Modificare cod pt 12f675 in 16f628a
critix
Salut
Am urmatorul cod in mikrobasic pt 12f675.
Doresc sa ma ajutati in modificarea respectivului cod pt a putea folosi pe un 16f628A. (nu reusesc sa ma descurc cu partea de intreruperi...)
Codul este urmatorul:
program testsymbol LED     = GPIO.5 const led_tmr= 10dim inter_cnt as bytesub procedure Init_Main()' Osccal restore  OSCCAL=OSCCAL  asm     BSF     STATUS,RP0    ; set file register bank to 1     CALL    0x3FF         ; retrieve factory calibration value     MOVWF   OSCCAL        ; update register with factory cal value     BCF     STATUS,RP0    ; set file register bank to 0  end asm  CMCON=7  ANSEL=0  GPIO=0  TRISIO=%001111  T0CS_bit=0               ' internal clock source for TMR0  PSA_bit=0                ' prescale assigned to TMR0  PS2_bit=1                ' 1:256 prescaler to TMR0  PS1_bit=1  PS0_bit=1  T0IE_bit=1               ' enable TMR0 interrupt  GIE_bit=1                ' enable  interruptsend subsub procedure interrupt    TMR0=61                 ' preload timer  ( ~50 ms overflow period)    Inc(inter_cnt)      ' increment interrupts counter    if inter_cnt=led_tmr then       inter_cnt=0      ' reset interrupts counter       LED=not(LED)     ' toggle LED    end if    T0IF_bit=0          ' reset flagend submain:'   Main program   Init_Main()  inter_cnt=0              ' initialize counterwhile TRUE   ' restul programului.....wendend.
Va multumesc anticipat.
  • Răspunsuri 4
  • critix
  • fratello
  • Voltus
program test
'symbol LED = GPIO.5
symbol LED = PORTA.5
const led_tmr= 10
' Osccal restore
' OSCCAL=OSCCAL
' asm
' BSF STATUS,RP0 ; set file register bank to 1
' CALL 0x3FF ; retrieve factory calibration value
' MOVWF OSCCAL ; update register with factory cal value
' BCF STATUS,RP0 ; set file register bank to 0
' end asm
CMCON=7
'ANSEL=0
VRCON = 0
' GPIO=0
PORTA = 0
'TRISIO=%001111
TRISA = %0000111 ; fac din porta.5 iesire
PS1_bit=1
PS0_bit=1
end sub
end if
end sub
main:
' Main program
Init_Main()
while TRUE
wend
end.
Poate te ajuta acest exemplu, desi este scris in PicBasicPro :
@ DEVICE pic16F628A, intOSC_osc_noclkout, WDT_OFF, PWRT_ON, MCLR_OFF, LVP_OFF, CPD_OFFDEFINE OSC 4CMCON	= 7VRCON 	= 0INTCON 	= 0	TrisB=0					' Make PortB outputs	TrisA.0=0:TrisA.1=0:TrisA.2=0		' Make only the specific bits of PortA outputs						TrisA.3=0:TrisA.4=1	PortA=0:PortB=0			     	' Clear PortB and PortAINTCON = %00100000OPTION_REG = %10000000ON INTERRUPT GOTO ISRINTCON = %10100000MAIN : ; aici e codul principalGoto MainDISABLEISR:   ; aici se pune ceea ce doreste a se face in intrerupereINTCON.2=0RESUMEENABLE
