ionel costin Postat Ianuarie 25, 2012 Partajează Postat Ianuarie 25, 2012 VA SALUT DRAGI ELECTRONISTI IN ACEST MODEL DE TV AM CA CIRCUIT INTEGRAT BV TDA 1771 L-AM GASIT ARS L-AM INLOCUIT DAR AM TOT LINIE .AM CAUTAT O SCHEMA LA ACEST TIP DE TV DAR NU AM REUSIT SA GASESC PE IESIRE AM 11 V CEIA CE IMI SPUNE CA CI AR FI BUN .MA POATE AJUTA CINEVA CU VREO SCHEMA CEVA ? MULTUMESC Link spre comentariu
dan cod Postat Ianuarie 25, 2012 Partajează Postat Ianuarie 25, 2012 viewtopic.php?t=95731&p=861147#p861147Sasiu PT90.Poate e stift TDA1771 asta nou.Nu ar fi mirare.Vezi si aici.viewtopic.php?f=17&t=102644&p=928893&hilit=pt90#p928893 Link spre comentariu
