Monitor Samsung B2330 nu vrea sa intre in standby
Vizitator alinu2006
Vizitator alinu2006
Am o problema cu un monitor pe care l-am cumparat recent.
Nu vrea sub nicio forma sa intre in standby.
Daca inchid calculatorul (sau calc intra in standby) monitorul imi afiseaza "Check cable signal".
Banuiala mea este ca are o mica problem cu EDID.
Am instalat Monitor Asset Manager si am vazut ca la power manager optiunile "standby" si "suspend" nu sunt active. (Am doar Acctive off/sleep).
Problema mea ar fi ca nu prea am reusit sa gasesc un program care sa imi modifice EDID in EPROM-ul monitorului. (Win7 x64)
Sunt cateva dar niciunul care sa imi mearga pe Win7 x64 / free.
Daca are cineva vreo idee ...
Monitor
Model name............... SMB2330H
Manufacturer............. Samsung
Plug and Play ID......... SAM0649
Serial number............ H9XB301556
Manufacture date......... 2011, ISO week 13
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Analog 0.700,0.300 (1.0V p-p)
Sync input support....... Separate, Composite, Sync-on-green
Display type............. RGB color
Screen size.............. 510 x 290 mm (23.1 in)
Power management......... Active off/sleep
Extension blocs.......... None
DDC/CI................... Supported
MCCS revison............. 2.0
Display technology....... TFT
Controller............... Mstar 0x1000
Firmware revision........ 0.1
Firmware flags........... 0x00000001
Active power on time..... Not supported
Power consumption........ Not supported
Current frequency........ Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.640 - Ry 0.330
Green chromaticity....... Gx 0.300 - Gy 0.600
Blue chromaticity........ Bx 0.150 - By 0.060
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-81kHz
Vertical scan range...... 56-75Hz
Video bandwidth.......... 170MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 870p at 75Hz - Apple Mac II
1152 x 864p at 75Hz - VESA STD
1280 x 800p at 60Hz - VESA STD
1280 x 960p at 60Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
1600 x 1200p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
1440 x 900p at 75Hz - VESA STD
Report information
Date generated........... 23/08/2011
Software revision........ 2.60.0.964
Data source.............. Real-time 0x0011
Operating system......... 6.1.7600.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,4C,2D,49,06,33,32,55,50,0D,15,01,03,0E,33,1D,78,2A,EE,91,A3,54,4C,99,26,
0F,50,54,BF,EF,80,71,4F,81,00,81,40,81,80,95,00,A9,40,B3,00,95,0F,02,3A,80,18,71,38,2D,40,58,2C,
45,00,FD,1E,11,00,00,1E,00,00,00,FD,00,38,4B,1E,51,11,00,0A,20,20,20,20,20,20,00,00,00,FC,00,53,
4D,42,32,33,33,30,48,0A,20,20,20,20,00,00,00,FF,00,48,39,58,42,33,30,31,35,35,36,0A,20,20,00,FD
Alin.
  • Răspunsuri 0
Zile populare
