danzup Postat Septembrie 8, 2011 Partajează Postat Septembrie 8, 2011 http://www.enjoythemusic.com/diy/0911/s ... peaker.htm Nu m-am prins ce Lowther / Fostex a folosit acolo... ai unde a pus Lowther PM6A , in slotul de bas sau e ala de se vede pe bafle ??? Link spre comentariu
adrian_pic Postat Septembrie 8, 2011 Partajează Postat Septembrie 8, 2011 We placed another baffle on top of this, adding another 30 inches of height and mounted a Lowther PM6A at 36 inches heightSe pare ca este un pic ambigua faza, ca zice ca a mai pus o placa de 30 de inches deasupra si difuzorul l-a montat la 36 de inches fata de podea (deci la 6 inches fata de marginea de jos a placii care a pus-o deasupra placii ce contine fanta de la woofere). difuzorul este : http://www.lowtherloudspeakers.com/pm6aDP.html dar tu cred ca ai vrut sa spui ce woofere a folosit. Nu scrie. Doar: The eight-inch (8") woofers are wired in either three in series, two in parallel to form a 12 Ohm load, or three parallel, two in series to form 5 Ohms. Because the wiring is slightly easier, I chose the 12 Ohms, but if you are considering using a passive crossover here, you would definitely go for the 5 Ohm arrangement for level matching. Ai asa mult spatiu in casa? (sunt enorme) Link spre comentariu
