adicontakt Postat August 14, 2013 Partajează Postat August 14, 2013 statia mea are alimetator de laptop de 19v 3 a si functioneaza bine Link spre comentariu
albasete Postat August 14, 2013 Partajează Postat August 14, 2013 Exact ce doream sa stiu ! Multumesc. Ce tip de letcon ai Adi ? Mai am o statie de lipit analogica home made clona Gor Dak si functioneaza super de cca. 3 ani, letcon Pensol Iron.Am intrebat de alimentator deoarece este mai ieftin decat un traf. - redresare - filtrare . Multumesc ! Link spre comentariu
adicontakt Postat August 14, 2013 Partajează Postat August 14, 2013 letconul este slomon sl cu manson albastru am incercat sa pun un letcon hakko si nu functioneaza cum trebuie Link spre comentariu
albasete Postat August 14, 2013 Partajează Postat August 14, 2013 Tot cu manson albastru am si eu ,nu am avut probleme cu el pana in prezent. Ideea este ca trebuie sa mai cumpar unul, dar ... una comanzi alta primesti. Link spre comentariu
fratello Postat August 14, 2013 Partajează Postat August 14, 2013 Schema prezentata anterior de albasete merge cu orice tip de ciocan de lipit cu termocuplu de tip K. Re-atasez schema (de la autor) si instructiunile de constructie/etalonare : The power transformer must be at least 60 watts ; because you use solder iron 24 volts/ 48 watts (Pensol SL10) , you will need transformer to deliver at least 3 amps minium ,at the begining of heating the soldering iron can pull current up to 3.5 amps .Is necessary to put bypass capacitors of 100n, impulse noise can be seen where it slips.In my station (I have stabilisator and work fine with him) I have add extra Tantalum capacitor close to chip atmega; the wires must be at least 1mm (wires that come from IRFZ44 to solder iron).How to calibrate:First need to disconect the negative pol of power supply of solder iron (that who come from IRFZ44), when is disconected you must leave the solder iron to get the room temperature with station power off .If you have room thermometer you will see what is the temperature,example 22 degrees; turn on the station with the negative pol of heating element of solder iron disconected - the display will show the temperature of room, then with potentiometer R5-47k ohm you will set the room temperature.After seting the temperature power off the station, connect the negative pol to pcb and try it. Link spre comentariu
albasete Postat August 15, 2013 Partajează Postat August 15, 2013 Multumesc Fratello, acum sunt lamurit. Sa soseasca cele necesare si va tin la curent. Link spre comentariu
Vizitator marian_ariciuc Postat August 19, 2013 Partajează Postat August 19, 2013 pentru schema de mai sus, postata de fratello, sunt mai multe cablaje desenate aici, pe acest topic: rety, GeoMar, Dinboo, fiecare si-a postat propriul cablaj...si eu mi-am desenat aceasta statie, dupa acel cablaj, este cu componente THD, si am desenat-o in asa fel incat poate fi incadrata intr-o carcasa de CDrom. daca sunt doritori va rog pm. poate in urmatoarele zile voi avea ceva timp si voi urca o arhiva cu toate cele nesesare. Link spre comentariu
albasete Postat August 19, 2013 Partajează Postat August 19, 2013 Felicitari ! Statia este in carcasa sau in faza de proiect ? Link spre comentariu
stryx Postat August 23, 2013 Partajează Postat August 23, 2013 Acum cateva luni am realizat si eu statia cu atmega la care. O folosesc alimentala cu 19V/4.2A. http://www.image-share.com/ijpg-2259-145.html http://www.image-share.com/ijpg-2259-146.html http://www.image-share.com/ijpg-2259-148.html http://www.image-share.com/ijpg-2259-149.html http://www.image-share.com/ijpg-2259-150.html PS: Scuzati calitatea pozelor. Link spre comentariu
briobit Postat August 24, 2013 Autor Partajează Postat August 24, 2013 ma bucur ca mai realizeaza cineva cate un montaj ....am gasit si eu 5 cutii la fel de la niste amplificatoare/microfoane nu stiu ce au fost, dar nu sunt prieten cu timpul liber .... Link spre comentariu
albasete Postat Septembrie 4, 2013 Partajează Postat Septembrie 4, 2013 Mi-am adus aminte ca am un traf. de TV Sport romanesc. L-am verificat si scoate 16 Vca. Probat cu un bec de 24 V / 75 W am masurat cca 2,4 A, nu-mi mai aduc aminte exact. Cred ca este suficient pentru schema repostata de Fratello, daca nu ...Marian ariciuc, pune o poza sa ne clatim si noi privirea. Eu voi folosi o carcasa de sursa ATX, desi merge si ceva slim dar statia va trebui sa stea in picioare, asa ca raman la ce am. Link spre comentariu
albasete Postat Septembrie 5, 2013 Partajează Postat Septembrie 5, 2013 Dintre aceia care au realizat statia cu Atmega si afisaj led (schema de mai sus), puteti sa-mi spuneti, se incinge stabilizatorul de 5 Vcc fara radiator ? Sau cat de "fierbinte" este acesta ? Statia va fi alimentata cu cca. 22 Vcc. Multumesc. Link spre comentariu
adicontakt Postat Septembrie 5, 2013 Partajează Postat Septembrie 5, 2013 se incinge destul de tare , eu unul am pus un stabilizator cu lm317 in afara placii Link spre comentariu
briobit Postat Septembrie 5, 2013 Autor Partajează Postat Septembrie 5, 2013 eu am alimentat partea de comanda dintr-un traf mic clasic cu tole undeva la 8-9 volti si partea de forta dintr-un alimentator de laptop 20v/4A si nu mai zapacesc 7805 ala cu 20 de volti si sa presupunem ca cedeaza sursa aia de laptop se duce partea de forta nu toata placa .... Imi cer scuze fata de colegii GanMark si Albasete pentru chestiile promise, nu am uitat de ele si incerc sa le rezolv cat mai repede ... Link spre comentariu
albasete Postat Septembrie 5, 2013 Partajează Postat Septembrie 5, 2013 Multumesc. Am constatat si eu incalzirea excesiva - dar normala - a stabilizatorului de 5 V. Incerc sa-i pun un radiator sau un stabilizator de 12 V. Statia am alimentato din sursa reglabila cu 20 Vcc. In sarcina aveam 19 - 19,5 Vcc si 1,75 A (letcon conectat). Nu am continuat cu alte teste. Am folosit IRFZ 44 N .Partea tragi-comica: la rece statia functioneaza corect, arata 511 fara letcon, porneste cu tasta T-, memoreaza cele 3 temperaturi dorite, se opreste (OFF) conform procedurii descrise de Geo-Mar. Acestea fara letcon. Cu letcon, se intampla aceleasi lucruri, dar dupa memorarea sau setarea temperaturii, ramane aprins ultimul digit din dreapta care incepe sa numere: 3,4,5,6,7,8 etc. Am reluat testele de inca 2 ori si aceeasi poveste. Letconul se incalzeste, functioneaza.Temperatura letconului nu am masurato din moment ce pe afisaj ramanea o singura cifra pe post de cronometru. Precizez ca letconul era cald (i-l utilizasem la statia cealalta pentru a o finaliza pe aceasta din topic). Este normal sa se intample asa, sa ramana aprins numai ultimul digit si sa numere ?Multumesc anticipat pentru lamuriri/sugestii.Briobit, stai linistit, nu-i problema. Cand te iei cu treburi, mai uiti de lucrurile marunte. Link spre comentariu
