GS Postat August 23, 2011 Partajează Postat August 23, 2011 Salut! Am un aparat foto Panasonic Lumix DMC-TZ5,sunt foarte multumit de el,dar vreau sa stiu daca se poate face ceva ca rezolutia fotografiilor sa fie modificata cand faci fotografia,nu dupa aceea ,la editare... Deci,am citit cartea tehnica,tot ce am gasit pe net,dar nu m-am lamurit...pe "Intelligent Auto" sau pe "Manual",informatiile unei fotografii sunt cam asa: - Primary Image Manufacturer = Panasonic Model = DMC-TZ5 Orientation = The 0th row is at the visual top of the image and the 0th column is at the visual left-hand side X Resolution = 180 Y Resolution = 180 Resolution Unit = Inches Software = Ver.1.0 Last Modification Time = 2010:08:09 12:00:20 YCbCr Positioning = Co-sited - Exif Specific Exposure Time = 1/800 sec [0.001] F Number = 21/5 [4.200] Exposure Program = Normal program ISO Speed Ratings = 160 Exif Version = 0221 Original Create Time = 2010:08:09 12:00:20 Digitalization Time = 2010:08:09 12:00:20 Components Configuration = YCbCr Compressed Bits per Pixel = 4 Exposure Bias Value = 0 Max. Aperture Value = 344/100 Metering mode = Pattern Light Source = Unknown Flash = Flash did not fire, automatic mode Focal Length = 8 mm Maker Note = 50 ......................... Flashpix Version = 0100 Color Space = sRGB X Dimension (Pixel) = 3456 Y Dimension (Pixel) = 2592 Sensing method = One-chip color area sensor Image Source = 03 Scene Type = 01 Rendered by Customer = Normal process Exposure Mode = Automatic exposure White Balance = Automatic white balance Digital Zoom Ratio = 0 Focal Length in 35mm Film = 48 mm Scene Capture Type = Standard Gain Control = Low gain up Contrast = Normal Saturation = Normal Sharpness = Normal - Thumbnail Compression = JPEG compression Orientation = The 0th row is at the visual top of the image and the 0th column is at the visual left-hand side X Resolution = 180 Y Resolution = 180 Resolution Unit = Inches YCbCr Positioning = Co-sited E!Eu vreau sa modific,sa maresc,coordonatele subliniate(rezolutia XY),pentru a avea o poza mai mica poate,dar cu amanunte necesare le un portret,de exemplu... Multumesc anticipat pentru raspunsuri.GVS. Link spre comentariu
Selena Postat August 23, 2011 Partajează Postat August 23, 2011 Informatia despre imaginea fotografiata este cu atat mai multa in fisierul stocat pe cardul camerei cu cat setezi camera la o rezolutie a senzorului mai mare (neinterpolata), in acord cu numarul de pixeli de pe senzor. Daca salvezi RAW, informatia aceasta (despre fiecare pixel de pe senzorul camerei) este neprelucrata de procesorul camerei, bruta (de aceea, vizualizata, arata destul de rau... insa permite prelucrarea totala ulterioara cu softuri grafice mult mai evoluate decat cel din procesorul camerei). Salvata jpeg, procesorul camerei aplica niste corectii, o "lustruieste" si comprima fisierul, pana la o dimensiune rezonabila. Lustruirea aceasta (depinzand de programul din procesorul camerei) este dictata de valorile implicite, sau de valorile pe care le setam noi, personalizat (rezolutia senzorului, balansul de alb, finete a contururilor, tipul scenei etc.). Dupa cum este de bun programul, asa iese poza finala, de aceea ni se pare ca un aparat este mai bun decat altul (dar influenteaza si optica). Datele exif sunt stocate separat de fisierul pozei si in ele sunt codificate date despre camera si parametrii fotografierii, data, locatia etc. Printre ele, este si rezolutia utilizata (setata), de exemplu 3456 x 2592 pixeli ai senzorului. De acesta si de programul din camera depinde calitatea (multimea) informatiilor stocate pe card. Dar aceste informatii trebuie apoi convertite in poza fizica, de privit: ori pe un monitor (unde iarasi avem pixeli, dar acestia sunt pixelii monitorului LCD), sau pe hartie (unde avem pete de culori latarete, puncte, pata corespunzand la mai multi pixeli de pe card, adica scaderea calitatii, a informatiei). Nu ma refer la vizualizarea pe monitor, ci la imprimarea pe hartie: De regula, camerele de firma au si imprimante foto dedicate, de la aceeasi firma, precum si softuri complexe (descarcare, vizualizare, prelucrare, tiparire, trimitere pe net). Adica poti conecta camera Canon la o imprimanta Canon si softul face automat imprimarea pe hartie foto. Automatismul acesta presupune o comunicare rapida si perfecta a camerei (prin datele exif ale fiecarei luari de imagine) cu imprimanta. Din sirul de date exif, datele dedicate exclusiv imprimantei sunt tocmai aceste misterioase cuvinte: X resolution = 72, Y resolution =72. Inseamna asa: Imprimantei i se spune sa stropeasca cu 72 pete (puncte) de cerneala pe o distanta de-a lungul axei X egala cu 1 inch si, la fel, sa improaste cernelurile sub forma de 72 pete pe 1 inch masurat pe directie perpendiculara Y. Rezulata pe hartie o poza cu lungimea (3456:72) inch si latimea (2592:72) inch, deci o poza mare, dar si cu pete mari ("granulatie"). E clar ca aparatul va fi setat din fabrica sa scrie automat in exif un numar mai mare, de ex. 300, in loc de 72, pentru o poza mai mica dar mai clara. Imprimanta se va autoregla si va improsca pete mai marunte, cate 300 pe fiecare inch al hartiei, astfel ca va avea nevioe de o hartie de dimensiuni mai mici pe X si pe Y. Poza pe hartie este mai mica, dar cu "granulatie" fina si clientul este incantat de calitate. Desigur, imprimanta se poate seta si dupa dorinta, deci datele exif nu mai sunt prioritare. Dar putem lasa imprimanta pe automat, si sa-i furnizam date exif modificate de noi: deschidem un editor exif si scriem cat vrem acolo (in fisierul exif salvat pe calculator odata cu poza) si salvam modificarea. Apoi trimitem spre imprimanta. De inteles ca, daca scriem numere exagerate, imprimanta le ignora si tot ce poate ea face... Pentru fiecare imprimanta este o valoare optima, ca aspect al tiparirii de calitate. In concluzie: Nu exista si nu ar fi necesar reglaj la fotografiere a acestor numere X si Y (ele sunt stocate in memoria camerei si sunt plantate automat in exif doar in vederea unei viitoare tipariri a pozei). Aceste numere nu vorbesc despre calitatea datelor digitale din fisierul captarii imaginii, ci doar permit comunicarea camera-imprimanta, date inspre imprimanta fara interventia utilizatorului; daca se doreste alte valori, utilizatorul modifica ulterior exiful, sau prelucreaza poza si apoi seteaza alta rezolutie a punctelor pe hartie pentru imprimare. Link spre comentariu
Vizitator Pandy Postat August 24, 2011 Partajează Postat August 24, 2011 Salut!Din ce am inteles, tu ai vrea ca inainte sa faci poza sa ai posibilitatea sa ii schimbi rezolutia dintr-un buton/ceva rapid. Nu este posibil asa ceva, cel putin nu la modelul tau din cate m-am uitat, singura varianta ar fii fost sa intri in meniu, sa schimbi rezolutia si sa revii la fotografie, dupa care, daca vrei sa te intorci la rezolutia initiala, sa executi pasii din nou.La camerele cu o clasa, doua peste ai o varianta, am avut un Panasonic FZ-38, aveai un buton dedicat Custom (C1,C2,C3) carora le dadeai tu setarile si le salvai profilele, spre exemplu la C1 aveam rezolutie 8MP, focus lateral, iso 400 etc. La C2 aveam iso 2MP, focus central, iso 100. (sunt doar exemple). Link spre comentariu
Selena Postat August 24, 2011 Partajează Postat August 24, 2011 Nu este vorba de rezolutia setata pentru senzor, ci de cu totul altceva, ce nu se seteaza si nu intereseaza in prima faza, la fotografiere: este vorba despre comunicarea cu imprimanta. Rezolutia reglabila se refera la pixelii senzorului camerei si asta determina calitatea informatiilor digitale despre viitoarea poza, in schimb, rezolutia X Y (nereglabila), despre care intreba in mod expres colegul GS se refera la punctele (petele de cerneala) trimise spre hartie la imprimare. Link spre comentariu
