SIMULARI SCHEME CU TUBURI ELECTRONICE
THOMAS
Am zis aseara ca nu avem aceleasi simboluri.
.... dupa cum se vede nu fac trimitere la .asy
.SUBCKT ECC88   P G K
Ce am subliniat in declaratia de mai sus (Plate ,Grid , Katode) sunt dependente de modul de configurare a contactelor in simbolul cu extensia .asy .
In simbolul .asy , de obicei , inceperea enumerari se face de la P(late) . De exemplu ,pt trioda : P=1;G=2 si K=3 .
  • 2 săptămâni mai târziu...
Salutare,am inceput constructia unui amplificator PP bazat pe tubul rusesc 6P36S, si as dori sa fac niste simulari in Simetrix a schemei pe care o am, sa vad cum s-ar comporta.As dori sa va intreb, daca nu aveti cumva un model Spice pentru 6P36S?Multumesc!
Salutare,
Multumesc!
Poate va ajuta acest model:
.SUBCKT 6P36S 1 2 3 4
+ PARAMS: Ex=1.3635175771 Kg1=309.0082813435 Kp=24.0913514299 Kvb=9.8400037131 Mu=7.9029901821
+ Exd=1.0147791563 Kd=92.2849119725 Ks=0.2709901421 Kg=0.0018988875
+ CCG=22.0P CPG1=1.75P CCP=9.0P
Eat at 0 Value={limit(0.636*ATAN(limit(V(A,K),0,2000)/KVB),0,1)} ; arctangent shaping
Eme me 0 VALUE={PWR(LIMIT(V(A,K),0,2000),EXD)/KD} ; diode line
Egs gs 0 VALUE= {V(S,K)/KP*LOG(1+EXP((1/MU+V(G,K)/V(S,K))*KP))} ; effective voltage
Egs2 gs2 0 VALUE={(PWR(V(gs),EX)+PWRS(V(gs),EX))/(KG1*0.636)} ; total space current
G1 A K VALUE={LIMIT(V(gs2)*V(at),0,V(me))} ; plate current
Escrn sc 0 VALUE={KS*V(gs2)*(1.1-V(at))} ; reverse arctan shaping for screen current
G2 S K VALUE={Limit(V(sc),0,10)*LIMIT(V(S,K),0,10)/10} ; screen current
* no grid current data available so comment out the grid current line
*G3 G K VALUE={PWR(LIMIT(V(G,K)+1,0,1E6),1.5)*(1.25-V(at))*KG} ; grid current
C1 G K {CCG} ; CATHODE-GRID 1
C2 A G {CPG1} ; GRID 1-PLATE
C3 A K {CCP} ; CATHODE-PLATE
.ENDS 6P36S
*1 2 3 4 A S G K
*************************************************************************************Este un model Spice.
Foarte buna alegerea facuta pentru un amplificator cu aceste tuburi,sunt unele dintre cele mai faine tuburi de BO cu care putem obtine performanta intr-un amplificator audio.
Sunt tuburi robuste si au un "sunet placut" in configuratii PP dar mai ales in SE conectate ca triode,felicitari! :aplauze
Buna ziua,Domnul Lazaroiu daca se poate si aveti ceva timp
va rog frumos sa puneti in Spice corectorul acesta de ton
Am in lucru un AAf ,SE cu 2 x G807 (paralel) si amicul pentru care il construiesc vrea un corector
pentru inalte si bass. Va multumesc anticipat ,cu stima !
Posted Image
Adaug si schema AAFului
Posted Image
La final, de ce nu alimentezi partea de atac după drosel?Cîte grile are 807?
Initial schema a fost proiectata pentru EL34 ,voi face modificarile de rigoare la timpul potrivit ,deocamdata sunt preocupat de corectia de ton, merci Zal ...
Aveti mai jos schema simulata in SPICE cu valorile componentelor propuse de dv.,eu mi-am permis doar doua mici modificari in asa fel incat acest corector de ton sa fie ceva mai stabil la frecventele superioare unde avea tendinta de a oscila in RF,modificarile fiind: C11 (330pF) paralel pe R9 si rezistenta de sarcina pe iesire R16=470K care in general este rezistenta de intrare a etajului urmator.
Tensiunea la intrare este standart de 0.707V[rms] iar la iesire este marcata pe schema in trei puncte pentru pozitia potentiometrilor; maxim,minim si jumatate.
NU stiu de unde ati luat schema dar reglajul pentru frecventele joase este un pic exagerat,dar pana la urma tot in practica veti realiza punerea la punct,oricum aveti mult de lucru... :da
P.S eu as fi ales un activ baxandall tone clasic.
Va multumesc Dnul Lazaroiu, schema e conceputa de inginerii de la SABA si deja
am pus`o,, la treaba,, adica e in probe pe un amplif.Regleaza ,,nemteste ,, adica pe intreaga cursa a potentiometrelor (nu doar la capete) si sunt foarte multumit .
Cu stima.
Posted Image
Posted Image
Va multumesc Dnul Lazaroiu, schema e conceputa de inginerii de la SABA si deja am pus`o,, la treaba,, adica e in probe pe un amplif.Regleaza ,,nemteste ,, adica pe intreaga cursa a potentiometrelor (nu doar la capete) si sunt foarte multumit .Cu stima.***************
Excelent,ma bucur ca sunteti "prins" de acest microb atat de mult si ca experimentati foarte multe montaje fara frica si cu o pasiune de invidiat,va felicit! In ceea ce priveste reglajul de ton propus de dv.,sigur ca funcioneaza liniar si are efect pe intreaga cursa a potentiometrelor iar eu nu am aratat in acea simulare ca efectul lor este numai la capete,doar am punctat maximul si minimul posibil de reglaj in gama audio,dar si in pozitia de 1/2 din valoarea potentiometrelor,reglajul este eficinet daca pot spune asa ; pentru fiecare ohm din valoarea potentiometrelor. REmarca pe care am facut-o referitor la reglajul pentru frecventele joase a fost doar pentru ca iese din standartele cunoscute pentru reglajele de ton,dar daca dv. va place atunci totul este perfect. Atentie si la schema etajului final,alegeti bine PSF-ul pentru cele doua tuburi finale G-807 in paralel in modul trioda si mai ales PSF-ul pentru tubul de intrare RV-12P2000 (P2000).Eu am verificat schema si pare interesanta iar daca o sa considerati ca va ajuta o pot trimite pe MP,bineinteles mai pe seara...
...Regleaza ,,nemteste ,,...
fără comentarii(roz):
Va rog sa fiti amabil si sa analizati si varianta cu cursoarele la maximum!De asemenea as fi incantat de o varianta de regulator de ton mai buna,va multumesc. P.S. Personal agreez modalitatea ,,fina ,, delicata , de reglaj ,verso reglajele abrupte ,incisive....
Păi nu prea e curba ce ar trebui, posibilele explicaţii ar fi existenţa unui puţometru de volum cu corecţie fiziologică permanentă, pe tot traseul pistei, în schema originală, sau necesitatea corectării unor difuri mai slabe ce veneau împreună cu ampliful.Schema originală?
Schema originala e exact ce am prezentat mai sus (in creion!) luata de pe= Saba privat forum= Mentionez ca eu sunt foarte multumit de cum lucreaza corectorul.
