lama Postat Noiembrie 1, 2011 Partajează Postat Noiembrie 1, 2011 Salut. Am o problema tare ciudata. Fie pu pic16f628a, cu MCLS pus la + prin 10k si o rezistenta de 1k si un led legate la RA7 (iar celalalt capat la masa).Fie codul de mai jos(care nu merge)Aveti idee de ce?/************************************************************************* ** Processor: 16F628a ** Pin assignments: ** RA7 - indicator LED ** RA6 - Buzzer ** RA1 - DQ la DS18B20 ** RB0 - RS ** RB1 - EN ** RB2-5 - D4-7 LCD ** RA2 - button pe pin pus la Vdd prin 10k ** RA3 - button pe pin pus la Vdd prin 10k ** RA4 - button pe pin pus la Vdd prin 10k *************************************************************************/#include #define _XTAL_FREQ 4000000 // oscillator frequency for _delay() /***** CONFIGURATION *****///FOSC_INTOSCIO I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN//WDTE_OFF Watchdog Timer Enable OFF//PWRTE_ON Power-up Timer Enable ON//LVP_OFF Low-Voltage Programming Enable ON//BOREN_OFF Brown-out Detect Enabl OFF//CPD_OFF Data EE Memory Code Protection OFF//CP_OFF Flash Program Memory Code Protection OFF//MCLRE_OFF RA5/MCLR/VPP pin function is digital input, MCLR internally tied to VDD__CONFIG(FOSC_INTOSCIO & WDTE_OFF & PWRTE_ON & LVP_OFF & BOREN_OFF & CPD_OFF & CP_OFF & MCLRE_OFF);/************************************************************** Main Program**************************************************************/void main(void){ TRISB = 0x00; // portB is output; TRISA = 0x00; CMCON = 0b00000111; // disable comparators PORTB = 0x00; // all low PORTA = 0x00;while(1){ //looping//RA7=1;__delay_ms(2000);RA7=0;PORTA=1;__delay_ms(2000);PORTA=0; } //loping} //main Link spre comentariu
Liviu M Postat Noiembrie 1, 2011 Partajează Postat Noiembrie 1, 2011 Ce versiunede compilator ai (stiu ca e picc de la HiTech, ma intereseaza releasul)? Ca eu am 9.80 si ce e la mine in pic16f62xa.h difera de ce ai folosit tu in cod (in directiva __CONFIG) // Oscillator configurations #define RCCLK 0x3FFF#define RCIO 0x3FFE#define INTCLK 0x3FFD#define INTIO 0x3FFC#define EC 0x3FEF#define HS 0x3FEE#define XT 0x3FED#define LP 0x3FECCu alte cuvinte, ca sa folosesti RA6&RA/ ca I/O iti trebuie INTIO (daca ai avea acelasi compilator ca mine). Link spre comentariu
MatyC Postat Noiembrie 1, 2011 Partajează Postat Noiembrie 1, 2011 Nu am documentatia la indemana dar ma intreb daca nu trebuie dezactivat si ADCON ? Link spre comentariu
lama Postat Noiembrie 1, 2011 Autor Partajează Postat Noiembrie 1, 2011 Ce versiunede compilator ai (stiu ca e picc de la HiTech, ma intereseaza releasul)?Ca eu am 9.80 si ce e la mine in pic16f62xa.h difera de ce ai folosit tu in cod (in directiva __CONFIG) // Oscillator configurations #define RCCLK 0x3FFF#define RCIO 0x3FFE#define INTCLK 0x3FFD#define INTIO 0x3FFC#define EC 0x3FEF#define HS 0x3FEE#define XT 0x3FED#define LP 0x3FECCu alte cuvinte, ca sa folosesti RA6&RA/ ca I/O iti trebuie INTIO (daca ai avea acelasi compilator ca mine).vers 9.83si are un heder separat ptr 628a.care arata c-am asa// Config Register: CONFIG#define CONFIG 0x2007// Oscillator Selection bits// RC oscillator: CLKOUT function on RA6/OSC2/CLKOUT pin, Resistor and Capacitor on RA7/OSC1/CLKIN#define FOSC_EXTRCCLK 0xFFFF// RC oscillator: I/O function on RA6/OSC2/CLKOUT pin, Resistor and Capacitor on RA7/OSC1/CLKIN#define FOSC_EXTRCIO 0xFFFE// INTOSC oscillator: CLKOUT function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN#define FOSC_INTOSCCLK 0xFFFD// INTOSC oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN#define FOSC_INTOSCIO 0xFFFC// EC: I/O function on RA6/OSC2/CLKOUT pin, CLKIN on RA7/OSC1/CLKIN#define FOSC_ECIO 0xFFEF// HS oscillator: High-speed crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN#define FOSC_HS 0xFFEE// XT oscillator: Crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN#define FOSC_XT 0xFFED// LP oscillator: Low-power crystal on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN#define FOSC_LP 0xFFEC// Watchdog Timer Enable bit// WDT enabled#define WDTE_ON 0xFFFF// WDT disabled#define WDTE_OFF 0xFFFB// Power-up Timer Enable bit// PWRT disabled#define PWRTE_OFF 0xFFFF// PWRT enabled#define PWRTE_ON 0xFFF7// RA5/MCLR/VPP Pin Function Select bit// RA5/MCLR/VPP pin function is MCLR#define MCLRE_ON 0xFFFF// RA5/MCLR/VPP pin function is digital input, MCLR internally tied to VDD#define MCLRE_OFF 0xFFDF// Brown-out Detect Enable bit// BOD enabled#define BOREN_ON 0xFFFF// BOD disabled#define BOREN_OFF 0xFFBF// Low-Voltage Programming Enable bit// RB4/PGM pin has PGM function, low-voltage programming enabled#define LVP_ON 0xFFFF// RB4/PGM pin has digital I/O function, HV on MCLR must be used for programming#define LVP_OFF 0xFF7F// Data EE Memory Code Protection bit// Data memory code protection off#define CPD_OFF 0xFFFF// Data memory code-protected#define CPD_ON 0xFEFF// Flash Program Memory Code Protection bit// Code protection off#define CP_OFF 0xFFFF// 0000h to 07FFh code-protected#define CP_ON 0xDFFF Link spre comentariu
lama Postat Noiembrie 1, 2011 Autor Partajează Postat Noiembrie 1, 2011 Incep sa cred ca trebuia sa pun FOSC_INTOSCCLK. Link spre comentariu
Liviu M Postat Noiembrie 1, 2011 Partajează Postat Noiembrie 1, 2011 Ai dreptate, le-au modificat. Eu nu prea mai am idei. Eventual sa activezi si PERTE. bit 3: PWRTE: Power-up Timer Enable bit (1) 1 = PWRT disabled 0 = PWRT enabled @MatyC : n-are ADC. LE Daca poi optiunea aia cu OSC iti scoate clockul pe pini si chiar nu-i mai poti folosi. Link spre comentariu
lama Postat Noiembrie 1, 2011 Autor Partajează Postat Noiembrie 1, 2011 Incep sa cred ca trebuia sa pun FOSC_INTOSCCLK. :cry: nu mergesi nu are ADC acest circuit , deci nu am ce oprin. Link spre comentariu
Liviu M Postat Noiembrie 1, 2011 Partajează Postat Noiembrie 1, 2011 Cu alti pini ai incercat? Merge ceva sau numisca deloc? Link spre comentariu
lama Postat Noiembrie 1, 2011 Autor Partajează Postat Noiembrie 1, 2011 Nu mai inteleg nimicAm incarcat in PIC un cod mai vechi care foloseste acest minunat pin RA7 (un 5 led chaser)Si culmea ca merge.Singura deosebire e in configurare, unde are PWRTE_ONUPDATE: e identic si hex-ul incarcat aprinde RA7 Link spre comentariu
lama Postat Noiembrie 1, 2011 Autor Partajează Postat Noiembrie 1, 2011 Am modificat codul din 5 led chaser (mai jos) si merge. DAR nu ma prind de ce./************************************************************************* ** Processor: 16F628 ** *************************************************************************** ** Pin assignments: ** RA6 - indicator LED ** RA7 - indicator LED ** RB3 - indicator LED ** RB4 - indicator LED ** RB5 - indicator LED ** GP4 - indicator LED sau RS232 ** RB0 - Legat la RA2 DUMMY ptr RB0 ** RB1 - Legat la RA3 DUMMY ptr RB1 ** RA0,1,2,3,4 - Touch PAD *************************************************************************/#include __CONFIG(FOSC_INTOSCIO & WDTE_OFF & PWRTE_ON & LVP_OFF & BOREN_OFF & CPD_OFF & CP_OFF & MCLRE_OFF);#define _XTAL_FREQ 4000000 /* Crystal frequency in MHz */#define cit_delay 200void main(void){unsigned char sPORTA, sPORTB; // port D init TRISB = 0x00; // portB is output; TRISA = 0x00; CMCON = 0b00000111; // disable comparators PORTB = 0x00; // all low PORTA = 0x00; while(1){ RA7=1; __delay_ms(cit_delay); RA7=0; __delay_ms(cit_delay); }} Link spre comentariu
Liviu M Postat Noiembrie 1, 2011 Partajează Postat Noiembrie 1, 2011 In primul cod n-ai nici un delay dupa PORTA=0;Asta inseamna ca sta in 0 1 us, dupa care trece inapoi in 1. Asta sa fie? Link spre comentariu
lama Postat Noiembrie 1, 2011 Autor Partajează Postat Noiembrie 1, 2011 In primul cod n-ai nici un delay dupa PORTA=0;Asta inseamna ca sta in 0 1 us, dupa care trece inapoi in 1. Asta sa fie?Am un delay de 2 sec Link spre comentariu
Liviu M Postat Noiembrie 1, 2011 Partajează Postat Noiembrie 1, 2011 Pai pune si tu tot codul, ca aici n-ai: while(1){ //loopin //RA7=1;__delay_ms(2000);RA7=0; PORTA=1;__delay_ms(2000);PORTA=0;} //loping Link spre comentariu
sosoi Postat Noiembrie 1, 2011 Partajează Postat Noiembrie 1, 2011 Subscriu celor spuse de Liviu In primul cod lipseste delayms(2000); dupa PORTA=0; Al II-lea cod merge tocmai pentru ca ai pus __delay_ms(cit_delay); si dupa RA7=0; Link spre comentariu
MatyC Postat Noiembrie 1, 2011 Partajează Postat Noiembrie 1, 2011 Mi-a ramas pe creier ADCON asta mai de demult. Liviu M ai dreptate ca la primul cod prezentat nu are delay la tranzitia din 0 in 1. Corect ar fi trebuit: while(1){ //loopin //RA7=1;__delay_ms(2000);RA7=0; PORTA=1;__delay_ms(2000);PORTA=0;__delay_ms(2000);} //lopingin ciuda faptului ca are efect asupra intregului port A. Nu cumva trebuie RA7? Link spre comentariu
