pompa recirculare myson cp 53
Vizitator frantiar
  • Răspunsuri 4
  • costi002
Zile populare
poate asta ajuta mai mult ?
Posted: Sat Apr 18, 2009 2:48 pm
here is the wiring scheme if u still need it.......
1 = red 2 = white 3 = brown 4 = blue 5 = mauve/purple L = Brown. The number 3 pin takes its brown wire from the second live pin (L). The black wire goes to the N pin. There should be a green earth wire that connects from earth terminal to the metal body of the pump . the 2 white capacitor wires should be already soldered to their 2 pins which are pin 5 (mauve/purple) from edgee of capacitor The white from central position on the capacitor goes to neutral (N) . i am not an expert but I recently bought an un-used Myson CP53 cheap at a boot sale - Not yet installed but seems to be in un-tampered state
Back to top
Read more: http://www.diynot.com/forums/viewtopic. ... z1eBZAgBxm
intre negru si maro trebuie sa ai aprox 230ohm.acolo se pune sigur alimentarea de la retea. apoi, pentru cele 3 viteze trebuie sa fie un fir comun (pt condensator care poate fi legat cu maro sau albastru) si in functie de celalat fir unde pui capacitorul obtii viteza. intrebarile sunt:- ai cumva doua fire legate intre ele (adica 0 ohm intern)?- sunt 6 cu tot cu firul de impamantare?
