output power (1 kHz; THD < 1%):
- 2x 120 W @ 4 ohm
- 2x 80 W @ 8 ohm
• Rated output power (20 Hz-20 kHz; THD < 0.5%):
- 2x 60 W @ 4 ohm
- 2x 40 W @ 8 ohm
• Frequency response (20 Hz-20 kHz @ 8 ohm): ą 0.5 dB
• Signal to Noise Ratio (A-weighted): > 90 dB
• Total Harmonic Distortion (THD): < 0.3%
• Crosstalk (1 kHz): > 90 dB
• Input Impedance: 10k ohms
• Input Sensitivity: 0 dB
• Input connectors: RCA, Jack
• Output connectors: Speaker, binding posts, XLR
• Cooling: Fan, heat sink
• Power requirements: 230V ~ 50/60 Hz
• Dimensions (W x H x D): 483 x 88 x 242 mm
• 19” Rack space: 2 RU
• Weight: 5.5 kg
Posted Image
Amplificatorul este construit in jurul unui integrat foarte laudat (Tripath TA2020 ) si functioneaza in clasa T. Din review-urile pe care le-am citit , majoritatea au declarat ca sursa de alimentare inclusa sau externa , furnizata la achizitionare , nu este suficient de bine filtrata si ca cel mai bine functioneaza alimentat dintr-un acumulator de 12V. Deci poate fi un amplificator destul de bun... factorul decisiv vor fi boxele.Din pacate boxele nu se potrivesc cu acest amplificator. Ai nevoie de boxe cu sensibilitate mare , minim 93Db/w/m.Eu personal a-si construi niste VTP-uri pe 2 cai sau cu un difuzor de banda larga , de calitate.
- 2x 120 W @ 4 ohm
- 2x 80 W @ 8 ohm
- 2x 60 W @ 4 ohm
- 2x 40 W @ 8 ohm
• Weight: 5.5 kg
Posted Image
Sa nu comparam pe king kong ala cu ceva amplificator Hi-Fi
Omul clar cauta ceva de calitate daca a propus un amplificator de 10W.
Pe de alta parte pentru house ,tech,filme si alte comerciale cred ca mai potrivit ar fi un amplificator de calitate ok dar ceva mai puternic un 30-50W
Cu 10 W daca nu ai boxe cu sensibilitate ridicata imediat duci in limitare amplificatorul.
Un amplificator mai bun Yamaha CR-440, e mai hi-fi ,costa 350 ron pe un site de licitatii.
Speaker Outputs: 2 x2 Speakers, 2 Phones
Continuous Power 4Ω: 30 + 30 (IHF); 40 + 40 (DIN) Watts
Continuous power 8Ω: 30 + 30 (IHF); 35 + 35 (DIN) Watts
Frequency Response: 10-40,000 (±0.5 dB) HZ
Damping factor: 40 (1 kHz) Ώ
Harmonic Distortion: 0.01 (Phono MM 0.04) % at rated output
Posted Image
