VAX Postat Martie 17, 2019 Partajează Postat Martie 17, 2019 Filtru elicoidal - schema + detalii. https://fccid.io/BZ5DTR10SC/Schematics/schematics-2266404.pdf Link spre comentariu
VAX Postat Martie 17, 2019 Partajează Postat Martie 17, 2019 Helical Resonator Notch Filter. Link spre comentariu
grosu99 Postat Martie 19, 2019 Partajează Postat Martie 19, 2019 http://www.155la3.ru/ aici gasiti date despre orice componenta sovietica Link spre comentariu
grosu99 Postat Martie 20, 2019 Partajează Postat Martie 20, 2019 Cautind dupa un integrat SL6270 am gasit cartea asta http://www.bitsavers.org/components/plessey/1981_Radio_and_Radar_Communications_ICs.pdf Link spre comentariu
grosu99 Postat Mai 25, 2019 Partajează Postat Mai 25, 2019 Ptr incepatori https://www.qsl.net/g3oou/progressiverxdesign.html Link spre comentariu
VAX Postat Iunie 15, 2019 Partajează Postat Iunie 15, 2019 https://uloz.to/!HsMEc8ttg/feynman-1-pdf https://uloz.to/!E2xBNPXiQ/feynman-2-pdf https://uloz.to/!sH29FznaF/feynman-3-pdf https://uloz.to/!Zhbz63eZ/the-feynman-lectures-on-physics-vol-1-pdf https://uloz.to/!zqT1asba/the-feynman-lectures-on-physics-vol-2-pdf https://uloz.to/!dDWSD1nn/the-feynman-lectures-on-physics-vol-3-pdf https://uloz.to/!FxgfRNnr/feynman-lectures-on-physics-complete-volumes-1-2-3-pdf 1 Link spre comentariu
VAX Postat Iunie 23, 2019 Partajează Postat Iunie 23, 2019 Class E Amplifiers http://www.norcalqrp.org/files/Class_E_Amplifiers.pdf Link spre comentariu
VAX Postat Iunie 27, 2019 Partajează Postat Iunie 27, 2019 Scormoniti bine la adresa asta, unde este data multa documentatie. https://the-eye.eu/public/Books/Electronic Archive/ Link spre comentariu
grosu99 Postat Iunie 28, 2019 Partajează Postat Iunie 28, 2019 https://dokumen.tips/documents/modern-communications-receiver-design-and-technology-586e0b00195b8.html Link spre comentariu
yo3fhm Postat Iulie 7, 2019 Partajează Postat Iulie 7, 2019 RSGB Radio Communication Handbook, 4th ed., 1968 1 Link spre comentariu
yo3fhm Postat Iulie 11, 2019 Partajează Postat Iulie 11, 2019 (editat) Radiocomunicatii cu banda laterala unica - I.C. Boghitoiu, 1972 Circuite cu tranzistoare - Tudor Tanasescu , Ed. Tehnica 1961 Editat Iulie 11, 2019 de yo3fhm Link spre comentariu
VAX Postat Iulie 12, 2019 Partajează Postat Iulie 12, 2019 Cand scanez carti prelucrez imaginile cu programul (free) Digital Camera Enhancer de la firma Mediachance, sau cu DCE Autoenhance. Dupa scanare contrastul nu este bun si trebuie marit. Uitati cum merge programul. Poza initiala (pe hartie color - film ORWO), anul 1983. Dupa prelucrare. Link spre comentariu
yo3fhm Postat Iulie 12, 2019 Partajează Postat Iulie 12, 2019 (editat) Acum 5 ore, VAX a spus: Dupa scanare contrastul nu este bun si trebuie marit. Pentru a nu vi se mai intampla acest lucru, trebuie ca mai intai sa revedeti setarile de contrast proprii ale scannerului. Asta e o chichita care de obicei se rezolva din aplicatia software proprie a scannerului sau direct din setarile driverilor acestuia. In setari veti gasi atat reglajul luminozitatii cat si al contrastului si chiar cel de gamma . Trebuie sa incercati succesiv de mai multe ori, pana cand obtineti ceva satisfacator. Pozele pe hartie nu au o rezolutie prea grozava, asadar nu vor iesi dupa scanare ca cele pe care le puteti obtine in format digital (nici macar daca veti folosi scannere foarte performante). "De unde n-are, n-ai ce sa-i ceri ! " . O solutie mai buna ar putea fi scanarea negativelor (daca le mai aveti) la un centru profesional care ofera astfel de servicii. Exista si echipamente performante pe care le puteti achizitiona, dar sunt scumpe. Iar scannerele de film destinate publicului larg, ofera o calitate medie. Marirea contrastului conduce si la evidentierea problemelor legate de zgomotul de imagine. Pentru a avea un zgomot cat mai mic, trebuie sa aveti un senzor cat mai calitativ si de preferat cu rezolutie foarte mare, de exemplu 4800x4800 dpi, 9600x9600dpi sau mai mult. Astfel, cand veti scana la rezolutie mai mica (1200x1200), performantele vor fi mult imbunatatite. Cand mentionez "rezolutie", ma refer la cea optica si nu la cea digitala (interpolata). Daca aveti un scanner mai vechi, care sa permita cel mult 1200x1200, atunci si zgomotul de imagine va fi mai crescut si nu prea aveti ce-i face ! Cu stima, Cezar Editat Iulie 12, 2019 de yo3fhm Link spre comentariu
VAX Postat Iulie 12, 2019 Partajează Postat Iulie 12, 2019 Progranul DCE Autoenhance imbunatateste imaginea si daca a fost obtinuta cu scaner de cea mai buna calitate. Accentueaza tranzitiile (de culoare, de stralucire) si se vad schemele mult mai clar. Eu il folosesc intotdeauna. Comprimarea o fac cu DjVu Solo 3.1 . Fisierele ies mai mici ca in pdf. Link spre comentariu
grosu99 Postat Iulie 25, 2019 Partajează Postat Iulie 25, 2019 http://www.f6evt.fr/savenbsradio.pdf Link spre comentariu
