Conectare 5 boxe
Vizitator cdcatalin1981
Salut ,
Sunt pe forumul acest si cu experienta spre zero in electronica .
M-ar interesa sa stiu cum leg 6 boxe cu rezistenta de 8 ohmi la um amplificator care lucreaza in 8 ,4 si 2 ohmi.
Detalii boxe :
Type : 2-way HiFi Pro, sealed box
Cabinet : Enforced PP4 ABS
Woofer : 6.5” HD Type
Tweeter : 1” HD silk dome on Varithroat horn
Impedance : 8 Ohm
RMS Power 8 ohm
AES Rated : 150 watt
Music - Program : 200 watt
Dynamic Peak (low-cut) : 400 watt
Detalii amplificator :
Behringer iNuke NU1000 Amplifier, 2 x 500 Watt into 2 Ohms, 2x 300 Watt into 4 Ohms, 1000 Watt thomann into 4 Ohms bridge mode,
sau daka se pot lega la acest amplificator :
echnical data: 720 watt pro final amplifier Output rating: 2 x 360 w, 4 ohm 2 x 240 w, 8 ohm
Va multumesc
  • Răspunsuri 1
  • Dj_Dog
