Vizitator cyclonb Postat Ianuarie 19, 2012 Partajează Postat Ianuarie 19, 2012 Vreti sa lucrati PSK31 de pe o tableta sau un telefon cu Android ? Softul de mai jos e excelent. Merge brici chiar si prin microfon. Se instaleaza in cateva secunde. Eu n-am avut probleme. https://lh6.ggpht.com/GbLlQ6L5a6kD6oXk_F67o_-v4_4YbvMZTAad3ITZuBWhMfLakKnU7khIEY7H233v2ztK=h230 Scanat cu BitDefender for Android (Nota: nu e reclama ptr. BitDefender, ci am mentionat clar cu ce am verificat produsul) http://t0.gstatic.com/images?q=tbn:ANd9GcSKZlq2nTe2CUYkpHY0vkLgKlwHxpQcC9m5CCUU_BSdmNY7DKT3t5RQ604 Link spre comentariu
Vizitator cyclonb Postat Ianuarie 19, 2012 Partajează Postat Ianuarie 19, 2012 Daca vreti sa stati si la discutii direct de pe telefonul mobil cu Android ... : https://lh5.ggpht.com/QyA7AMUphLXEw4xu09AabctGJEW0-p20dPmhgLc7wI8bfHNRv7rw7nPOfRPOFLgoJVj4=h230 Limitari: Although Relay is the default, and will generally give the best performance, the following limitations currently apply: - You can initiate a connection, but you cannot receive one; stations that try to connect to you will receive a "No route available" error message. This means that Android or iPhone users that are using the Relay mode cannot connect to each other. - Because there are only a small number of relay severs, you often cannot connect to the same conference or conference server that another node using the Relay mode is already connected to. This means that two Android or iPhone users that are using the Relay mode often cannot join the same conference at the same time. Mai multe aici. Link spre comentariu
Vizitator cyclonb Postat Ianuarie 19, 2012 Partajează Postat Ianuarie 19, 2012 Sunteti in portabil si vreti un log la indemana? Daca aveti un telefon cu Android, merge cu aplicatia asta: https://lh5.ggpht.com/2xIdzfwec5WrT1NPfKAziTWHPeymVBsh7BF6hogEaqL6W2U5GOhlKEhhJLI5ZJSLjwA=h230 Exista si alte solutii, dar asta e simpla si fara briz-briz-uri inutile. Link spre comentariu
