Radio casetofon auto RCD 300
petcu_daniel
  • Răspunsuri 19
  • petcu_daniel
    7
  • catalin004
  • ghita_cosma
  • dan cod
Am gasit aici,http://forum.softpedia.com/lofiversion/index.php/t562256.html.,va multumesc, dar acum incepe distractia. Trebuie sa-l conectez pe un W Touran. Revin cand aflu mai multe despre casetofonul cu care este echipat. Stiu sigur ca e mufa iso dar nu stiu inca cum e cu CAN L si CAN H si cum isi face cel de pe masina STAND-BY.Pe masina e un Blaupunkt TravelPilot DX-R4. Am tot cautat dar la asta nu gasesc configuratia. Ma poate ajuta cineva?
posibil daca nu sant aceasi generatie sa nu ai can pe masina pe care vrei sa-l montezi si atunci numai poti sa se opreasca din contact ,sa se aprinda luminile pe fata cand pui pozitia ,etc
Vizitator comfel
Iata schema de RCD 300/500, se mai numeste si Quadlock:Probabil despre aceasta mufa este vorba ....Traduse in Engleza Multi-pin connector 1, 8-pin, loudspeaker outputs1 - Loudspeaker, rear right, positive2 - Loudspeaker, front right, positive3 - Loudspeaker, front left, positive4 - Loudspeaker, rear left, positive5 - Loudspeaker, rear right, negative6 - Loudspeaker, front right, negative7 - Loudspeaker, front left, negative8 - Loudspeaker, rear left, negativeMulti-pin connector 2, 8-pin, voltage supply, CAN bus, telephone mute switch9 - CAN high10 - CAN low11 - Telephone mute switch12 - Negative connection, terminal 3113 - Not assigned14 - Not assigned15 - Positive connection, terminal 3016 - Anti-theft system control signal, SAFEMulti-pin connector 3, 12-pin, telephone signal input1–5 - Not assigned6 - Telephone NF signal input, negative7–11 - Not assigned12 - Telephone NF signal input, positiveMulti-pin connector 4, 12-pin, CD changer control and CD audio input signals1 - Headphone output signal, right, positive2 - CD changer, left and right channels, negative3 - Headphone output signal, audio earth4 - CD changer voltage supply, positive5 - Headphone output signal, left, positive6 - CD changer, bus DATA OUT7 - Not assigned8 - CD changer, left channel, positive9 - CD changer, right channel, positive10 - CD changer, control signal11 - CD changer, bus DATA IN12 - CD changer, bus CLOCK
Multumesc mult pentru intentia de a ma ajuta dar cred ca nu m-am facut inteles. Pe masina este montat din fabrica DX-R4 la care nu am configuratie sau mai exact ceva seamna din ce am primit de la domnul zvasile dar nu vad pe acea mufa CAN. RCD 300 l-am descusut,am identificat toate firele dar din documentatia pe care o am pana in prezent raman cu CAN-ul lui RCD 300 in aer.
Ai citit ce am scris mai sus ?
Este exact ce cautam.Din cate vad aparatul are pe el configuratia pinilor.Se pare ca nu am CAN pe masina in mufa aparatului.Imi amintesc sigur ca mufa care are CAN in configuratie pe masina nu exista. Ma gandsesc sa ma leg direct pe canul masinii(cele doua fire portocalii cu dunga x si Y pe care le am notate pe undeva). Ce parere aveti?Pentru cei care au nevoie, portocaliu cu dunga maro CAN-L si portocaliu cu dunga neagra CAN-H.
