dancostea2002 Postat Iunie 4, 2016 Partajează Postat Iunie 4, 2016 Va multumesc!pacat ca nu este un buton Thanks aici! Link spre comentariu
Liviu M Postat Iunie 4, 2016 Partajează Postat Iunie 4, 2016 Cu mine vorbesti? Sunt singur aici, nu-i nevoie de plural. Sa-nteleg ca vrei sa folosesti codul din postul anterior? Am sa te rog sa postezi aici daca merge sau nu. Daca nu merge sa postezi si ce anume nu merge. Link spre comentariu
Vizitator Eolos Postat Ianuarie 1, 2017 Partajează Postat Ianuarie 1, 2017 Hi there ! The code works fine with pic16f877A.. I created the hex file for pic18f4520 and pic18f4550 but i couldnt get any readings from the Lcd Display. Can u re write it for pic 18f4520 or 50 ? Link spre comentariu
Vizitator Eolos Postat Ianuarie 1, 2017 Partajează Postat Ianuarie 1, 2017 The Code is Belown.. I use Port A and E for ADC reading by Opamp.. Port B is for LCD, Port C and D are for output that controls some leds, relays etc.. Crystal is 4 Mhz. //LCD sbit LCD_RS at RB7_bit; sbit LCD_EN at RB6_bit; sbit LCD_D4 at RB5_bit; sbit LCD_D5 at RB4_bit; sbit LCD_D6 at RB3_bit; sbit LCD_D7 at RB2_bit; sbit LCD_RS_Direction at TRISB7_bit; sbit LCD_EN_Direction at TRISB6_bit; sbit LCD_D4_Direction at TRISB5_bit; sbit LCD_D5_Direction at TRISB4_bit; sbit LCD_D6_Direction at TRISB3_bit; sbit LCD_D7_Direction at TRISB2_bit; //Declarare variabile unsigned char ch, ADCx; unsigned int Tens, Curent, PVV, P24, P48, OFV, PV, DV, PI, P2, P4, OF, DW; unsigned long V, I, Pw, Av; char text[10]; const char *mesg1="%100"; const char *mesg2="%90"; const char *mesg3="%80"; const char *mesg4="%70"; const char *mesg5="%60"; const char *mesg6="%50"; const char *mesg7="%40"; const char *mesg8="%30"; const char *mesg9="%20"; const char *mesg10="%10"; const char *mesg11="AKU BOS"; void strConstCpy(char *dest, const char *source) { while(*source) *dest++ = *source++ ; *dest = 0 ; } //Functie principala void main() { INTCON = 0; // Dezactivare intreruperi TRISA = 0xFF; TRISE = 0xFF; // RA0, RA1 setate ca intrari TRISC = 0x00; // RC3 si RC4 setati pe iesire PORTC = 0; // Resetare port c TRISD = 0x00; // RC3 si RC4 setati pe iesire PORTD = 0; Lcd_Init(); // Initializare LCD Lcd_Cmd(_LCD_CURSOR_OFF); // Dezactivare cursor Lcd_Cmd(_LCD_CLEAR); // Stergere Ecran Delay_ms(600); // Delay 1 secunda Lcd_Out(1,5,"HYPERNOVA"); // Mesaj initial 1, prima linie Lcd_Out(2,2,"ELECTRIC"); // Mesaj initial 1 linia 2 Delay_ms(800); Lcd_Cmd(_LCD_CLEAR); // Stergere ecran Lcd_Out(1,4,"ALTERNATIVE"); // Mesaj initial 2, prima linie Lcd_Out(2,4,"POWER SYSTEMS"); // Mesaj initial 2, linia 2 Delay_ms(1000); Lcd_Cmd(_LCD_CLEAR); while (1) { //ADC Tens = 0; Curent = 0; PVV = 0; P24= 0; P48 = 0; OFV = 0; for (ADCx=0; ADCx<10; ADCx++) { Tens += ADC_Read(0); // Achizitie ADC pentru Tens Curent += ADC_Read(1); // Achizitie ADC pentru curent PVV += ADC_Read(7); P24 += ADC_Read(2); P48 += ADC_Read(5); OFV += ADC_Read(6); Delay_ms(30); } //Voltage Tens = Tens/ADCx; // Alocare valoare Tens V = (long)Tens*1000; // Converteste rezultat in milivolti V = V/1023; // 0...1023 => 0...1000mV ch = V/1000; // Extrage sute 100.00 Lcd_Chr(1,1,48+ch); // Afisare rezultat in format ASCII linia 1, coloana 1 ch = (V/100) % 10; // Extrage zeci 010.00 Lcd_Chr_CP(48+ch); // Afiseaza rezultat in format ASCII ch = (V/10) % 10; // Extrage unitati 001.00 Lcd_Chr_CP(48+ch); // Afiseaza rezultat in format ASCII Lcd_Chr_CP('.'); // Afiseaza caracter '.' ch = (V/1) % 10; // Extrage sutimi 000.10 Lcd_Chr_CP(48+ch); ch = V % 10; // Extrage zecimi 000.01 Lcd_Chr_CP(48+ch); LCD_Chr_CP('V'); // Afiseaza caracter 'V' Delay_ms(30); //Current Curent = Curent/ADCx; // Alocare valoare curent I = (long)Curent*5000; // Convertire rezultat in milivolti I = I/1023; // 0..1023 => 0-5000mV ch = I/1000; // Extragere zeci 10.00 Lcd_Chr(1,9,48+ch); // Scrie rezultatul in format ASCII linia 1, coloana 9 ch = (I/100) % 10; // Extragere unitati 01.00 Lcd_Chr_CP(48+ch); // Scrie rezultatul in format ASCII Lcd_Chr_CP('.'); ch = (I/10) %10; // Extragere sutimi 00.10 Lcd_Chr_CP(48+ch); // Scrie rezultatul in format ASCII ch = I % 10; // Extragere zecimi 00.01 Lcd_Chr_CP(48+ch); Lcd_Chr_CP('A'); // Afisare caracter 'A' la final Delay_ms(30); //Power Pw = V*I/1000; // Seteaza valoare Putere ch = Pw/1000; // Extrage mii 1000 Lcd_Chr(2,1,48+ch); // Scrie rezultatul in format ASCII linia 2, coloana 1 ch = (Pw/100) % 10; // Extrage sute 0100 Lcd_Chr_CP(48+ch); ch = (Pw/10) %10; // Extrage zeci 0010 Lcd_Chr_CP(48+ch); ch = Pw % 10; // Extrage unitati 0001 Lcd_Chr_CP(48+ch); Lcd_Chr_CP('W'); // Afiseaza "W" la sfarsit Delay_ms(30); //Protective Read PV = ADC_Read(7); DV = ADC_Read(0); PI = ADC_Read(1); P2 = ADC_Read(2); P4 = ADC_Read(5); OF = ADC_Read(6); DW= DV*PI /100; //Protective 24V if (P2>= 388 && P4< 388 && PV >=286 || P2>= 388 && P4< 388 && PV <286 && PI >=818 || P2>= 388 && P4< 388 && DW > 234) { PORTC.F3 = 1; PORTC.F4 = 0; } //Protective 48V else if (P4>= 388 && P2< 388 && PV >=572 || P4>= 388 && P2< 388 && PV <572 && PI >=818 || P4>= 388 && P2< 388 && DW > 468) { PORTC.F0 = 1; PORTC.F6 = 0; } //Button Protective - Onn Off else if (P2>= 388 && P4>= 388 || OF >= 388) { PortC.F4 = 0; PortC.F6 = 0; PortC.F3 = 1; } else { PortC.F4 = 1; } // Aku Seviye 24V Sistem if (OF >= 388 && PV > 256 && PV <= 275) { strConstCpy(text,mesg1); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } else if (OF >= 388 && PV > 254 && PV <= 256) { strConstCpy(text,mesg2); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } else if (OF >= 388 && PV > 252 && PV <= 254) { strConstCpy(text,mesg3); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } else if (OF >= 388 && PV > 249 && PV <= 252) { strConstCpy(text,mesg4); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } else if (OF >= 388 && PV > 246 && PV <= 249) { strConstCpy(text,mesg5); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } else if (OF >= 388 && PV > 243 && PV <= 246) { strConstCpy(text,mesg6); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } else if (OF >= 388 && PV > 240 && PV <= 243) { strConstCpy(text,mesg7); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } else if (OF >= 388 && PV > 237 && PV <= 240) { strConstCpy(text,mesg8); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } else if (OF >= 388 && PV > 231 && PV <= 237) { strConstCpy(text,mesg9); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } else if (OF >= 388 && PV > 215 && PV <= 231) { strConstCpy(text,mesg10); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } else if (OF >= 388 && PV <= 215) { strConstCpy(text,mesg11); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } // Aku Seviye 48V Sistem else if (OF >= 388 && PV > 511 && PV <= 530) { strConstCpy(text,mesg1); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } else if (OF >= 388 && PV > 508 && PV <= 511) { strConstCpy(text,mesg2); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } else if (OF >= 388 && PV > 504 && PV <= 508) { strConstCpy(text,mesg3); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } else if (OF >= 388 && PV > 499 && PV <= 504) { strConstCpy(text,mesg4); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } else if (OF >= 388 && PV > 493 && PV <= 499) { strConstCpy(text,mesg5); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } else if (OF >= 388 && PV > 487 && PV <= 493) { strConstCpy(text,mesg6); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } else if (OF >= 388 && PV > 480 && PV <= 487) { strConstCpy(text,mesg7); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } else if (OF >= 388 && PV > 473 && PV <= 480) { strConstCpy(text,mesg8); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } else if (OF >= 388 && PV > 462 && PV <= 473) { strConstCpy(text,mesg9); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } else if (OF >= 388 && PV > 429 && PV <= 462) { strConstCpy(text,mesg10); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } else if (OF >= 388 && PV > 401 && PV <= 429) { strConstCpy(text,mesg11); Lcd_Out(2, 9, text); Delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); } } } Link spre comentariu
quinn Postat Aprilie 17, 2017 Partajează Postat Aprilie 17, 2017 am atasat hex-ul pentru PIC16F876A care permite afisarea unei tensiuni de max 50V si 10A, pentru schema din topic mai aveti acest hex? Multumesc! Link spre comentariu
minel Postat Noiembrie 20, 2018 Partajează Postat Noiembrie 20, 2018 Am construit si eu acest v-a. dupa schema de sus si intampin 1 problema: valoarea dupa virgula nu este stabila,variaza in limite mari uneori si 5 ordine de marime(sute de mA si mV) in conditiile in care tensiunea/curentul masurat este stabil pe multimetru. Link spre comentariu
informer Postat Noiembrie 20, 2018 Partajează Postat Noiembrie 20, 2018 Nu cred ca-s chiar "ordine de marime"... inclin sa cred ca-s de fapt "unitati elementare"... :). Pe de alta parte schema asta, dupa parerea mea, nu-i vreun "aparat de masura" performant... ii o exemplificare a ce poti face c-un microcontroler, nu o scula de laborator. Poti sa modifici soft-ul sa faci media pe mai multe masuratori cu scaderea "vitezei de reactie"... poti sa alegi un PIC mai din zilele noastre... s.a.m.d.... oricum, sper ca n-ai cautat un trf. cu 20Vca neaparat... :D Link spre comentariu
Mircea Postat Noiembrie 21, 2018 Partajează Postat Noiembrie 21, 2018 @minel, pune 47-220nF (prin tatonare) in paralel cu D5 si R13. Link spre comentariu
minel Postat Noiembrie 21, 2018 Partajează Postat Noiembrie 21, 2018 (editat) Multumesc pt. raspuns Thunderer2018,am incercat solutia propusa de dvs. dar nu a avut nici un efect dar oricum, astfel mi-ati oferit alta idee si am decuplat intrarile 2,3 cu cate 100nF la masa iar acum fluctuatiile s-au redus ca intensitate si frecventa. Referitor la raspunsul ironic si rautacios( sper ca n-ai cautat un trf. cu 20Vca neaparat...) al lui informer imi cer scuze pt. ignoranta cu care v-am deranjat dar mi-ati spus ce stiam deja:ca sunt prost.Pentru mine este acceptabil aceast v-a pt. ca nu fac cercetare iar cu programarea am ramas mult in urma pt. ca nu am programat decat in Basic mici programele pe timpul HC-urilor... Editat Noiembrie 21, 2018 de minel Link spre comentariu
Mircea Postat Noiembrie 21, 2018 Partajează Postat Noiembrie 21, 2018 @minel, pai exact intrarile (pinii) 2 si 3 erau vizati de propunerea mea. Probabil ca traseele catre acesti pini sunt lungi, nu stiu ce cablaj a fost facut. Link spre comentariu
minel Postat Noiembrie 21, 2018 Partajează Postat Noiembrie 21, 2018 Am inteles de la inceput ideea dvs., cablajul intr-adevar nu e ok e cel de test... Link spre comentariu
informer Postat Noiembrie 21, 2018 Partajează Postat Noiembrie 21, 2018 2 hours ago, minel said: Referitor la raspunsul ironic si rautacios( sper ca n-ai cautat un trf. cu 20Vca neaparat...) al lui informer imi cer scuze pt. ignoranta cu care v-am deranjat dar mi-ati spus ce stiam deja:ca sunt prost.Pentru mine este acceptabil aceast v-a pt. ca nu fac cercetare iar cu programarea am ramas mult in urma pt. ca nu am programat decat in Basic mici programele pe timpul HC-urilor... Imi pare rau c-am devenit asa de seriosi incat nu mai putem intelege o gluma... te asigur ca n-am vrut sa dau nimic de inteles, am sa fiu mai atent pe viitor la exprimari. Referitor la acel transformator, m-a distrat alegerea avand in vedere ce tensiuni stabilizate se obtin... atat si nimic mai mult. :| Link spre comentariu
minel Postat Noiembrie 22, 2018 Partajează Postat Noiembrie 22, 2018 Citez autorul proiectului despre alegerea tensiunii respective: "M-am folosit de un amplificator diferential cu AO, in speta 358, alimentarea sa va fi la o tensiune auxiliara de 20V si asta pentru a permite o mai buna flexibilitate in ceea ce priveste CMIR maxim admis pe intrari ( common mode imput range ), care la 358 constat ca este intre -0,3v si pana la Vcc. " Link spre comentariu
informer Postat Noiembrie 22, 2018 Partajează Postat Noiembrie 22, 2018 34 minutes ago, minel said: Citez autorul proiectului despre alegerea tensiunii respective: "M-am folosit de un amplificator diferential cu AO, in speta 358, alimentarea sa va fi la o tensiune auxiliara de 20V si asta pentru a permite o mai buna flexibilitate in ceea ce priveste CMIR maxim admis pe intrari ( common mode imput range ), care la 358 constat ca este intre -0,3v si pana la Vcc. " OK, multumesc... nu mai comentez ca se interpreteaza cum n-as vrea. Link spre comentariu
