volhov Postat Octombrie 7, 2011 Partajează Postat Octombrie 7, 2011 Disponibila statia din titlu, varianta fara TNC intern.Frequency range TX(T): 144-147.995MHz (FM)RX(T): 118-135.995 MHz (AM)136-173.995MHz (FM)TX&RX(E): 144-145.995MHzOperating mode 16K0F3E (FM)/8K50F3E (Narrow-FM)F1(9600bps)/F2(1200bps)/10F3 * 1/A3E (RX only DR135TMkII)Channel steps 5, 8.33, 10, 12.5, 15, 20, 25, 30, 50 KHzMemory channel 100 channels + 1 quick recall (CALL)Antenna impedance 50ohm unbalancedFrequency stability +/- 2.5ppm TCXOPower supply requirement 13.8V DC +/- 15% negative groundCurrent drain Approx. 11.0A TX HighApprox. 0.4A squelchedUsable temperature range -10 - +60c (14 - 140F)Dimensions (w/o projection) 142(W) x 40(H) x 174(D) mm5.59"(W) x 1.57"(H) x 6.85"(D)Weight Approx. 1.0Kg (35.3oz)CTCSS tone encoder/decoder 39 tonesDigital Coded Squelch encoder/decoder 104 codesTransmitterOutput power Approx. 50W (HI)Approx. 20W (MID)Approx. 5W (LOW)Modulation system Variable reactance frequency modulationSpurious emission Less than -60 dBMaximum frequency deviation +/- 5 KHz (FM) / +/- 2.5 KHz (NFM)ReceiverReceive system Double-conversion superheterodyneSensitivity (-12dB SINAD) *2 Less than -16.0dBuIntermediate frequency 1st IF 21.7 MHz, 2nd IF 450 KHzSelectivity *2 -6dB: 12KHz or more-60dB: 28KHz or less (FM)-6dB: 6KHz or more-60dB: 16KHz or less (NFM)Audio output power More than 2W(8ohm 10%THD)Note: * 1 Optional units required* 2 Typical within the amateur radio band(s).Optional AccessoriesMicrophones EMS-57 DTMF/Remote microphonePret: 300 leiDetalii suplimentare pe PM. Link spre comentariu
volhov Postat Octombrie 16, 2011 Autor Partajează Postat Octombrie 16, 2011 .... inca disponibila ..... Link spre comentariu
